- '85 CGT front subframe rear bushings
- Fuel System in 1981 5+5
- 1984 3 speed Automatic transmission
- Etch
- 86 4000 quattro fuel leak from airbox
- Replacement of vacuum advance for Coupe GT
- Headlight swap
- How to identify 85 CGT engine
- reverse light and brakes like
- Audi Fuel injection
- 1987 Audi 4000S
- 1984 4kq: Resurrection
- 1985 4000s wont keep running
- 1986 Audi coupe GT - Coolant lights comes up on acceleration
- Forum Rebirth
- Four spoke steering wheel
- Coupe GT - buyer
- help with headlights
- Audi 4000Q (been sitting for 4 years)
- H and R lowering springs and bilstein strut
- New owner - 1986 Coupé GT
- Brake line flare for 1986 Coupe GT
- Low beam headlights
- Will 17x8 et 43 wheels for on a coupe gt?
- Check out my 85 4000s
- 1986 Coupe GT Brake Lines from Brake Pressure Regulator to Master Cylinder
- Coupe GT shift finger
- 86 Audi4000cs quattro Gauge Cluster
- For Sale: 1987 Audi 4000 Engine, Fuel System and Exhaust
- looking for doors for an Audi 4000 w/vent-windows
- audi 4000 parts
- Performance Exhaust GT coupe 86 ?
- Engine wiring help!!
- Audi 4000 Door Handle Retrofit?
- FOR SALE: 1986 Audi Coupe GT
- Need advice guys
- Anyone selling coupe gt
- sell steerling wheel Audi GT Coupè
- 87 CGT coolant temp issues
- 4000cs quattro throttle issue
- CGT tstat housing stuck?
- 87.5 CGT SB rescue
- Black Friday/ Cyber Monday deals from Car Parts Discount
- New 4000 to me
- 4000s Quattro IAC Bad
- Audi Coupe GT floorpan vs Audi Coupe Quattro floorpan
- 87 Audi 4000 S Check Engine Light
- Quiet(er) Radiator Fan Suggestions
- WHAT NOW!?!
- Special promotion for Audi World Forum members
- Forum group buy with Car Parts Discount
- Bleeding brakes '87 4000s (FWD)
- Air flow meter/fuel distributor swap
- Rear end noise in my new to me Audi 4000s
- Need help finding A/C Low Pressure Valve Port
- Bad ignition coil?
- Water Deflector Restoration
- My '87 4KQ Project
- Special promotion for Audiworld members
- fuel sender resistence
- 1987 Audi Coupe GT 1.8i engine transplant options
- 1987 Audi GTT Coupe
- wheel options?
- Reliving the Dream
- 1986 Coupe GT front and back bumer removal
- WTB: Gauge cluster from 2.2L 5-cylinder
- 1986 audi coupe GT C/E
- ppoida's 1982 Coupe GT 5S
- At last, a dream come true! My Coupe GT...
- 87 GT Coupe, want to make manual trans
- 1982 Audi coupe gt
- help with 87 2.2kv auto coupe gt stalling in drive
- Only left side signals flashing when hazard switch is on. (1985 Audi Coupe GT)
- help with 87 quattro 4000 cs
- '86 coupe gt won't start when engine is hot
- 86 Coupe GT flooding + won't start
- Radiator fan not working AND both temp gauges reading low
- '86 4000cs Quattro for sale in Colorado
- Audi 4000 CS Quattro Illustration
- Help Help Please: Adding Freon
- 1986 Audi Coupe GT - Parts
- New Coupe GT Owner
- lowering question
- 1985 Audi Coupe GT Automatic cranks but will not start
- '86 4000cs Quattro alternator?
- Audi Coupe GT 1985/ 2.0L 5CYLINDER AUTOMATIC TRANSMISSION
- 1987 Audi 4000 CS Quattro
- '86 Coupe GT smoke
- 1986 Coupe GT - photos & introduction
- Transmission rebuild
- Engine removal
- Quattro finally met its match?
- 87.5 Special Build CGT for sale soon.
- seat fitment question (audi vs vw)
- New owner with a few questions
- Setting ignition timing problem
- 4000cs running too lean, no power
- audi coupe gt for sale
- Bent rims
- best and most simple way to secure car
- need parts Audi coupe gt, front body parts
- NEED 4X100 HUBS
- Successful window regulator rebuild
- need advice :(((((
- CONVERTING REAR DISCS TO BACK TO DRUM
- NEED HELP IDENTIFYING PART NUM PLEASE HELP
- First Car 4KQ
- wheel change (need help)
- coupe gt front end problemt
- handbreak sticking
- need advice in regards to wheel changing
- 1987 4000cs Quattro for sale or parts
- buying parts
- need advice
- common faults with coupe gt
- NEED HELP ASAP
- Stuck injector tip (cap, aircap, hat)?
- Introduction
- Dumb question but here goes
- Mystery Light
- 5000tq engine into 4000s
- Exhaust Fit?
