View Full Version : TT (Mk1) Discussion
- replace ecm or sell?
- Audi TT MK1 1.8T THE BEST DIVERTER, RECIRCULATION, DUMP VALVE ? (Installation Guide)
- Replacement convertible top - Robbins or GAHH?
- 3.2 V6 brake parts obsolete
- Keyless door entry
- AUDI TT MEET 16/10/2022 @ (Ockham bites) over 130 TT's
- TT Mk1 engine swap
- Should I do more maintenance?
- May Buy 2001 TT Coupe - 147k miles for $3800
- Removal And Refitting An Upgraded Mtech-Engineering Custom Gear Knob
- 2006 TT with Trans Issues
- Can I jump start my audi quattro tt?
- 2001 MK1 5 Speed, 1.8 FWD, Over-Revving Noise
- Don't buy cheap parts for your car!!!!! Audi TT mk1 8n 1.8T oil and filter change + O
- No crank no start
- Amp Removal?
- 2001 Audi TT Roaster Remote Control and Convertible Top issues
- Audi TT mk1 8n Project fuel pump replacement and upgrade
- Convertible Top Issue
- key not recognized fault
- What is this?
- FI: Where are the groundings/earth points?
- TT resurrection nearly 'complete', need help with idle issue
- Audi TT mk1 8n Project Gets Some Well Needed UPGRADES
- Audi TT 225 - Downpipe installation - helpful info
- TT Quattro MK1 AWP vacuums
- engine mount - ok or not?
- Audi TT Quattrophneia London to Brighton TT run 2022 vid
- Help me diagnose no start Dash Cluster Blip (Video)
- Auto headlight,
- Third Brake Light Housing- Painting Advice
- What is the estimated indy labor hours to replace the throw-out bearing?
- AUDI TT MK1 8N ENGINE BAY DRESS UP KIT(QUANTUM QUALITY SOLUTIONS LTD)
- Side covers
- banjo bolt on back of engine block?
- AUDI TT MEET 21/08/2022 @ (Ockham bites)
- Help. Info on Window/panel seal guide slot
- bad central locking module
- secondary fuel pump help needed
- How To Restore Headlights PERMANENTLY ( make them look BRAND NEW )
- TT Immobilizer prob
- TT Randomly won't start
- Advice needed 2000 TT Quattro
- Vacuum line kit
- Unable to open driver side door lock with key manually, able to open passenger side
- 2001 quattro - fuel pump primes when?
- Mk1 Audi TT Hybrid Turbo Install Part 2
- AUDI TT MK1 8N PROBLEM QUICK FIX (rear light)
- Selling car on BaT
- Rear Spoiler Removal- Roadster
- PROBLEM WITH A AUDI TT MK1 (VIN WINDOW)
- problem backing
- UK: AUDI TT MEET AT SPRINGFESTT 2022
- Anyone recognize this part? Valve Body Replacement
- external wastegate
- CY: INECTORS
- OEM HID Headlight tabs?
- Tiptronic/automatic - jumps-out at low RPM between 3rd&4th gear
- 2004 tt Quatro Roadster
- Bose Issues
- 2004 Audi TT Roadster Key fobs not working as rainy weekend
- Fuel line routing
- New Owner of 2001 MK1 Convertible 225Q - Needs TLC
- How to Replace? Cracked/missing lower-section of Front bumper & skid plate
- Help needed in removing parts to get the headliner out, PLEASE
- Broken knob climate control unit
- New Project Car Reveal + Upcoming TT vs G35 Race
- Shifter stuck.
- Rollin in a TT music vid
- 2002 Audi TT dash lights stay on with key out and car does not start
- UK: Remap?
- Looking for part
- Chicago-Area DSG shop
- 5w30 vs 5w40 225hp 01
- '04 TT front seatbelt igniter switch needed
- 2001 Audi TT roadster optic leather interior
- Audi TT Roadster MK1 - DIY Seat Reupholstering
- The baTTle of Hastings Southeast TT meet 11/6/22 (VIDEO)
- PVC Hose NLA 06A 103 213 AN ? 06A103213AN
- anyone need a jump starter ?
- Possible TT purchase
- Audi TT mk1 8n safe mode radio code fix (quick vid)
- Rubber Cap?
- Turbo cuts and stutters
- A tale of two Audi
- comfort module
- Stalling Issues
- Mk1 TT suspension parts
- AUDI TT MK1 8N 3.2 V6 (can you still get a bargain??????)
- Turbo sits too low for manifold
- 2001 audi tt quatro
- Ecm swap
- UK: AUDI TT BREAKFAST MEET 22/5/2022 (HEMEL HEMSTEAD)
- 03 audi tt quattro not starting
- lift points for 2-post lift - somewhat confused
- Independent shop recco in DC area
- Complete parts file - Audi TT MK1?
- should you buy a mk1 tt? vid
- Hose Identification
- OBDeleven - MK1 TT Quattro 180hp
- UK: Audi tt London to Brighton test run (QUATTROPHENIA)
- Catch can/PCV question
- Clutch replacement time
- airbag 65535 code fix??
- Double Din console available
- 180 or 225?
- Instruster cluster fuse (#11) blows as soon as you plug in headlights?
- 180 mk1 fwd tt
- Getting my TT back on the road
- replacement front bumper
- R&R Center Taillight
- 2002 Audi TT Gauges Flickering and Going Crazy
- Milltek Exhaust Fitting problems
- Audi tt p0411
- Audi tt p0411
- High Mileage TT ?
