View Full Version : S7
- AutoTuner One Smartphone Flasher Now Supports both ECUs and TCUs!
- S7 Interior Refresh【Final result】
- Airlock after Mercracing HX Install
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- AIR Suspension EDC delete kit
- RS7 grille on S7
- In the market for:
- Hello All - coming back to AudiWorld & one question
- Discussion: CarpuTech Carplay Kits for 2012–2018 Audi A7/S7
- Air Suspension Issues
- S7 vs rs7 (loudness on straight pipe)
- APR Ultralink: At Home Flash Tuning is Now Here! (4.0T EA824)
- Tune and cruise issue
- Prepurchase Inspection of S7 in Grand Junction
- How long does pcv breather valve last?
- Good buy or no?
- Sucking oil, suggestions on where to start?
- Phone app can not connect to vehicle
- Lane assist unavailable
- Wire Harness
- Picked up a '14 S7, couple minor issues
- Looking at a 2014 S7 - verify recalls done?
- Massage Chair Broken - Need Fix
- Clunk/Thump noise
- bTres Special
- Alternator Fault Warning 2013 S7
- Many, many ERRORS!
- Changing the oil Filter on the 2023 S7
- Rear camera
- Help shutting off air suspension compressor
- Low Compression Cylinder 1
- Need help identifying this part...
- Best Intercooler for S7 C7.5?
- Replace horn is ridiculously expensive - 2017 S7
- New S7
- Beeping noise coming from engine
- S7 2013 slight oil leak
- CarPlay possible?
- Rumble at tight turn - Center differential clutch pads?
- 21" wheels --- flat tire every few weeks!
- Audi s7 2017 wont crank
- 2014 Audi S7 C7 COD activation
- Maintenance, downpipe, and tune... what a difference!
- RMP surge after stopping
- IE Intake
- S7 Intermitent Engine Start Issue - have fun with this one
- Audi s7 2017
- Christmas Holiday Sale
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Exhaust Cutouts
- c7.5 S7 Lowering Link Faults
- I need your help to get my car fixed!
- 3 attempts to get start
- Reprogramming my Sport Diff module
- 2014 S7 Air suspension conversion
- 2014 S7 Air Suspension replacement cost
- Will this tune pass emissions???
- American message board members.....
- Audi S7 C7 Air Suspension Issue
- Greetings from SuperSprint Italy
- New S7 Owner Questions
- Euro Tag causing front sensor to beep...
- Vossen- VFS -2 for S7
- S7 USED HIGH MILES
- Map view in drivers display
- Dreaded Suspension Fault and Headlight Fault
- Need help recognizing where this ground goes.
- 2014 s7 boost issues
- S7 not recalled for oil restrainer yet?
- short to ground
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- All Season Tires for 2022 S7
- Winter Tire Options?
- '14 has weird "hum" from front axle, NOT a CV joint
- Clutch slipping
- Oil shop overfilled 2016 S7, hydro locked
- OEM 2017 Audi S7 Rotors & Pads
- Cyl 8 Misfires, Oil on Spark Plug Electrodes
- My 2014 Audi S7 misfire on 4 cylinders
- S7 2013 Part number
- 2015 S7 Fault Code P2196
- Most/Least Reliable S7 Model Years?
- Ver nice spoiler!
- Inventory Sale - Stance SF01 20x10.5 Gloss Black Tinted Face
- RPM surge when decelerating
- Capless Gas Tank?
- 15' S7 (8 Fault Codes)
- 2014 Audi S7 C7 Whining sound on idle and while accelerating
- 2014 Audi S7 Intermittent EPC Light and “Do not exceed 4000 RPMS”
- S7 in EPC throwing fuel system too rich
- Seat Memory
- Turbo Warranty
- Audi 4.0T Running Rich, Random Misfire
- 2018 s7 mmi update
- A7/S7/RS7 Trunk Motor Replacement
- Electrical issue
- Caliper size C8 S7 versus C7 A7
- Looking at S7 with damage history
- Looking to buy Audi S7. Which year should i buy to avoid replacing turbos?
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Steering feel (weighting)?
- APR Stage 2
- Side Mirrors
- Rpm goes down and then up again between 0 and 1
- 2014 Audi S7 apr stage 1
- Stage1 Want to see the performance logging
- Seafoam?
- Very high average consumption
- A7 Body Scrapes
- 2017 Audi S7
- S7 Intro
- Music 2 my ears.
- Steering wheel airbag removal; controls not working
- Looking for parts for 2013 s7
- Andover, MA Cars Coffee Tomorrow
- 2016 Audi S7 Sensor B2 S1 LOCATION HELP
- Leveling Sensor Mechanical Failure Codes
- Start Stop intro year
- 2015 S7: High Mileage?
- Needing a 2016 S7 Grill with Nigh Vision
- S7 lowering
- 2015 S7 singing rear differential?
- Highbeams Misaligned Relative to Lowbeams (LED Lights)_
- Cost of Extended Warranty
- S7 Heartache
- Tuned and exhaust
- New S7 Owner
- New S7 Owner
- 4.0T Turbo Failure, with filter revision G installed
- S7 Stage 3 + hardware & shop options
- Does the S6 diffuser fit an S7?
