- High Idle at operating temp
- Welcome to the AdBlue Delete club
- Faint whine when cruising
- Need Advice for Subwoofer Install
- All Season Tires?
- Expensive before ... and after
- UK: Audi b9 head gasket
- Rear Coil Spring
- Seats from B8.5 or other models?
- Rear Deck Not in Correct Position?
- Child lock: fault
- Pre sense malfunction
- FR: Audi A4 pre-purchase check
- 2019 A4 Best way to tame the rear deck rattle from sub?
- Rear end feels very loose - can't figure out why
- UK: Audi a4 speed issue at high speeds
- Permanent 360° view fix + Unlimited map updates
- 6-Speed Clutch Bleeder Valve Operation
- Rear parking aid: malfunction! Obstacles cannot be detected
- Audi Connect
- What's comimg for 2025?
- Audiconnect
- how much does the mild hybrid addition to the 45 tfsi engine help or hurt
- 2017 A4 Quattro..new quiz posted!
- Blacked out 2018 Audi a4 Sline best looking rims?
- Steering Rack Issue
- Audi 2.0 35 TFSI - vibrations in idle
- Waiting time
- MMI - Car menu not working??
- Interior lights doesn't work individually
- What are some front lip splitter option for B9.5?
- hazard switch a4 b9
- 2017 Audi A4 Suddenly Unable to Connect Phone to Audi Smartphone Interface
- Is anybody selling their NON-sport suspension components?
- Can the adaptive suspension be modified using VCDS?
- Inspection message info? Help
- Engine Code Difference? - CVKB vs DEMA
- Please help! How to fix wire?
- Potentially Purchasing 2024 A4 45 Premium Plus
- U0155 error - instrument panel blank on B9 A4
- IE: Front suspension knock/clunk, 160k km
- 2017 Audi A4 B9 DSG Reverse Issues
- 2017 Wiper Blade Infuriation
- 2017 A4 coolant loss
- Gearbox oil change
- How to test seat heaters?
- Anyone know if the front seat upper are the same on driver and passenger side?
- A4 B9 2022 - Automatic Opening Leaving Home
- Alignment
- Oil change supposedly done but only 1/3 oil level
- Cruise Control Dropping Out Randomly
- Looking for New Summer Tires - Recommendations
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- AudiCare Maintenance/Service History/Records
- Long Term Reliability?
- Steering Wheel Upgrade 2017 B9 A4
- mmi screen flickers
- Coolant Temp Sensor P0116 P2181
- AC not blowing cold
- Grille
- Grille
- New Product - A4, S4, RS4, A4 Allroad Hidden Electric Hitch Package
- Audi connect pricing
- New Forgedlite TF Series 1pc Forged Monoblock - Custom Made for your Audi
- Helppp
- Tailgate closing button problem
- 2017 A4 Coolant Bleeding
- 2023 ar 40 mpg
- Are they tracking us?
- Not sure if this is normal ? Help?
- Dash cam query
- Anyone with Rear Main Seal leaks?
- MMX Wheels 1P 2P 3P & 4P Forged Aluminum Wheels Master Distributor Wheel Designers
- AV input on TV tuner
- Royal Ride
- Rattle or loose hardware after dealer work -2017 A4
- Loss of power - 3.0 TDI 272cv
- Water Pump DIY on AUDI B9 A4
- 2019 A4 FACELIFT rear diffuser
- Audi A4 B9 2020 35 TDI VCDS Coding Problem
- P2681 / 2181 - 2017 A4
- UK: HELP - A4 car won't start (SAFE)
- Fluids change
- CarPlay faulty
- CZ: Vehicle Jerking - Faulty transmission or clutch or something else?
- Keyless engine start Not working
- '17 A4 - Transmission Malfunction - DTC P07B600
- NL: A4 B9 Sedan/Missing Subwoofer?
- Quattro Rumble….fixed
- Vibration
- How do i replace the fluid from the Transmission Pump 2019 audi a4 quattro automatic
- https://static.nhtsa.gov/
- MMI issues on '18 A4
- Has anyone installed a high output alternator for big audio system?
- Bimmer owner is gonna be p*ssed
- Engine mounts and upper control arm bushings bad at 60k
- A4 B9 Brakes upgrade
- A4 B9.5 Grille Question
- Steering weirdness
- Right mirror assembly part number?
- Seeking Advice on battery replacement and programming
- Android Auto frequently disconnects
- Fault: Turbocharger Boost Control Position Sensor, P256300
- Starter life
- Interchangeable B9 parts
- Upgrading door modules
- Exhaust Setups!!!!!!!!
- Seatbelt warning reactivated
- AudiConnect
- Reductant Heater Circuit Codes
- Noise coming from steering column
- Clutch Slippage After TCU Tune (Integrated Engineering)
- UK B9 A4 Autohold Retrofit- RHD - Manual
- 2018 A5 engine failure after 52K
- A4 BBK compatibility and requirements
- Seat heat not working
- BE: Audi A4 30 TDI (100kw/136hp) oil capacity?
- So whos going to be trying the new IE trans tune next week?
- High pitch noise
- UK: 2016 2.0 tfsi Quattro front wheel noise (not wheel bearing)
- Mirroring ndroid auto on virtual cockpit
- Car stalling/shaking on hills
- Oil cooler leak
- Service/oil change Chicago area?
