- Chrome grill pieces for my A8L
- Audi A8 D4 problems after turbo failure
- WTB 2017 or '18 S8 or A8 Sport
- Audi Connect
- MMI screen not coming up
- WTB from private D4 4.0 never smoked in dynamic package and black optics package
- How do you adjust/calibrate front camera for parking assist?
- Navigation
- D4 A8/S8 reverse light bulbs
- Headlight passenger side replacement
- Plastic jack point is loose. Are these things supposed to be glued on?
- 2011 audi a8l BOSE SYSTEM
- D4 battery replacement options
- Audi a8 2012 steering wheel stuck
- Rs8 bumper?
- Side cargo nets
- D4 W12 Carbon Clean/Spark Plug write-up
- 2013 Audi A8L 4.0
- 6.0 Litre transmissionu
- A8 soft close doors
- Rear Door Weatherstripping
- Audi S8 Front Brake Discs and Pads Replacement Video
- Audi S8 / A8 Rear Brake Pads & Discs Replacement Detailed Video Guide
- HVAC Head Unit not working 2013 Audi A8L
- Rhythmic screech from dash. Seemingly random. With video
- 2017 S8 Plus - Brakes
- Oil screen PCV advice 2015 S8
- Keep or Trade 2014 A8L diesel?
- Thinking of selling my 2013 s8
- S* questions from a newbie.
- CarPlay module install
- 3g+ MMI and iPhone XS
- Ambient lights custom
- Particulate Filter Lifght Audi A8 4.2 2011
- 2011 12 A8 known issues?
- S8 Front Lower Spoiler on A8
- Check Engine Light P11BE
- Arm Rest Issue
- 2013 Audi a8l passenger door Bose subwoofer replacement
- 2015 TDI
- Sunroof switch bites dust after windshield replace/camera alignment
- Fuel Sensor Fault
- Engine fire recall 2013-1018
- CPO/PO A8 - Go for it?
- 3.0T performance
- Oil Leak/Timing Chain Cover
- Launch control inquiry
- New D4 S8 (to me) - APR vs ?
- Parking Aid Sensor Failure. (ACC And Audi Braking Guard Unavailable)
- S8 downpipe install help
- P164E00 Code
- Headlight lense replacement?
- 2014 A8L 4.0T P2004 and P2005
- RSE Screens removal
- Roof Channel/Sunroof Drip Rail Won't Stay Completely Down
- left rear display does not move
- Passenger Headrest replacement
- 2013 S8 D4 exhaust options
- CTEK 40-206 MXS 5.0-12 volt charger
- occasional suspension squeak
- 4.2 Engine: Last of its Breed
- MMI update
- Extended warranty
- winter wheel and tire combo for D4 S8 plus
- AC Problem (only blowing cold air on driver’s side)
- Looking at 2015 a8 3.0
- Ambient lighting?
- Oil Capacity / Dipstick Locator
- 2012 Audi A8 4.2l exhaust and other bits
- 2011 MMI and Navigation advice
- SMR Silly Rabbit Intake installed with stock airboxes
- Dead Battery, Switchblade key won't turn even after DW40
- Tire pressure?
- Front brake guide pin/slide pin bearing bush
- 2013 W12 speed governor/limiter - HOW?
- 2013 W12 MIL + P0101 + P2179
- 2017 S8 on ADV1’s
- MIL light won’t turn off
- Armrest won't go down all the way (broken)
- Squishy Front Brakes - Damper Spring Position Tip
- Newbie with 2016 S8 plus
- Help with codes after facelift retrofit
- Rear Brake Pads
- where did my dipstick go??
- Accelerometer and dB/Sound Meter
- Coding ABS to disable TPMS?
- Anyone know these wheels?
- Octane booster - is it worth it?
- IL: Helping air suspension
- Water pump
- MMI, SD Cards and Rear Entertainment
- Stasis FD11 20x10 forged
- Looking for new tires for my s8? 275 35 21
- Water pump
- Bnicksr
- Top Speed?
- A/C no cold air - Fault Code VCDS - any help?
- Tire Pressure?
- A8 D4 Terminal 58s HELP
- Trunk Intermittent - A8L TDI D4 (2015)
- UK: engine under tray?
- Radiator Bleeder Screw - Replacement Options?
- S8 or + vs 3.0..D4 vs D5?
- Your car story
- New place to detail your Audi in Glenview IL
- audi a8 2013 transmession oil mix with coolent
- Part number for left back caliper Audi S8 2007
- 4-seater/full leather package swap anyone?
- where can i get keyfob for 2012 A8 in GA/Fla under $600?
- 2011 a8l paddle shifts not working
- 2012 Audi A8l high mileage
- A8 18 inch winter wheels?
- Rear license plate bracket and rear brake pad HELP!!!
- Ambient lighting not working
- 4,2 TDI Problem when i try to accelerate slowly
- License plate lights stopped working
- Did you know?
- Can my 2013 A8 D4 Use a Third Party SIM?
- 2017 A8 lowering issues . Vcds
- A8/D4 MMI unit gps fakra connection?
- One ambient light not working
- No "How -To's" for any A8 models?
