View Full Version : TT (Mk1) Discussion
- Temp gauge starts at midway
- Meet CALLIE
- AC not always responding
- Code p0102 and ESP light stays on
- CONTROL MODULE. ECU - 8N7962267A
- looking for my old TT
- What are these connectors ?
- Fuel Gauge and/or Sender? 2002 MK1 1.8T tt roadster
- Timing of 1.8 base?
- Hope this helps, I will try to get a closer picture tomorrow.
- New TT to me....
- What crank bearings are in the 225 version?
- TT MK1 Overheating Solved
- Exterior Door Panel Trim Peeling
- 225 BAM Suddenly no boost
- Blasted glow plug/engine maintenance light when headlamps are OFF
- early 2000 Audi TT 180hp (atc) TWO coolant temp sensors
- OBD codes 00293 and 00789 after leaving the shop
- 2006 TT with Bad Transmission
- Indentify wires in steering wheel TT Mk1 225
- Central Locking
- Problem with interior lights/key fob
- Trunk problem
- Sport struts to replace stock ones?
- Mk1 TT steering wheel to a 2018 facelift
- Which end wears tires quickest?
- 2001 TT Quattro
- How many miles is too many?
- Unclog ac drain pipe?
- 2008 audi tt convertible glass broken after install
- Trying to understand the Wind Deflector electronics / controls
- Tt Roadster starting issues
- Issues
- Issues
- Wet spot by accelerator pedal
- spare?
- WTB - tonneau cover and car cover for New To Me 2001 Roadster
- 02 TT Quattro Vacuum hose line break
- A friend in Seattle took this pic...
- Audi TT MK1 Wind Deflector Unit
- Cluster repair
- New alternator, still not charging
- Convertible top leak
- Brake Pad RATTLE
- 2001 TT Quattro Gages intermittent after fried alternator cable
- (Help)My cars is throwing multiple codes after timing belt change
- Timing belt replacement
- 2002 TT Temperature Gauge Pegged
- Iso amu 225 motor
- A/C unit buttons removal?
- REPLACE ECU?
- GR: Where can I find wether stripping?
- 04 Audi TT convertible window coming off! How to fix??
- 04 TT rear hatch won't unlock
- New owner of a 2002 TT
- OLDER VS 2016 TT
- Haldex help!
- Brake lights stay on
- Burning oil, but...
- 2001 Audi TT Rocker Panel Question
- Dashboard button??
- 225hp Q Roadster Suspension Suggestions
- Floor Mats
- TT 02 glove compartment
- Audi TT 2001 mk1 - Window
- Roadster ccm
- Roadster Tonneau cover and Car Cover
- What is this thing?
- ABS or battery trouble
- 2002 TT O2 sensor B1S1 Location
- Smoke from exhaust when shifting?
- 1.8T 110kw AUM - Fault Codes J271 and no Boost
- Low Speed Fan Fix - 3.2 TT
- ABS Control Unit
- Speedometer Acting Up
- UK: Possible Wastegate/Actuator Issue
- 2001 audi tt mk1 225 timing belt kit
- Help Identifying Parts For Replacement?
- Will crank but not stay started
- Sold the TT this weekend
- Timing belt, age vs mileage
- Speedometer Upgrade
- Seats and tops
- 2004 audi tt mk1 AC suddenly blowing hot air
- Worn upper front strut mounts ?
- locked out. Can't open door from inside or out.
- Help with finding where to order a hose
- Looking for some good, used, Performance parts Audi TT MK1
- Does anyone do engine rebuilds/replacements in Staten Island or NJ?
- Unknown wires / bracket
- Looking for seals (weather stripping) for MK1 TT roadster
- Ceased engine:(
- Anybody know what these two wires are for?
- Issues
- Some TT parts.
- red Oil Pressure light at 2000 revs
- CD CHANGER
- STEERING CONTROLS?
- Clearmounts DriveSafe 2020 - Custom Audi Phone Holder
- Catch can kit
- Head rebuilt, engine revving then wants to stall.
- Overheating
- Overheating
- Quick Release Hub for DSG paddle shift
- Transmission Rebuild?
- Cruise Control
- Cruise Control
- 5th digit engine code????
- shoutout to Lifetime Audi Parts
- CPS
- Interior door lock not working
- Maintenance OBD tracker
- Gain access to a stored TT
- Brake pad options?
- Unknown Broken Part
- Tuned FWD ecu in Quattro TT?
- Dashpod repair
- Front Axle Torque Specs
- Some Picture Help Please
- Where can I find this hose?
- value question on tailights
- Lowering Project
- Tools for Axle Replacement
- What is this hose underneath my intake manifold?
- Homelink
- $1200 Audi TT 225 First Drive | Canyon Run | Fixed with a $0.65 Bolt
- TT MK1 Retro-fit Cruise Control near Cambridgeshire, UK?
