PDA
View Full Version : A4 (B9 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Slippery situation
  2. ES: A4(B9) cambio manual de 6velocidades
  3. A4 B9 spacers
  4. OBDII device for Audi A4
  5. Which oil extractor?
  6. 034 Motorsport street density motor mounts
  7. Amplifier Audi b9
  8. New owner 2022 A4 prestige
  9. Key Fob battery life
  10. PL: How to enable fog rear light?
  11. Help Guys, Recieved a Drive System malfunction. Wastegate has Excessive Play
  12. Rear wheel housing liner
  13. 2019 Bumper Stuck
  14. Should I stop putting money into my 2.0?
  15. S-Line sport suspension too firm, variable dampening?
  16. disconnect camera and lane detection
  17. Driver Assistance Package -Germans behind the Japanese
  18. Massachusetts hybrid turbo tune?
  19. Normal AC Refrigerant Pressure Range
  20. chances of getting stuck in the sand? (Also a brake question)
  21. Radiator protection
  22. Door wiring tapping
  23. Mobile signal on screen but no sim card
  24. Massachusetts custom tune?
  25. McGard wheel locks part #
  26. Using Parking brake as brake hold?
  27. 2022 A4 prestige same as A5?
  28. MD: Stage 3 and engine differences?
  29. Michelin CC2 Recommended Tire Pressure?
  30. 2020 vs 2017 ride quality?
