PDA
View Full Version : Audi 4000 / Coupe GT Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
  1. Any experience with 034's bushings?
  2. Small update: Parts for the 4kQ are in the mail... :)
  3. Anyone looking for a Coupe GT parts car/project near Charlotte, NC?
  4. 2 hrs left, if anyone wants it, ebay
  5. Justin, can you link me to the hazard relay you mentioned? TIA
  6. I like this...
  7. Will an adjustable cam gear for the 4cyl work on the I5 ?
  8. yay strut is leaking oil :)
  9. Quad headlamp bucket I got isn't for urq as advertised.
  10. Safe back in Indiana
  11. anyone ever add a third brake light to a 4000q? My 84 doesnt have one
  12. What's the canister hiding behind the R-F fender? Charcoal canister? I need to change those vac line
  13. I'm still begging for an alt bracket (see pic). Need an instrament cluster too.
  14. Surgery sucks guys
  15. anyone have a diagram of the vacum system on a 86 4000 quattro?
  16. Can someone explain to me what the diff locks do?
  17. 195/65/15 Blizzaks on 4 x 108 nine spoke Audi wheels - central CT - $250
  18. Congrats Mikey! Top 4000 forum poster for 2008....now if only you had another 4k ;-)
  19. `87.5 ^_~ sweet... but hurting
  20. Speaking of RHD....seen earlier today...
  21. So... what do you think about this 2-door?
  22. Red 83 CGT FS in Md...
  23. lost pressure on the brakes. Didn't see any fluid leaks. What do you think?
  24. 100s coupe on ebay
  25. The battery tray wasn't silver so...
  26. Bad vibration over 70mph.
  27. Anyone have a 'star wheel' alt adjuster bracket they want to unload?
  28. First hUmpday Carlisle report-->Registration open! May 15-17, 2009 @ Carlisle, Pa Fairgrounds!
  29. body kits?
  30. what weight oil raises oil pressure?
  31. Question for the masses: What is this, and what purpose does it serve?
  32. Update on this local 130kmi CGT I'm thinking about buying as a runaround beater...
  33. ebay stuff
  34. OK what gives????
  35. Crosspost from the 5k forum 'cause I've added to the heard.
  36. Interesting 4kq
  37. Ok, on to the alt. bracket. One small bolt from the front, or a long one from the back?
  38. Can someone snap a pic to show how the PS pump tensioning bracket goes on?
  39. Welp, the CGT we picked up is no more!
  40. CSV wiring question..
  41. X-Post-my early minty 84 Scirocco headed to Vortex for sale-head's up...
  42. Oooh... looky what I found... (must have for future turbo swap people)
  43. OK so I lied... 84's back off the street...
  44. Jerky don't fvck around when it comes to painting his 2.6L!! :-p
  45. New cap and rotor, oem tri-electrode plugs and still getting a miss!!! :(
  46. Arggggg- new noise from under the car when I got home Friday.
  47. Ok to drill bolt out of strut housing? no luck with heat, fork, pressure..etc.
  48. fast
  49. Michael I know you want a Ur-Q, maybe you will consider this?!
  50. headlight removal questions?
  51. Why is it that whenever I try to save $$$$, 84 4kq's falling out of the skies???
  52. 3 spokes sport steering wheel on audifans.com
  53. No wrenching today...but this got dropped off on my doorstep...
  54. advanced the timing, tuned the CO and idle now i back fire a little.....
  55. The days efforts...with some questions...Long...
  56. picture of the back of a H1/H4 Hella, Bosch or Cibie Euro?
  57. Audi Coupe Gt sport shocks
  58. '82 4k w/110k mi. in Dover NH for $699...
  59. Might be picking up a CGT. General things to look out for?
  60. '79 Fox GTI in OK...
  61. Zermatt help....
  62. Weekend wrenching plans?
  63. 87 GT Trans
  64. Was going to advance the timing... some questions...
  65. Are the tierod ends threaded through the strut? Or can they be removed with a hammer?
  66. FWIW, a 85 4000 hood fits nicely in an A6 C4 Avant.
  67. So when does all the Carlisle chatter start?
  68. five speeedlines in nice condition............
