PDA
View Full Version : A4 (B9 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Trying to clean the buttons on my 2017 A4 MMI Controller
  2. Auto Start stop Malfunction
  3. Armaspeed Audi A4 B9 carbon fiber cold air intake
  4. Rotor and Pad Kits?
  5. Ambient light retrofit
  6. Audi A4 S-Line B9 Battery Voltage Issue
  7. Battery Charging Problem
  8. McGard wheel lock caps
  9. Drive System : Malfunction
  10. Westfalia towbar for B9 - replacement swan neck
  11. 2022 A4 shown
  12. Location Alerts - has anyone else seen them?
  13. More aggressive muffler options?
  14. AFE Axle Back exhaust?
  15. PUT CAR INTO REVERSE WHILE DRIVING
  16. 2017 Daytona Grey Build Thread *LOTS OF PICS*
  17. UK: A4 B9 front parking sensors
  18. H&R Sport Springs
  19. Radio Turned off while driving
  20. Will a 2016 A6/S6 20" OEM wheels with 265/30/20 tires fit the B9 + sport suspension?
  21. Eibach Sportline Springs
  22. My new 2019 A4
  23. Audi Pre Sense Question
  24. Road noise on my A4 Avant (B9)
  25. 2020 A4 or 2020 A5 Sportback?
  26. Replace OEM sport suspension springs with coilovers vs lowering springs?
  27. Tachometer Question
  28. 2018 A4 B9 camera recalibration?
  29. Audi A4 B9 - Leaking Water Pump / Thermostat
  30. 'Sudden' battery drain causes?
  31. What's the stock exhaust pipe dimension?
  32. 2020: hole where mmi controls used to be
  33. New 1st Time Audi Owner - Must Have Accessories?
  34. Audi A4 B9 - Engine bay is very hot
  35. Parcel shelf speakers
  36. Window opens after I try to close it
  37. How to skip songs from steering wheel when using Apple Carplay?
  38. EPC Light when hot
  39. Subwoofer and Amplifier Plug and Play cables
  40. Should I go with 20" wheels for A4 Quattro S-line?
  41. Remote Start
  42. Suggestions for new tires/wheels?
  43. Looking to trade mods
  44. How to code Online Radio
  45. Xenon to FULL LED
  46. Thoughts on how to fix this?
  47. Throttle Position reporting 85% on P3 Gauge with WOT
  48. CTS Turbo Intake vs 034 Motorsports Intake?
  49. Water on the ground coming from the right-back of the car (near the wheel)
  50. My Rotors Finally Gave Out - Perfect Opportunity to do a Stud Conversion
  51. Mewant Steering Cover 2016 A4 B9 S Line steering wheel
  52. Front and rear windshield molding missing?
  53. CocoMats Alternative
  54. Introducing OEM A4, S4 LED Taillight Packages...
  55. a4 b9 function question
  56. Nav on demand
  57. Virtual cockpit and mib2 retrofitting
  58. Options/VIN Look Up resource?
  59. Rear bike rack for B9 A4 saloon
  60. How to active navigation?
  61. How to program comfort entry with vcds?
  62. 17 A4 Quattro Shifting to Manual Mode Automatically
  63. 2019 A5 - accidentally used wrong oil
  64. OEM Tires
  65. Updating Audi MMI software in 2020 Audi a4
  66. So I now have a 2020...
  67. Where do you keep your glasses/sunglasses?
  68. B8 A4 Motor blown, can I swap a S4 motor in?
  69. Basic setting for 2017 A4 driver assist
  70. Clunk and long beep every 30 seconds when car is off??
  71. Steering problem after Start/Stop event
  72. Driving shoes?
  73. 034 Motorsports Intake For Sale
  74. Water guidance - Plenum chamber and Fender plastics
  75. 2019 A4 - Performance Package/Summer tires?
