View Full Version : TT (Mk1) Discussion
- Boot Cover
- Rear window coming unglued
- Haldex Gone ...? Reman or Rebuilt ??
- Power Steering Pressure Hose...
- Sound Deadening
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- very little base on xtron head unit
- 2004 Audi TT 3.2 Quattro Air Leak
- Timing Belt Kit
- Has the OBD port fairy been...??
- 2002 Cluster
- Werid turbo sound - not consistent boost
- AUX connector for OEM Concert radio
- Central Locking and Electrical Issue
- central locking,fuel cap,boot opener not working
- how do you adjust the rubber bump stops in the boot/tailgate
- carbon fiber mirror caps
- vibration while shifting gear
- Bulb Out Warning Light
- Rough First Gear in Traffic
- Audi TT TDI Haldex pump issue
- '05 3.2 S-line Start/starter issue
- Warning HOT Weather is coming. Is your cooling system ready?
- getAudiparts.com | Give a little TLC: Genuine Audi Car Care Products!!!
- 8,000 mike 2000 TT 1.8
- driver door lock
- ABS Question and Central Lock/Alarm
- CCM question
- xenon headlight change
- 2004 S-Line 24K Miles - DSG Service?
- 2002 1.8 tt
- Always check the Cabin filter when buying a used car.....
- Is my 2001 TT 1.8L Roadster overheating really???
- Electronic issues
- How do I remove the battery box
- Technical Tips for TT & TT Quattro 2000-2006
- Timing belt
- smoke from exhaust audi TT
- Flashing red light
- disconnected battery, now problems
- spare key 3 button
- Need some advice
- Lifted pad when changing cluster lcd
- I'm thinking of a headlight upgrade...
- radio buttons
- just joined the tt club
- Fuel pump problem... Please help
- Register now for TT West 2018, A Grizzly Drive, Sept. 9-14
- Need some help passing emissions (CT) Codes and readiness issues
- Lower Front Drivers Grill Question
- Want to Purchase Boot (Tonneau) Cover
- Independent Audi Mechanics in Central Arizona
- How to check accuracy of coolant temperature sensor?
- Steering issue
- Missfire question please HELP
- I want to run staggered on my 2004 TT Roadster?
- purchase
- HELP!!
- FLASH SALE! ECS Stage One Clutch Kit Lightweight Flywheel + Performance Clutch!
- Power Top on 2001 TT Quattro
- Electrical tape?
- Filling up @ 1 gallon an hour... click, click, click...
- vin split on 02 sensor
- Audi TT gauge piller
- head lamp washers jets
- check out this fuel filter..dirty? wow
- Electrical Problem
- Random Loss of Throttle Response
- No FWD when Haldex Fuse Removed
- 5-6-2001 date in cluster
- Turbo inlet torn (suggestions on replacments)
- MK2 Cluster into Mk1 worth it? Will it even work?
- Boost Leak
- killed my rear hubs!! TT 225q
- 2001 Roadster Dome Light?
- Quattro 5spd and 6spd cluch data help
- windscreen washer leaks
- 'No Magazine' displayed when the CD changer is installed
- Juddering / Shuddering vibration differential
- Bought the wrong clutch
- 2002 TT Roadster - convertible top problem
- 2000 Audi TT braking/ABS problem
- Buying an 05 Audi TT 225 Convertible
- Hello ? About the instrument cluster on a 3.2 tt
- Power steering pump
- Battery
- TT 2005 225 quattro Coupe 6spd Engine cooling light
- Met a guy today that put a 2.5 into his Mk1
- Wiring schematic for Radio
- Wondering about interchangeable MMI part numbers.
- Convertible top hydraulic line replacement
- Headlight problems
- 2005 Audi TT suddenly blows out freon
- PCV valve location Audi TT 2002
- is a 180 tt quattro worth buying?
- REAR LID RATTLE
- Factory Timing Belt for MK1 Audi TT
- Audi TT 2004 Coupe New To Community
- Issues with convertible top on 2009 TT's?
- Xenon issues
- factory lock
- votex rear boot spoiler
- Proper process for paint job on Audi TT Quattro
- Wanna buy a used 03 TT, have some concerns.
- rough idle when warm only
- Want to Restore a MK1 TT
- 2002 Audi TT hiccup problem VIDEO help please
- Audi TT Xenon Headlights
- Looking for 3d printer design...
- Best Audi Phone Holder - Discount Code Available!
- Rim offsset setup
- seat heater
- When starting car automatically goes to redline
- Audi TT Quattro 2000 no crank. Why?
- Why does the fuel gauge jumps back and forth?
- Engine Stalls, wont start for a while
- how to release steering lock A1
- help ecu problems maybe????
- TT boot compartment
- Hard Nipples!!!! Turbo inlet pipe nipple size
- Heater
- Satellite Radio?