  69. Teh 84 4kQ is back on the road!!! And will have a nice weekend trip tomorrow...
  70. Geeee.... I wonder why I'm still single....?
  71. A great "car in a barn" find
  72. need speedo transmission gear 84 4000
  73. side window attachment to metal thingy
  74. This is nuts!...
  75. Wish you a Happy and Healthy New Year Guys & Girls!
  76. Best $20 I ever spent on my Audi...Sheet Metal for Radiator cowling
  77. Whats is the deal with Audi and its power steering fluid...
  78. '87 4000 S coil springs
  79. Is the distributor supposed to have an o-ring or somethin? The o-ring I tried didn't seem right.(KX)
  80. clutch
  81. Lambda Idle Sensor
  82. OT help.. RE: Windoze XP start up...
  83. In reference to my post below, Is the front subframe interchangeable between a 4kQ & CpeGT?
  84. Found my lack of heat problem yesterday...
  85. Well... it's garbage day... and guess where I found the keys to the rally car!
  86. Anyone interested in a front and rear bumper to an '86 CGT? Act now, Act Fast!
  87. Fumes in cab - it's not the heater core - any ideas?......
  88. For those with Jeeps.....
  89. electrical problem solved
  90. Coupe GT hesitation problem
  91. Ok, so I guess I fixed my clutch hydraulics... (Power bleeder ?'s)
  92. Dash harness grounding point - anyone know where it is?
  93. bad electrical peoblem tonight :(
  94. Wheel lug pattern
  95. What's the procedure to align the snub mount properly? Let the car idle & settle, then tighten?
  96. What size speakers fit in the rear deck?
  97. O2 sensor questions (Frank? :P)
  98. I may quite possibly be rejoing the 4kq community...
  99. Source for dash
  100. A small o-ring looking circular spring came with the lower gasket kit. Any idea what it goes to?
  101. Motor Swap
  102. Alternator question.
  103. Are there any of you track junkies or up and coming junkies making it out forThunderhill?
  104. finally going to tackle my much needed alignment but a few Q`s first
  105. Tensioning alternator belt
  106. Trying to remove center console without removing entire dash...
  107. Leather or Wood? got two shift knobs can't decide
  108. Rims
  109. Good deal on some stuff here
  110. Motor mounts.....
  111. Look what found its way into the Audi....
  112. speedo mechanism
  113. The waiting is over.. My R8 is finally here...
  114. Merry Christmas one and all!
  115. Ho-Ho-Horrible price?
  116. OK, how the heck is this tiny bolt supposed to keep the idler pully on the block?
  117. Peek-a-boo...ICE see you!!!
  118. Deer season almost over here... been missing you guys/gals....
  119. Is it wrong...
  120. Someone pulled a hit & run on my '86 CE 4kq last night...
  121. CGT 1/2 of page 26 in Jan 09 Hemmings Sports & Exotic Car.
  122. Safe travels to all for the holiday season!
  123. Looks like potential for a trurbo donor
  124. G11 is blue right?
  125. so I snapped my shift rod off last night. Drove home with a screwdriver down the shaft
  126. The Mille Miglia is the same weekend as Carlisle
  127. Stray condenser w/ broken wire attached to body by the driver's headlight. Any idea what it goes to?
  128. Am I silly?
  129. I STFA.. any BTDT's with removing the brake booster completely?
  130. MERRY CHRISTMAS to all my "AUDI family"....
  131. Does anyone know where ground point #28 is for the dash harness?
  132. Snowy rings.
  133. Nice 84...
  134. Got the A4 stuck last night!
  135. Charging system issues
  136. Ughhhhh... 14 hour 725mi. round trip to pick up the 2.6L short block... got back a 11:30pm
  137. Cold weather
  138. Wasn't someone looking for this? Coupe dash badge
  139. Rear timing cover removal...help?
  140. I love this snow!!!!
  141. i need a 4x108 ronal r8. who's got one?