  31. Just did DIY of the DSG fluid, would like double checks of my work.
  32. EMD hybrid turbo
  33. Loose turbo wastegate solution?
  34. CRTC engine wobble
  35. Brake servo restricted message
  36. MMI not working, water damage?
  37. Lane change retrofit
  38. UK: Audi A4 diesel air filter query
  39. 2018 B9 2.0T AIR CONDITIONING TSB
  40. Calibrate fuel level
  41. SOS error always up
  42. How much power can a B9 2.0 push?
  43. 2017 Audi A4 Prestige
  44. Test Drive :-O
  45. Looking for wheels
  46. Part number help
  47. UK: A4 1.4TFSI Timing Belt Replacement
  48. Adblue error? Or need a top up?
  49. Class Action Settlement for Water Pump
  50. New to Audi
  51. Spark plugs with APR tune.
  52. Audi Retrofit
  53. Dealer scratched car bumper during service
  54. Help with disassembly?
  55. B9 Klimatronic knob temp display dimmed out/off on
  56. e85
  57. Fault code P158800?
  58. UK: Audi A4 B9 diesel (2016) showing the engine oil level without initiation?!
  59. HVAC blower motor not working.
  60. Possible VVT problem?
  61. MPG down after Service
  62. Turn on thump after adding LOC, Sub and amp to 2021 B9 Quattro sedan (non B&O)
  63. Keyless Entry - Door Handle Sensor?
  64. Hearing a faint rattle in the engine bay at idle, help my hyper awareness!
  65. UK: 2nd gear engaging issue! Help?
  66. AU: A4 B9 2018 Avant - Rear Vertical Spoilers replacement publication
  67. Remote key issue
  68. Alignment
  69. UK: A4 1.4TFSI Timing Belt Replacement
  70. Chrome badges?
  71. How to open the key fob?
  72. Connectivity keeps cutting out
  73. New owner of a 2018 A4 P+, has some cosmetic flaws I’d like to fix up.
  74. Caliper Covers
  75. MFSW Buttons Upgrade
  76. Ambient Light retro fit.
  77. Windshield Info
  78. RPM jumping up / high clutch
  79. Lane assistant stop working after service
  80. 2017 Audi A4 prestige as my first car
  81. Android Auto going away
  82. Discrepancy between myAudi connect and odometer reading
  83. Audi roadside assistance: how long does it last?
  84. How can I confirm what part number do I need
  85. B9 Armrest Phone Cradle for Android Auto and Apple CarPlay
  86. BrokenStud A4 Build Thread "Luna"
  87. Loose Steering Wheel Lower Trim
  88. Steering wheel still turns
  89. Error Code P2681 / 15462 - Sensor Location
  90. Kind of hate my A4…
  91. Has anyone built one of these motors?
  92. Wiring Help!
  93. 2022 Audi A4 Fog Lights
  94. Fuel Level Gauge not working Check Engine Light P2068 Code
  95. Rusty hubs
  96. Android Auto not displaying
  97. A4 B9 ACC - security code
  98. Changing a LED control module
  99. Center Console Rattle
  100. Who’s running tunes while still under factory warranty?
  101. PL: Leveling sensor audi a4 b9
  102. A4 B9 power windows coding
  103. B9.5 Exhaust Coating Chipping
  104. DK: A4 B9 / A5 F5 PFL MH2P conversion GUIDE
  105. Headlight micro cracks
  106. CZ: HUD - is it worth?
  107. 2022 Steering wheel replacement
  108. Codning Audi a4 b9 pre Sense camera
  109. Brake Pads for Sale
  110. Strut replacement dilemma
  111. randomly unlocking doors when in drive
  112. Performance filter with turbo inlet hose vs CAI?
  113. Drive System & Start Stop System Fault
  114. Audi Care Extension-Good Deal?
  115. Infotainment Screen Replacement
  116. DSG Transmission Fluid
  117. Newbie to Audi . . . Couple Questions!
  118. Muffler Delete or DP?
  119. Electric seats not moving
  120. Motion for Audi app with dongle
  121. How do I know if I have a maf sensor?
  122. OBD O BLA DA
  123. Road Range?
  124. getAudiparts.com | NEW Genuine Audi Dynamic Center Caps Sets!!
  125. Looking for more info about stage 1 and stage 2 tune.
  126. MIB and MIB2 change region Us -> Eu
  127. 2021 Audi A4 B9.5 Question about Intakes/parts
  128. PODS Recall
  129. Audi RS7 Style Wheels on A4?
  130. WHEEL QUESTION
  131. RHD folding mirror parts
  132. Next reasonable upgrade?
  133. 2017 A4 Quatro - Jukebox stopped working
  134. Why does apple CarPlay disconnect when I put car in reverse?
  135. What size rotors do I have? 2017 Audi A4 Quattro Premium Plus
  136. 2022 Custom Order
  137. A rodent just chewed thru my coolant cable
  138. Has stock Spark plug gap recommendation changed?
  139. Tire pressure 18'' wheels?
  140. A4 2020 prestige matrix enable?
  141. Adjusting windshield wipers after windshield repair
  142. Leaks and squeaks
  143. 4G whiz
  144. Highline door control modules
  145. Will it rub? Tire/wheel/lowering advice
  146. Audi a4 b9 PDC - Park sensor
  147. 2017 Audi A4 Clock spring Is Not Communicating With Steering Control Module.
  148. Pre sense warning level adjustment
  149. is this sort of minor play normal??
