- 2013-2015 s8 search is on
- Neutral Idle Control Activation?
- Maintenance work plenum chamber cleaning
- SRM intake removal of bottom half of oem airbox
- Cooling options for my stage 2 s8
- A8 3.0 tdi quattro DPF Problem
- Sound question
- Equipment Listed in My Audi
- 2017 S8 Plus Mid Muffler Delete and Rear Muffler Delete
- Advice on buying 2013/2014 S8
- SSP for NA D4?
- A8/D4 Bose Sub-woofer Replacement
- Parking Heater Key
- Guide link replacement question
- Anyone know where I can get a used offside wing?
- Apple iOS 13.x MMI / AMI Issues
- 3k-4K boost hiss
- 2015 S8 Looking for Front bumper optic black grille
- What do you think about air struts from a used Audi?
- 2013 A8 3.0T
- TANK SYSTEM MALFUNCTION-CONTACT WORKSHOP
- Help: Coding Rejected error 31 request out of range?
- Possible RSE, Extended Leather, 4-seater Interior Sale
- Cruise control causes turbo flutter/surge
- "Courtesy Closing Door" Feature? 2013 A8L
- Driver side door switches not working
- Vibration at 65+ MPH and new tires.
- The search begins: '16 - '17 Audi S8
- Exhaust tips
- Panel Removal
- Logging boost
- Sport Differentials fluid change FYI
- New to the S8 community.
- A8 Tdi - Sport package vs night assistant?
- 2012 A8L Intermittent Starting Problems
- Considering selling due to 4.0 turbo issues, what next?
- 2012 front pad replacement
- Internet Access via onboard WiFi to Apple iPhone
- A7 Tires on a D4?
- Partial throttle boost surge with srm intake
- D4 A8L 4.0T Pre-Facelift Modding?
- Couple of issues with my (new to me) 2011 A8L
- Need Help with 4.0T Transmission Hard Shifting Issue
- Car doesnt act to remote from one of the keys
- ‘13 4.0T slight rough feeling at low speed driving -VCDS scan results
- Maintenance Items 2013 A8L 4.0TT
- S8 Stage 3 Build Completed!
- Audi S8
- Talk me off the ledge on an S8 Plus!
- Front Suspension Question
- Question about MMI update and rear seat entertainment
- 4.0T Turbo Failure Prevention
- Sputtering when I start the car
- Audi A8 D4 MMI Issue.
- Black emblems
- Are stock mufflers restrictive?
- TDI Questions
- Undertray clips
- Wheel question
- Will a Lowering Module Void My CPO Warranty
- Best Leather Cleaner
- More Audi EPA Fraud: faulty fuel economy affecting many D4 S8's, W12's & 2015 4.0T's
- Starting issue
- Tires or Maybe A Steering Issue?
- Selling my 2013 S8
- S8 apr stage 1 to stage 2 with srm intake
- Selling my 2017 S8 Plus with 16K on her
- Incorrect Software Version level control module
- MMI updates
- Do I need map update with Google Maps?
- Need expert help identifying an oil leak on S8
- Rear Brake Release
- First time D4 S8 Owner (2014)
- Audi 3G+ MMI Video playback from SD Cards guide
- 2017 S8 Plus - New owner
- Which cooler/condenser is leaking?
- Bluetooth switching
- Looking to buy a higher mileage D4 A8 - advice?
- A8L TDI After Emissions Fix
- Long coding matrix headlight in OBDEleven
- D4 S8 wheel confusion
- Rs7 exhaust on an S8?
- replaced comfort control module, cant sync the keys
- Aftermarket Cooling Install (2013 A8L 4.0T)
- CarPlay and Mirrorlink retrofit DIY project complete
- Sirius Traffic Information
- S8 stage 2 engine air filter options?
- New squeek in front suspension
- console under armrest removal - add USB port
- Audi A8L D4 Bose Sound System Coding numbers needed.
- Using Siri
- 2013 A8 3.0 Oil Leak?
- Weird steering issue
- MMI 3GP update 2G service to 3G
- Replacing Battery and Latest MMI Software
- Replacing stick rear cans only on S8
- Stitching coming undone in diamond pattern on driver seat
- What setting is correct for putting this car on a lift
- 2015 Auudi A8 D4 Panoramic Sunroof Roller Shade
- Adaptive Corning light bulb replacement
- Car is not feeling the horn any more LOL
- Purchase advice
- VCDS help
- Brake Pads warning light
- Recommendations for 75k Service - Chicago/Western Suburbs
- Suspension too stiff
- Just picked up "Manny's" D4 (vancouver)
- Another Emissions Fix/Action for 2014-2016 3.0L TDI
- Buzzing/vibration in gas pedal
- Clear Corner Headlight Lense
- @015 A8L 3.0L - Aftermarket Sub Feedback Issues
- Gearbox problem
- 2011 A8L VIBRATIONS IN FULL TURNS. HELP PLS.
- 2011 A8 D4 Coolant Leak
- Considering trading my '14 SQ5 for a CPO '15 S8
- Suspension Fault
- Brake warning light
- 3.0 downpipes.... CTS Turbo
- Fixing Front Cup Holder Cover (tilted) ?