- IN: Correct tyre pressure A4 with 225/55R 17 101W?
- Klima zone error
- I got Hit
- UK: Heater not getting hot, 2017 diesel
- Need help understanding car repair options
- A4, S4, RS4 B9.5 Matrix LED Headlight Activation Information...
- S3 8v Brakes on A4 B9
- Disable dimming
- Left headlight issue
- New owner questions 2024 A4
- Estimated mileage range incorrect
- 7-speed DL382 - 0CL transmission gearbox oil replaced
- DOES AUDI A5 REAR DIFFUSER FIT A4
- 2017 A4 etron (side marker lights 30 minutes)
- Tires already ⅔ worn with only 5,000 miles driven?
- Audi Recommended Maintenance - Tire Rotation
- Rear bumper swap
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- $79 for tire rotation with Audi Care?
- Broke headlight lens
- Minor Rear end 2021 A4 - worth repairing? Got very high quote..
- TCM Seals TSB 2058875/1
- B9.5 A4 S-Line vs 8V S3
- HR: Audi A4 B9.5
- Audi a4 2021 center console passenger side
- Hey, it's only paint!
- Intermittent DAB Issues
- Continual Coolant Issues
- How to remove Transmission underbody cover
- 7-speed DL382 - 0CL transmission filters replaced!
- AliExpress ambient lighting kit error codes
- Help! 2019 A4 starts but won't move
- Widest tire fitment
- Control Arm Recommendations
- SE: Audi A4 parking heater help
- Anyone with B9 high mileage reliability data?
- Audi A4 B9.5 2022
- Last year without Mild Hybrid
- Repair estimates at 100k km
- Wheel cap removal tool
- Screen upgrade to 10.25"
- My A4 can haul a$$, but can it haul anything else?
- Concerns with CPO 2023 A4 Premium Plus S-Line?
- Not driving much. Still need to do transmission fluid work at 8 years?
- Does A4 have hands free trunk release?
- A4 rotor compatibility
- Adblue/DEF: Fault. No restart in 650 mi.
- UK: TPMS fault A4 Avant 2017
- My car is coming up on 50k miles. What services does it need?
- Prospective A4 owner
- 2018 A4 MMI constantly rebooting while driving
- $18k from Rocklin California Audi??
- Side Marker on Headlight
- ECU position ****
- UK: Nearside brake hotter than offside
- Auto Headlight Operation
- Guess I won't be buying an EV
- Multiple Safety System Errors
- Spark plug gap
- Dealer says they will only replace the brake pads with the rotors as a package
- Next car -- what are your plans?
- A4 B9.5 quattro maintenance
- Lifespan of a crankcase plug
- B9.5 possible retrofits
- Adblue to 650 then CEL came on.
- Brake squeal
- Audi B&O advanced coding project.
- Used B9 A4 buying advice
- Mice ate through my wiring harness - What is the best way to prevent this?
- Custom Exhaust for my B9 TDI
- Audi ACC problem + error codes
- Cold Start Engine Rattle + cars shuts off in reverse
- 2018 A4 Misfire - Dealer Says Needs $18k Engine
- UK: B9 A4 40 TFSI Grey/White Smoke
- 7 speed DCT Stuttering when shifting at low speeds
- Warning lights on startup - electrical fault?
- New connector Manifold Runner Position Sensor.
- Lazy stereo question
- 2.0 150cv NO POWER
- Remote tailgate closing via key fob - Need a TEST car
- Jerking motion when in reverse
- Audi a4 weight reduction
- S-Tronic behaving weird in slow traffic.
- Weak heating when driving
- Canadian A4 Progressive MY19 - Torsen or Ultra?
- Front parking sensors 2016 wiring route
- Audi 360 camera retrofit issue
- Shifter electronics noise when changing gears
- Not blowing hot air when car warmed up
- AU: Carbon fibre side skirts
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- Coolant Smell in Garage
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Anyone know the weight on the back leather seats?
- Can I add dynamic turn signals for headlights?
- USA -> EU Audi A4 B9.5 (Facelift)
- Seeking Advice on Audi A4 B9 3.0 Engines (2016-2019) - Crankshaft Issues
- mmi stuck on red menu
- Cts high flow cat
- S line lower front bumper honeycomb grill inserts
- 2020 b 9.5 a4 s line rear bumper diffuser replacement?
- 2018 Audi a4 6 speed manual transmission issues
- Water pump belt cover - DIY
- UK: A4 2.0 TFSI "Stage 1" Gains?
- Spare tire and tools replacement
- MMI speech language and Navi not working in english
- 2017 B9 A4 key - deactivates after some time
- Audi A4 B9.5 2022 20k km Vibrations
- Sourcing New Brakes and Rotors
- 80K service questions
- LT: Engine slightly vibrates in the end when coming to a full stop.
- Interior lights with ignition ON
- 6 years with the factory windshield wiper blades
- Too Frequent DPF Regens
- Forgedlite Wheels Black Friday Sale 11/6 to 11/27
- Air Pressure in Tires 245/35R19 A4 S line Prem Plus?
- UK: Wheel spacer help?
- I change timing belt but car wont turn on
- Volkswagen and Audi Primary Engine Water Pump Class Action Settlement
- Do I have electronic dampening control?
- B9 S4 Rotors on 2019 A4 Progressive
- FR: Battery régulation module 80 no comunication
- This device is not currently supported when using USB
- What itch?
