PDA
View Full Version : A4 (B9 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Shaft cardan noise when switching between gears (reverse, drive)
  2. Random momentary “hiccups”
  3. Where do audi techs get the part numbers from?
  4. MMI Data Dump
  5. Traffic Sign Regognition - Speed Warning Increase
  6. Color code for silver accent in VC B9?
  7. Christmas Lights and CEL
  8. shaking
  9. Speedometer calibration
  10. CYMC timing chain measurement between the cams, anyone know the specs ?
  11. Kick to open trunk not working after oil rust proofing applied
  12. Seatbelt alarm sounding
  13. IN: 20% ethanol blend effects?
  14. B9.5 20k Mile Service & Oil Change
  15. Does this suspension sound normal to you?
  16. Has anyone installed a throttle controller on their A4 B9?
  17. 2018 A4 - Drivers Assistance Not working
  18. How to get inside instrument cluster glass?
  19. At a loss
  20. car system settings are unavailable
  21. Intake runner + car start problems
  22. Arm rest USB C broken
  23. Delay in Reverse and 1st gear
  24. UA: Fatigue Warning and Distruction Warnings?
  25. Anyone having timing issues with their b9 ?
  26. Low Coolant Warning. But full coolant reservoir
  27. Brake Caliper Bolts - Torque Specs
  28. Questions after VVT solenoid replacement
  29. 2014 A4 Firmware update error
  30. 10.1” upgrade info confirmation needed
  31. match 6 dsp upgrade
  32. A4 Facelift (2019-) Sound System [UK]
  33. B9 problems
  34. Control Arm Replacement on Jack Stands
  35. Shaking at idle (Sometimes Stalls) - Misfire all cylinders
  36. Front wheel sensation/shudder when accelerating when steering is cranked either way
  37. A4 Manual Quattro Vibration/Up and Down Wobble from Gearbox/Center dif?
  38. CarPlay/MMI Volume always at maximum
  39. Going Stage 2... testpipe vs HFC noise and FMIC options
  40. 6 speed manual fluid change
  41. My 2017 vibrating in D mode
  42. DE: No carplay on B9.5?
  43. Launch control RPM drop
  44. 2017 a4, code P00AF help please!!
  45. NEED HELP PLEASE READ. ELECTRICAL OR TRANNY PROBLEM
  46. Engine coolant wire harness needed B9 A4: P/N?
  47. OBDII Scanner Recommendations
  48. 2017 A4 2.0T MT Clutch Rear Thud
  49. A4 Subframe Removal
  50. Audi A4 2017 turbo problem
  51. Audi a4 b9 sound upgrade
  52. B9 A4 Non S-line body cosmetics
  53. summer tire recommendations?
  54. Cannot delete myAudi destinations from App
  55. Lane Departure Camera Calibration For Manual B9
  56. A4 B9 Xenon to Matrix
  57. Thermostat Replacement / Suggestions - PLS HELP
  58. B9 6mt clutch- anyone replaced/upgraded?
  59. Fuel Related DTC's
  60. MMI oil level varies between OK and overfull...
  61. Thumping thudding & vibrations from rear
  62. BRAKE SYSTEM FAULT STOP CAREFULLY
  63. Traffic sign recognition - activation
  64. Car Scanner and Elm327 drain battery
  65. Looking for a B9 factory intake - 5th VIN digit N
  66. Sometimes you feel like a nut ...
  67. 2022 Audi A4 - Speaker Upgrade
  68. Broken A4 B9.5 Premium shark fin antenna
  69. Can't reset Inspection Notice
  70. What’s this noice coming from the engine?
  71. Sound while accelerating quickly
  72. New TSB for Quattro Ultra rumble
  73. PCV Part find
  74. Auto start/stop delete cable risks?
  75. Vehicle shaking when driving at 100-130 km/h
  76. Squeaky suspension/ bushings with only 16k miles
  77. A4 B9 ACC Retrofit coding help
  78. [UK] Removing previous Key User from Audi MMI?
  79. rough idle, almost stalling - is it PCV, camshaft position sensor, something else?
