PDA
View Full Version : Audio, Video and Security Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69
  1. Yay! Engine Noise Problem Solved...No line driver needed
  2. Finally, some publicity from USAC finals. Check the link - click on the "stealth" install
  3. Finally getting the first part of my installation done...
  4. Anyone interested in buying my factory 6cd changer from my s4?
  5. How do i free up more sound from the trunk?
  6. What size are the rear deck speakers in a MY2000 A4 (non-bose)?
  7. What do you guys think about Diamond Hex Series speakers?
  8. ppi and solobaric combo ..
  9. Can i fit 6.5 speakers in the rear doors? i was thinking
  10. Different head units with Bose Premium Audio Package?
  11. CD Changer
  12. ok, quick speaker question:
  13. Best CD-Rs to use with BOSE stereo
  14. How do I connect the Blau adapter for the Symphony HU?
  15. any good 6.5" rear speakers out there?
  16. Anyone want to sell their OEM Bose radio (1999A4,1999A6,TT)??..
  17. Which wire on the bose amp(2001 s4) is the remote????
  18. Adding Subwoofer to 97 Delta Head Unit
  19. LCP - thanks for the legwork on the EQ settings!...
  20. AHHH. Blew crappy rear speaker in bosed S4. any other replacements w/ same connections? help
  21. Infinity Kappa 255a in a Tahoe
  22. Where to mount crossover / line driver in dash area?
  23. schematics for 2001 A4 1.8T bose stereo
  24. Is this the right Blaupunkt Adapter for 99.5 Concert headunit? (pic 1)
  25. More A4 CD Changer Trouble
  26. who have fit a deck in Double Din Head Unitst . need pictures
  27. Strange Audio cutout..
  28. Alternater whine is GONE! F/U Post
  29. After market Head Units,..Computer Problems????
  30. Where do you guys mount your amps?
  31. Adding a sub to a '01 A4 1.8T w/ Bose...
  32. BOSE: my two rear deck speakers arent playing at all!
  33. RCA outs on Factory Bose Head Unit?
  34. I'm still getting engine whine
  35. Any reviews on Kicker amps??
  36. I finished one of my door pods for my Infinity 6.5" perfects.
  37. Re: Poor aftermarket radio reception... Did anyone find a solution...
  38. Which amps can safely be mounted upside down?
  39. Anyone install flat screen in A4 rather than fold-out style?
  40. Difference between Bose and standard HEAD UNITS in S4?
  41. Any suggestions on a amp to power 5.25 Rockford Fosgate components???
  42. I Hate Double Din Head Units
  43. Do I setup my front components with a 2 channel amp and remove my rear speakers for my subs or....
  44. Poor AM reception
  45. A6 Bose - RH trunk storage compartment usable?
  46. What kind of rear spkers u guys put it on?? and can u tell me why u choose it??
  47. Non-Bose Symphony users: You must make changes with the hidden equalizer. I did. OMG!!
  48. Should I change myPPI pc660 for RF Power h800a4 amplifer if I want more power?
  49. my new system setup
  50. Suggestions: Need new in-dash single CD player w/detachable face for $200-$300 for '89 Accord. TIA
  51. 2001 A4 Bose System
  52. Anyone have experiences with Sony ES Components? How are they? Are they on par w/ BA Rally's? thx
  53. Found @ Bay Area Fry's, Pan 8-disc changer for..
  54. CMH - when you went to HIN, when did you set up your car??? more...
  55. Classifieds down so I'll post it here... I'm selling my 6-disc changer from 98.5 non-Bose...
  56. Anyone who's installed an aftermarket headunit into an A4. Some questions for my install...
  57. installer in northern jersey needed to install CVA-1000 w/ video modification
  58. FYI, pick up a copy of Car Audio & Electronics mag... the current issue has a nice A4 install...
  59. Are the front non bose 2001 5.25 or 5.5? Also, what runs well off stock system? Infinity? Boston..
  60. Audi Nav Plus
  61. Check out the specs for this amp? thd @ 0.01% for a $250 amp? Is it too good to be true?
  62. which MB Quart?
  63. Poor FM reception with new headunit - Tale of woe
  64. Cable Pin out assignments
  65. Adaptor for Panasonic CD changer to Symphony in UK?
  66. Concert to Panasonic changer connection
  67. Can someone direct me to a source of getting the MBQuart Adapters for the front speakers? Thanks
  68. Is it possible to use an aftermarket 4-channel amp to boost the sound of the stock "Concert" sound?
  69. Rear speakers
  70. Nokia 8860 trying to create a mute circuit...
  71. Boomy Bass... suggestions needed.
  72. cd changers for 2000 S4 Bose?
