View Full Version : TT (Mk1) Discussion
- 2001 Audi TT 180hp overheating! Please help!
- HELP! DSG issues - car jerks when driving
- 2004 Mk 1 225 quattro rear wheel camber?????
- 2001 Roadster Smog problems
- 2003 TT Roadster
- :: ECS Tuning :: FREE SHIPPING on orders over $200!!!
- :: ECS Tuning :: MKI TT 225HP Single Mass Flywheel Kit
- 03 With AT trans problems
- has spark, has fuel, has air, don't has start....
- Car takes 3 tries to start. Every time
- AUDI TT AC NOT WORKING HELP!!!
- good morning all help needed
- what wing is this?
- Please welcome M'Autolite; new vendor on AW and receive 20% discount on all items!
- hamn465
- Front suspension noise - I can't find it
- 1 question, 2 concerns
- Mechanic can't remove abs module! help?
- Ideas on How My Engine Can Handle Boost
- :: ECS Tuning :: Back In Stock!! MKI TT 1.8T Coil Pack Conversion Kits
- :: ECS Tuning :: Now Available!! MKI TT Quattro Ksport Kontrol Pro Coilovers
- :: ECS Tuning :: Now Available!! MKI TT FWD Ksport Kontrol Pro Coilovers
- Acceleration Delays
- Radio upgrade while keeping original "Concert"
- Front plate installation?
- HELP temperature gauge
- Concert Radio with SAT issue
- :: ECS Tuning :: NEW!! FrankenTurbo F23 Hybrid Turbo Upgrade
- Brown wire with black tracer...
- I think my car was wrecked...
- Any TT owner in Elkhart, IN
- A Newb and his 2001 TT...help and advice
- Battery Drain
- new fuel sender now more problems
- Egr solenoid problem
- audi tt 180 dp for sale
- AUX and AC fans not working
- Something missing?
- Audi TT Gauge Pod
- Broken Dipstick tube!
- :: ECS Tuning :: NEW!! ECS Various Length Conical & Ball Seat Locking Wheel Bolts
- Wheel bearing replacement
- My youtube videos for washer pump and wind screen fix
- Help finding oem rear springs
- Is my TT really a Quattro?
- :: ECS Tuning :: MKI TT Quattro ST Suspensions Rebate Sale!
- 2.0 red top coil upgrade spark plug gap
- 02 MK1 EPC Light
- Engine Rattle loud noise at Idle. Ideas please?
- 2003 AUDI TT QUATTRO BEST MUFFLER
- Water Coolant
- Audi TT coilovers
- power problems
- 2000 MK1 door lock MESSED UP!
- Fuel Gauge Issue
- fan only run when A/C is on ?!?!?
- fuel gauge problem
- :: ECS Tuning :: MKI TT Quattro KW Suspension Spring Promotion!
- :: ECS Tuning :: MKI TT FWD H&R Sport Spring Set
- need new coil packs and spark plugs...
- :: ECS Tuning :: MKI TT ECS GEOMET© Rotors
- MKII (or later) brakes on MKI?
- New Clutch
- 2005 Audi TT - FOB key stopped working, need assistance on what to do next???
- Fluctuating temp and P2181 code
- Audi TT mk1 clutch issues
- 83,000 miles with no oil change turns Audi engine into a mess
- TT West registration closes Monday the 23rd and some hotel rates end the 20'th
- Bobbyh: I left I came back - 6 yrs later same issue (long)!
- audi tt tail light covers??
- :: ECS Tuning :: MKI TT 225HP Koni Performance Suspension Sale!
- Hydraulic to manual ragtop conversion- done!
- Hatch (liftgate) interior panel removal?
- 2001 base TT - 50M mi - new batt - barely cranks - no clue
- Cluster
- 2001 TT Coupe Antenna
- 2001 TT 225Q Gear Oil
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - March, Monday 25th - Sunday 29th
- Audi A3 2001 Fuel gauge problem
- Mirror Switch Replacement
- Audi TT downpipe
- :: ECS Tuning :: MKI TT Vent Integrated Digital Interface
- Need help for my Audi tt 225
- :: ECS Tuning :: MKI TT VF Engineering Performance Drivetrain Mount Kits
- What is this part called?
