PDA
View Full Version : A8 / S8 (D4 Platform) Discussion
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. New wheels+ rear suspension adjustment
  2. Bleeder valve on 2017 Audi S8
  3. Need Help Regarding Leak
  4. Replace Audi A8L grill 2014 A8L 3.0T
  5. Need purchasing advice
  6. Center Caps - With or Without?
  7. OBDeleven OBD2: "ACC and Audi Brake Guard assist not available" cleared?
  8. Vibration at 60-71MPH
  9. A8 W12 2012 D4
  10. Buzzing Sound from Car Driver's Door
  11. A8L tires: 265/45R20 v 265/40R20?
  12. Serpentine belt change
  13. SRM TCU gains
  14. Engine start system fault! Please contact dealer
  15. Insurance Claim for Water ingress (windshield)
  16. 201a audi a8l quattro
  17. Thermo fans activation
  18. Factory Sport Exhaust
  19. Transmission Malfunction Keep Driving
  20. Help coding heated steering wheel
  21. Actual/Real mileage information
  22. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  23. Coolant leaking regularly
  24. Wire harness part # for parking aids and ACC
  25. Battery drain
  26. audi A8 D4 start stop problem
  27. 2013 S8 with multiple misfire and Camshaft adj codes
  28. HPFP seals...any kits that include the internal seal?
  29. Borescope Checking Turbos (Before Warranty Expires!)
  30. CWA150 aux water pump on D4
  31. AE: MMI Radio not working
  32. HEADLAMP QUESTION....
  33. Auto high beam not working
  34. Mystery Hole
  35. 2013 audi a8
  36. 2013 audi a8 air suspension problems
  37. Replacing Front Struts
  38. If you aint breaking stuff you aint making enough HP.
  39. MMI Screen Brightness
  40. No auto high beams on 2010 A8 full LED ?
  41. Oil in turbo
  42. I still think the bTres is my favorite mod
  43. Center cap opinions
  44. RH high beam flickering, Light Malfunction (2011)
  45. A8L locked up...unable to start...
  46. STAGE 3 S8 HP NUMBERS?
  47. Where should I start looking for a coolant leak?
  48. New issue, sunroof dont open
  49. 2013 A8L 4.0 coolant temp sensor location
  50. 2013 A8L 4.0 coolant temp sensor location
  51. Thats it, im done..... probably
  52. Rear View Mirror Sensors etc
  53. Rolling back a digital odometer
  54. DPF regen tool.
  55. A8L running the tail of the dragon in NC
  56. Battery tender hookup points.
  57. 2012 a8 quattro static from front left dash speaker
  58. Moving from Air suspension to DRC?
  59. Steering wheel defective
  60. Lower RPM Noise
  61. Cold weather noises
  62. 2012 W12 sport package arrived!
  63. 22x10.5 et27 - Tire Size Dilemma : 265/30 / 285/30 or 295/25
  64. PL: Breaks?
  65. USB upgrade/cupholder
  66. Bedsprings from the from end....
  67. SE: How many hours to change front upper control arms?
  68. Michelin Pilot Sport Acoustechs
  69. Rear seat entertainment control from front?
  70. Bluetooth Synced Cell Phone
  71. My S8 ALMOST gets roasted on Youtube
  72. Mirror Controls not working
  73. A8 adding a qrt of oil every 1865 miles?
  74. Oh just a random cold start video, nothing impressive
  75. Overhead console removal
  76. I crashed the Christmas Parade
  77. received text message from my dealer regarding Turbo oil filter (CODE21H7) change
  78. UK: Lots of errors!
  79. Rear Armrest Catch
  80. Heating or Cooling Surge on Acceleration
  81. Warranty expiration clarification help
  82. ZF 8HP90 transmission advice
  83. Coilover conversion help with suspension dash lights
  84. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  85. UK: SOUND UPGRADE FROM STOCK