  73. How will this sound?
  74. Quick advice for '98 A4
  75. Is there a lot of work involved in changing the fronts speakers w/ 5 1/4's? What fits well? thanks
  76. Please help - Concert Replacement problems..
  77. Need some recommendation on choosing an amp..
  78. CD Changer for '97 A4 Bose System - will this work?
  79. Does this sound reasonable? Any comments on the speakers or amp that I'm planning to buy? Thanks
  80. Amp problem...need help/suggestions
  81. Will i be ok running Rockford fanatic Q 5.25 components off of a sony 50 x 4 cd receiver w/o 2nd amp
  82. Whazzit worth? PPI 6 channel (100 W / channel) power amp, one year old
  83. ok, I'm ready to start doing audio work, do i have this right??
  84. Do u guys recommend Polk Audio DXseries components for my front speakers running off the stock deck?
  85. my new subz
  86. 4ohm or 8ohm dilemma
  87. Any suggestions on how to silence the trunk rattles from the bass?
  88. What are good 5.25 speakers for front doors if im NOT using an amp???
  89. where is a good point to connect a ground wire in the trunk of A4?????
  90. Subwoofer for sale in the Bay Area
  91. Stereo Installers in VA
  92. component speaker locations for a custom install.
  93. what size are the door speakers in the 2001 A4 non-bose?...anysuggestions on...
  94. Stealth box for 99.5-01 a4/s4
  95. Where can I get a blau adapter? (Crutchfield is on backorder)
  96. Older Bose Head Unit question
  97. anyone want these parts?
  98. Anybody know when satalite radio is going to be turned on/ released whatever
  99. Where can i buy 5.25 brackets for front doors????
  100. Can you guys sugest rear deck speaker replacment?
  101. LCD Display on 98.5 A4 not working properly and need feedback
  102. Question about S4tt Bose amp...
  103. Good place to buy a prefab .5 cu ft sub box? Or if i go custom, what is a fair price?
  104. Need Adapters for the Front on 2001.5 A4?
  105. Can i run Rockford Frantic Q's 5.25" off of my stock speaker wires w/o amp?
  106. MTX 8000 5.25 Components. any reviews?????
  107. Where did you get your single DIN spacers from? How is the quality and what was the cost?
  108. New Component speakers...
  109. anyone see Ed Chambers system in Car Audio&Electronics?
  110. Component Opinions?
  111. Since I've received a bunch of emails for the Radio Removal FAQ, I posted it!
  112. Soooo confused...!!!
  113. Two quick questions....
  114. SONY will have an MP3 on CD player for this year
  115. Can I take out the rear Bose Amp
  116. For those using the aftermarket front component....
  117. Preamp addition to Bose...
  118. Question: Use amp filters with external crossover?
  119. Hey, I created a FAQ on how to remove the 2000 and up Head Unit. I submitted it...
  120. does this make sense?
  121. sub + rears?
  122. Anyone know of any good Tampa area installers?
  123. Found a pair of Kicker 690i 6x9's that I only used for 3 months...
  124. Question?????????
  125. Who make the Symphony HU for AUDI
  126. Bose removal tool
  127. Installation cost?
  128. Genesis Amps?
  129. X-Post: For those using the Bose/concert head unit equalizer...
  130. I'm helping a buddy install a head unit into a 99.5 A4 - which "fit kit" is best?...
  131. I think something may be wrong with my built in crossover...
  132. Options for 1997 Audi A4 Delta System
  133. Hooking up a portable MP3 player to Delta system?
  134. x-post... Those who've replaced the head unit, please read!
  135. Ok Audio Gurus !!! I need some advice please. ....
  136. 2001 s4 sympony HELP
  137. Kenwood KVT910DVD
  138. ALPINE EQ 3217
  139. X-POST SO. CALIFORNIA PEOPLE- READ the OC REGISTER's ACCENT SECTION!
  140. Delta Bose options (long)
  141. Ok, I spent two hours trying to remove radio from 2000 A4, now I'm pissed
  142. ok...got the cx-dp88u cd changer...now where do i get the adapter? crutchfield audpan98??
  143. HOLY CHEET MAN!
  144. anyone know a good installer in Dallas/Richardson/Plano??
  145. anybody know of a good stereo shop/installer in OC? my gf needs a new one for her honda. TIA
  146. One more note on the Infinity Basslink
  147. could be a big stereo weekend! I am going to take a molds of the car for some small kick panels.
  148. where is the plug for the Charger???
  149. Alpine and Symphony
  150. What would you do in my situation?
  151. Boston Acoustics 4.4 Proseries
  152. Ok to use y-adapters on RCA interconnects?
  153. pioneer avm-p9000r & avd-w8000
  154. Need help with older Bose
  155. Tos-link digital instead of line out
  156. Alpine CD changers w/ Symphony HU (MY 2001.5)
  157. what's the watts (RMS output) and frequency response for the stock speakers?
  158. ok, after my first choice of sub got nixed (the company discontinued the sub!) I have next (m)
  159. about speakers........
  160. ski sack removal ques.
  161. quick question...