- Any advice on painting wheel hubs
- Engine mounts
- Brake Fluid - 2001 TT
- Underhood labels
- How to fix your shift fork |No 1st Or 2nd| Pt.3
- Fans
- Custom Audi Phone Holder!
- 2001 Autdi TT Quattro Parts For Sale
- 2005 TT 1.8l quattro turbo tensioner bolt broke
- 6000 dollar platinum service contract
- Numerous Acceleration Problems
- I hit an exposed sewer and lost all my oil
- Martin Powell
- 2003 mk1 tt lcd screen broke
- Brake Upgrade Options for 2001 TT
- AUDI TT 1GEN CUSTOM KEYCHAIN
- Rear Shock Length
- 6-disc CD changer and Denison Bluetooth device
- 09g torque converter refill?
- Small Brushed Aluminum Cap
- Replaced rear brake calipers
- TT 1.8
- Coilovers
- A little help on Vagcom
- Interior lighting short
- Battery Died, Replaced, Check Engine light
- Windshield Wiper Fluid Leak
- Greetings
- Anyone selling the OEM roof bars/mounts?
- TT mk1 atc ecu to awp conversion
- Want to win an RS5 or eTron?
- Boost issue
- TT 1.8t vs A4 1.8T
- Haldex Issues- Looking for Advice or Faux Quattro Specialist in NJ.
- Roadster top maintenance
- Audi TT Part Of Headliner Replacement - Awesome interior Fabric
- Different safe problem
- Audi TT convertible top replacement
- Stage 3 tune/tuner suggestions?
- Steering Angle Sensor Basic Settings OBDEleven
- Auto-dimming mirror
- 2001 to Won’t Start
- Exhaust upgrade recommendation
- Homelink in an mk1 roadster?
- 2001 TT Roadster
- What car do I have? Any Ideas
- Uses for VCDS?
- 2004 3.2l TT Quattro Electronic System Failure
- Considering Purchasing a used 2002 TT Quattro. Things to look out for?
- V8 Engine swap in TT?? La swap?
- Bought a 2006 Audi TT 225 in Dolomite Gray...except that it's really Lava Gray Pearl?
- Battery light problem
- 3 chimes
- OBD Scanner to measure for worn timing chain / belt?
- Adjusting a 6 speed shift linkage?
- Peak OET European Vehicals (Coolant)
- Mk1 TT 150K refresh?
- Water from the crank pully?
- display cluster pod lost pixels
- Missing part next to CCM
- My poor 2004 TT .. Bent frame?
- New radio for Mk1 TT?
- Question for the experts.... Car in gear but it wont move
- UK: locked out
- Antenna base PN needed
- car running hot...
- HELP: Changed seats in 01 Roadster, now Airbag light is on
- Code issues
- Driver door not engaging when shut
- ESP and ABS won't go off
- Several fault codes - Help?
- Wind deflector- a riveting discussion
- Switch compartment lid
- Wiring Audi tt 2003
- car cover question
- rear lift gate seal
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Airbag Light
- GB: Hi new to this site: 2004 Audi TT
- Wind blocker
- Clutch
- so it is winter now
- Question on emblem re-use
- typical glovebox issue
- 2001 Audi tt Double Din
- Electrical Cluster Unit replacement...$2400?
- Air bag light always on
- Thinking about getting a high-mileage TT
- Cruise control not turning on
- Need guidance
- What is this line?
- Audi TT mk2 2002 turbo
- Rain deflectors
- fuel door acuator
- Smog reset set for repaired Audi Quattro TT
- 04 tt 225 quattro catch can question
- HEAT IN THE CAR
- Missing top gear
- Just need help diagnosing some issues
- Senile Dashpod? Won't stop chiming randomly SOS!
- TT over-heating?
- Possible Turbo Surge/Flutter
- Headlights: TT vs TT Quattro
- I'm troubled.
- 2000 TT
- tire interference 245/35/18
- 2005 TT Storage Compartment Door Latch
- Acceleration Problem
- First gear getter— lateral shifter cable bell crank bushing.
- Camshaft Seals
- 2001 Audi TT Quattro-replaced dead battery, won't start!
- Help! Lots of Circuit High codes.
- How rare is my new to me Audi TT 225?
- Any positive or negative recs for auto shippers?
- EPC light
- Shock Recommendations for Eibach Pro-Kit Lowering Springs
- New (returning) member, tail light error with an odd solution?
- My 2002 TT 225 Quattro
- Tips on 3.2l VR6 Serpentine belt install
- Fuel Distributor hose.
- Looking for "Lower Cover" cylinder around shifter
- Steel Shift shaft/fork for 2002
- Convertible roof would not open or closed automatically
