- Hood / Bonnet Difficulty Latching
- Audi A8 D4 L Base Oil Leak front right of engine
- Turbo inlet oil?
- SA: Engine issue? Opinion
- Should I be concerned (34: Level Control)?
- Winding noise during REVERSE D4
- D4 Outer Tail lamp LED
- S8 Plus Model Years
- Coolant leak, 4.0T
- ACC not available VCDS log help pls
- New to me S8 Plus
- anyone try vredestein hypertracs?
- S8+ changing direction while braking
- 4G on A8s?
- Sunroof just stopped working..
- 2015 A8 intakes
- Privacy glass
- Audi s8 d4 blow off valve
- A8 panoramic sunroof - shade cables?
- PPI inspection?
- SA: Weird ticking noise while de acceleration
- Help! Rotational 'howling' noise that goes away when braking
- Audi 1995 ABZ D2 A8 Sold need info on new purchhase
- 2105 Audi A8 TDI Firmware
- Does Occupancy Sensor module need calibrated?
- UK: Audi A8 Cameras SE Eexecutive
- Three beeps from the back of the car after shutdown
- 2016 A8L 4.0 T rear seats heating option
- Buying a Q??
- Hood gas struts?
- Oil pan removal
- Any OS 13 issues?
- SA: Gearbox opinion!
- 3rd Party Warranty Expiration
- 2015 Map Update / Cellular 3G
- Airbag light ??? Bright !
- Fan noise after start
- 2014 S8 Stereo Upgrade
- Key Fob two way communication
- D4 - has anyone reinstalled side skirts??
- OBDeleven vs VCDS
- Is it safe to warm SPAM sandwiches on my turbo exhaust system?
- Retrofitting D4 rear window blinds/shades
- Help in Search for Missing Exterior Trim Pieces
- Ski bag
- UK: D4 rear indicator stopped working
- Windshield Wiper 2012 A8L?
- How to change rear height sensor?
- Intakes?
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- S8 Plus owners opinions, is it a reliable vehicle?
- 2014 S8 loses all power while driving
- Trunk side cargo nets
- WNY (Buffalo) area recommended independent shop?
- What is the best course of action re: calibration/installation
- Inflation Relief - Black Friday thru the end of November Sale...
- Tdi oil vacuum port
- Audi A8 Won't Start
- D4 Transmission Hard Shifting
- SIM Card and SD Card
- Tire pressures for S8+
- IL: Audi a8- The car tends to the right
- Looking into buying an S8 Plus, advices from owners?
- 2012 D4 4.2 TDI misfire under load
- Timing Belt?
- Goodbye for now
- How to secure D4 for long distance transport?
- Gas Gauge/Miles to empty Issue 2017 A8
- Paint thickness
- Oil Change?
- S8 0-60 Stock
- 3G Will Soon Be Shut Down
- Crazy Noise - I thought it was OVER!
- Hard steering wheel!
- New Member
- SA: Hard steering!
- Slight jerk from 6th to 5th gear. Urgent help!
- Exhaust flap malfunction. Easy fix?
- Windshield cowl removal
- Water pump @53K
- EBC Red Stuff Pads
- Sun roof noise
- RO: Diesel Fuel consumption?
- Brakes after 8,500 miles???
- Multiple short to ground and plus errors. Help needed!
- 2016 Audi A8 rear defogger issue
- '15 S8 EPC Light / Various Intake Codes
- Front squeaking noise
- S8Plus. 91 Costco (Cenovus) gas vs 94 Suncor gas
- New to me 2017 s8PLus. Audi CPO
- Sat Nav Update - New A8 Owner
- Anyone running the $400 Ali Turbos?
- 2014 D4 S8 "Howling" from the front at 60-75 MPH
- Gearbox Issue! Need opinions
- 2022 Audi A8 Facelift
- Input on coolant leak w 4.2L?
- Update
- Hello, New 2017 S8 plus owner here
- Fuel Pump (intank) removal diy?
- Front parking senzor beeping constantly
- Moving from A8L 4.0 to 2016 S8 Plus
- A8 D4 4.2 Ticking
- 2014 D4 S8 Low Speed Wobble From Rear
- Warranty purch on 2013 A8: What would you do?
- MMI screen issues
- SK: A8 D4 2011 4.2tdi Low Power
- A8 2011 4.2tdi 258kw
- A8 D4 2011 4.2tdi Low Power
- S8: EPC and limp mode
- SA: Car heating issue
- Windshield Cowl
- Did a thing today...cut up a SRM intake
- Additional option under Drive Select for Side Cushions?
- NL: Audi S8 2015
- Wakaa car play
- FI: What is this engine part/ancillary?
- NO: sports differntial yellow light helø
- 2013 S8 P0299
- No build sheet and color match problem
- UK: New d4 owner (4.2 tdi)
- UA: A8 with 21" Wheels?
- A8/S8 front struts same?
- SA: Engine Oil & Gear shifting! - Urgent opinion
- body control module?
- Brakes, I’m confused?
- Front Air Strut Blown Bag
- Body rattling over small bumps?
- Oil dip stick?
- Speakers upgrade’
- Extended warranties....
