- '87 Coupe Gt
- LCD's on digi dash
- 86 Audi 4000cs quattro in perfect condition
- My winter driver
- I NEED HELP
- Value of quattro 88' 4000 CS
- connector under seat
- heat issue
- Audi Coupe GT Engine
- Minor warm-up annoyance.
- Semi-new 4000S Owner Considering Engine Swap
- pass. tail lights won't work
- STARTING PROBLEM 4000s
- Center Caps
- Coupe GT Questions
- 87.5 cgt -- burning oil, maybe coolant?
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- HELP REQUIERED
- audi 4000 type 81
- 4000s 3spd Auto transmission cable needed Help!
- Carlisle registration open for 2010 may 21st through 23rd
- starting problem is back
- rear diff schematic?
- I have a radiator fan that will not turn ON
- I have a radior fan that wont turn off.
- Window Regulator Question
- power steering rack source needed
- CGT Turbo swap questions
- Noob Lookin at '85 4000 quattro in Wisconsin
- Air Filter
- Gearbox problems
- Turbo conversion
- Audi 4KCS Tail light lenses
- 84 cgt timing belt position?
- starting problem kinda(lots of details)
- 84 cgt fusebox issues
- I miss my 4KQ!
- center differentail problems
- Engine Size?
- i need help
- Clock not working....
- 84 ur quattro
- 4000CS quattro starting problem
- How many were made/Came to the USA?
- CGT Electrical Weirdness - Lighting & 12V Port
- tranny fluid
- speedo pinion gear 84 4000S
- Anybody in the search of a 5ktq donor car?
- Advice Appreciated on Idle/Emissions Issues
- 1982 Audi 4000 2 Door
- fuel pump
- Basketweave BBS rims
- any tricks on replacing the clutch cable on an 84 cgt?
- 4000 Q
- Does anyone know anything about this car?
- 431 711 221 shifter bushing?
- trouble shifting
- oil temp
- Fuel Pump relay jumping question
- trunk locking problems!!
- Brake booster replacement woes
- My visit to Audi Forum Museum Mobile
- I rescued a Coupe, 1981. Advice plz
- wonder what it is worth
- CGT Shift knob question
- Flooded start
- the coupe is back but rough start (long)
- Audi Coupe GT 1986 FOR SALE
- 4000Q transmission interchange?
- Help requested in the form of pictures of a series 1 4000 rear end (84 and older)
- 87 4kcsq electrical issue HELP
- Heater Control Valve - 4000S
- WTB: 1987 Coupe GT MT Shifter
- New CGT Owner!
- 4000Q steering wheel interchange?
- speedo transmission gear
- CGT Digital Dash Swap into 4000
- High oil pressure
- Wanted: Headlight Switch Harness
- Need P/N for 87 4k FWD front axles
- Automotive wire
- 2226 10v/20v kits....
- audi 100 c4 92'automatic gearbox problem
- Finding Parts
- Clusters Coupe GT vs 4000
- WTB 86' CGT Fuel Lines W/Fittings
- california junk...
- Wide body kits
- 1985 Coupe Gt
- springs/strut mount?
- '86 4ks choke & knock sensor probs
- Electrical
- original quattro A2
- body kits or aftermarket upgrades
- Coupe GT Gauge Cluster
- Test and/or repair VDO gauges from a Coupe GT
- washed engine bay now car wont start
- Help me please
- For Sale
- 1987 audi coupe High idle and hard to start
- My Grandpa's 1984 4000S
- 85' Coupe GT, factory fit aftermarket floor mats?
- 85' Coupe GT; temp light blinking but not hot!
- This Forum
- Great Parts Source
- 1984 Coupe GT Value?
- need help with mount (85 Coupe GT)
- '87 CS Quattro: Poor Condition, Advice needed
- Any good mechanics in Chicago for Audi 4000s
- No Brake Lights
- WTB: 87.5 Coupe GT SB.
- Passengwe side door for 86 coupe
- 85' Coupe GT; replacement spare donut tires? Where do you get one?
- Running the fuel pump while the engine is off on a 1986 Coupe GT
- 85' Coupe GT; trunk won't open! Help! :)
- Urq/4k garage sale
- Help with radiator fan
- Where is the fuel pump relay on my 1986 Coupe GT?
- My coupe had an incident
- Center Cap
- 87 4KQ Diff locks,,,
- I need a Vacuum Diagram for a '84 quattro 4000s
- Any others out there??????
- Coupe GT Sports Suspension
- (please)would like to know if this is a kit , custom or what
- LTB Euro Lights
- Custom Speedo
- Will 5k seats fit in a 4k?
- 87 4000Q Parts - clunker program
- fuel distributor
- coupe gt shift linkage grommet?
