- In car mic sounds "robotic"
- UK: Audi A4 Fuel Consumption display going up and down erratically
- Clutch kit and Dual Mass flywheel replacement - Non dealer parts?
- Heating with ignition on
- Issues with iPhone music and Audi MMI (A4 2017)
- UK: Audi a4 2017 TDI 2.0 MPG issue?
- MMI Right Function Button no longer activates Android Auto
- '18 B9 top of lower DTR led stopped working (horizontal)
- Looking for new tires for my ‘18 A4
- Settings Raaaarrrwww
- P2185 Code - Check Engine Light
- Voice Assist / microphone issue
- 17 DCT insert question, DCT JB4 longevity
- B9 A4 replacement dampers, std suspension
- New Audi A4 1.8t quattro Owner. help please
- A4 B9 / A5 F5 ACC retrofit guide
- A4 B9 1.4 2017 heater/ac issue
- Instrument cluster screen not working
- A4 B9 Performance Facebook Group
- A4 9.5 2021 navigation activation
- dynamic tail light retro fit question
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- Rearcam <<
- Cluster replacement
- Smelly odour when using fan
- Audicare DSG service at 4 years at less than 40K miles
- PL: Jak zakodować składanie lusterek i audi side assist(blind assist)?
- Looking for Prestige backup - Coding
- A/S 4/5 vs Q5 body proportions
- 2018 A3 AudiCare Question
- Audi Sound System
- Strange things with transmission
- A4 B9 retroffiting taillights from dynamic led to b9.5 matrix
- 2021 Quattro windshield wiper replacement
- 2020 A4 S-Line -- looking for exterior mods
- How to show M<gear>S on Virtual Cockpit
- HR: Automatic transmission problem
- New lease advice help
- MMI Tiles
- Replacement OEM Brake Pads?
- mud flaps
- Music formats - SD and USB
- OBD2 Code U001800 CAN Bus fault code?
- Underside damage to car
- Performance engine mounts
- Pre sense calibration
- MMI Audi Smartphone Interface
- UK: Audi A4 2017 ABS Pump Query
- Heater vents not warning up on drivers side.
- UK: A4 B9 1.4 Manual. Squealing when setting off
- AU: Windows Seal
- Fuel smell in oil
- 205/50 R17 ??????
- What is this for in the glove box?
- Android Auto & WiFi
- Post-Facelift Hands on Detection Flat-Bottom Steering Wheel Packages...
- Distance to empty is... gone?
- Clutch change kit?
- Navigation map updates
- Really disappointed in the MMI / CarPlay on my 2018 A4
- Can you get rid of the amber reflector in the headlights on the B9?
- Climate control dial
- Had to use spare key(primary key lost), but A4 doesnt recognise the spare key
- Auto Start Stop ... query
- oil meter on MMI showing full after 5qts
- Audi Tablet
- B9 A4 3.0TDI Vibrations
- Does Green Menu still exist?
- B9 A4 - Service Manual, TSBs, Self-Study Programs
- Change Cluster Color
- Transmission Mount Update - Different Brands
- Maybe First Audi - How's Reliability & Maintenance?
- DSG service vs fluid exchange?
- ABT Tuning for B9 A4
- 60000 km service missed, 20000 km overdue
- More comfy seats for 2017 A4 SLine
- Cooling fan fault Audi RS4 B9
- Front headrest removal
- Is the headroom on the A4 actually worse than the VW Passat?
- When to PM replace the battery?
- Virtual cockpit anomaly
- Buying out A4 lease… can I CPO it?!
- Hello, a4 b9 calibration
- RO: Hello, I just changed my 2 pedestrian airbags under the hood, and I have etriere
- ECS Trunk Spoiler pics?
- A4 AC Losing its cool.
- 2019 Audi A4 T-Boned
- New owner/front plate Q
- License plate frames?
- Warning lights panel out
- MMi / Connected Car
- Best tires for less road noise?
- Should I ...Extended Warranty?
- RO: Hello, carplay a4 b9 activation?
- "Hey, Google" kills A4 radio volume?
- UK: A4 2017 P2237 Fault Code
- What Is This Red Plus Sign On My Dash
- NOX Sensor fault?
- Tire rotation mixup
- A4 3.0 TDI Transfer case oil
- Is there a way to make carplay "full screen" on the MMI? (i.e. hide the Audi menu?)
- New 2018 Audi A4 owner questions
- AUDI A4 BRAKES?
- Sunroof unable to open fully due to roof insullation obstruction?
- Audi A4 2.0 TDI engine rattling sound
- SE: Audi a4 2.0tdi possible to get over 300hp?
- transmission 40k maintenance?
- Fender bumper screw
- VCDS Transmission Functions
- New Audi A4 Quality Problems
- A4 B9 2.0 TDI coolant leak advise needed
- Muffler delete ?
- mismatched tires and Quattro system
- Black lug bolts?
- Audi A4 B9 MMI Nav update help
- 2019 Audi A4 Cold Air Intake
- 2019 A4 B9 Mods
- Front Passenger Window Switch Replacement
- A4 B9 clicking sound
- Audi firmware updates
- How much are these worth?