- alarm module location
- New owner
- Door lock barrel
- UK: AUDI TT MK1 S3 MK4 GOLF R32 CHECK YOUR EARTH STRAP
- Hello - and what's this?
- TT BREAKFAST MEET THIS MORNING
- Parts for Audi TT
- Mk1 Cruise Control?
- replacement of strut bearing?
- PCV issues / question
- UK: AUDI TT MK1 IS GOING ON A 5K CHARITY RUN TO ISTANBUL
- Repairing head & turbo - 2001 225hp AMU
- 2002 TT Electrical? Alternator?
- 2005TT Roadster..Check Engine light on but will not scan code.
- 2000 TT goes forward when in reverse
- Transmission issue 2001 Audi Quatro TT
- Climate control codes - 2003 TT 150bhp
- Hard upshift on 5-speed
- Seeking a VR6 passenger side engine bracket
- model type classification?
- Hitch receiver for bike rack on MK1 Roadster?
- 1999 Mk 1 tt starting problems
- Audi TT problems continued
- 2001 mki TT problems
- 2001 Audi TT Quattro power steering leak
- Audi TT Mk1 alarm location Sirius
- Not stolen?
- I bought a 2001 grey TT has no key and battery's out also need a seal on exasy
- carbon fiber hood
- Haldex 65535 - Internal Control Module Memory Error
- Xenon to Halogen coding help!!!!
- Rumble and vibration at 3500 rpm in all gears
- Just bought a TT Quattro
- Who wants the last spot for TT West Rockies Roads August 22-27?
- Weird vibrating engine break sound on acceleration
- Best single DIN stereo?
- Instrument cluster failure
- Question for anyone who has removed the Central Control Module on a Roadster
- Mk2 help please
- What size skis and snowboards fit in the back with the seats down?
- New 180 owner looking for coolant hose helps
- Will any Mk1 catalytic converter fit my Mk1 TT? or must the cat's engine code match?
- I let a mk1 owner have ago in my mk2
- Timing Belt Tensioner Bolt sizes and pitch
- 04 TT Quattro - Clutch Hesitation in Cold Weather
- 2001 Audi TT Quattro Instrument Cluster repair needed
- 2003 TT 225 Roadster Comfort Module
- ABS module/pump for my 2003 TT 225 Roadster
- VCDS, Seatbelt Alarm Disable???
- 2003 TT Emobilizer code
- White flakey buildup on Aluminum Grab handle
- Missing wire harnesses
- Married Parts
- new mk1
- New to the Club, '02 ALMS, Looking for parts
- Roof help needed
- Roadster Subframe
- VSS LOCATION
- ATC 1.8 COIL HARNESS ISSUES
- Intake Wiring
- Mk1 TT key fobs not working
- glass wind deflector screw lift
- OBD, VCDS? OBDeleven? Etc?
- front drop link for audi MK1
- Need Autocross Upgrade and Tuning Advice for MK1 TT 225
- Things to look for buying used 2001
- Audi tt concert radio
- Check Engine Light - 3 Codes (Vacuum Line?)
- Unexplained Overheating Issues (it's not the water pump, radiator, or thermostat)
- need advice and help with instrument cluster
- Coil Pack Harness for 1.8 ATC
- new vibes
- RIGHT FRONT AXLE
- CAI recommendations?
- SEM INTAKE MANIFOLD
- Ty door locking makes passenger window roll down
- 2000 audi tt mk1
- Tons of CEL codes P0300, P0302, P1103 and more, SOS
- Oil Deflector
- Problem diagnosis
- Any Bright Ideas?
- MK1 roadster roof stuck down..
- audi tt quattro 3.2 what brakes to get?
- Hit a deer tonight.
- Laggy / FLAT SPOT TT
- How much is required to switch a 180 hp model to a dual exit exhaust?
- Mk1 Audi TT convertible top not working
- Heat Issues, What am I missing ?
- Coil pack wire harness replacement
- Just got a TT mk1 and want to sort out 2 issues (A/C and P1296)
- HELP - Speedo & Tach needles point straight down
- Black Friday / Cyber Monday SALE ON NOW – Best prices of the year!
- Audi TT MK1 1.8T Quattro Clutch Failure
- New turbo recommendations
- 2001 Audi TT MK1
- 2002 Audi TT Quattro Roadster
- New TT owner, need help!
- Coolant level & Check Engine Light ????
- Yes, you can deer hunt out of a 01 TT
- 4wd hopping
- Driver side door will not open from outside
- HALDEX inspection port threads have fallen!!
- AU: Oil leak
- Audi TT MK1 Haldex Options
- Audi TT MK1
- Smoke Test for Boost/Vacuum lines?
- Ajq 1.8t mk1 audi tt
- New to me tt
- Rear windscreen of Roadster smashed
- mk1 project thread build
- Just bought my first TT, please help!
- Gauges suddenly not working.
- Coolant Hose Quest
- Another odd window behavior
- Dsg / drive issues
- Check Engine turning off
- 04 TT 3.2 with DGS problems!!
- Check Engine. Stubborn Codes
- MKI 5V 225 HP Timing Belt
- 2000 TT's rear seats won't go back up
- Big SocalEuro 2021
- Unexplainable problem with my 2004 Audi TT
- Leak repair, do I need to remove the convertible top?
- Does Anyone know what this strip is called?
- Turbo fan
- MK1 Parking brake aftermarket mods
- 140 AMP ATERNATOR
- Upholstery Recommendations
- DK: Headlight. Hos to unmount the plastic cap for xenon bulb
- Audi installers?
- 01 TTQ hub conversion
- Best water pump
