A4 vacuum leak
after a gas fill up , do you get a 5 second delay ? like it takes few seconds to start the engine. ( just after the fill up, in the gas station)
if yes, then its the purge valve. a cheap and fast fix
good luck
I have heard that if the screen is out it needs a fuse.Where is this fuse located?
I have heard that if the screen is out it needs a fuse.Where is this fuse located? All I can find is location on a Q5.
