- 4kq cracked firewall
- 4kQ for under $500?
- Strange Clutch Problem
- inaccurate fuel range reading
- 4kq for Sale
- paging Tony C
- Getting Aggrivated now
- AC: To Convert, or not to Convert...
- for the love of god, i need help!
- I still have parts for sale from 874kq let me know what you want
- After-run on 1987.5 CGT: Mine finally kicked in...
- Project car questions
- On an 86 CGT CE where is the oil temp. sensor?
- Woohoo- look what I got!
- Nothing Serious but I need a lil Help
- Jason : 84CGT contact me! I want your Car!!
- A Suy is trying to sell me a Kamei Ground Effects Kit Pt# 44889 for $699
- saab starter to 4000q?
- How much?
- mother f!@#$% son of a bi@#R% (long)
- Just bought a 85 4kS, noticed some odd problems
- Hot start fix 85 cgt found here.
- Head Gasket help
- About the Door Issue....
- 1984 4KQ FOR SALE IN CT!!!
- coupe gt general questions
- I've got 7 4kq/cgt wheels up for sale
- heater hose?
- Found UrQ For Sale, Should I Buy?
- Wheels and tires, wheels and tires
- Euro Headlights
- Track Experience
- had the clutch replaced on the 4kq
- Overheating question from a newbee
- Picking up a 85 4000s tonight and need advice
- Sport camshafts available from Europe
- Hot Headlamp Switch
- Relay question
- Must sell 16" wineglass whls&tires...Came off 2002 A6 with 1200mi on em....anyone...anyone!
- FS: Passenger Headlight and Turnsignal!!!
- 16" rims+40 series tires (4 weeks old)+thunderstorm+pothole=2 bent rims...
- Hey Dwight, how'd the Audi do at Pagoda?
- is the metal 4kq radiator direct bolt-on
- Source for custom exhaust for '86 4ks (4-cyl.)???
- hey are those rims and tires still for sale? its been a while but i thought id try here first..
- QwikBoost<sup>TM</sup> R134a Performance Additive
- Oil Over-fill?!
- Ok, where'd they hide the trans code?
- NEED HELP- 1986 4000s ignition PROBLEMS!!
- Update on lock situation
- How low is your ride?
- Oil Light on at idle!
- Does your after-run come a lot on your 87.5 CGT?
- I know this has been covered, but...
- Burbling miss?
- 1984 Audi Coupe For Sale
- a few AC questions
- secondary radiator
- 85 4000s dies after start
- Two part... (long)
- The 4k has got to go - now listed on Ebay
- Idle just a tad low or bigger issues?
- Turbo TURBO turbo Turbo. Here is what I have been up to.
- I am looking at the rear R wheel bearing. The wheel made noise and I disassembled it. What is the
- horrible grinding noise on startup
- Dwight V.: I want your seal!
- Old CGT advertisement
- Which Audi Should I Buy?
- yard parts (www)?
- ac compressor
- three questions...
- Horn?
- 87 4kq starter
- Autocrossing results
- back to coupe... waterpump installation hrs?
- Water pump, radiator questions...
- Power locks and Odometer
- MC1 vs MC2
- Another question (Starting and idle issues)
- Audi 4000CS Quattro 1987
- Vaccume Can, Leak
- duandcc, did you get my email about the window seal?
- AudiSport4000 (Interior comment)
- Problem discovered today, while in traffic. HELP!
- Need opinions (2-part)
- What on earth is that smell? Answer inside.
- Will Spark Plug Wires meant for a 85 4000 fit on a 84 Coupe GT
- Fuel Pump (5000T on a 4kQ?) And car detail (new to group)
- Seat question
- So, Dwight, I was flipping through....
- NF/NG engine mixup?
- windshield washer problem
- transmission differences
- 1984 4000S: SOLD
- Tire problem w/Bridgestone & Review of Dunlop Sport A2 (long)
- Speedo Question
- need Four 14' stock 4 x 100 wheels
- Audi Car Club nationals event info is on-line
- Its alive....
- Speaker confusion...
- Control Arm Bolt
- Turn signal flashers
- Tools
- proportioning valve
- Window seals?
- Headlight bulbs?
- Power antenna question/problem..
- Questions about the 84 4000S.
- Needing help on Coupe GT Starter
- Febreze on the interior? what could it do to the old material?
- Ignition Question
- Need Help with oxygen sensor
- Oil Additive Recommendations???
- Digital Gauge
- Bought a UR Quattro for $2.99 !!!(no typo-two dollars and ninety nine cents)
- Quick hydraulic clutch question
- Digital Dash Question
- More CGT's
- Ronal offers 14-17" wheel/tire packages...4x108
- 84CGT Engine Code
- Coupe GT CE on E-bay @ $530 now
- Here's one I've been holding off on asking...
- SPAX PSX KIT
- crank case breather hose
- brake lines...
- nice try, god! (longish)
- Oils in my air box, wtf?!
- WTB/TRADE FOR: 1985 to 1987 4000!
