PDA
View Full Version : A4 (B9 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. OBDEleven
  2. Is it possible to use 2 different tunes??
  3. Replacing stock Philips D5S bulb with aftermarket D5S
  4. RO: Ceramic Brake pads for 1LE PR code?
  5. 255/35/19 with A6 wheels on A4 B9
  6. Coding passenger EU seat in US car
  7. RaceChip Install Question
  8. 20/30/40/50 Prepaid Maintenance Conditions and Terms
  9. Back Up Camera Stopped Working
  10. Replace Just Muffler Box?!
  11. Integrated Engineering vs Unitronic
  12. A/C Cleaner and A/C drain
  13. Dynamic indicators on rear lights
  14. Data connection not available
  15. Saving current location as a nav favourite
  16. FUSE LISTING BY SIZE and AMPS?
  17. Does not go into 2 gears
  18. 2017 A4 Stock Wheels?
  19. Firmness differences between same suspension versions?
  20. Noise when accelerating and turning left - not loud, but noticeable
  21. Steering Wheel Squeaking On Turns When Cold
  22. Anyone knows what is this?
  23. 2017 Audi A4 - Where is the Power Steering Fluid Location?
  24. B9 Phone Cradle For Android Auto / Apple CarPlay – Single Size for Short/Tall Phones
  25. 2021 A4 Downpipe?
  26. Ride height of sport suspension?
  27. Measuring 0-60 times
  28. Options for 40K service?
  29. ECU Remap suggestions and experiences
  30. Want to upgrade turbo, have questions
  31. creaking back of the car
  32. Anyone have a link to the quattro font?
  33. upgrading coils and spark plugs when tuning to stage 2
  34. Carbon Fibre trim
  35. 2017 A4 Door Locks
  36. Difference Between 034's HFC and CTS Turbo's HFC
  37. A4 sun blind trim removal (rear door)
  38. Engine air filter parts numbers
  39. Predictive route data fault?
  40. Thermostat housing replacement
  41. 265/40r18 or 265/35r18
  42. Window grooves - debris buildup
  43. Mixed coolant color on a used A4
  44. Handsfree option grayed out
  45. New to Audi - Need help on purchase decision
  46. New A4 Owner, already broke it.
  47. Slip ring part codes
  48. Traffic sign recognition fault
  49. Front and rear pocket light locations
  50. Virtual Cockpit Energy Consumers Display
  51. Audi s4 2018 to 2020 front bumper
  52. RO: A4 B9 07.2019 - No Data for inserted SIM ( NAR to EU )
  53. EU Map updates MIB2
  54. radio unit+screen+virtual cockpit upgrade
  55. Licence plate mounting
  56. wireless charging
  57. 2018 Drive System Malfunction
  58. Anyone driving 245/35 or 255/35 on a 20" wheel?
  59. GR: audi a4 2.0 tdi quattro b9 2016
  60. Android Auto missing?
  61. B9 A4 Remote Start without Key?
  62. Windshield replaced = Light Sensor Malfunction
  63. Driver Seat setting memory
  64. ABS pump and ACC
  65. Purple Passion
  66. A4 B9 Head Up Display (HUD) Retrofit
  67. 19" wheels: Delicate and a mistake?
  68. 2017 S Line center grille
  69. Engine Mounts
  70. "Function on Demand"
  71. seat heaters does not work after climatronic panel upgrade
  72. Upgrading virtual cockpit displays on B9 RS4
  73. Heel/Toe on B9 A4?
  74. getAudiparts.com | Stay Cool with Genuine Audi Sun Protection Accessories!
  75. Backup Camera A4 Avant B9
  76. MIB2 MMI screen trim
  77. RO: Audi A4 B9 MMI firmware update
  78. The door keeping locking itself
  79. Coolant Reservoir Blue Cap vs Black Cap?
  80. what tire pressure?
  81. myAudi - key user reset
  82. 2017 A4 190 tdi Quattro avant diff rumble when turning
  83. CarPlay settings on iphone
  84. help troubleshooting
  85. Oil Change Confusion
  86. Homelink losing programming??
  87. Accelerator Pedal clunk
  88. Steering wheel jerk
  89. Finally completed my led retrofit from bixenon
  90. Pre Sense Setting in MMI
  91. upgrading exhaust tips to dual quad
  92. Just bought my first Audi!
  93. Overhead Noise/Rattle Over Bumps
  94. B9 A4 Mythos Black vs Florett Silver
  95. Anybody know what this might be?
  96. Wireless charging pad
  97. Place to get tires?
  98. Make space behind volume knob useful
  99. Looking at a 2017 A4
  100. Rear lights coding A4 b9 US to Europe
  101. 2021 B9 A4 Aftermarket Exhaust?
  102. adhesive for trunk spoiler?
  103. Error Codes
  104. Dredded Hesitation Issues!!
  105. Android Auto | system pauses | USB
  106. Useless ledge and other interior questions
  107. MMI / Comp issues
  108. Fuel system additive?
  109. 2021 Flat bottom steering wheel
  110. Help :/
  111. aftermarket exhaust + mods
  112. Repairing front bumper and grille
  113. ION system?
  114. UK: Metallic rattle Audi A4 2018?
  115. Internet radio - stations are gone
  116. Automatic seatbelt pretensioning
  117. Rear Side Assist Wire Harness for A4 B9
  118. Signal Steering Column
  119. Audi a4 b9 Dash wiring
  120. Aftermarket exhaust fitment to fake tips in bumper?
  121. Climate Control (8w0820043) component protection eprom
  122. Audi Key Fob - Remote Battery Low
  123. A4 B9 Performance Facebook Group
  124. Garage Door Transmitter Location?
  125. BCM replacement
  126. UK: 2019 a4 bumper help
  127. Canada - Cabin Filter Needed for A4 B9
  128. Audi Key Cover (uk website)
  129. advice on all season tires?
