- A4 AR In Transit - Audi App shows feature deletions?
- What plugs into this!!!!???
- Another Coolant Leak Thread, Just Not Where You'd Expect
- S Tronic Weird Sounds
- Turn signal fault, when hazard lights activated
- No Start and P068400, drive system malfunction
- Headlight modules
- Active lane assist no longer working
- A4 B9 2018 Hands free Bluetooth disabled
- Custom wallpaper on mmi screen?
- Info on these older OEM Wheels?
- 2021 A4 Allroad Oil Change Details
- Lighted Emblem Install Q's & Pictures
- RO: Steering rack replacement
- 255/35/19 vs 245/35/19?
- How to DIY DSG change on B9 Platform
- ES: Static gateway error
- WTB set of brown walnut wood inlays for my B9.5 S4
- Estimate Repair Cost??
- MMI screen blank
- Need help with first step
- 2021 A4 low mileage- cockpit sound while accelerating
- rear seat headrest removal?
- Window Hesitates to roll up (video)
- Erratic Transmission Behavior
- Replace footwell LED lights
- A4 Steering shaft exposed in foot well.
- how to program new a4 b9 key?
- Ultra -- torque steer?
- '17 A4 entire L headlight died simultaneously(Headlight/high/DRL/Indicator)
- JP: Artificial steering feel?
- MMI control unit replacement?
- Engine Control Module (ECM)
- 3G network going away
- Has anyone driven the Genesis G70 2.0t?
- A4 and A6 Reliability
- Never ending misfire
- UK servicing?
- B10 first spy shots
- Phone Bluetooth connection lost
- Whistling noise in 5th gear when accelerating
- Maps 20/21 update today?
- How to remove front plate nut plates
- Engine light
- Out in force
- Phone Mirroring on the MMI screen
- Tweaking lane assist parameters
- When opening dr door from inside, all doors unlock
- Ambient Lighting Retrofit
- RO: CRTC Rough Start when cold
- UK: Heater going cold when it rains
- Issues with Charging and Android Auto after Android 12 Update
- Trunk Lock Hook is Damaged, where can I find a replacement part?
- tires: higher pressure in front or in back? Manual and doorjam differ...
- USB #2 is non standard?
- TCU Update version 0004
- Which A4 B9 to choose
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Gracenote database update
- How much does the 4 year warranty cover?
- Does all 2017 model support Android Auto?
- Coolant For 2017 A4 Premium Quattro
- LT: 2017 a4 B9 quattro (7 speed DSG) stalls at parking speeds/slowing down
- Inflation Relief - Black Friday thru the end of November Sale...
- Black Optics “Y” spoke - Wheel Maintenance
- Blank MMI Screen. TSB 2062115/7
- All Weather Floor Mat Question
- 2018 Audi A4 B9 does not start
- XPEL Interior Pre-Cut PPF kit for 2021 A4
- tire rotation
- VC needle sweep lag
- View button without virtual cockpit?
- Rear aftermarket parktronic on B9.5
- Still Compliments
- Key fob Chip
- Newly listed recall - passenger seat airbag disabled
- Navigation & Map Update
- Brake pad sensors
- B9 A4 Quattro break squeal
- Engine start
- Key fob difference, if any?
- 2016 front left clicking noise accelerating Not CV axle/bearing
- MMI Screen on start
- Wheel Identification/Part Number
- UK: Grey tab position satnav
- Sensors
- Heated seats buttons not working for driver or passenger
- who is running TVS TCU tune with another tuners ECU?
- Good car shops near Boston?
- 2019 A4 basic maintenance
- OBD11 - Do I need/want this?
- Audi A4 B9
- Ambient lighting
- Spare tire tools
- Virtual Cockpit Boost Gauge
- GR: Interesting (?) discovery about the basic suspension variations
- "Genuine" VW/Audi oil
- B9 COLD START NOISE
- P0811 Code Error 2017 B9
- IE: Audi a4b9 Avant 2016
- Audi A4 2017 refuel light question?
- 2017 A4 Stock Wheels for Sale
- OBDeleven TPMS Display?
- UK: European Driving: RHD vs. LHD
- Intake, intercooler and tune Dyno?
- Does Drive Select Affect Torque Split?
- WELCOME sound MIB 3 does not work
- Exhaust drone problem.
- Battery problem
- A4 b9.5 WiFi Tethering
- Would dealer adjust my brake pedal sensitivity?
- Are my wheels backwards?
- 2021 Mechanical Issues
- RPM Change When Toggling Drive Select Mode
- UK: Has anyone removed a 6MT gear shifter? Reverse gate question
- Battery replacement
- hearing noise in suspension after installing 034 springs
- will these brakes fit on the B9 with the OEM 18" wheels?
- Popping noise in driver's seat of '21 A4
- What's up with the 2022, 261 hp engine?
- Side Assist Retrofit
- Dreaded Coolant Leak?
- Finally a fix for rattle with the B&O Speaker System
- Should I buy 2 year extended maintenance program
- Vibrations in 5th gear?
- 2 month old CTS Turbo Cold Air Intake for Audi B9s.
- 2018 A4/S4 Owners Manual variations
- Problem with heater
- OEM Wireless Car Play retrofit?