  80. OBDeleven coding to disable interior motion sensor?
  81. A4 fuse and relay pulling as anti-theft measure
  82. Dimmer wire behind headlight control switch
  83. Over 100k miles
  84. A4 B9. 2020 A4 Prestige bucking at low speed
  85. 2017 Audi A4, missing cover?
  86. Do the ACC grille's come out from the front the same as the B8?
  87. Anyone know what this noise is?? Doesn’t sound good at all…
  88. Rear brake pads for B9
  89. A4 b9 2.0tdi 2019 gearbox oil
  90. Audi sound system woofer
  91. Wastegate Actuator Consistent Noise
  92. Sparkplug choice for 2021 A4?
  93. AUDI A4 2022 (B9.5) - SOUND SYSTEM UPGRADE MIB3 - NON B&O
  94. 2018 DSG/Stronic transmission fluid change
  95. Simple Front Brake Pad Replacement
  96. motor mount hardware, is it all TTY (remove&replace)?
  97. how to install subwoofer?
  98. Weird issue with Gearbox ?
  99. UK: 2022 Audi A4 B9 sound system?
  100. 2022 Audi A4 B9 – 12V Mild Hybrid Auxiliary Battery Fault Stop/Start Not Working
  101. Engine Motor Mount OEM or 034?
  102. The B9 + B9.5 Activations + Retrofits Information Post...
  103. For Audi A4 S4 RS4 2008-2018
  104. IE Flexfuel: Problem After Problem
  105. ECU Connector Pin Part Number For t105
  106. 2017 Audi A4 transmission noise
  107. How to source a clutch kit for Audi A4 B9 1.4 TFSI
  108. Heater matrix
  109. Audi A4 B9 steering wheel buttons
  110. Problem with dome lights
  111. Intermittent Engine Light – P2004 Code (3.0 TDI 272 Quattro)
  112. UK: Temperature gauge starting at 90°c
  113. FM Radio logos
  114. Drive system malfunction
  115. A4 B9 Avant how to identify tow hook preparation?
  116. IN: b9.5 MMI sim card / SD card slots?
  117. Carplay takes a really long time to play music?
  118. 2019 B9 A4 Missing Oil Spec Sticker Under The Hood
  119. Leaf depository
  120. Removing speedometer
  121. What fluids should be replaced on a new to me 2017 A4 Allroad?
  122. Dealing with Powertrain Malfunction
  123. Do I have to update MMI with my VC?
  124. Audis Held at Port
  125. A4 0CK ATF/MTF
  126. If anyone wants a pampered '17 A4
  127. Considering a used B9. What should I look for?
  128. Taillights wrong failure signals in dashboard (rear-left, rear-right, fog rear left)
  129. Should I keep the B9 A4 6MT?
  130. Wifi not working
  131. Brake Servo Dash Alert
  132. KR: Rust in specific part of engine room : brand new A4.
  133. Cars feel nimbler in ESC off mode?
  134. A4 B9. 2020 A4 Prestige Alignment
  135. MIB3 (2020+) MMI rebooting spontaneously 2020 A4)
  136. Failed LED Headlight Ballast and/or Headlight Control Module
  137. Paint peel from OSR wheel arch
  138. ASS MIB2 headunit DSP configuration modification
  139. B9.5 DSG service
  140. UK: Mmi panel
  141. Front seat back panel
  142. UK: A4 Refinement Advice
  143. Many sudden faut codes
  144. Disabling traffic sign based speed warning
  145. Audi A4 U044700 fault code in battery regulation
  146. B9.5 intercooler options
  147. New Tire/Wheels: Will it fit?
  148. Crushing rear tailgate
  149. Odd Start-Stop Issue
  150. audi a4 honeycomb grill
  151. Bluetooth/Sat nav not working/No data connection/SOS not working
  152. Contrast Premium Plus B&O sound system between cars
  153. What if you lose your key on a long trip?
  154. Rear seat heating Retrofit - Help needed
  155. MA: Audi A4 B9 TDI whistling/whining noise
  156. IN: Funny just how thin 0w20 can get at 5000 miles
  157. Transient Error Codes
  158. Phone & Navigation Stopped Working
  159. Audi A4 B9 blower issue
  160. GUIDE: B9 B&O Speaker Crackle / Pop / Rattle
  161. Very few A4's on Dealer Lots?
  162. No Central Connivence 046