- looking for a low mileage transmission
- Safari S7
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- AWE Black Friday 2020
- Oil Seperator/PCV
- Spacers and lowering
- Stage 2 S7 2013 O-Rings Failing
- S7 Odometer Display Failure
- Extended warranty hidden detail
- "DEF" in odometer dash display
- S7/A7 OEM 20" Wheels #4H0601025BS
- 2014 Audi S7 Vibrating/humming noise only at 2000rpm (in 1st and 2nd gear only)
- Considering purchasing 2016 S7 - looking for a brief summary of known issues
- 2013 S7 overheating issue - difficulty diagnosing
- Enhanced Wheel Alignment?
- 2016 Audi S7 glove box removal steps?
- 2016 Audi S7 headunit removal issues any guidance?
- Buying 2014 S7 42k Miles? Help Please!
- Looking to buy 2014 S7 42k Miles. Help Please!
- Steering wheel for sale
- 2017 s7 Tuner
- Is this a good deal?
- Engine cuts out / S7 2013
- I just bought a low miles 2017 Audi S7, and I want to know everything about it.
- Warranty Issue
- Audi s7 mmi
- Seat organiser / kick pad for kids in back
- Experiences with Audi built-in Wireless Apple Car Play
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Looking to buy S7
- We Build Faster. Shorter lead times on AWE Exhausts.
- Air Suspension Error Help!
- Front Calipers for 400mm rotors
- Start Up Issue - 2016 S7
- Any S7 Owners Drive a CLS 550 4Matic?
- Tires- educate me please
- Looking for a tow hitch for 2016 S7
- Question regarding the Cargo Mat for S7
- S7 Tire Question
- 2020 S7 - Sport Package - Yea or Nay?
- WARNING!! QUICK JACK 5000SLX BARELY FITS S7!
- What model should I buy ?
- AWE's Annual Holiday Special Pricing Event Starts Now.
- F/S 2017 S7 Prestige- Glacier with Sport Pkg, B/O and Alcantara- 19k miles $56k
- Picked up a 2016 Audi S7 with extended warranty the mod bug has bite me
- 13 S7 PCV Valve replacement?
- Can someone take a pic of the tonneau cover installed?
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Suspension rear drop (no code)
- AWE BLACK FRIDAY 2019 STARTS NOW.
- Night Vision System Fault
- lost key for 2018 s7
- Engine oil leaking into coolant system
- 2017 S7 vs. 2020 S5
- Car battery replacement cost
- Engine Coolant & Transmission Cooler Problems?
- Suggestions for improving exhaust sound
- S7 gets Blacked out by GMG
- Used S7 Stronic
- Tuning my S7 2017 do or don’t
- JHM oil screen replacement kit
- 2014 s7 trim configurations
- 2017 S7 Replacement bumper with RS7 (has it been done?)
- Replacing Tools
- AK-Racing-47 lowering module?
- 4.0T APR Catback-Exhaust System!
- Ordering guide for 2020 Audi S7??
- getAudiparts.com | Genuine Audi Black Rings Sets!
- Location of Engine Coolant Temp. Sensor
- Repair Manual/Mechanic's Book
- EPL Stage 1 ECU & TCU tune & cable
- Used S7 advice
- S7 Burger Motorsports JB4 UPDATE! 5/1/19
- 2020 Audi S7 revealedx
- 2016 S7 Auto Shutoff?
- Misfire
- 2013 S7 Reliability?
- Facebook Page for S7 Owners?
- Suggestions for extended car warranty for s7
- 2015 S7 Turbos blown!
- Is it a good deal? 2016 S7 Prestige for 56k
- New Product - Programmable CETE Exhaust Valve Controller...
- S7: ACCIDENT ADVICE NEEDED
- S7 Burger Motorsports Tune
- RELOCATED - 4.0TT Turbo Failure Thread - S6 S7 RS7 A8 S8
- 2016 Audi S7 - Need to replace Right Intake Manifold
- Need Car Seat Help!!!
- AWE Annual Holiday Special Pricing Event
- TSW Bathurst wheels 20 inch only- pics
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Europrice.us Black Friday Deals are almost here...
- UK: UK/US S7 sports exhaust option?
- S7 Transmission VS RS7 Transmission
- 2018 new Audi S7 transmission for sale!!!
- 2013-2015 S7 vs 2016
- WINTER SETUP FOR SALE $1,500
- Is my MPG lower than it should be?
- DIY S7 Battery Replacement
- getAudiparts.com | Genuine Audi Collection Key Rings!
- PARTS FOR SALE - S7 FRONT GRILLE & REAR DIFFUSER
- LOOKING FOR C7 S7 PARTS!
- C7 A7 / S7 retrofit C7.5 RS7 bumper & headlights
- Lowering Links + VCDS Audi S7
- New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
- Need advice
- 2015 S7 Sunroof stuck open
- How to remove HUD trim
- Warranty for APR Tune
- Audi Recall PODS (74D5)
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- 2005 Audi A6 Quattro Reading P2004 & P2006
- Dealer BS? Rear left toe out of alignment from “bumping” a curb?
- Key Fob Settings - Auto Start-Stop
- S7 wheels get dirty fast
- 25% Discounts! - Revo by Alcon 355 and 380mm Big Brake Packages...
- S6/S7 Winter Tire/Wheel Question