- Remove instrument cluster
- 2004 tt 3.2 quatro s line front brakes/rotors
- Check engine light on MAF
- :: ECS Tuning :: MKI TT 180/225 ECS Lightweight Underdrive Pulley Sets
- 01' TT 225HP: timing belt failure - what now?
- I've got a MCPI DEFCON suspension system on eBay if anyone is interested. .
- Signal lights
- Bad gauge
- glove box door
- Shifting Hesitation between 1st & 2nd
- Tail Light Gasket
- Battery light but no issues
- :: ECS Tuning :: !!10% Off Exclusively Through ECS On ST Coilovers 2/5 - 2/15!!
- R8 Coil pack replacement
- MK1 replacement muffler
- 2003 TT Mk1 Quattro 225 HP Coupe
- 2002 TT Rim Replacement....Suggestions?
- Clearing Service Light
- key fob won't program
- 01 TT Quattro Roadster for PARTS ONLY!
- engine mods for 2002 225 audi tt
- Can someone help me identify the fittings on the Intercooler?
- Aftermarket stereo, is there a converter cable?
- 2004 AUDI TT 3.2
- NAvigator controls component?
- :: ECS Tuning :: MK1 TT 225HP ECS Rear Big Brake Kit
- engine codes and diversion valve flutter
- (first post) question about differential upgrade
- anyone selling headlight for a 2002 tt 225?
- LL TEK Motorsports
- Sudden Shifting (manual) problems
- High beam flasher works, but the switch won't turn them on
- Joystick Shifter
- Joystick Shifter
- New user, some questions
- Door Electrical Circuit
- :: ECS Tuning :: MKI TT 1.8T Bentley Service Manuals
- Trying to sell my Audi TT! But don't know for how much?
- :: ECS Tuning :: MKI TT 225HP 40k Service Kits
- 2000 Audi TT quattro headlights
- Why won't my Airbag sit flush?
- :: ECS Tuning :: MKI TT 180HP 1.8T ECS Aluminum Coolant Split Pipe
- :: ECS Tuning :: MKI TT 225HP Timing Belt Kits
- I think my Audi TT has a gremlin, Need some advice...
- Brake light flashing causing a misfire
- Problem with the driver side door locking mechanism on my MkI
- 2015 Audi TTS Roadster Detailed Walk Around Video
- Should I purchase used Audi TT with very low miles?
- 02 ttq225, no cooling fans, no a/c at all
- 2004 TT cd player problem
- Having trouble putting transmission in 1st gear
- Clutch Slipping on '01 TTRDSTR w 30K miles
- 2006 Audi TT 1.8 Brake Light Switch
- Idling problem
- Anyone know the steps to remove a prop shaft on a 2000 TT?
- Anyone know how to put in a new front Prop Shaft?
- Last weeks to get registration discount for TT West
- break light issues while headlights are on 1999 audi a4 1.8 turbo
- Building my tt
- 2004 TT Roadster radio issue:
- Belly pan air diffusers/deflectors
- Rare set of brand new OEM seat belts in Winnetou red for TT 8N (mkI)
- Mk1 purchase advice
- 2005 TT Tonneau Cover Bag
- Is the Neuspeed Air Intake Quieter than the K&N?
- TT Rims
- Frankenturbo!!
- Lots of Questions about my TT
- Looking for a writeup for vacuum issues
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - December 12th - 19th 2014
- No front wheel drive only rears
- Is it worth upgrading the Bose Speakers in my MK1??
- Desperate
- Anyone go from stock 18" to aftermarket 17" wheels? Thoughts?
- Timing Tensioner Roller: Wrong Part?
- Changing Stereo, would you go OEM or Aftermarket??
- MAYDAY MAYDAY MAYDAY!!!
- Any recommended seat covers for a TT?
- Did Audi offer a different shade of grey (interior) in 2003 vs 2004?