  162. Anyone buy the type IV 8 disc changer from autotoys?
  163. My Car is for sale! Anyone interested in the car with the stereo OR the stereo alone???
  164. How did you all tap into the line out leads for the Symphony head unit?
  165. Will a 5.25" speaker able to fit into the front door? The stock speaker size is 4" only..
  166. install question -
  167. CHECK OUT MY NEW INSTALL - DOUBLE DIN on PRE '99 - L@@K!
  168. Panasonic CD Changer just went dead. Any clues?
  169. Factory non bose head unit...... 1- 10 ratings please
  170. pics of my new Avant install
  171. Mark P How many cubic is your box??
  172. MAXIMUM BASS, has been achieved
  173. Phone & Nav System
  174. If you had to mount a huge amp in the trunk, how would you do it? (m)
  175. alright guys I've found the sub I will install in a couple of weeks....
  176. Looking for info on amp racks...
  177. looking to place a center channel in the defrostr vents butthe damn sunsensor for the HVAC system is
  178. This is unreal.....
  179. FOR SALE -
  180. Does anyone have pics of a Stereo system in an Avant?
  181. Sound Shop in the DC/MD/VA area
  182. Tape head unit swap for CD
  183. static/buzz..alternator interference?
  184. Help Needed re: my Kenwood VZ 907
  185. having a surge from my PPI when I turn off my Symphony head unit..HELP
  186. Need help: S4 trunk dimensions?
  187. how do i get power to amp? i've read poke a hole through ecu housing..what other route is there?
  188. How did you guys remove the Symphony head unit?
  189. which is a better setup?
  190. In Cockpit Subwoofer Mounting
  191. Big improvement to non Bose Symphony stereo
  192. Can someone define "ground loop"
  193. Has anyone mounted their amps under the rear deck?
  194. Does anyone here have a head unit/navigation system either OEM or aftermarket....
  195. Anyone provide a little troubleshooting help?
  196. How many pins does the connector on my 6 CD changer have?
  197. Any good stereo installers in LA/Orange County Area?
  198. Which amps are good? Xtant, Precision Power, a/d/s or MTX
  199. a/d/s good or not?
  200. Q: I have the Bose system and I notice that under heavy bass (hip-hop, techno)...(m)
  201. I get an RPM drop at idle when playing it loud, any suggestions?
  202. TT speaker options
  203. Anybody get aftermarket audio equipment installed in NY Capital District area?
  204. Any places to get Boston Acoustics online for a great price?
  205. Details on new System. Please help w/ Engine Noise! (long)
  206. Those who have used the Blau adapter, please read....
  207. Stereo Upgrade on the Cheap??
  208. Is it possible to retrofit the 4's Avant's Subwoofer into a S4 sedan?
  209. Infinity Beta series 4" good for loud playing music???
  210. Speaker size
  211. Crutchfield no help - how about you?
  212. System setup question.
  213. do you think $900 is good for a JL 12" sub, custom box, and MTX amp is...
  214. what manufacturers are making or plan on making mobile SACD / DVD Audio players?
  215. Considering stereo upgrade for my A4..(more)
  216. Jimtunes, what is the optimal recommended enclosure size for the Eclipse 88100 DVC?(in sq ft.)Thanks
  217. so does the 2001 A4 bose headunit have outputs for lines to an amp?
  218. Anyone ever used Alpine HU with V-Power built in?
  219. Installing an Alpine headunit
  220. small problem with bose+aftermarket sub install, any suggstions/ideas?
  221. need help with getting an amp
  222. need help...how do I hook up an amp and sub to the stock bose headunit...
  223. What are best components for front doors?
  224. XPOST DC/MD/VA Krispy Kreme Run #1 - YAY
  225. If anybody wants an Infinity Perfect 12 send me an e-mail, just replaced it with 2 BA Pro 12.5's
  226. has anyone ever installed a new light onto the celing of the car and if so where and how did you run
  227. What is the best place to connect ground wire??
  228. Anybody interested in a PPI Art Series A600.2?
  229. DAMN!!!! what color is the acc wire for the head unit!!!!! 96 a4
  230. How can I eliminate engine noise?
  231. New Stereo Pics
  232. Does anyone use Kicker subs here??
  233. How will it sound if I just add an amp and sub to stock head unit?...whats good...
  234. delta manual/instructions
  235. Bose Equalizer Settings
  236. kick panels or pods for front speakers in A4?
  237. aftermarket head unit radio reception problem
  238. results of new system install (2000 A4 Avant)
  239. Does a ground wire have to be the same gauge as power wire????
  240. adding an amp to a Symphony non-Bose head unit, please help
  241. Need some recommendation on setting up a new stereo system for the car.
  242. anyone have a non-working concert headunit they would sell me cheap?
  243. Anybody know what the angle of the back seats is, realtive to the floor of the trunk
  244. Is there a problem with replacing the head-unit in a 2001 car??
  245. what are the best sounding 8 inch subs for a small sealed box! accuracy not SPL. with ~200 watts
  246. Installer in Western New York?
  247. question on head unit
  248. Also Does anyone have idea on the perfect system for an A4 taking into acount the size and shape of.
  249. How do i take off factory grilles without hurting them?
  250. SF Bay Area Installers?