  163. A4 w/ Lighting Plus and Beam (?)
  164. A5 = A3 + tariffs
  165. Main user in MMI
  166. Heater mirror and static errors
  167. Heater errors
  168. Windows won't stop fogging up
  169. Need help reinstalling intake manifold
  170. P0670
  171. Navigation update bug
  172. Chasing intermittent vibrations
  173. B9 A4 6MT USA Production Database
  174. Tuned A4 Drive Malfunction
  175. MMI Navigation - Map updates
  176. mph to kmph
  177. Coolant flush at 2 years?
  178. Grill shutter motor
  179. VCDS or OBDEleven for basic work
  180. A few observations about my new A5 vs. my A4
  181. Possible to add Navigation ?
  182. Tire question
  183. MHI2_xx_xxxxx_Sxxxx: Does S-Version works with "Adding FECs" via M.I.B ?
  184. A4 B9 paint and clear coat
  185. Ambient light passenger door doesn't work
  186. Intermittent ACC/front parking sensor fault
  187. Should I turn off the stability control in snow?
  188. Loss of pressure light came on randomly while driving. All tires look fine but.
  189. Don't know why this happened. Slow starting
  190. UK: Battery keeps g?
  191. Goodbye to my beloved A4
  192. All warning lights on
  193. Why the change from 5w-40 to 0w-20
  194. whistle/high pitch noise while driving and breaking
  195. Audi Sound System Crackle nose from passenger door speaker
  196. Chirping noise at highway speeds
  197. Only white ambiant light?
  198. Strange noise coming from the steering wheel
  199. Headlight replacement help
  200. OBDeleven enable Joker (*) button
  201. OK to engine clean or?
  202. Rear diffuser replacement help
  203. Right parking brake motor voltage supply, open circuit
  204. Guide to running wires through the firewall
  205. New (used) B9-questions/problems
  206. Avaria cambio s-tronic
  207. NL: Diesel Change of oil, 5w30 or 5w40?
  208. Need Advice on Control Arm Bushing Replacement for 2017 Audi A4 B9 – High Quote
  209. OEM S5 wheels on a Audi A4?
  210. Battery Replacement 2019 A4
  211. Car flashing with no sound
  212. What is this part name and/or number to buy replacement?
  213. A4 2016 tfsi 2.0 b9 rear diffuser help
  214. Brake recommendations please.
  215. Door locks, lights
  216. APR tune passing SMOG in CA?
  217. Getting "Cam Shift Actuator "A" Cylinder 1" fault in ODB11, Cruise control stopped
  218. D5S bulb life
  219. Engine Management Light- secondary coolant pump
  220. IN: Disabling auto stop/start?
  221. What xenon bulb do I have?
  222. Issues with HomeLink Setup
  223. Issues with HomeLink Setup
  224. Upgrading my MMI unit? Help Needed!
  225. Exhaust system
  226. Drive System Fault / Cruise Control Not Available
  227. Oil level 163%??
  228. Replacement Engine Mounts?
  229. Do I or can I have Apple CarPlay?
  230. IM: Cold warm up
  231. New upper suspension arm looks like split
  232. Weak/No Heat
  233. HU: Company fleet purchase opportunity: A3 8V or A4 B9?
  234. Interior lighting 2024 A4
  235. A4 B9 Rear Seat Protector
  236. Anyone experienced with cam plate reseal?
  237. Coolant Leak
  238. 12V Mhev battery, Audi A4 2020.
  239. HVAC/Climate/Aircon - temperature and positioning no signal (20 codes in total)
  240. S line Door Sill Not Working
  241. Upgrade High gasoline Pump - A4 B9 2018 - Stage3
  242. How to steer with no power?
  243. DIY Audi A4 B9.5 ACC retrofit
  244. Pondering next ride
  245. Winter tires
  246. My sister Overfield the oil in her Audi please help
  247. VTA?
  248. Reverse Engineering Virtual Cockpit Display Images
  249. DIY Guide: How to remove mechatronic, change filters & oil in DSG & rear differential
  250. Water Pump/Thermostat??