- Thumping noise from rear
- PHONE PREPARATION KIT - AUDI TT 2001 225HP
- Flash SALE 15% off ECS Stage 1 Clutch + Lightweight Flywheel TT MK1 180HP FWD
- BOOT LIGHT AND DOME LIGHT
- Odd electrical issues
- Turbo Muffler?
- Transmission fluid?
- TODAY ONLY Save 10% on DKM Stage 1 and 2 Clutch Kits
- Radio wiring
- error code 01228 on 2006 TT won't go away
- Identify this part?
- HVAC flap actuator
- 15% off Malone Tuning Engine Software Upgrades
- Tracking Issue
- Battery drain
- MK1 TT wheel and Tyre combination
- Engine block coolant drain plug location? AUDI TT mk1 Tank heater questions HELP!
- Battery Drain Help
- Is your car ready for winter?
- up to 15% ECS Service Kits for your TT
- Audi TT 1.8T Overheating
- audi tt
- Stage 3
- Defrosting
- P0507 Code Only 1.8t
- Help price my TT?
- Homelink
- roof operation 2005tt mki 1.8.
- Manual Shift
- unpredictable power curve
- TT MK1 Toy Thread
- TT build - first time Audi owner
- intermittent no start no fuel- not pump, relay, or temp
- Head lights
- rear diff/ haldex whine
- looking at buying 01 convertible, questions
- Removal of headlight aiming system
- torque specs
- hard coolant pipe....under intake manifold question?
- 2001 Audi TT Roadster 1.8 Turbo Quattro Owners Manual?
- Audi TT mk1 1.8 turbo quatro what fluids to use
- Getting a 01 225, what wheel size for good stance?
- Suspension - what's wrong in this picture?
- engine noise
- bolts size and type for turbo oil return
- TT Roadster door courtesy light switch location
- Suspension springs
- 2001 Roadster TC & ABS lights
- roof will not open
- blinkers do not work, but hazards work and so does the alarm on the signals all light
- Does anyone know how to check what transmission is in the car?
- Bleed air from cooling system?
- Transmission Failure
- Communication error
- Clearmounts Commercial!
- Air Bag light
- Custom Cellphone Holder - by Clearmounts
- TT-East 2018: A Return to Helen
- Transmission to Engine Bolt Layout
- radio wiring
- If Audi USA discontinues a part, is it still available in Germany? Roadster antenna
- Hello I’m having a bit of a issue
- New clutch break-in troubles
- would i be able to run 275-35-18 tires on a 18x10.5 wheel?
- Me7 logger - FATS times?
- Radio draining battery
- Audi tt mk1 apx engine "fuel and no spark"
- Engine clean by teraclean
- Radio Sound Turns Off When I Turn On The Ignition
- Hazard lights electrical problem
- 1999 TT Immobilised
- What's this? see picture
- HI
- difficult engaging 1st gear
- LCD Display Issue
- Audi TT Turbo Quattro 2001
- Tire Pressure Monitoring System on 2003 TT?
- What is this and where does it go?
- Engine skips under load
- 225 Coupe Requested boost falling around 4k RPM or WOT
- Vacuum line help
- Friend wants to buy a low mileage TT for his son
- Engine Misfire
- Passenger door lock
- Stupid Question
- Mass air flow sensor
- TT: Engine problem
- 2004 3.2 TTQR with 215K as a second car
- TT225 vacuum system clean up - direct vent
- Can you identify the name of this rubber hose in the 2002 Audi TT engine bay?
- Need help on swapping broken CCM !! And Symptoms
- Remote key fob
- Wheel spacers for your TT!
- 2001 roadster
- audi turbo
- Ride Comfort and Tinny Door?
- audi a4 2004 turbo
- 10% off FrankenTurbo TT turbo upgrades! Ends 10/31/2017
- 255 or 265 tire fit on Mk1 TT225
- DKM Clutches For Your Audi MK1 TT | SO CLUTCH!
- 2002 audi tt quattro not hitting full boost
- Audi TT Mk1 Tuning video! Check it out!
- audi a3 start stop all lights on in and out
- fender bender advice
- New Headlights
- Help: Coolant System trouble shooting
- Another air bag light question
- Camber Correction After Lowering
- A/C and both Fans OFF
- 2002 AWP - Bent Valves
- Very high engine vacuum, rough idle/hunting, stalling, negative fuel trims
- Direct vent option
- 2001 180hp TTq - Issues I'm trying to resolve.. Ideas?
- My car won't stay on
- Temperature gauge
- ABS light on - OBD says no errors - What do?
- Oil Pressure Warning Light, after pick up tube cleaning.
- Cold startup
- TT MK1 "SNAKING" UNDER HEAVY NRAKING
- New tires messing with ESP?
- 2015 audi TT music interface
- automatic headlight leveling
- New ECS Adjustable Sway Bar End Links for your TT MK1!
- Replaced Thermostat. how to get air out?
- Weight reduction attempt.
- Any views on 18inch wheels on TT cabriolet?
- Would you recommend a tt?