  86. Air duct to air filter
  87. S8 D4 - Soft touch door
  88. I HATE these kind of drivers!
  89. Engine air filter change and intake pipe replaced
  90. Wanted to see how low it could go!
  91. Remote start installed
  92. Snow Tires and Wheels for S8 with V10?
  93. Another trasmission thread - S8
  94. Bluetooth track change steering wheel?
  95. 2016 s8 window control from remotes?? Obd11
  96. 2016 s8 obdeleven ride height??? Help
  97. Electrical feed back noise with engine on?
  98. Backup camera not working
  99. Air suspension fault - C11AF F0 [009]
  100. D4 S8: any use of the MMI port in the armrest box?
  101. Torn between 2 cars. Need to decide in by tomorrow
  102. Seeking recommendation of an Android Auto / Apple CarPlay box for the A8/S8 D4 platfo
  103. Level control fault C11AF F0 [009]
  104. tires , tires . don't go cheap
  105. Well, this happened last night..
  106. Pre-purchase inspection found oil residue on turbo lines on 4.0T
  107. Vacuum hose/connection?
  108. D4 related but its more about a Porsche 911 Turbo S
  109. Rear Sunroof/Sunshade Problems!
  110. Took my s8 for oil screen recall….
  111. 2014 A8 4.0t Coilover swap
  112. Screech and grinding sound when moving
  113. Cracked intake pipe
  114. Replacing Bushings
  115. Sunroof issue
  116. A8L - excessively loud highway him. 22x10 w/. 285/30 Nitto Invo
  117. Audi Farewell - For Now
  118. Front suspension noise over speed brakes
  119. A8L Quattro 4.2l 2022
  120. New Key Fob Shell DIY
  121. D4 2013 S8 front air struts
  122. Air Ride Compressor Relay Location
  123. Replacement Wiper Blades?
  124. S8 MY 2014 car cover?
  125. Anyone seen the new SRM TCM system?
  126. Looking at buying a 2014 A8L 4.0T - oil strainer recall on Carfax
  127. 2013 S8 Transmission woes
  128. JB4 Group 11 1/4 Mile Time - 17 A8 4.0
  129. Audi 2015 A8 TDI 125,000 miles radiator fluid
  130. Which service manual should I get
  131. Suspension control arms/bushings, which ones typically needs replacing first?
  132. Air Filter without fleece sock
  133. Oil Screen video from MAG Audi (my car)
  134. O2 Sensor Help.
  135. Bruh.. Sad Day 😔
  136. Turn Signal Problems
  137. Power Steering Fluid
  138. D4 2011 4.2tdi not blowing hot air in cabin
  139. AppleCar play not working.
  140. CarPlay in 2017 S8+
  141. UK: NEW Audi S8 D4 2014 owner
  142. Custom seat belts
  143. Air Suspension Fault
  144. Car randomly dies- weird.....
  145. Audi exclusive rear seat foot rests
  146. Chrome delete 2015 Audi A8
  147. ACC, parking sensors, AMI problem
  148. Disabling ANC for Bose System - Coding Question
  149. 2012 A8L Air Suspension calibration problems
  150. D4 Winter wheel/tire setup for sale
  151. 2012 A8 DRL not working
  152. New meth system and TS1 turbos in!
  153. ACC, Main beam assist, air suspension faults
  154. Audi of Nashville
  155. Continued suspension issue - front not venting
  156. HomeLink not working from 2016 A8
  157. Considering APR Tune
  158. Oil leak
  159. Oil leak?
  160. Power steering pump failure
  161. Dynamic Mode, Launch Control, Harsh Shifting
  162. S8 stage 1, stage 2, stage 2.5 dragy results
  163. D4S8 Upgrade opinions
  164. ACC BRAKE GUARD / active lane assist all unavailable.
  165. transmission mount insert - 3.0 gas engine
  166. Audi B8 CVT Transmission Compatibility
  167. Tire pressure?
  168. Soft close doors
  169. “Brake servo” error message