- Outdoor summer storage
- BS: Strange buttons?
- Okay, Which One of You Did This?
- D4 Market Value is Depressing
- Windshield mounted rear view mirror
- Random Pic of your D4 RIGHT NOW
- Full Size Spare Tire Wheel Combo
- Oxygen Sensor, Pre CAT ,Part Number?
- A8L
- Add Apple Car Play via RSNav **Review**
- Is this too dark?
- HELP! No start after installing lowering module
- brake judder/uneven pad wear
- 2013 Audi s8 speaker size
- w12 wrong plugs - poor power - resolved
- Looking for A8 betwwen 2016-2018
- 2014 S8 - New owner with a bid problem
- W12 US Production Figures
- 2013 A8L - Upper Control Arms Replacement, w/Pics
- HUD retrofit on 2013 S8
- DIY: Retrofit Tailgate Lock Button on Pre-facelift D4 A8
- Upgrade to D4 TDI questions
- Transmission Malfunction: Continue Driving ???
- Compression numbers for a A8L 4.0t
- Need help with wiring for facelift trunk close button
- 2010 Rear Suspension Leak
- Coolant change 2013 s8
- VCDS Starer Code P3054! Help!!
- 2013 A8L - Rear Sway Bar Links and Bushings Replacement, w/Pics
- Should I buy a 2017 A8 used?
- Valve Cover Gasket?
- Coronavacation photo shoot
- Shop tools you have
- High mileage reliability?
- Floor mat options for my ‘16 S8?
- STRANGE MISFIRE
- Buying a used Audi A8 D4, common problems?
- Ignition Switch
- IS APR STAGE 2 THE BEST? TRYING TO SET RECORD WITH S8
- HELP! Front passenger side seat memory & window switch no power
- D4 A8L 3.0T 0-60 time with APR stage 1
- Blurry HUD?
- DIY: Retrofit Autohold on NA D4
- UK: Start/stop issue
- D4 A8L vs B8 S4 Thoughts opinions?
- Need help with coding for Autohold
- My power button cover broke off
- "hoofing" no longer opens the trunk....ideas?
- Side Mirror Memory Not Working?
- C104807 stiff suspension
- S8 Driver Clocked @ 142mph
- Throwing Air Suspension Fault (yellow) after sensors fixed
- New S8 owner
- Windshield Replacement By Dealer
- What To Replace To Clear 5 Codes?!
- S8 Plus, stock wheels and stock suspension height.
- Switched power source for phone charger?
- ABS Pump Location?
- What do you think of this reliability website?
- Fast A8L 0-200 km/h 124 mph in less than 9 s!
- Need help. Workshop cant locate problem.
- The Boss in a A8L W12😎
- Reeves Motorsports - HyperTune?
- 2013 W12 production numbers
- Humming from the front
- Accessory fuse box location?
- Issues with Garage Talk
- S8 Plus Knocking Noise In The Engine
- Mystery wire really torn up housing
- Illuminated Door Sill Trim
- Cylinder Head Cover Gasket Part #
- Backup Camera; "No Camera" icon
- Rear caliper carrier bolt size
- 2011 a8 paddle shifts not working
- Oil Dipstick?
- Rear diff noise?
- Scratch repair in aluminum trim?
- Audi s8 d4 2015/2016
- Audi a8l D4 engine crank lock location
- 2012 A8 After Run Coolant Pump Problem
- Oil in intake hose
- Donate to Discount so you can Quarantine in Your Garage...
- VCDS for turn signal blinks
- 2013 A8L/3.0T Thermostat Replacement - LONG Post With Pictures
- D4 A8 Black Optics Package for Grill Only
- 93 Octane @ $2.25 With Nowhere To Go
- Hitting Calipers : Audi Rotor spokes wheels
- A Different Overheating
- A8 D4 3.0 tdi remap
- Oil seal part numbers needed
- New here just saying what’s up!
- Top view not working
- 2013 S8 sunroof motor issue
- battery -dealer installed a++
- A8 D4 4.2 overheating briefly.
- Transmission Malfunction Warning
- Oil Extractor Method: Filter?
- Memory seat stopped working
- Best repair Manual
- Suspension control module
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- 01400 Air suspension 05 A8
- 2012 Audi A8L
- Mild thud noise coming from center console/gearbox
- S8 brakes on an A8
- 4.2 V8 and 4.0T - cam chain (and rattle)???
- Uneven Wear on OEM Tires
- If someone offered me $500 I wouldn’t fix it again!
- Self levelling headlight fault
- UK: Audi A8 window problem
- W12 FSI - carbon cleaning?
- OEM Battery Life Span?
- Carbon build up on 13 S8
- Cracked windshield at the dealer
- Scan Codes!!
- turbo screen and APR recommendations '13 s8
- A8 4.2 FSI Transmission Whine or Whistle
- Lights not turning off
- What is this?
- Fourings W12 Timeline
- Rust?
- Need Favor - Wiper Arm Service Position
- Cete Active suspension control
- low coolant warning light which disappears after 2 minutes
- UK: Replacement battery for 2011 4.2TDI?
- S8 v10 temperature gauge going straight to 50 on a cold start
- suspension issues
