PDA
View Full Version : A4 (B9 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Anti-Theft of Side Mirrors?
  2. Unknown noise at idle
  3. Error code for Pressure Sensor
  4. Ceramic Brake Pads for 2017 A4
  5. Auto Up / Down on Driver window not working
  6. Lower dash trim removal
  7. UA: Audi a4 2020 (MIB3) US to EU region change.
  8. A4 Throwing every code but operating fine
  9. ABS Warning. How serious is it ??
  10. Not Audi Pure Protection but instead "The Mechanic"?
  11. Mechanic recommendation in Mass., Conn.
  12. Full Exhaust System Installation Guide
  13. Rear deck vibration with heavy bass
  14. Torn Control Arm Bushing?
  15. BR: Oil for 2016 A4 B9 140 Kw
  16. Audi B9 Avant UK.
  17. UK: Timing Belt change advice 2.0TDI 2016
  18. heated seat error
  19. Hiccups at idle
  20. Help: how do I remove the little cubby from center console trim?
  21. Totaled?
  22. OEM 10.1” screen conversion
  23. Water in trunk - 2020 A4
  24. HUD Content?
  25. Real Bad News - Felicity Ace on Fire
  26. UK Based MMI & SAT Nav Update
  27. Radiator lower radiator blind and wiring
  28. Meyle HD suspension arms
  29. AUDI MMI (INFOTAINMENT)
  30. Slippery
  31. Lowering an audi a4 B9 avant quattro
  32. Brakes & Rotors
  33. ODB2 Port
  34. Another tuner available for our gen3
  35. Timing belt
  36. Easy DIY: Tinted Vinyl Headlight Eyelids
  37. Sound stays muted, unable to increase the volume
  38. 4G Update blocking OBD Port
  39. Driving and receiving message: Your mobile phone is still in the vehicle
  40. UK: Audi A4 B9 wheel bolt size ?
  41. Extended Warranty for A4
  42. 2019 A4 wiper blade replacement
  43. B9.5 ECU Tune?
  44. Brake Sensor OEM vs Aftermarket
  45. Audi A4 or S7
  46. Where do I find my MIB Product Number?
  47. ctrl modul faulty VC
  48. Exported settings file decryption Audi 8WH
  49. S-Tronic clutch adaptation went from 7 to 13 bar
  50. Dash Cam hardwire install.
  51. Interior Aluminum Trim Material?
  52. 245/35 R19 93Y: need quiet, quiet, quiet?