  170. Problems with TV signal
  171. Overheating no coolant loss
  172. A cpl gallons of E85
  173. Cete Module Installed
  174. UK: Front control arm bush part numbers?
  175. Trade up to S8?
  176. Audi A8 4H 4.2 tdi turbo sensor
  177. D4 platform curb weights and weight reduction.
  178. A8L (2015 D4) Pass rear door, NO POWER!
  179. 1/4 mile passes - Stock Base Line - 17 A8 4.0T
  180. 2016 A8D4 3G and additional accessories
  181. Ride Height Sensor Replacement process
  182. MY: 2011 D4 3.0 tdi owners manual?
  183. ACC and Line Assist not work
  184. Front seats move forward/back a fe mm - Has play in track
  185. Catalytic Converters/O2 Sensors - PO420 code
  186. UK: strange suspension problem
  187. Oil Filter Drain Plug
  188. Yours roll back/forth a fraction when you stop? Also have a seat rocking issue.
  189. IE: Audi A8 Service intervals with parts to be replaced
  190. Wheel swap?
  191. Anyone have broken B&O tweeters laying around?
  192. Grill Fitment Question
  193. 2016 Audi S6 or 2017 Audi A8 sport
  194. Recall completed
  195. New Owner Wheel Fitment Question
  196. New owner, have some questions
  197. Rough running with codes (both banks too rich)
  198. Rear seat removal S8
  199. Tune 2016 A8 V6
  200. D4 A8 4.2 bounces at stop.
  201. 2012 S8 Slow Fuel Gauge
  202. Bad steering rack at 26k miles 2017 4.0
  203. Staggered 22 inch Wheel Fitment help 2015 Audi S8
  204. A8 D4 MMI motor disable
  205. Seat belt not staying "clicked in"
  206. Audi Smartphone Activation
  207. Lemon Law Buy Back - Should I or Shouldn't I Buy?
  208. Trunklid spoiler : Maxton Design
  209. Rear upper control arm replacement
  210. A8 Parts Diagrams, search results and worthless commercial posts
  211. Passenger Door Lock won't release
  212. Climate control unit wiring diagram please
  213. Help!
  214. Transmission fluid change
  215. A8 W12 (2012) How do I access and replace my PCV Valves?
  216. Removing Inner Rear Tail Light Assembly
  217. 17 S8 - oil separator required when turbo screen is being replace?
  218. 2013 Audi A8L 3.0t pcv valve replacement
  219. Scheduled my recall.
  220. To Recall or Not Recall
  221. A8 service schedule based on miles
  222. Trans mount upgrade for 3.0?
  223. A-8 Air suspension
  224. 2014 A8 help with "entertainment is being initialized. Please wait."
  225. 3G to 4G anybody?
  226. Low mile 2012 A8L. Vs 2015 A8L
  227. Cyl 8 Misfires, Oil on Spark Plug Electrodes
  228. Should I go stage 1? Or 2? or neither?
  229. BG: AUDI A8 D4 what is the most reliable facelift engine /petrol/diesel etcs?
  230. I need your help on suspension..m
  231. Coding for #34 Level control after Reset all adaptions
  232. MMI 3G+ second AV input?
  233. Changing the factory 10' sub
  234. Need Tire Recommendations 265 40 20inch
  235. Rearview Mirror
  236. Thinking of Trading 2017 S8+
  237. Potential New owner looking for some guidance
  238. Advice looking at 2017 A8L 4.0T
  239. Jack Pads
  240. Driver side window replacement
  241. VN: Audi A8 2011
  242. Taillight wiring
  243. A8 D4 2011 voltage stabiliser fault - no communication
  244. Just in
  245. Audi A8L 2012
  246. 2012 Audi A8 D4 air conditioning?
  247. Passenger seat adjustment at speed
  248. D4 Audi A8l Wheel Sizes & Tires
  249. ACC stopped working whilst driving! But fix was the cheapest ever for an Audi...
  250. Coolant temp/level issue