- D4 to another D4
- Long term maintenance blogs/journals?
- Has anyone bought used with a 3rd party warranty?
- Help with security code
- D4 Matrix high beam range?
- Draggy times, these seem okay?
- Clearing DTC’s in Green Menu or via OBD11 / VCDS
- Is there a way to read my AMAX counter?
- 4.2 V8 CRANK PULLEY
- Ambient door lighting
- Mechanical Failure Confirmed
- Audi A8L D4 interior rearview mirror removal and how to check for a bad camera
- RO: Stabilization program Fault+air suspension fault+ 2 more
- AL: Audi A8 D4 Engine noise
- Audi A8 D3 amplifier circuit BOSE 4H0035223
- 2013 Audi A8L air suspension valve block replacement
- 2016 S8 Stupid Question
- Indy mechanic Palm Beach County
- A8L 4.2 UK 2014 D4 FACELIFT
- Let the paint correction begin!!
- Audi A8 D4 Bluetooth not working
- Question on VAGCOM lap timer, HUD, gear display, shift light
- Factory Boost Gauge Reading
- a8 d4 facelift retrofit
- Door panel alcantara peeling
- So glad to be back with my dream car and here is a little story....
- Programming 100Ah battery?
- UK: Firth Gear Audi S8
- Back again! Have a color question
- Coolant leak,yup. But more of, might as well parts
- KZ: 3.0TFSI FORCE Start / Steering Defective Error
- 2013 S8 power loss
- FI: The Audi A8 hybrid
- UK: A8L W12 FULL SPEC VS A8L D5 MEDIUM SPEC
- Wiper washer Weirdness
- A8 Boot/Trunk problems
- 4.2 Hard start
- D4 S8 - Air suspension: system fault
- Suggestion to change MMI behaviour for car to stay online
- Cracking noise from right blower after engine start
- Getting a flat turned out to be problematic... almost
- Trailer Hitch, ys for my s8 for jet ski
- UK: A8L brake disc, please help
- FI: TPMS system fault. How to reset with VCDS?
- A8L 2014 facelift dynamic indicators/turn signals?
- Added, Niyarmi LED 3D Ghost Shadow Door Projector Logo Light
- Liqui Moly Engine oil
- Emergency key issue
- Hazard Lights doesn’t work!!
- WIFI playing tricks on me
- ACC driving program
- Need pictures of factory Head Up Display
- Valcona leather wear?
- HU: Audi A8 transmission driving me crazy. Need Advice
- Help, 2017 A8L 4.0T Air Suspension Too Low, Ground Clearance Too Low
- 2017 A8 4.0T Oil Changes While Under Warranty
- S8 2016 thoughts on reliability
- Gearbox Not Engaging
- A8 facelift Front Grille?
- Do these rotors need replacement?
- Steering wheel is hard to turn!
- Changing NAR Radio frequency to EU?
- Rear sunshade stopped working.
- 2017 A8…serious issue???
- 2012 a8l 3.0TDI
- Rear facing child seats
- How to enable Google Earth?
- A8 sport suspension vs S8 suspension, are they the same?
- Audi a8 d4 common problems
- Audi 2011 error codes
- Seafoam
- wrong GPS position
- Need help with measurements for facelift front grille
- Downpipes 2016 s8?
- ACC and Brakeguard Unavailable but Lane Assist works
- Error during the map auctions 6.32.1
- Switch near battery
- Check engine (MIL)?
- ETC failure
- New S8 buyer
- Selling Car/Carfax Report
- Pothole parts
- Fuel injector seals
- Audi A8 TDI 2015 transmission service?
- Looking into buying a 2011 or 2012 models. Any input appreciated.
- Engine Starts fine until restarting, then I have to apply gas pedal to start
- Background & Experience + Guidance on Audi D4 A8 S8 Front Suspension
- Chassis stiffening for D4 S8
- Need help with coding for retrofitting rear comfort seats
- Advice about DIY rear climate control install
- ACC and Braking assist not available
- Disassemble of center console part
- CD changer stuck in a loop
- Help with 20" Wheel offset
- One-Touch, Button-Up Options
- 2013 A8 Leaking Rear Main at 70k miles??
- Power steering is shot
- BAAAAAD idle. died last night.
- DE: UNDER CAR AUDI D4?
- Anyone tried the Goodyear Soundcomfort tires?
- Audi OEM Red Calipers for 2017 S8 Plus
- Why so hard to find loaded up S8's & A8's? Anyone selling?
- Programming new advanced keyfob
- Modding the A8 with S8 parts
- New D4 A8L owner
- Fuel Filter Replacement
- 2011 A8 4.2 FSI
- 22” ABT HR wheels with Continental tires for sale
- APR TCU Tune on A8 4.0T
- Braking vibration under VERY specific conditions
- Yet Another Audio Thread - Any and all input Appreciated
- Surge When Parking
- New 4.0 V8 SSP
- Looking for 2016 or 2017 bumper
- Fuel Filler overflow Drain
- Insurance premiums for a8
- My car is dead, won't start
- Oil separator lines repaired
- Audi a8 tdi Feeder line AdBlue
