View Full Version : TT (Mk1) Discussion
- What TT to buy?
- Another newb designing a TT stereo system
- Headlight Question
- Please Help Me Locate a Hose
- Mystery cable connection
- MK1 door interior refurbishing?
- Mk1 Audi TT Top Mount Big Turbo Gt35
- Fair price for this 2001 MK1?
- Oil Pressure Sensor Stripped Out
- Need help identifying this thing
- Mk1 Audi TT Quattro Project : Interior Update
- Flashing BRAKE light only when I start driving
- UK: audi tt mk1 camber angle
- audi tt mk1 remote key release
- UK: Mk1 tt o2 senseor problem 1.8T
- Gen 1 Haldex Controller 177856 swedish on a TT?
- Mk1 Audi TT Quattro Project : Clutch Carnage! / Southbend Stage 2 Clutch Upgrade
- N249 Vacuum Box Delete
- Dumbfounding overheating issue
- turbo remove
- Radiator fans running after engine off and key out
- 02 TT Roadster AC issue
- Manual transmission issue
- Driver side window issue - HELP
- Convertible top works only once
- Removing the TT Fuel Tank?
- 2002 TT ABS Module Discontinued?
- code P 0343
- UK: Spherical Dogbone vs new Poly Bushes
- Project Thread: My 2002 Audi TT Quattro
- Subwoofer Time
- Grinding/ whining noise and low speed
- Lock or unlock
- Instrument Cluster Rebuild- Best Vendor?
- Clutch diagnostic
- Good Deal Alert - Borla Cat Back, New
- Boost problems!
- 02D525275B - Rear Driveshaft Flange Seal
- I think my n249 ground broke, what to do?
- Infotainment System
- RPM Jump when 2nd gear engaged
- Best repair manual/OBD/software recommendations?
- Temperature help!
- Single THUD at 2000RPM in all gears
- Help to find cause of emissions diagnostic codes?
- Headlight not working
- TT lost power now wont start
- ABS light, no code
- code 1296
- Buzzing/Droning Noise when hitting 3000rpm+
- Adjusting headrests?
- Another clutch question
- European lighter adapter?
- A new proud papa of a black on black MK1 QQTR
- 2001 Audi TT - Roadster -driver door lock or adjustment
- Mk1 TT clutch, please help
- Front Driveshaft question
- Diagnose No start no crank
- Last chance to sign up for TT West and COVID vaccination no longer required
- TT MK1 Convertible top range issues
- Mystery bolt??
- Abs system
- Best chipping options today?
- Parts Thieves!
- YAW Sensor equivalent part?
- Opinions on 04 3.2 with DSG
- Haldex leak - 2000 Audi TT Quattro
- Airbag light?
- Ok, Best Color Combo?
- Still no AC - reviewing next steps... anyone that knows the AC systems would be super
- Seat Rising Mechanism Changes?
- SoCal Shop for Timing Belt Replace
- 2001 TT - Front Bumper Attachment Bolts bent?
- Instrument Cluster Removal
- acc wire under the bonnet?
- Fitting between clutch line and slave bleeder
- New to the TT club
- 01 Audi TT 225 APR stage one 146k miles need help PLEASE!!
- Fuse Blows and Loses Cluster
- TEMPERATURE SENSORS
- Baffling complete battery drain after new fan relay module/3 fuses replacement!
- Wheels?
- AJQ MK1 2000 - At a loss, with constant LIMP mode - N75
- Mk1 TT clutch help
- 2002 TT wind deflector seal
- TT Idle Issues
- Looking for an 01 Nimbus TTQR
- Considering buying a used 2006 V6: how is the condition of this engine bay?
- Coolant overheating after SAI/N249 Delete
- Help please, 01177 mystery
- Flat tire in a TT roadster
- Audi tt mk1 Boost Problem
- 2006 Mk1 Roadster Convertible Top Issue F171
- TT Mk 1 Suspension Upgrade
- TT Mk1 ABS Randomly kicking In
- Front Parking Lamp Tip... and a headlamp question
- Audi TT mk1 225hp roadster brake problem
- Speedometer Needle
- Advice needed - Looking for a nice Mk1
- Registration is now open for TT West 2021 - The “Bucket List” Color and History Tour
- Rear Brake Dust Shield Bolts Part Number
- Audi TT Mk1 3.2 engine and DSG swap
- New clutch, still slipping, can't get air out, no leaks
- Interior material loose?
- Airbag control unit location
- Hello Audi TT new oil pressure level sensor pressure good oil light keeps Flashing
- HID Lighting Controller/Ballast
- P0501 Vehicle Speed Sensor code but speedo still works
- Coil Overs
- Can't Unlock Car from Inside, Windows are Wonky, and Alarm Going Off Randomly
- Bea tt, only 2 wires for g 28 sensor??? HELP!!!
- Looking for rpm wire to hook up turbosmart e boost2
- TT is in "on" mode without the key
- Installing a backup camera, which of these wires in the cluster is the reverse bulb?
- Where can I find MYDs link, FAQ or other resources?
- New to me 2001 TT 225
- Need pricing advice for 2000 TT
- Making 35-40 psi boost , what is the best electronic boost controller??
- Coolant level sensor
- screaming noise on start up from behind the seat
- Fuel pump puzzle..