- i need 4000 cs quattro parts
- A little help with pricing.....
- 4kcsq motor swap ? will a v8 work with stock trans
- I need a new rear window
- 1980 4000 starting issues..
- Need advice - replacing vacuum lines 4kcsq
- Just to be sure about something
- Trunk Button
- Window regulator
- My 1983 Coupe GT is For Sale
- front sway bar link 84 4000 S
- Is this the SE motor?
- A/C Issues
- WTB Bilstein front struts for 4000Q/90Q/URQ
- 90 B2 V8 conversion ???
- 4kcsq minor idle issue
- WTB Euro lights
- how do i check fuel pressure
- Squeaky cabin fan blower
- Tune Up Parts
- Need tips on cooling / temps - 4kcsq
- normal operating temp
- A/C High Pressure Problem
- 86' GT Coupe Radiator Fan Problem???
- Meet in NorCal
- Stock Radio
- Slave Cylinder
- HELP!! Radiator issue - need fix NOW!!!
- Audi 14 ronal wheels
- Selling my '86 4KQ CS
- My 85 Gt work start
- A/C Issues....
- struts and springs on a 86 4ks 5cyl?
- Urq/4k parts garage sale
- Was just given some new interior...
- The Truth in 24
- 86 4kQ slave cylinder help
- Just Asking
- Turn Signal Help - Need Electrical Experts With Schamatics
- Broken Cruise control bellows, anyone know where to source a new one?
- 4000 Quattro Stereo Help
- Tail Light Cover
- The hunt for the Audi
- New Coupe GT, stuck throttle (?)
- Do I need new shoes or the whole drum?
- Ideas on no start after radiator blow out?
- Selling '84 5-cyl FWD 4KS 3-spd auto
- Cracked Exhaust
- vacuum lines
- Obsoleted parts, lets make a list
- Audi Coupe GT
- 1985 4ks window trim removal
- Door handle 86 Audi 4000 CS Q
- Show me your 82-84 Coupe interiors
- floor mats
- towing capacity for 86 gt coupe??
- Replacement Parts
- what do you consider a 1983 audi 4000 sport coupe, whats another name
- forget my post about it eing on the road...
- Parking Brake Cables for 4000 FS
- just got the CGT on the road again
- 85 4000S Quattro fuel pump not running
- Audi Coupe quattro Group A rally cars
- FS: 1985 4KSQ
- Good home for a 1986 Coupe GT
- RWD Audi coupe GT
- Help! 4000CSq runs poorly, fuel distributor?
- WTB Quattro Coupe front clip
- CGT - Oil pressure warning light
- Anyone going to Carlisle have CGT or 4k FWD front springs?
- Where to get Differential/Tranny Mounts for 4000 Quattro. Help asap!
- Tune up parts on Chicago CL
- New to Audi - Picked up Audi 4000 CS Quattro- Pics Inside!
- Performance boost..
- wtb quattro headlights or Blacking out lights
- Shocks and springs
- Tic tic tic noise in the engine Coupe GT
- New to the 4K...
- o2 Sensor Location?
- Calling all Coupe GT and 4000 owners!!!
- Throttle cable connection, replace in NOW
- New Forum?
- Searching for a pic ?
- Where do you put in clutch fluid in a Audi 4000 CS Quattro
- Carlisle update--37 Audis registered! 5/15-17...
- 4wd Coversion - The Car
- turbo 10v conversion parts TQC
- intermittent charging
- New Audi Coupe GT
- Good home for 1987.5 Coupe GT?
- 1985 4000S Quattro, alternator output, 13.6v
- Carlisle update--> 30 Audis registered. 5/15-5/17
- 1985 4000S door handle(s)
- 86 4000, is this a deal or headache?
- Help with CV boot replacement
- gear options
- Front/ Rear Rubber subframe bushings
- The hUmpday Carlisle update--26. Shirts available & dinner RSVP open!
- timing issue?
- Intro and 5-lug conversion on CGT I did a search, but am more confused!
- SELL RARE COMPOMOTIVE TH
- 1984 Coupe GT electrical problems
- had enough abuse from my wife, Urq for sale at Carlisle
- clutch squealing
- Interested in trade? MSW 14x7 for stock Ronals
- Your hUmpday Carlisle update-->23 Audis registered. SHIRTS available to order!
- Cool! I found out we can't edit our posts!
- need a part number
- silver urq or cgt spotted on NY/CT boarder
- Carlisle 2008 video!
- rear suspension bushings
- Slave Cylinder question
- Carlisle shirt sneak peak...
- Weekend wrenching plans?
- A play by play of last weeked
- MC2 swap help
- The hUmpday Carlisle post...22 Audis registered!
- Parting out 4000s...
- Interesting concept