  76. Stay outta the water!
  77. Missing Plastic Cover Under Hood?
  78. Brakes still good at 60,000 miles?
  79. Popping/Tapping sound from rear after shut off
  80. Creaking noise help!!!!!!
  81. Blue 2018 is gone, Manhattan Grey is now in the Garage
  82. Source for locking lug nut caps
  83. GB: Hi everyone newbie here with a lot of questions! Thanks in advance
  84. A/C Cut off
  85. BBB Auto Line & Audi - warranty disputes
  86. Remote start questions - compustar CM-DC3 & ADS-THR-AU3
  87. Stock Intake Heatshield Screws
  88. MMI Update Online
  89. oemvwshop trusted?
  90. Carbon Fiber Grille Accent (where to buy)
  91. Audi is software-challenged
  92. Active lane assist, is it updated on 2020 models?
  93. New Battery Needed?
  94. Water splash under the engine - A4 B9 2.0 TFSI
  95. RO: Fan like noise after engine stop - A4 B9 2.0 TFSI
  96. Oil label info for A4 Ultra
  97. Alloy's width?
  98. PSA: Very weird OBDeleven bug on iOS
  99. Fixed CarPlay "Unknown" track info bug
  100. Do we have regular or AGM batteries? Battery charger/maintainer tips?
  101. APR ECU stage one on a lease
  102. ECU light is displayed before starting the engine
  103. Black Optics Window Trim
  104. Compartment Knob for Right Side Trunk Compartment
  105. What ever happened to ECS's 2pc Front rotors?
  106. Lease is ending - got a great deal
  107. drivers seat moves rearward when opening the door
  108. Misfire on cylinder 2 in NEW CAR? P0302 CODE
  109. Both resonator delete sound
  110. Audi exhaust options
  111. 2017 Audi A4 backup camera woes
  112. Looking for guidance running wire
  113. Oil change?
  114. Front Seat Belt Removal
  115. Electrical insight needed
  116. Please Help Removing This Piece!
  117. Matrix LED Driver Search
  118. Resonator/Muffler delete. Opinions?
  119. Oil separator (PCV Valve) replacement
  120. TPMS Error Message
  121. interesting video premium vs reg fuel
  122. 17 A4 error messages popping up
  123. Virtual Cockpit without Navigation Package
  124. Winter tire sizing
  125. 2017 A4 S Line ... Differential issue
  126. Safety system malfunction after changing steering wheel
  127. B9 sports trim 2015 interior lighting?
  128. If you could change anything about your a4, what would you change?
  129. Wireless charge box for B9
  130. A4 B9 Virtual Cockpit retrofit
  131. Grill removal procedure
  132. New Alzor 628 18 inch Rims
  133. Colourless Liquid
  134. Just bought 2018 A4 Ultra Premium Plus...in love with the car but
  135. Hum from front left wheel on 2020 Audi A4 Allroad
  136. A4 b9 SOA 2017 rear pdc retrofit help...
  137. Possible to have two car seats, one on the side and another in the middle?
  138. Heated Steering Wheel to Flat bottom
  139. Valet tickets stuck in dash
  140. Oil selection?
  141. A4 B9 Homelink retrifit
  142. Just turned in my lease.... 2018 A4 Manual Trans with Sport Plus
  143. myAudi app inaccurate
  144. B9 A4 2016 steering wheel swap
  145. 2019 Audi A4 Prestige - Preinstalled puddle lights?