- At a total loss, someone shed some light. PLEASE!
- Source for wind screen threaded shafts?
- User manual
- Door panel is off & can't get door open HELP:)
- 2006 Audi TT Quattro
- Acceleration Hesitation- Solved!
- Brake pedal goes hard.
- Clock Not Lighting Door Open, Battery Light On
- 2006 TT 3.2 V6 engine undertray removal for oil and filter change
- Clutch pedal don’t work
- Turbo Upgrades?
- mk1 convertible
- Double DIN 3D Print?
- 2004 Audi TT Quattro
- Vehicle Speed Sensor
- Pistons methanol yellow top batteries. Seeking advice from those who come before me.
- TT Mk1 head scratcher..
- Hose Diagram for Mk1 8N Quattro AMU
- Roadster roof problem
- Best Bluetooth adapter for original TT radio?
- 02 Audi TT radio code help
- 2001 TT - Crank no start (vcds output)
- New TT owner-needs your help
- New TT owner, question about the key fob
- 1.8T
- Bonnet Cable Snapped!! Help!
- Convertible top cover for sale
- 2002 tt having strange electrical problems.
- O2 sensor error
- Audi TT 225 Downpipe install help
- Starts and dies
- Votex
- Need Computer Reset
- For Sale: 6 Spoke Wheels - Columbus OH
- Clutch Pedal went to the floor as I shifted into 6th
- Need- Intake Manifold diagram - ATC 2000 TT 180
- Electrical issue
- who makes this gauge pod
- Hurricane Zeta rescue
- Audi Custom Phone Holder - Discount Code!
- DEFCON Adapter Dimensions
- should i paint my 2004 TT roadster
- Time for timing service
- New Mk1 owner - '01 225 6M Roadster - 39k miles!
- Advice on buying a timing belt tool kit
- has anyone fitted an android 10.1" screen or..
- 2002 ALMS AC control switch covers
- mods
- Cluster repair help
- Code P2422
- 2002 Mk1 TT
- 2000 Audi TT Quattro Coupe AWD
- Transmission Issues
- 2003 TT Coupe - Restoration (Father/Son) -Advice/Suggestions
- 225 MK1 8n Turbo upgrade
- Radio with 7 inches screen installed
- TT MK1 Powered Window Fault
- can anyone find me this wing? i really want to get it on my tt!
- Central Control Module
- Car won't start after Tire Change ;)
- Replacing A/C Compressor
- window drop, wackyness; tried alot, need help...
- 3.2 DSG underheating / slow warmup
- Headlight help
- Stage IV
- Question regarding P/N 8N7962267A - central locking module
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- AFR Wire Tapping
- Need advice, new to Audi
- Lost instrument cluster
- New to the audi world..
- Odd window behavior
- CD changer multi cassette
- Synthetic Oil Change
- 01 TT 180 issues
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- need help!! eletric issues, misfire, open circuit coils, will cashapp$$ for help!!
- Leather Car Seats
- 2004 Audi pcv valve location
- Any tips for buying a 3.2?
- Help! windows and hatch not working.
- Replacement key
- Need to set sale price of 00 TT quattro
- Steering wheel connection to to system is off
- audi tt 2002 180 fwd crankcase breather hose
- Loss of power and three fault codes in the 2000 TT
- Ski Rack Available
- Let's throw more money and parts at it....
- Air Suspension wheel set up
- New 2006 Mk1 TT owner - what should I do first?
- Car won’t start
- Radio Mode button not working
- Left over parts - any ideas?
- Door Won't Lock With Key From Outside
- Audi TT Roadster Control Module 8N7962267A
- Changed my radio, but now ac/heater controls don’t work
- So many Ground Faults and a power draw that eats batterie's
- New pump running, no gas to engine
- car cover for sale? (mk1 roadster? part: ZAW400106)
- EOM Tires for ALMS
- TT MK1 bumperettes/tumors
- Glue roadster rear window - rare earth magnets
- Help with steering column....
- Car died and won't start but cranks, then started when I tried again 8 hours later
- Oil reservoir front right 02 TT Quattro
- need some hep
- 2000 tt Quattro.
- New & improved Audi Phone Holder!
- Missing Hose/Part?
- 2002 Quatro TT - sometimes electrical is dead
- 2001 Audi TT Quattro
- 2001 TT 225 coupe
- Having a p0441 code after evap delete
- Have a p1476 but i did a evap delete how can i get rid of it
- New to Forum; Requesting DIY Reference Info
- Only Tweeters Working Bose Concert Sound System
- Can you damage the engine driving with a bad Vent Valve?
- 2001 Audi TT No Power after changing high voltage fuse box
- 2006 Mk1 Roadster Top Issue
- Line Out/RCA Output from stock Bose Amplifier?
- Audi TT MK1: Crank no start
- Help with 2000 1.8 FWD roadster
- Help 2001 audi tt quattro 225hp vibration
- New Timing Belt for low mileage 2001 TT ?
- 2006 audi tt 3.2 Special Edition
- Mark 1 2005 Bosr Stereo Sound
- Audi TT 1.8T 150hp AUM - help
- New 01 TT Quattro - Advice needed
- Cluster repaired but car still won't start!!!