- For Sale 85 4kQ race prep 10VT and AAN/01E ready to install
- Reading spark plugs
- Replaced fuel lines for 1986 Coupe GT
- Need hand brake parts for a 1986 Coupe GT
- my Coupe is available
- Audi coupe gt 1987.5 swap
- A few problems with my 1987 Audi 4000CS
- Audi Urq/CGT T shirt group buy!
- 85 4000s for sale
- Kostal Wiring
- 4000CSq "Michelle Mouton Commemorative Edition"
- Outer window scrapers
- 85 CGT CIS probs
- New to me 87 4000CS
- Fuel line troubles
- Hey guys new to the forum
- Some jerk hit my car
- 87 4kq refurb
- Fuel Pressure Regulator Bosch part # 0438161010
- 1984 Audi 4000s Quattro for sale
- a/c belt adjustment on 1985 4000s 1.8
- New Guy With QUazzy Thoughts
- rebuilding a 2.0 10v
- 87" 4000cs Swap?
- The Great Fuel Debate
- Replacement intake boot options
- Front strut ? 4k-CGT
- Oil pan/sump gasket
- 1986 GT Coupe suspension upgrade question
- 85 CGT Wont Start - HELP!!
- Fuel System - 86 GT Coupe
- Blank key for 86 Coupe GT
- Going to look at a 1983 Audi Coupe Gt
- newbie with a coupe gt5s
- I need help once again
- Audi 4000S Help
- IDEAS PLEASE!!!!!
- im swaping the 2.2 n/a to 2.2 i5 turbo...auto tranny 2 5 speed swith? what to change
- Things to look for in a 4000
- What Tools, What spares.
- headlight re wire
- 80-90 psi oil pressure a bad thing?
- Dash switches
- bye bye CIS-E, hello 4 barrel carb
- Help with tail light corrosion
- interchangeable parts with vw ABA?
- Does anyone ever...
- For Sale: 1987 4000CSQ
- Help, need a shifter boot for a 1983 MK 1 Coupe GT
- FYI: cheap 'n easy rear disc brakes for the Coupe GT
- Erratic timing
- Anyone know the name to this part ?
- 4000 Quattro 2.7t swap
- Question about 1987.5 Audi Coupe GT
- coupe problem
- Bell housing question, b2 trannies cant bolt to anything?
- Tail light out but brake light works
- Brock Yates - 1985 Audi Cannonball Quattro
- temp sensor sender 4000q.which is which
- anybody in british columbia?
- It's 10 degrees outside... where's my heat!?!
- couldnt pass up a deal on a 2.8 30v, can it replace my i5?
- Coupe GT runs rough
- bad water temp sensor or bad fuel pump?
- Ignition timing help! 2.3 NG
- dropping in 2.2 turbo i5 from 89 200 5000 into my 85 gt coupe. wirring the same?
- Swap question, what will go in?
- Fuel pump relay hunt
- audi gt soupe 4000 1986 dash/?
- Hans Auto Parts, Cheap oem VW/Audi parts
- DigiDash repair/replacement, getting desperate.
- New 87.5 GT member
- what motors can i drop into85 gt 4000 coupe?
- HELP - Very poor running and other weird behavior - 4kcsq
- 82 Coupe GT runs fine, then stalls randomly.
- Picked up this little beauty today!
- Spring Question
- another no start question
- New to AudiWorld; A few CoupeGT questions
- 2 set Wheels for sale 15 inch Ronal 28 plus original wheels redone with snow tires
- 1986 Coupe GT refrigerant pipe problem
- Starla mufflers, opinions?
- New member inside ;-)
- Need help with identifying what is below the brake master cylinder
- Remove and press wheel bearings while still on the car
- Pressing sway bar link bushings without removing the control arm
- 4000CS Strut mount replacement help!!!! Cv in way.
- idle stabilization valve? fuel pressure regulator? vacuum leak?
- Car not starting properly.
- 1984 Audi 4000s for sale
- cluster lighting and guages.
- What's wrong with this picture?
- 84 GT Coupe for sale
- Mystery wire
- Right front axle tips and tricks???
- Audi S2 steering wheel
- Does an Audi Coupe quattro 1990-91 suspension fit an Audi 4000 S
- Looking for a some parts and some answers...
- Timing belt idler?
- another engine swap question
- Heated air flap on air box
- car somtimes shuts off and after turns on.
- Almost on the road (82 Coupe)
- Fuel system issue?
- Window regulator
- 10v Turbo Intake Manifold
- quattro windshield fit an 84 4kq?
- DIY fuel injector cleaning?
- Trying to fix rough idle, quesiton on CPA amperage
- Any thought on converting quattro tranny to fwd
- 1982 Coupe 2.2 L5 10v turbo conversion
- Any source for the rubber intake boot for 1.8L 4K VW fox or Quantum use same boot
- Part # or cross for filter between tank and pump on 84 4000S 1.8L
- Anyone know the actual part # for :
- Timing belt
- Turn signal relay
- Help! My 86 coupe gt wont start!
- Identify missing connector(s) behind glove box
- automatic shifter linkage problem..
- Coupe GT front brake conversion
- Need help finding a part
- Morning, and hello..
- Pre 7a swap thread
- FS: 1987.5 Audi Coupe GT "Special Build"
- Rear shocks.
- CV shaft dilemma