- UK diesel remap recommendations pls
- In car mic sounds "robotic"
- UK: Audi A4 Fuel Consumption display going up and down erratically
- Clutch kit and Dual Mass flywheel replacement - Non dealer parts?
- Heating with ignition on
- Issues with iPhone music and Audi MMI (A4 2017)
- UK: Audi a4 2017 TDI 2.0 MPG issue?
- MMI Right Function Button no longer activates Android Auto
- '18 B9 top of lower DTR led stopped working (horizontal)
- Looking for new tires for my ‘18 A4
- Settings Raaaarrrwww
- P2185 Code - Check Engine Light
- Voice Assist / microphone issue
- 17 DCT insert question, DCT JB4 longevity
- B9 A4 replacement dampers, std suspension
- New Audi A4 1.8t quattro Owner. help please
- A4 B9 / A5 F5 ACC retrofit guide
- A4 B9 1.4 2017 heater/ac issue
- Instrument cluster screen not working
- A4 B9 Performance Facebook Group
- A4 9.5 2021 navigation activation
- dynamic tail light retro fit question
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- Rearcam <<
- Cluster replacement
- Smelly odour when using fan
- Audicare DSG service at 4 years at less than 40K miles
- PL: Jak zakodować składanie lusterek i audi side assist(blind assist)?
- Looking for Prestige backup - Coding
- A/S 4/5 vs Q5 body proportions
- 2018 A3 AudiCare Question
- Audi Sound System
- Strange things with transmission
- A4 B9 retroffiting taillights from dynamic led to b9.5 matrix
- 2021 Quattro windshield wiper replacement
- 2020 A4 S-Line -- looking for exterior mods
- How to show M<gear>S on Virtual Cockpit
- HR: Automatic transmission problem
- New lease advice help
- MMI Tiles
- Replacement OEM Brake Pads?
- mud flaps
- Music formats - SD and USB
- OBD2 Code U001800 CAN Bus fault code?
- Underside damage to car
- Performance engine mounts
- Pre sense calibration
- MMI Audi Smartphone Interface
- UK: Audi A4 2017 ABS Pump Query
- Heater vents not warning up on drivers side.
- UK: A4 B9 1.4 Manual. Squealing when setting off
- AU: Windows Seal
- Fuel smell in oil
- 205/50 R17 ??????
- What is this for in the glove box?
- Android Auto & WiFi
- Post-Facelift Hands on Detection Flat-Bottom Steering Wheel Packages...
- Distance to empty is... gone?
- Clutch change kit?
- Navigation map updates
- Really disappointed in the MMI / CarPlay on my 2018 A4
- Can you get rid of the amber reflector in the headlights on the B9?
- Climate control dial
- Had to use spare key(primary key lost), but A4 doesnt recognise the spare key
- Auto Start Stop ... query
- oil meter on MMI showing full after 5qts
- Audi Tablet
- B9 A4 3.0TDI Vibrations
- Does Green Menu still exist?
- B9 A4 - Service Manual, TSBs, Self-Study Programs
- Change Cluster Color
- Transmission Mount Update - Different Brands
- Maybe First Audi - How's Reliability & Maintenance?
- DSG service vs fluid exchange?
- ABT Tuning for B9 A4
- 60000 km service missed, 20000 km overdue
- More comfy seats for 2017 A4 SLine
- Cooling fan fault Audi RS4 B9
- Front headrest removal
- Is the headroom on the A4 actually worse than the VW Passat?
- When to PM replace the battery?
- Virtual cockpit anomaly
- Buying out A4 lease… can I CPO it?!
- Hello, a4 b9 calibration
- RO: Hello, I just changed my 2 pedestrian airbags under the hood, and I have etriere
- ECS Trunk Spoiler pics?
- A4 AC Losing its cool.
- 2019 Audi A4 T-Boned
- New owner/front plate Q
- License plate frames?
- Warning lights panel out
- MMi / Connected Car
- Best tires for less road noise?
- Should I ...Extended Warranty?
- RO: Hello, carplay a4 b9 activation?
- "Hey, Google" kills A4 radio volume?
- UK: A4 2017 P2237 Fault Code
- What Is This Red Plus Sign On My Dash
- NOX Sensor fault?
- Tire rotation mixup
- A4 3.0 TDI Transfer case oil
- Is there a way to make carplay "full screen" on the MMI? (i.e. hide the Audi menu?)
- New 2018 Audi A4 owner questions
- AUDI A4 BRAKES?
- Sunroof unable to open fully due to roof insullation obstruction?
- Audi A4 2.0 TDI engine rattling sound
- SE: Audi a4 2.0tdi possible to get over 300hp?
- transmission 40k maintenance?
- Fender bumper screw
- VCDS Transmission Functions
- New Audi A4 Quality Problems
- A4 B9 2.0 TDI coolant leak advise needed
- Muffler delete ?
- mismatched tires and Quattro system
- Black lug bolts?
- Audi A4 B9 MMI Nav update help
- 2019 Audi A4 Cold Air Intake
- 2019 A4 B9 Mods
- Front Passenger Window Switch Replacement
- A4 B9 clicking sound
- Audi firmware updates