- :: ECS Tuning :: 10th Annual Customer Appreciation Holiday Sale|Save up to 30%!!!!!!!
- Xenon HID headlight lost brightness and has a red-ish look
- End of an era: "HIS TT" and "HER TT" are breaking up
- Flash Sale @ DetailersDomain.com - 15% off and Free Shipping - ends 11/22/14 mid est
- TT WONT START
- 2005 TT 3.2 Convertible Top Sensor Issue
- 2000 audi tt quatro 1.8 overheating
- Replacing Drivers Info Display Cluster
- boss amp pin out to connect aftermarket amp with sub
- Stock bose cable thickness?
- Just picked up a TT, need help
- :: ECS Tuning :: Gift Card Give-A-Way!! Peek Inside for Details!!
- Hole in Transmission!
- Tranny Grind in Second & Other Tranny Problems
- 2006 Audi TT 1.8
- :: ECS Tuning :: MKI TT ST X Performance Coilovers - Free Shipping + $50 Gift Card
- Fluid Types and Capacities
- Central Locking/Comfort Module
- Need new front springs
- Sitting around 6mo., now won't start
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - November 27th - 30th 2014
- What do you think of this price for a 2005 TT?
- DYI road rash rim repairs w/ pics
- Lost lug nut
- Lowering Question.
- Weird Squeal on Start?
- 2000 TT Owners Manual
- :: ECS Tuning :: MKI TT Wheel Storage Protection
- What Hose is this?
- :: ECS Tuning :: MKI TT ZIZA LED Interior Lighting Kits
- HEADLIGHT SWAP INFO NEEDED
- are headlight assemblies blanks the same for haligon and xenon
- Fuel line bad move and Crank Shaft Sensor
- Need a hand with Adapters
- Manifold to turbo Torx bolt backs out and gone
- Streaming Audio Options
- 2002 TT Quattro Clutch job question(s)
- Drive w/o a cluster?
- New Member and First AUDI!
- Help with multiple electrical issues all happening simultaneously
- Registration open for TTW 2015 in April in AZ and NM. 11 cars signed up so far.
- New here. Few questions (of many to come, I'm sure)
- Door won't open!
- 1999 Audi TT Quattro (Red oil light)
- :: ECS Tuning :: MKI TT ECS Performance Front Control Arm Kit
- Suspension on special at AWE Tuning
- 8N TT 1.8T 163 cv
- does the manual tt show gear position on dash
- problem with my 2002 1.8 TT ALMS
- Rear brake piston
- Changed Crank Speed sensor now i have a new problem
- :: ECS Tuning :: MKI TT ECS Stage 5 Big Brake Kits
- Seafoam use with a 2001 MK I
- I'm too young to be broke! Airbag Module help
- kayak rear tie down
- 2002 TT 225 HEATING UP CLIMBING HILLS IN HIGH GEAR
- Just bought one, a couple of questions
- Stock internals 180 quattro
- Corner with Confidence. Special pricing on Bilstein and H&R at AWE Tuning
- Options for a 180 Quattro Downpipe?
- Hi, newcomer here
- Rear Speaker Grills
- 2001 TT OEM Cd Changer
- Looking at 2002 Quattro Roadster 225hp Part Two
- Overheating again. NO FAN
- 2000 180Q Engine Failure (timing belt)
- 2004 TT stereo in an 2002 TT
- Haldex not disengaging
- Moving Sale - Help us move out - Detailer's Domain
- NEED HELP, PLEASE
- 42 Draft Designs 180Q High-Flow Intake!
- TT RS brakes
- REALLY NEED SOME FAN HELP.
- GForce chips for TT
- Control. For less. Special Pricing on H&R Springs and Sway Bars from AWE Tuning
- Vagcom doesnt speak to my car
- Electric roofs goes down, but not back up!
- Light warning on dashboard
- Wanted: Used Coil Overs (2002 TT Coupe 225)
- Playing Music Help!
- An introduction, a message from AWE Tuning
- Can't select 5th to 4th Gear
- What is the best indoor cover for a 2001 TT Roadster???
- Red warning sign issue