  142. What does ETKA mean - when there is the paranthesis?
  143. Is the harmonic balancer bolt supposed to have a washer or just goes on raw?
  144. Ebay 83 coupe, $200 starting bid
  145. I think I will end up busting the lower radiator bushing when removing lower shroud nut.
  146. Little Fun... I wanted to share :o)
  147. Speaking of cars and movies... Le Mans was on last night... 1971 w. Steve McQueen...
  148. AudiSport4000 - YGM
  149. Big vibration causing banana anyone?
  150. Attention person with Radio Problems
  151. Back to my flooded out 90....
  152. Flash!! Snow in the PNW and....................
  153. I show the starter bolts at 18 ft lb. That seems a bit light. Is 18 ft lb actually correct?
  154. Made a big mistake...started looking at 4000 turbo pics and videos...
  155. Just made a reservation for 100 at the Market Cross Pub in Carlisle for Friday May 15!!
  156. Since things are slow here... lil 4000 update...
  157. Warm air hose.
  158. Gotta love this. No Audi though.......................
  159. Ouch!
  160. Found my vibration issue!
  161. Why don't I have a snub mount? Broken bracket! Anyone have an A/C-snub mount bracket 4 sale?
  162. Finally met a local Audiworlder...
  163. More window trim clips 811 853 329e
  164. calling 4corners again or anyone who knows about the corner relay >>>
  165. Alternator BTDT question...
  166. Interesting motor for someone who doesn't want to go the I5 turbo swap route
  167. For those with 2b coilovers.. (pic request)
  168. Paging CGTBrad
  169. Paging Ted(inline5fan) YGM
  170. i finally found a souce for new electrical pin connectors
  171. Looks like Carlisle 2009 price rose to $20, camping still $15.
  172. New addition to the fleet, a Christmas gift for the wife........
  173. Ideas for car guy type Christmas gifts for $100 or less?
  174. Did they ever make a 4000 sedan without a sunroof?
  175. Snowing in Portland!!! :D
  176. just a little teaser... ;)
  177. Cibie h1/h4 adjustment screws
  178. Damn, CV boot is torn!
  179. New Photo of my 4KQ
  180. NG Motor...Starved for fuel?
  181. calling 4corners!
  182. rear window questions
  183. Managed to take pics of the 2 junkyard Audis today...
  184. awwww crap
  185. All I want for Christmas
  186. So this is all I have to do to lower my car?
  187. Question:" What happens if the thermostat is fittind the wrong way up?
  188. On the subject of the Laforza
  189. Think the meyle rubber radiator mounts are made in china?
  190. "Brake" light on in the idiot light display. Resevoir is good.
  191. Gas price check? 1.25 in Fort Wayne!
  192. Random question... would an '86 CGT have a manual or elec sunroof?
  193. Decent looking '82 CGT on auto trader...
  194. Just found a sweet pic of a 959 rallying...
  195. What a crime, found '84 coupe and '86 4000q in local pick ur part... :-(
  196. 87.5 driversdoor trim
  197. Oily stuff in the intake boot/TB
  198. For those who have done full builds before... starting point? (motor, brakes, suspension, etc)
  199. Master cylinder issue? soft pedal, brakes locked, expert advice needed!
  200. Heated seat a sucess...
  201. URQuattro at work today!!!!
  202. Couple questions regarding the 4000 transmission...
  203. Will CQ hood fit 4kq?
  204. Crank lock tool is 73.50 w/ tax, worth it?
  205. so how easy is it to replace the clutch cable? it's too cold to go out and look right now...
  206. A small update on life
  207. Red CGT on Rt 940 in the Poconos at the snowboard shop, Anyone here?
  208. AUDI 4000 QUATTRO
  209. still engine rattle
  210. Howdy to all. Just a lil intro.
  211. anyone have a clutch cable or know where to get one for an 84 cgt????
  212. Brick + Windshield = Ouch!
  213. Cant be stock blue 84 4kQ.. looks pretty neat... (NH)
  214. Essica rides again! Woo hoooooooooo!
  215. Who wants to play "name that gasket"?
  216. couple questions...wheels and heated seats related!
  217. CV Axle 87.5 Coupe GT
  218. Got the oil pump out. Should I open it? Any seals in there to rebuild?
  219. Problem with coupe Gt
  220. EPL's 2008 Holiday Specials! (repost)
  221. Anyone in Germany willing to help me buy some wheels?.........
  222. Since I talking alternators, will the 115 amp from the 5ktqm fit the 4kq?
  223. Source for clutch lines? Would like to replace the rubber line @ slave & the feed to the master
  224. In the midst of replacing the timing belt, how the heck do i get the bottom cover off!!!...
  225. Well, we added a new one to the stable this past weekend!
  226. So my alternator belt has been squealing for sometime now, finally snapped on Saturday night.
  227. i decided on one of my christmas presant for my wife.........
  228. yippeeeeeee!!!!!! the cgt becomes a daily driver tomorrow.............
  229. dead 4k :(
  230. VR6 Swap
  231. Photos...
  232. WooHoo my first snow drive in the Quatt .........
  233. Saw an amazing UrS4 or UrS6 today...dude went by rockin' the thumbs up! lol
  234. so is the manual transmission dead (in your opinion)?
  235. Got my tri-electrode plugs today!!!
  236. Hello photos of my 1986 Coupe GT
  237. The person was wrong! Its another 80q and not a 4kq!!
  238. Friday Poll- what do you guys think about bailing out the US auto industry?
  239. PSA kunifer rulz!!
  240. FINAL REMINDER: EPL's 2nd Annual Dyno Day/GTG - TOMORROW
  241. Hey boxerfan......
  242. Champagne 4kq for $400 in my area...should I scrap up the dough and add a 5th to the herd? lol
  243. hahaha!! The 84 passed emissions and now has 2010 tags lol...
  244. Spotted, Red 84 4kq
  245. Any Quantum owners ? Charging question... brakets/altenators
  246. Pictures of the new family member!
  247. Paging 1984cgtturbo: Question about your 84 4kQ
  248. more questions :)
  249. Dare I say it....a possible quattro alternative? (Putting on my flame suit....)
  250. Digi dash into 84 4kQ -> kvquattros how to will be ok to use?