  53. BR: 8w0407696b equals 8K0407696G?
  54. Dynamic/active steering errors
  55. Is Bang & Olufsen worth it?
  56. RO: Maxhaust Exhaust System installation A4B9
  57. '18 Audi A4 (B9) Ultra Premium Plus Upgrades & Tuning
  58. Audi body repair
  59. Really needing an oil change?
  60. Replaced MMI Controller, lost the writing capability
  61. Wireless Carplay Drops Out
  62. Matrix light specs across the entire range
  63. A salvaged B9's item list
  64. Quick questions about OBDeleven
  65. Audi Pure Theft Protection?
  66. AudiCare - DSG fluid & spark plugs way too early
  67. Seat Upholstery Switch between Electric/Manual
  68. Stuck while upgrade B9 Avant 8W from Halogen to LED Tail lights - How to unlock conn?
  69. Window Washer Fluid Issue
  70. UK: Seats broke, does warranty help?
  71. Anyone have photos of their RSNAV retrofit?
  72. How can you tell if you have adaptive or sport suspension?
  73. Unitronic stage 1+
  74. Lane Assist Icon disappeared after using ACC?
  75. Passenger airbag defect
  76. Burning coolant smell? Again!
  77. 2007 A4 2.0T with engine knock
  78. B9 Transmission Fluid Change or No?
  79. Koni Special Active
  80. Will these wheels fit?
  81. Drive system malfunction
  82. Questions regarding Audi's OS/ECU.
  83. Brake Clearance for 19x9.5 et42
  84. OBD port stopped working
  85. UK: Diesel Timing belt change correct??
  86. 3G Shutdown coming
  87. What are Key Users in Audi Connect?
  88. Traffic Sign Recognition activation
  89. Video Formats for the MMI?
  90. Audi a4 b9 keyless entry problem
  91. Wireless Carplay for 2019 A4 ?
  92. BR: IS38 on A4 B9 190hp
  93. SK: Some noise from rear of car
  94. Radio doesn't turn off when leaving car
  95. Best intake?
  96. Interior Door Lights
  97. IT: Full Led headlight problem
  98. New Vehicle Battery for my A4, hopefully I have everything set OK
  99. Question about OBDeleven Ultimate subscription
  100. AU: TSR in Australia A4 B9 2019 model
  101. shopping from parts.audiusa.com
  102. LT: Coding from USA to Europe?
  103. B9 SPEEDOMETER RETROFIT
  104. Transmission Error on 2018 A4
  105. Transmission Rattle Noise when changing gears
  106. B9 8" to 12.3" Android Head Unit Conversion Installation
  107. 1BR (Off-road/Bad Road) Suspension Option
  108. The turbo pressure sensor of A4 B9 30TFSI
  109. Engine light
  110. Audi A4 B9 Avant tailgate light problem
  111. Rear Bumper Repair
  112. AE: Audi A4 40TFSI S-Line 2018
  113. Mythos Black Metallic touch up paint on offer
  114. Added some ambient lighting
  115. Vehicle image on infotainment system and reverse sensors blank (MMI) not showing up
  116. BR: Screws character protector and exchange protector
  117. UK: Stop/start not working
  118. JP: Battery Information Needed
  119. Audi phone box covid credit
  120. Side marker light on front bumper?
  121. A4 AR In Transit - Audi App shows feature deletions?
  122. What plugs into this!!!!???
  123. Another Coolant Leak Thread, Just Not Where You'd Expect
  124. S Tronic Weird Sounds
  125. Turn signal fault, when hazard lights activated
  126. No Start and P068400, drive system malfunction
  127. Headlight modules
  128. Active lane assist no longer working
  129. A4 B9 2018 Hands free Bluetooth disabled
  130. Custom wallpaper on mmi screen?
  131. Info on these older OEM Wheels?
  132. 2021 A4 Allroad Oil Change Details
  133. Lighted Emblem Install Q's & Pictures
  134. RO: Steering rack replacement
  135. 255/35/19 vs 245/35/19?
  136. How to DIY DSG change on B9 Platform
  137. ES: Static gateway error
  138. WTB set of brown walnut wood inlays for my B9.5 S4
  139. Estimate Repair Cost??
  140. MMI screen blank
  141. Need help with first step
  142. 2021 A4 low mileage- cockpit sound while accelerating
  143. rear seat headrest removal?
  144. Window Hesitates to roll up (video)
  145. Erratic Transmission Behavior
  146. Replace footwell LED lights
  147. A4 Steering shaft exposed in foot well.
  148. how to program new a4 b9 key?
  149. Ultra -- torque steer?
  150. '17 A4 entire L headlight died simultaneously(Headlight/high/DRL/Indicator)
  151. JP: Artificial steering feel?
  152. MMI control unit replacement?
  153. Engine Control Module (ECM)
  154. 3G network going away
  155. Has anyone driven the Genesis G70 2.0t?
  156. A4 and A6 Reliability
  157. Never ending misfire
  158. UK servicing?
  159. B10 first spy shots
  160. Phone Bluetooth connection lost
  161. Whistling noise in 5th gear when accelerating
  162. Maps 20/21 update today?
  163. How to remove front plate nut plates
  164. Engine light
  165. Out in force
  166. Phone Mirroring on the MMI screen
  167. Tweaking lane assist parameters
  168. When opening dr door from inside, all doors unlock
  169. Ambient Lighting Retrofit
  170. RO: CRTC Rough Start when cold
  171. UK: Heater going cold when it rains
  172. Issues with Charging and Android Auto after Android 12 Update
  173. Trunk Lock Hook is Damaged, where can I find a replacement part?
  174. tires: higher pressure in front or in back? Manual and doorjam differ...