  130. Fusebox C Driver Side Cockpit
  131. OEM S4 Rear Diffuser on 17 Sline A4?
  132. Airbag fault code 9577969!
  133. Just bought a 2018 A4 - what now?
  134. Activate Cameras Manually
  135. UK: Service advice needed
  136. Bixenon to led install and code
  137. Larger tire on stock wheel?
  138. 2017 Audi A4 splash shield loose clips?
  139. Which one of these brake sensors are for the front and rear?
  140. Case for Goodwill Repair?
  141. Steering Angle Sensor Calibration
  142. interior and exterior mods
  143. steering wheel stiff while driving in curve road
  144. Cold air near driver seat switches in motion
  145. CA SMOG Now Checking for ECU Flash?
  146. Black Edition outer door trim
  147. Honeycomb grill looks great
  148. Sour AC smell - how to clean evaporator?
  149. Audi Map Updates?
  150. Virtual Cockpit showing different model OBD11
  151. UK: My audi a4 b9 starts just by pushing start
  152. Changing Seat Skins
  153. B9 Brakes 2017 v 2021
  154. FR: Installing electric adjustments seats in audi A4 b9?
  155. Steering wheel set angles vcds
  156. Computer system upgrades
  157. Has anyone swapped out their rear valance for a diffuser?
  158. Premium Plus Auto Dimming High Beams?
  159. Question regarding retrofitting.
  160. oem windshield vs aftermarket?
  161. What to look for? Used 2018 a4 allroad
  162. CTS Turbo Intercooler and 034 Motorsports Carbon Air Scoop
  163. 2021 Engine Change?
  164. Presenting the ColdFront™ Intercooler for the Audi B9 A4/A5
  165. Electric Tailgate Coding
  166. Audi A4 2016 Avant - Rubbish Camera
  167. Oval RS Style Exhaust Tips
  168. Interior Trunk Release without Key?
  169. Knocks on D4 after start
  170. Will these fit?
  171. Will these wheels fit?
  172. To add a race cat back In my system and intercooler upgrade??
  173. Hill Descent Control question
  174. Sunroof obstruction inside roof
  175. SG: Lost Engine Warranty due to Lack of Service
  176. Considering an A4 and Have Questions
  177. JB1 on audi a4?
  178. A4 B9 MMI screen upgrade
  179. Bang and Olufsen trim speaker piece
  180. OBDEleven for Sale
  181. New Owner!
  182. Obd11 used for headlight retrofit
  183. Rear vent modification
  184. Turbo blanket for A4 B9 2.0 TSFI?
  185. Coding for 2018 Audi A4 B9 Headlights?
  186. Safety Malfunction: check Owner's manual
  187. MMI Screen rim mod?
  188. Engine Failure After Oil Change
  189. What are these holes for?
  190. Expected front brake pad/rotor life
  191. 2020 Audi A4 Steering Click
  192. Diverter Valve Spacer vs Blow-Off Valve vs Turbo Muffler Delete
  193. Rear sport shock?
  194. MMI Factory Settings
  195. 034 Suspension/Driveline Upgrades - Lets Talk
  196. MMI Bluetooth and Google Pixel 3 connection issues
  197. replacing heated a4 seats with seats from s4
  198. Multiswitch Panel coding
  199. Bad strut mounts
  200. Installed the Aliexpress 4K integrated dash cam
  201. Wheel size
  202. Horn Troubles...
  203. 2018 a4 S Line
  204. Undercarriage cover replacement
  205. Koni FSD with sports suspension
  206. 40,000 mile Scheduled Service?
  207. PSA: Salt Lick inside B9 A4 engine bay - top of wheel well
  208. 2 USBs under armrest = Apple CarPlay - Yes or No?
  209. Reverse Rake fix?
  210. Black Makeover (large pics)
  211. Honeycomb Grille (RS Style)
  212. Damage inside the tail light
  213. Unfinished paint job?
  214. Coding retrofit folding mirror
  215. UK: Audi A4 b9 help with light failure and warning lights
  216. UK: smelly car
  217. MMI display resonates when revving at ~2100 rpm
  218. Audi A4 2016 replace basic mmi screen to mmi high screen
  219. A4 B9 - The perfect daily driver with some mods
  220. Bump Stop question / rear clunk
  221. IE: Help needed for halogen to LED tail light retrofit Audi A4 Avant B9
  222. Rear Shelf Vibration Solved
  223. I can't choose a wheel?
  224. Weird Radio Name/Text/Logo Issue
  225. Timing Chain or Timing Belt?
  226. Brake changing time
  227. Upgraded my audio system a bit... BIG Photo Thread!
  228. New Owner on 3-20-21
  229. Seatbelt Removal
  230. A4 Rear Cross Traffic Alert without parking sensors
  231. Screw/spring hanging down from rear undercarriage
  232. Speaker Buzz/Rattle - '19 A4
  233. 2 Different rear light part numbers
  234. Passenger air bag sensor/alarm
  235. AUDI A4 2017 Parts diagram catalog
  236. UK: Audi A4 with unrecorded damage
  237. Windshield crack, fix or replace?
  238. Air Hose
  239. FI: Address 80 Battery Regulation no communication
  240. GROUP BUY | Schwaben Professional Scan Tool 25% to 40% off | Closes April 1st, 2021
  241. In for wireless Android Auto
  242. Newcomer questions
  243. MMI Replacement
  244. Disable Parking Sensor View in Backup Camera
  245. Homelink?
  246. BG: BCM1 location ?!?
  247. Aesthetic Mod Options - B9.5
  248. Entertainment console lights not working
  249. A4 grill color change
  250. Function limitation due to missing message
