- I got Hit
- UK: Heater not getting hot, 2017 diesel
- Need help understanding car repair options
- A4, S4, RS4 B9.5 Matrix LED Headlight Activation Information...
- S3 8v Brakes on A4 B9
- Disable dimming
- Left headlight issue
- New owner questions 2024 A4
- Estimated mileage range incorrect
- 7-speed DL382 - 0CL transmission gearbox oil replaced
- DOES AUDI A5 REAR DIFFUSER FIT A4
- 2017 A4 etron (side marker lights 30 minutes)
- Tires already ⅔ worn with only 5,000 miles driven?
- Audi Recommended Maintenance - Tire Rotation
- Rear bumper swap
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- $79 for tire rotation with Audi Care?
- Broke headlight lens
- Minor Rear end 2021 A4 - worth repairing? Got very high quote..
- TCM Seals TSB 2058875/1
- B9.5 A4 S-Line vs 8V S3
- HR: Audi A4 B9.5
- Audi a4 2021 center console passenger side
- Hey, it's only paint!
- Intermittent DAB Issues
- Continual Coolant Issues
- How to remove Transmission underbody cover
- 7-speed DL382 - 0CL transmission filters replaced!
- AliExpress ambient lighting kit error codes
- Help! 2019 A4 starts but won't move
- Widest tire fitment
- Control Arm Recommendations
- SE: Audi A4 parking heater help
- Anyone with B9 high mileage reliability data?
- Audi A4 B9.5 2022
- Last year without Mild Hybrid
- Repair estimates at 100k km
- Wheel cap removal tool
- Screen upgrade to 10.25"
- My A4 can haul a$$, but can it haul anything else?
- Concerns with CPO 2023 A4 Premium Plus S-Line?
- Not driving much. Still need to do transmission fluid work at 8 years?
- Does A4 have hands free trunk release?
- A4 rotor compatibility
- Adblue/DEF: Fault. No restart in 650 mi.
- UK: TPMS fault A4 Avant 2017
- My car is coming up on 50k miles. What services does it need?
- Prospective A4 owner
- 2018 A4 MMI constantly rebooting while driving
- $18k from Rocklin California Audi??
- Side Marker on Headlight
- ECU position ****
- UK: Nearside brake hotter than offside
- Auto Headlight Operation
- Guess I won't be buying an EV
- Multiple Safety System Errors
- Spark plug gap
- Dealer says they will only replace the brake pads with the rotors as a package
- Next car -- what are your plans?
- A4 B9.5 quattro maintenance
- Lifespan of a crankcase plug
- B9.5 possible retrofits
- Adblue to 650 then CEL came on.
- Brake squeal
- Audi B&O advanced coding project.
- Used B9 A4 buying advice
- Mice ate through my wiring harness - What is the best way to prevent this?
- Custom Exhaust for my B9 TDI
- Audi ACC problem + error codes
- Cold Start Engine Rattle + cars shuts off in reverse
- 2018 A4 Misfire - Dealer Says Needs $18k Engine
- UK: B9 A4 40 TFSI Grey/White Smoke
- 7 speed DCT Stuttering when shifting at low speeds
- Warning lights on startup - electrical fault?
- New connector Manifold Runner Position Sensor.
- Lazy stereo question
- 2.0 150cv NO POWER
- Remote tailgate closing via key fob - Need a TEST car
- Jerking motion when in reverse
- Audi a4 weight reduction
- S-Tronic behaving weird in slow traffic.
- Weak heating when driving
- Canadian A4 Progressive MY19 - Torsen or Ultra?
- Front parking sensors 2016 wiring route
- Audi 360 camera retrofit issue
- Shifter electronics noise when changing gears
- Not blowing hot air when car warmed up
- AU: Carbon fibre side skirts
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- Coolant Smell in Garage
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Anyone know the weight on the back leather seats?
- Can I add dynamic turn signals for headlights?
- USA -> EU Audi A4 B9.5 (Facelift)
- Seeking Advice on Audi A4 B9 3.0 Engines (2016-2019) - Crankshaft Issues
- mmi stuck on red menu
- Cts high flow cat
- S line lower front bumper honeycomb grill inserts
- 2020 b 9.5 a4 s line rear bumper diffuser replacement?
- 2018 Audi a4 6 speed manual transmission issues
- Water pump belt cover - DIY
- UK: A4 2.0 TFSI "Stage 1" Gains?
- Spare tire and tools replacement
- MMI speech language and Navi not working in english
- 2017 B9 A4 key - deactivates after some time
- Audi A4 B9.5 2022 20k km Vibrations
- Sourcing New Brakes and Rotors
- 80K service questions
- LT: Engine slightly vibrates in the end when coming to a full stop.
- Interior lights with ignition ON
- 6 years with the factory windshield wiper blades
- Too Frequent DPF Regens
- Forgedlite Wheels Black Friday Sale 11/6 to 11/27
- Air Pressure in Tires 245/35R19 A4 S line Prem Plus?
- UK: Wheel spacer help?
- I change timing belt but car wont turn on
- Volkswagen and Audi Primary Engine Water Pump Class Action Settlement
- Do I have electronic dampening control?
- B9 S4 Rotors on 2019 A4 Progressive
- FR: Battery régulation module 80 no comunication
- This device is not currently supported when using USB
- What itch?
- Audi A4 back bumper grill
- How Does Audi A4 B9's Engine Compare to My 2010 B8 V6 Engine?
- Brake/Rotor Replacement- Can I do it?
- Which headlight do I need?
- DE: 40 TFSI vs 45 TFSI (4 variants) opinion/review?
