View Full Version : TT (Mk1) Discussion
- Need help Identifying/replacing engine component.
- Wheels
- Weird Electrical Problem and Overheating...
- 2000 TT Quattro Bumper
- Buying 2006 TT 3.2
- feels sluggish
- Car wont start..
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- will clearing a CEL with APR software affect the readiness?
- anyone with a stock oil cooler laying around?
- ECU # 8N0 906 018 T
- suspension question
- Exhaust
- Anyone interested in 19"x8.5" HRE C20 wheels?
- OZ Canyon II - wondering if I could get some help
- Anyone interested in a Phatbox?
- New Tires
- K04 upgrade.. Anybody?
- Strange noise while driving after rotating tires
- Forge Spiltter
- Malfuction Indicator Lamp (MIL)
- what do you think thumbs up or down????
- Cruise Control
- Fans wont turn on?
- Haldex accessibility under car with jack stands? Also anyone willing to lend wrench?
- Mk1 TT front (Euro) license plate filler panel
- Help with Power Steering Leak Please!
- MK1 180 Turbo Sound?
- 225 VS 180
- CARFAX Request..Thanks.
- Sirius Issue
- squeal noise during 1st gear
- Replacement parts for interior console?
- Yikes, Audi TT being torched in Greece during riots
- ::ECS Tuning:: TT MkI Tonneau Cover - 87% OFF
- TT-West 2010 registration is open.
- Body Shop in NoVA??
- Anyone have this for sale????
- TT-East 2010 registration is now open.
- 02 Audi TT Quattro For Sale in FL
- Wind Guard/Deflector?
- MK1 Rear Valance
- tacometer jumping around
- TT-East 2010 update...>>>
- TT Mk1 Brake Pedal Cover
- Selling my 2004 TT225 Roadster - Advice?
- Need help with my radi fans. Please help.
- Alcohol Injection System Install
- tt highbeam icon stays on after projection light install
- Radio in Texas, very week signal/After-Market Sound System
- 2001 TT Quattro Recommended Battery
- :: ECS Tuning:: Concert II head units and CD changers 92% OFF
- Exhaust Leak: Suggestions?
- Money into the TT
- what is that behind my left TTailight?
- which timing belt kit??
- TTaillight MOD
- Strut Tower Brace
- TT-ECU fuse keeps blowing
- Good place to buy Timing Belt/water pump ?
- Electrical Issue
- washer fluid resovoir warning FUSE. i just want to pull the fuse
- TT sold for S4
- Fuel guage help!
- STaSIS Street Sport
- what happened to all the old threads?
- strange alarm / dome light problem
- Need a fat five
- Headlight Squirters?
- Power Steering Fluid Leak
- Belly Pan part Number?
- Undertray cost $$??
- Where to buy a rear seat back?
- Safe mode reset every restart.
- sea foam? intake?
- TTS ORDERED
- Newbie Question
- Can anyone recommend a good surface scratch remover?
- 265/30/19??? FIT
- No window lift upon opening/closing door
- TT Collectables
- Front Wheel "Loose"? is it normal? or a greedy shop
- Window Worriess
- new axle why so thin?
- Simplify Vacuum System
- Concert I, Concert II...? Just not sure...
- ABT limited rear spoiler
- Central Locking Issues VAG-COM scan inside
- Trouble posting in classified section.....anyone know why?
- TECH HELP - Breather system
- oil leak,- cams shaft seals / valve cover
- Airbag Warning Light Codes
- What the heck is this part??
- Quattro and Headlight problem.. 2001 TT
- gnition Switch Issue..When I turn the key it just KEEPS SPINNING
- Issue with rpm meter when idle
- How much is it worth?
- Driver Power Window
- Hey 'ol Friends! Need wheel recomendations
- malfunction power windows
- Deist harnesses and Stable Energies harness bar
- TT-West 2010 Event Registration is Now Open!
- Completely Numb Steering!
- Bent Tie Rod
- Tierod Boots?
- Trans. problem
- TT-West 2010 Event Registration Opens Monday!
- Lighting Issue
- What is missing from my trunk? (2004 3.2 TT Roadster)
- Ready to Give in?
- Paint shop recommendations in SoCal ...
- check engine light
- Headlight Bulb replacement???
- Is this true?
- New to Audi World!
- TT won't start...beeping and flashing sounds
- Central locking, windows, and convertible top
- Stop roof leak?
- Both Windows Stopped Working
- TT tuning for economy
- Free Audi TT Tonneau cover
- HID fitment trouble
- water damage and electrical quirks
- best 1/4 mile of audi tt ?
- Anyone know size of small tubing on top of turbo Pipe?
- Aliens
- lowering springs and 1/2 Kmac on ebay
- What usually goes when the TB breaks?