  175. USB #2 is non standard?
  176. TCU Update version 0004
  177. Which A4 B9 to choose
  178. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  179. Gracenote database update
  180. How much does the 4 year warranty cover?
  181. Does all 2017 model support Android Auto?
  182. Coolant For 2017 A4 Premium Quattro
  183. LT: 2017 a4 B9 quattro (7 speed DSG) stalls at parking speeds/slowing down
  184. Inflation Relief - Black Friday thru the end of November Sale...
  185. Black Optics “Y” spoke - Wheel Maintenance
  186. Blank MMI Screen. TSB 2062115/7
  187. All Weather Floor Mat Question
  188. 2018 Audi A4 B9 does not start
  189. XPEL Interior Pre-Cut PPF kit for 2021 A4
  190. tire rotation
  191. VC needle sweep lag
  192. View button without virtual cockpit?
  193. Rear aftermarket parktronic on B9.5
  194. Still Compliments
  195. Key fob Chip
  196. Newly listed recall - passenger seat airbag disabled
  197. Navigation & Map Update
  198. Brake pad sensors
  199. B9 A4 Quattro break squeal
  200. Engine start
  201. Key fob difference, if any?
  202. 2016 front left clicking noise accelerating Not CV axle/bearing
  203. MMI Screen on start
  204. Wheel Identification/Part Number
  205. UK: Grey tab position satnav
  206. Sensors
  207. Heated seats buttons not working for driver or passenger
  208. who is running TVS TCU tune with another tuners ECU?
  209. Good car shops near Boston?
  210. 2019 A4 basic maintenance
  211. OBD11 - Do I need/want this?
  212. Audi A4 B9
  213. Ambient lighting
  214. Spare tire tools
  215. Virtual Cockpit Boost Gauge
  216. GR: Interesting (?) discovery about the basic suspension variations
  217. "Genuine" VW/Audi oil
  218. B9 COLD START NOISE
  219. P0811 Code Error 2017 B9
  220. IE: Audi a4b9 Avant 2016
  221. Audi A4 2017 refuel light question?
  222. 2017 A4 Stock Wheels for Sale
  223. OBDeleven TPMS Display?
  224. UK: European Driving: RHD vs. LHD
  225. Intake, intercooler and tune Dyno?
  226. Does Drive Select Affect Torque Split?
  227. WELCOME sound MIB 3 does not work
  228. Exhaust drone problem.
  229. Battery problem
  230. A4 b9.5 WiFi Tethering
  231. Would dealer adjust my brake pedal sensitivity?
  232. Are my wheels backwards?
  233. 2021 Mechanical Issues
  234. RPM Change When Toggling Drive Select Mode
  235. UK: Has anyone removed a 6MT gear shifter? Reverse gate question
  236. Battery replacement
  237. hearing noise in suspension after installing 034 springs
  238. will these brakes fit on the B9 with the OEM 18" wheels?
  239. Popping noise in driver's seat of '21 A4
  240. What's up with the 2022, 261 hp engine?
  241. Side Assist Retrofit
  242. Dreaded Coolant Leak?
  243. Finally a fix for rattle with the B&O Speaker System
  244. Should I buy 2 year extended maintenance program
  245. Vibrations in 5th gear?
  246. 2 month old CTS Turbo Cold Air Intake for Audi B9s.
  247. 2018 A4/S4 Owners Manual variations
  248. Problem with heater
  249. OEM Wireless Car Play retrofit?
  250. UK diesel remap recommendations pls