  146. Are the 2021 A4 2.0T engines getting a torque increase to go with the 13 hp bump?
  147. A4 8W US rear lights to EU rear lights
  148. Extended Warranty 2017 A4?
  149. A4 B9 Avant Trunk Cover Rails
  150. Perforated Shift Knob Trim?
  151. Offset help
  152. Ami cable to play music from iPhone 8
  153. Memory seat module
  154. A4 B9 Ultra - How long should the backup camera stay on?
  155. Map updates no longer available for download from audiusa.com
  156. Apertura portellone con movimento piede
  157. 2018 A4 interior trim replacement doesn't match
  158. Replacing Audi A4 rear light cover (red part)?
  159. Safety System Malfunction and Traffic Jam Assist (active Lane assist))
  160. 2017 A4 Premium Plus - Auto Start/Stop
  161. DSG fluid replaced ... at 28,295 miles
  162. A4B9 - Modernizacja wydechu.
  163. What size are the OEM rear license plate screws?
  164. Used A4 shopping hints for retiree
  165. Can't navigate
  166. Help needed, Fender liner-spoiler for prestige package
  167. Help needed, Fender liner-spoiler for prestige package?
  168. iPhone 11 ringer set to 100% after connecting to A4 Bluetooth
  169. How to replace the door boot?
  170. Painting Crash Bar (RS/Honeycomb Grill)
  171. Engine code question
  172. My 2017 A4 with new 19-inch APR Wheels
  173. AudiCare besides DSG where’s the value?
  174. audi a4 b9 how to remove the exterior mirror insert
  175. Did the dealer actually change my transmission fluid? Is 'gear oil' the same thing?
  176. How to: remove side mirror caps (NO NEED to take off mirror/screws)
  177. 2018 A4 B9 - LED Accent Lighting Fuse?
  178. DSG Service
  179. Swap for German ECU?
  180. Center Console Armrest
  181. Audi dealers not taking back cars at lease end?
  182. Black Optics: Remove black mirrors?
  183. Audi Master Tech Reddit
  184. S line on non sport package question
  185. Purchase Help and Some Q's
  186. 5 Reasons to have Adjustable Upper Control Arms & Review of 034Motorsport's Track Spc
  187. Jump to preset using # pad
  188. Curb weight discrepancy between U.S and Euro spec?
  189. Stock audio system upgrade?
  190. New to Audi and researching the price
  191. Audi ring/puddle lights
  192. Lower Switch Replacement (Adding Accessories)
  193. Gloss Black Exterior Upgrades | The New Hotness
  194. New ECS B9 Front And Rear Adjustable Sway Bars
  195. UK: Crack in tail panel
  196. DE: Door trim light?
  197. OBD Eleven Specific questions for A4 B9
  198. Renewed Audi Connect ... for the last time
  199. 2017 Premium Flashed Audi Sense While Driving
  200. Red door lights/2nd trunk light wire harness
  201. Sport Supsension
  202. Brand new 2017 A4 owner!
  203. 2017 A4 CPO
  204. 19x8.5 et28 will if fit?!
  205. B9 2019 a4 seats to fit into a b8 2016 a4.. Help !
  206. Battery Problem?
  207. SE: Audi A4 B9 – really poor quality
  208. Seeking advice on purchasing a B9 A4
  209. Headlight Assembly Alignment after Collision Repair?
  210. Audi A4 B9 - central locking safety issue
  211. PDR rear quarter panel access
  212. EE: Upgrading from cloth seats to leather seats
  213. Custom garage opener button installation
  214. Need new A/S tires
  215. audi a4 2016 strange sounds
  216. Spacers help!
  217. 2019/2020 map update
  218. NEW! ECS Vacuum Formed ECU Cover!
  219. how to remove rear center console trim?
  220. Wipers Not Working
  221. Donate to Discount so you can Quarantine in Your Garage...
  222. Locking lug nuts?
  223. OEM vs. China puddle lights
  224. Need to replace single tire
  225. A4 Door Kick Protector
  226. A4 Door Kick Protector
  227. high beam assist
  228. Draggy Numbers Inside....
  229. Bad vibration, not wheels or tires, help
  230. A4 reliability & cost of ownership vs BMW
  231. Erwin Audi PDFs
  232. Honeycomb front lower grills for B9
  233. Active lane assist - a near death experience
  234. 2018 A4 Premier Plus Rack + Pinion.
  235. Basic coding question
  236. OEM Blackline LED Tail Lights
  237. Which tires get used more, front or rear?
  238. Help me make a choice, please
  239. 2017 Audi A4 2.0 = German grenade?
  240. ECS Intake: How to retrofit to MAF sensor cars (2.0T Ultra/190hp)
  241. Stock system Sub woofer upgrade
  242. My NEW Glacier White 2020 A4
  243. Software Version?
  244. Very annoying front wheel sound on A4 B9
  245. Keys?
  246. Audicare - scheduling maintenance early for oil change?
  247. Anybody here using an oil catch can?
  248. Anyone with transmission mount insert with issues?
  249. 2017 Audi A4 Premium Plus Questions?
  250. New (to be) A4 Owner - Tires or Wheel Size?