- Rotors and Pads
- Radio Code
- WTB Quattro with blown motor
- Question about quattro
- Interior wiring issue!
- Audi TT 2001 5th gear grinding problem.
- temperature sensor
- Timing Belt Replacement: waterpump recommendation
- Power steering whine - engine noise?
- Oil in coil/spark plug well
- TT 6 spoke 17" Center cap question
- Airbag lights on
- Nitto Invo Tire Review [Video]
- 18" Wheels and 245/40-18 on '01 Roadster?
- Starting Interlock & Fuel Pump Relays. MK1 TT
- AC Compressor (aftermarket) - issue with wire harness
- Relay locations
- ok accessed the HID bulb but how in the hell do you get the ring off to get bulb out?
- HID bulb replacement, do I have to remove whole front fascia for access?
- EPC and TRACTION control lights ON!!
- seat swap for Mk I TT from Mk II TT
- Couple quick questions
- Looking for a manual TT transmission>>
- Fuel Gauge Problem
- Items for sale...TT 1.8t FWD
- USA to UKI CD RADIO "TRANSPLANT"
- What do you think?
- Stasis Streetsports
- Spare tire changing fiasco
- Fuel sender?
- Please show me the location of the Vacuum Lines for Seafoam
- Heater not blowing hot air
- What is the 'Car' symbol with key dash light?
- Help needed with Radiator hoses!
- Replacing H2S lamps, but should I be concerned about...
- Anyone have any Forge diaphragms sitting around?
- Is there any rev limiter in TT's MK1 ?
- What could cause this problem? Running rough and drop in MPG
- rmm
- My baby just celebrated her 10th birthday ...
- Can I convert my TT from FWD to RWD ???
- I'm looking for a 2001 a6 4.2 v8 headlight igniter (ballast)
- Strange Sound????
- removing intake manifold
- help identifying sensors
- update: back on the road...
- 01 Audi TT with a P138 and a P1136
- HELP :D
- Privacy screen - broken clips replacement?
- Modulare Forged
- Need help wiring in subwoofer and amp to stock bose HU
- radio wiring issues. PLEASE HELP
- Need parts: bolts only, fuel door 2004 TT
- Engine Check warning Light
- 2001 tt quattro wont start
- Car won't start. Sputter then whistling noise and dies. TURBO DEAD?
- New girl here...
- Noisy engine after timing belt change
- TT risers
- looking for a good Audi Mechanic near Baltimore
- fuel filter change
- Starting Issues...
- Transaxle removal
- Would VAG COM help me?
- Buying a 2001 TT Quattro Turbo - should I?
- help with my rear wheels please?
- help wit tt rear wheels
- 2001 TT 225 6cyl manual
- Neuspeed, tein, or Eibach?
- DetailersDomain's Holiday Special 15% off and Free Shipping over $75.
- APTuning Holiday Special, Half-off Differential install!!!
- ALL Peloquin and Quaife Diffs on Sale at APTuning!!!!
- Audi TT Cylinder 3 misfire/possible wiring harness issue?
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
- Engine Speed Sensor (G28) replacement Tips
- Anyone sucessfully put a Concert II inplace of the Concert I?
- sorry to those who find this inappropriate
- HI New here with ?
- Partial boost issues, can anyone help?
- How much is too much $ to fix my car? Just lost first and second gear.
- WTB a broken pass headlight!
- coolant drain?
- LED TT mk1
- HELP
- :: ECS Tuning :: Holiday Sale and massive Holiday Giveaway 2009
- **Cash In On Revo Technik This Holiday Season!**
- looking for an oem rear bumper cover
- :: ECS Tuning :: TT Radios on Severe Discount!!!
- TT head light set
- anybody need a air filter inlet pipe?
- used mofo on ebay
- Clutch pedal replacement
- brake light bulb # help
- Need help making decison on Rear Brake components..
- replace front parking light bulb
- 2005 S Line Features?
- ***Avoid*** Valenti Motors - Watertown, CT
- Brake pedal feels stiff after parked
- Dent fixing
- 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
- another "help id that part" question
- Help Identifying part #
- Brakes
- Used TT 225Q or Used WRX?
- alignment read out needed
- Vacuum Canister Issue
- Proper way of changing brakes and ABS
- 01 225HP TT Coupe for $12.5?
- twin turbo 1.8t?
- :: ECS Tuning :: TT Votex after market body parts from $59.95
- Improved Coil Packs
- How do you replace xenon headlight bulb?
- Help me decide on a used 225TT
- Electric disaster!!!
- Anyone here that is still here after so many years?
- Purchasing a TT and have a problem
- WOT Capability?
- My 2001 TTR is slow to warm up. The heater
- transfer case removal 2000TT
- Stock Head Unit