- Ok, got the times back from my first autocross event...
- When turing the AC on.. if the slider thingy (lack of better word)
- Need parts for 1987 CGT (1985+ 4K parts would work too)
- Hydraulic Clutch Overhaul
- Help again update
- Rust issues (aka car cancer)
- Curious, And im sure it's been discused...
- Help Again
- By searching the archives it seems 12 degrees of timing is about right...
- Diff oil?
- ok guys......my 4kq needs some stuff :(
- FS: Audi Coupe GT Digital Gauges
- Shift Linkage
- I got caught drifting...
- Alternator Help
- Spark plug wires.
- Would these cars be good for amateur rally?
- Voltage Regulator Update
- Whats a "Baffled Oil Sump", and whats the highest degree camshaft i can get?
- Knocking with startup gone.
- CV Joints on a 4000, Pain to change?
- Has anyone their own done a rear wheel bearing on 87 4000?
- White CGT spotted with white leather?
- Setup and shakedown day is done, this car handles wonderfully!
- I have a 4E badge on the right side of trunk, what does it mean? TIA
- what do ya'll recommend for high performance for a audi CGT
- DIGITAL DASH PROBLEM!
- Anyone ever try to put a G60 supercharger on their 1.8L motors?
- AutoXers, I'm setting my pressure at 42 all around to start for the first run...
- Early 4000 steering wheel vs. early Coupe wheel
- Just added a new toy to my driveway.......
- Need Help
- does the 4000cs quattro drivetrain fit a CGT???
- R134a conversion didn't happen
- Oil light question... (long)
- Nice Coupe GT/4000 non quattro wheels on eBay
- Just purchased 1986 4000S quattro 5cyl. Questions.
- Can anyone reccomend a cheap online bosch dealer? plugs etc.
- New problem
- ISV Cleaning?
- 2 Part Problem
- can someone tell me what the c and the s mean on my 4000cs?
- Reset of OXS Switch
- Hot weather is just around the corner...how is your A/C ??
- An Odd button?
- Kudos to Ken
- overheating?
- New UR-Q development articles posted
- Do you need parts for your Audi 4000? Headlights? Whatever? Email me with year and model!
- Where can I get parts for my 86 4000cs.
- 86 5000 cs turbo
- Everone needs to see this
- Thought I would re/re tie rods today....
- Back from Las Vegas....OT
- WHO WANTS AN '87 4000CSQ?
- New website for So. CA. audis/VWs
- 86 Audi 4000cs won't start. Need help!!!
- 4000s Quattro new owner any advice on modifications
- Too much body roll
- Is this normal??
- Do I need to flush the radiator? Temp sits above the half normally
- Cibie eurolights on Ebay!
- VIN lookup
- CTG starting problem- Part Deux
- clutch master rebuild
- What weight?
- looking for CGTCOMM86
- Knock Knock Knock
- european car
- Bling!
- CGT starting problem
- Replacing the Radiator Fan
- Boge question..
- Cheap Bentley Manual
- coupe gt tranny rebuild??
- IS 42 degrees good enough?
- 85 4000 S I got a 4 cyl but don't know which one, what types of engines could this 4000 S have?
- 86 Coupe Redline? top speed? kinda long....
- '83 4000E wiring question
- fuel pump relay part #
- Door Lock Question
- fuse panel
- Looking for a 4kq trunk spoiler in Zermatt Silver...
- ok...
- thermostat issue...
- Rear transfer case
- I need more HP and Torque!!!
- Hello, and could someone please direct me to the parts bin....
- Anyone put another interior light in? Like on the pass side B pillar.
- Need suspension help
- Anyone know if an Audi 5 cylinder diesel will fit in a 4kQ?
- rough idle&very poor throttle response when cold
- Loking for wheels
- slave cyl on 4kcsq
- Summer is near, which type of oil do YOU think is best?
- Hiccups when hot?
- Misc. I5 parts.
- "KX" Oil pump!
- 1986 "KX" Pistons & connecting rods?
- Best Plugs?
- Many thanks plus Radiator Fan Questions
- Gas gauge N 02 sensor q's
- Sorry for all the pictures...
- Bad Gas?
- For sale: Rare AWD '87 VW Quantum Syncro Wagon $2,595 VGC Fully Serviced, New Stuff, Check it out...
- Wheel Problems
- I need a winter car for VT snows.....I dont want to spend more than 4 or 5 thousand....
- Need some help and any suggestions appreciated..
- Sway bar question
- Anybody parting out a 4k/CGT?
- Struts ?
- hesitation
- Is the temperature at 100 degrees celsius (212 F) too hot?
- Help with burnt out (?) speedometer
- Eek! A 20VT stuffed into a CGT!
- Multi-speed Radiator Fan?
- Is replacing the front speakers worth the trouble?
- Updated 84 pics...
- Coupe on Ebay
- Exhaust Question
- Audi cgt wont start after new vacuume lines
- Spring cleaning done, and I have the pics to prove it...