- Slow coolant leak, found drops under radiator
- Display Apple iPhone email
- URGENT HELP NEEDED GEARBOX DRIVE
- DSG fluid sump leaking
- ETA in Navigation Display
- Stain on grille plastic
- Screen2Auto
- CTS Turbo vs 034 Motorsports High Flow Cat
- IN: Cruise Control - Simple Vs Adaptive?
- When does the CPO warranty start?
- Yet another B&O sub thread
- What's the difference between engine codes ?
- 6-Speed Manual Low-Speed Shifting Problem
- Help Needed……………Ride Height Sensor Install
- Active Lane Assist
- UK: USB ports under armrest not working
- Another B9 Audi Sound System full upgrade
- Use of the Manual Gear Shift mode ??
- VCDS Security access code
- New Air Intake
- Does anyone know what this is?
- 2021 A4 Cannot Log In To MMI As Key User
- Dashboard A/C Sensors
- Water coming out of driver side AC vent
- Chipmunk destroyed washer fluid line and wires!
- Object hanging from under A4
- JB4 Install Question
- A4 - 23CY and 96G4 software update
- B9 3.0TDI Quattro lowering option
- Dangling panel under car
- 2017 A4 P2227 fault
- AU: Is it transmission?: car shaking while reversing in a slight hill.
- UK: Trunk grocery hooks?
- Considering changing the seats
- Switching traffic from Audi Connect to SiriusXM (again)
- OEM+ Modifications
- Accord > A6?
- b9 a4 headlight problem
- a4 b9 headlight issue
- 2018 Audi A4 Backup Camera Improved with RSNAV?
- Matrix Headlight Upgrade
- Considering buying a 2019 a4 prestige.
- Seat heaters coding / retrofit?
- 2018 a4 s line + black optic
- Unitronic tcu tune torque limit?
- Gear selector lights malfunction
- Coolant level alarm but coolant level is fine?
- DSG issues after doing Stage 1 tune?
- AA Wireless -- plug-in question
- Audi A4 Avant B9 Adblue Fault
- A4 2021 PP ambient lighting+baby ready?
- WeatherTech Rear Seat Liners. Thoughts?
- Front left wheel clicking sound
- Audi Saved My Life
- 2018 S4 Transmission
- front driver speaker rattle B&O
- Muffler (NOT exhaust) Options?
- Smitten and scared - Audi A4 (B9)
- Mmi function mode led lights stopped working
- Hartmann 20” on 2021 - Spacing
- homelink sucks
- The Audi App..
- A4 Exhaust
- Exporting Canadian Audi to Belgium: questions
- Rear turn signal error
- JP: Coding for Ambient Light Setting in MMI
- Bad video quality in Android head unit
- Oil read change ???
- UK: Door handle trims
- Help please! What part is this?
- Dead Battery, Noise frrom glove box,
- Extended Ambient Lighting
- Virtual Cockpit part numbers
- A4 B9 3.0 V6 ticking sound
- 2017 A4 P2563 Code
- Windshield shortage?
- 2022 Black Optic vs 2021
- Violent shaking at startup
- A4 Drive system malfunction
- 2018 A4 Quattro 2.0 Grille Options?
- Glacier white cheap amber reflector delete
- MMI module locations
- What is the use of this plastic part on rear left bottom ?
- Turbo inlet hose. Make a difference?
- Anyone added a LSD to their B9 A4?
- Buzzing sound next below airvent
- Over-ride tailgate auto-close/open
- 2020 A4 Engine Oil Spec?
- How to fix this scratch?
- Rear window goes up a bit then back down?
- 2017 Audi A4 B9 Cold Air Intake?
- Springs or Coilover
- Enthusiast Brands 7pc Carbon Fiber interior overlay?
- HK: A4 Ambient Light?
- DK: A4/A5 B9 pre-facelift taillight upgrade - GUIDE
- MIB2 Latest Firmware
- Can't browse songs via bluetooth
- 188 mpg Read Out Doesn't Make Sense
- AC only works when headlights are turned on.
- 17” winter wheel sizing?
- Audi A4 B9 Reductant heater B control circuit HIGH
- Confused about Audi Connect
- Where to get Bilstein shocks
- questions about Audi Care package verbiage
- Audi A4 B9 complete stereo upgrade
- A4 2019 Grill
- RO: Closed the trunk weirdly, now it won't open
- Replaced stock Xenon headlight bulbs with aftermarket 5500k bulbs bulbs
- recommendations on lowering?
- 2017 Quattro Premium Plus Drive System Malfunction Help
- Comforting the Comfort Base Suspension
- Audi A4 2014
- Aftermarket Wireless CarPlay Module?
- Integrated Engineering Tune Flash fault
- 2017 A4 battery replacement
- 2021 A4 Presense
- Lowering an audi a4 B9 avant quattro
- Any good sources for a set of brown walnut wood inlays?
- Car settings Unavailable
- SI: Coolant temp over 90C 3.0 TDI
- Post-facelift tail lights retrofit to pre-facelift A4
- 2021 Front License Plate Brackets
- Google Earth Without Audi Connect
- 2017 A4 S-Line - Rear pad sensor wire broke?
- safe to add racing cat couple months before tune?
- A4 2021 - online traffic data missing
- Terrible Audi A4 B9 Transmission oil Leak
- Any good second hand warranty experiences here?