  150. AU: Electric Leakage on B9?
  151. Digital dashboard: make gas gauge appear in center
  152. Animals (rats) or vandalism to front bumper lip?! Geico Collision repair shop advice
  153. Lot of transmission errors A4 2016
  154. Im new to the Audi community! I had some questions.
  155. Window Regulator / Adjustment - expensive?!?
  156. App can't check oil
  157. New buyer advice?
  158. HK: Removal of Quattro on grill?
  159. Annoying rattle in the driver door?
  160. Engine temperature gauge
  161. Help me understand how replacement key work please.
  162. Fog Lamp Covers
  163. Audi A4 S Line plus carplay
  164. Bearing noise??
  165. Coffee grind Like in my used oil change 2.0t 2006
  166. Idle Sound - Clicking
  167. Can I keep the MMI on Radio after the car connects wirelessly to CarPlay?
  168. UK: Help with Audi A4 B9
  169. Steering Wheel Vibrating with Tight Turning
  170. Central control buttons not working?
  171. Audi Pure Protection experience?
  172. 2020 b9.5 wireless charging MMI remind
  173. How I got my external SSD working in MMI
  174. Engine Control Unit - How reliable ??
  175. MU: Tag delivered with A4 B9
  176. A real steal, um, steel
  177. Difference of Ultra vs Premium & Premium Plus
  178. Coolant leak from where hose attaches to tank
  179. Question for all owners who have their car tuned
  180. UK: Audi A4 b9 1.4 tfsi engine code cvna dmf and clutch kit oem
  181. Knocking sount at startup
  182. 2017 B9 Rear Suspension Question
  183. IE: Have I a problem?
  184. Audi Connect (B9) Expired
  185. I have a problem
  186. Integrated Engineering Stage 2 mini review
  187. A4-2019 - Oil Dipstick
  188. Can Gateway module be replaced by independent tech?
  189. Can Gateway module be replaced by independent tech?
  190. Giving in to Stop-Start
  191. UK: HowTo remove plastikote acrylic?
  192. UK: Aircon error
  193. New Owner, take 2
  194. GPS/GSM (shark fin) antenna removal
  195. Vibration over bumps
  196. Audi Pure Protection with expired factory warranty
  197. Exhaust Test Pipe Combo Sound
  198. Front lip - where to purchase
  199. Gear not shifting to ( D - R ) A4 2016
  200. 10k Minor Service Price
  201. 2017 Audi A4 Premium screeching noise when starting. 7 attempts
  202. Can’t shift to P ( A4 - 2016 )
  203. Need help: how to remove climate control panel from dash trim piece?
  204. How long is the CPO warranty, actually?
  205. Crack in strut tower
  206. Lower dash trim removal - afraid of breaking by pulling too hard
  207. Audi A4 2015 starting problem
  208. Audi pickup?
  209. UK: Locking wheel nut problem
  210. 1.8 liter engine??!!
  211. B&O A pillar / D pillar trim parts
  212. 2022 A4 - Questions!
  213. Brake pad dilemma
  214. UK: A4 vs S4 Avant (B9)?
  215. How to change relative volume level for different media inputs?
  216. VCDS tweaks
  217. Aftermarket Wheel Locks
  218. Multi spine door screws
  219. Multi function steering wheel control.swapout
  220. Thinking about buying a used 2021 TSFI 40
  221. Ambient lighting kit any good?
  222. 2017 A4 2.0 TDI 110kw noisiness ?
  223. UK: To not chrome delete
  224. OBDeleven apps - now start/stop and rear parking sensors not working
  225. Navigation
  226. Engine lugging at low cruise RPM
  227. Chrome delete - Insitu or remove
  228. Horrible customer support from Audi USA. Audi Connect/MyAudi issues.
  229. Anyone ever changed their EVAP Pressure Sensor?
  230. UK: Part number query
  231. C&D Recommends A4 and A5 for reliability
  232. Hill Hold Assist retrofit help please with sourcing parts
  233. Auto Start-Stop Feature Disabled Quick and Easy
  234. Flat Bottom Steering wheel suggestions
  235. Cold weather causing misfire on Unitronic ECU tune
  236. A4 B9 diffuser installation issue
  237. ODBeleven "simple" mods
  238. Rear view mirror broken
  239. Tire choices in 2022? (cross posted from AR forum)
  240. Question about ride height with coilovers.
  241. Audicare 60k+70K is good idea @$1099?
  242. Body shop on Peninsula to San Jose (SF Bay Area)
  243. No sound from front door woofers (B&O Sound System)
  244. Anyway to have Google Maps show up on the Dash?
  245. Navigation, Traffic Sign Recognition, Predictive Control
  246. Only 1 zone for Ac working
  247. Body roll reduction
  248. RO: Audi A4 B9 Washer Fluid sensor change?
  249. RO: 45 TFSI vs 45 diesel?
  250. Toronto mechanics on east side of the city with good knowledge of Audi?
