A4 vacuum leak
T, welcome aboard! Can you get someone to scan the car with VCDS? It'll provide more specific info. "Vacuum leak" is very generic.
after a gas fill up , do you get a 5 second delay ? like it takes few seconds to start the engine. ( just after the fill up, in the gas station)
if yes, then its the purge valve. a cheap and fast fix
good luck
I have a 2007 A4 b7 with navigation. The screen is out, but everything works. I am assuming the nav works too.
I have heard that if the screen is out it needs a fuse.Where is this fuse located?
[QUOTE=sawyerauction@gmail.com;25240662]I have a 2007 A4 b7 with navigation. The screen is out, but everything works. I am assuming the nav works too.
I have heard that if the screen is out it needs a fuse.Where is this fuse located? All I can find is location on a Q5.
V24
06-16-2011 03:04 AM
dang
10-02-2007 08:19 AM
Avantéix
VAG-COM Discussion
02-05-2006 11:21 AM