- PPF Center Counsel/Piano Black Trim
- VCDS or Links
- 90K Service Interval 2014 A8 4.0/Rotor Size?
- Whine
- Any recommendations for a really good Audi mechanic in the Chicago area?
- Android Auto options on 2013
- another 2013 A8L 4.0 twin turbo failure
- Linking up
- 2013 A8L 4.0TT - Yellow suspension light and tire change mode
- 2014 S8
- AC blows cold air occasionally
- Intake air temperature sensor 2 (G299)
- APR down pipe replacement?
- P2096 Check Engine Light
- Nashville area
- Off-roading: A8 Quattro or Toyota Tacoma?
- Whirring noise A8 D4 2010
- 2013 S8 battery dead
- Brake light just crazy
- What is this for?
- help with vcds scan
- Outer edge tire wear?
- Audi recall
- Time for brakes
- Does the dual pane glass option make that much of a difference?
- Any recommended Audi mechanics in Maryland?
- Cool Feature - Center Vents and MMI Voice Commands
- carrista faults 00766 00767 front vent sensor
- Door locks - Is it just annoying, or is it "A Problem"?
- New audi owner
- Is it possible to have screen mirroring for our MMI?
- Best Carbon Ceramic Brakes and Pads
- Sports Differential Modes
- Quietest riding 20 inch tires
- Where do you keep your key fob while driving?
- BLUETOOTH Problem!!
- Undocumented Fault Code 89H/137
- Selling my "Winter" wheels and tires. Then the car
- oil filters for a 4.2 engine
- coding air suspension
- Europrice - New Website - New Products...
- Brake Pads/Rotors?
- Need help
- (Help) Newbie - Would you buy this 2014 Audi A8?
- 2013 A8L 3.0T standard
- A8 with Splash Guards
- D4 off road?
- Hot Country !?!?!?
- 2015 S8 Front Caliper issue. DO NOT REMOVE TO TORX SCREW THAT HOLDS PAD. ALSO KNOW
- A/c issuse
- Help me to better understand drive modes and ride height
- D4 last platform for SWB S8 in the U.S.
- VCDS vs OBD11
- Looking at 2015 CPO--axle replaced????
- Compression Dip At Speed Causes MMI Screen To Retract On Its Own
- Brake pads warning
- 2013 A8L TT dreaded yellow suspension light need help
- APR Stage 2 upgrade worth it?
- 4.2 tdi not starting when warm
- Amp install upgrade to Bose system
- Amazing mpg
- Timing chain drive tensioner noisy
- Blown turbos
- 2011 4.2, intermittent P0420 code
- Lost all SiriusXM presets
- 2014 t mobile va beach
- ACC, braking guard, and lane assist unavailable
- 2017 black dash inlay replacement
- Hello
- oil smell, and oil level warning
- Help with 2012 Audi A8L manifold actuator
- Audi towing mode
- Audi Wheel Lock part number for D4 S8?
- A8 to S8 with more miles?
- Audi a8 4h ambient light
- EPB Failure after replacing battery
- Cabin outside air vent location to deodorize
- Smoke from engine bay 3.0 TDi
- Some info about A8 D4 MMI
- 2013 A8L 4.0t
- How Good Are D4 Headlights?
- 0378 - Coolant Circulation Pump fault
- Intermittent Pinging Sound: Front Passenger Suspension
- 2013 Audi A8 Base v6 Sway Bar Bushing Size
- Need PPI Recommendations
- 2011 Audi A8 4.2 TDI
- replace MMI control unit 2012 A8
- 0 Satellites
- Iridium vs platinum spark plugs?
- (Dilemma) 2014 E63 (non S) or 2013 Audi S8
- Audi extended warranty for PCV letter.
- Looking at D4 W12
- 2013 Audi A8 D4 Nav Offroad
- AMI not working
- ACC stop&go time to resume driving
- Audi A8L D4 3.0
- How reliable are these Audi's after 100k? Do they become money pits?
- getAudiparts.com | Genuine Audi Black Rings Sets!
- Help with a newly purchased 2016 CPO
- Would a 12' Audi A8L with high miles be an okay purchase?
- Intake Manifold Flap - Bank 2
- "Knock" or "Tap" through Gas Pedal
- Coming from an S4
- dust coming from vents
- 2016 A8L AC Refrigerant - Freon R-22?
- 2013 Audi A8L D4 Door Panel Removal Help
- Buying a 2011 A8, weird sound from the engine compartment
- 2016 A8 4.0t insurance claim
- 2014 A8 - Hunting and jerky transmission
- OEM 21" Rotor Arm Wheels (local pickup)
- To all OBD11 users
- Blown bang and olufsen speaker question
- reliability
- Parking Brake Setting Itself
- Fuel consumption indicator
- Wandering Navigation/MMI Update
- Brake and rotors suggestions
- turbo screen replacement cost?
- apr stage II pricing
- MMI 3GP TMC in EU
- Adios amigos!
- My D5 review
- Need guidance on dealer's engine repair
- planning on replacing my 2015 A8L Tires
- Potholed!
- my dealer confirmed Turbos are covered 7yr70k
- 2015 Audi S8 CPO
- Service due reminder.
- trunk leaking
- Does A8 Limo mean it's an A8L and Options Decoder?
- Acceleration cuts out around corners?