- Scan Gauge or Ultra Gauge with B9?
- Rattling noise coming from the engine?
- P105000 Bank1 Camshaft adjustment valve (open circuit)
- Retrofit camera + carplay unit
- Exhaust Options for Audi A4 S-line?
- RO: Integrated dashcam for A4 B9
- Audi a4 b9 tail light change to b9.5
- Door sill light not working
- Whine noise during cold start (Video attached)
- Blue shade in reverse camera
- Backup/Reverse Lights
- Should I wory about side mirror removal?
- Need guidance removing exterior plastic trim on B/C pillar
- Weird intermittent window issues 2017 a4
- 50,000 mi. Service through dealer
- Audi A4 B9.5 Spacesaver
- My set of Brown Walnut inlays are up for sale (SoCal)
- Add POI in the MMI for a 2020 A4
- Good fitting Tumbler
- Has anybody modified their suspension to be softer/more compliant?
- CarPlay Navigation Issues
- a4b9 update mib2
- Is Avant diffuser same as Saloon
- Engine Swap on 2018 A4?
- Have you upgraded the subwoofer in the base sound system?
- ME: few questions?
- Rear End Vibrations When Turning Steering Wheel Fully
- erWin access or similar for repair manuals?
- UK: Replacing rusted bonnet latch mount
- O2 sensors ( Upstream )
- Please help identify this sensor
- Transmission problems…”Lost communication with transmission fluid pump”
- A4 B9 2018 Quattro 2.0 won't start
- blurry camera problem (zoom in) 2017 Audi A4
- Wierd sound
- A4 B9 front grill fit the B9.5 2020 facelift?
- 17x7.5 offset+35 Winter set up?
- 2017 B9 A4 hesitation/hiccup under acceleration
- Tire Rack + Discount Tire = Satisfaction
- Ultra service
- Tips/directions on changing my brakes?
- Follow up on my adventures with toasted gear unit.
- Unitronic tcu tune
- So how are expensive are the '19 sport wheels?
- Searching for an accessory
- Audi EGR OE Code?
- High Flow Cat?
- OEM Hankook tires lasted 18,000 miles (29,000 KM). Better alternatives?
- OBDeleven Passive Fault After Transmission Fluid Change
- Cabin air blower speed
- ASS speaker upgrade is too shouty - what do I change?
- Headlight high beam too low
- Auto start stop malfunction
- Loose/defective spark plug installed by Audi totaled engine?
- Engine Mount Replacement?
- Slippery steering wheel
- Matrix headlights
- S4 9.5 after light colission indicators and wipers control doesent work !
- 2020 to 2023.. some things I’ve noticed
- Audi B9 Ambient Lighting issue
- It shakes and shuts off when i start
- Automatic Driving Like a Manual
- My a4 B9 wont play sound from snapchat , tiktok , insta , etc
- BE: change of fuel filter?
- Please check towing bracket
- Rain sensor
- 2017 A4 B9 Fans Always On
- UK: Spark Plug Change Help
- Transmission issues - mechatronic unit?
- Rear Spoiler Help
- Dirt Under Protective Film
- UK: Wing mirror compatibility?
- Low Coolant Light coming on. Any ideas?
- Upgrade tail lights to S-Line
- D2 to D1 minor shaking
- Motor Cleanliness Oil Check - NO Dipstick?
- UK: my left wing mirror bent backwards
- Wireless Android Auto now enabled?
- LT: Question regarding B9 DL382 transmission
- TR: SFD Protection on 2024 Coded A4 B9.5
- Water on Drivers rear floor when A/C on , on a hot day
- Rear diffuser help
- 2020 A4 PP B9 Front License Plate Holder
- Audi a4 b9 gearbox warning
- Wheel locks set: missing the most important part?
- Stage 1 and flywheel problems
- Discount Tire Co.: A mistake?
- Seeking input on a 2019 A4
- Car wouldn't let me in
- B9 A4 Engine noise
- Audi a4 b9 2017 makes weird sounds
- Is there anyone here in the Nyc/ct area with 6MT and JHM shifter?
- Cabin Vibrations In Low RPMs
- a4 9.5 installed forge bov not sure if its done correctly
- body kits for b9.5
- UK: 2.0 TDI oil filter access...
- Trunk Release: Foot Sensor No Longer Works
- UK: Audi A4 Avant B9 Heated Seat Retrofit
- CTS Turbo Catback (CTS-EXH-CB-0019)
- Limited Quantities - A4, S4 LED Blackline Taillight Packages...
- Repro transmission
- Audi a4 b9 2017 squeaking noise
- 2017 A4 Sedan - Yakima or Thule feet and pads/clips
- Where to buy center console metal trim clips?
- Am I getting all the oil out?
- A4 B9 drain hole location between front door?
- A4 2017 Quattro - which fual is the best ?
- AdBlue P21CA00 - how bad is adblue?
- A4 Avant - Rear Diffuser / Part Number Request
- A4 B9 100-200 times with tune?
- B&O sounds better with the windows down?
- Quattro Ultra and Driveline Questions
- APR stage 1 tune on my B9 6MT
- 2020 A4 shift points are drastically different above 90 degrees oat
- Update to MMI - Speed Limit Icon Now Gone from Virtual Cockpit
- How urgently should I change the Ultra clutch fluid?
- Click sound when go over 40-50 Km/h
- Wireless CarPlay B9.5
- How to do Adaptations After Timing Job
- Mystery Misfire - Compression Related NEED ADVICE
- Used A4/B9 Maintenance and Care Items
