- BRAKE light on dash
- TURBO HELP!
- Brake Replacement
- UK: Problem with Heather?
- Brake Replacement
- coolant issues and repair
- P2014 Intake manifold air control actuator position sensor/switch
- Need Help: Shudder on deceleration S8
- VCDS Lowering question
- Question, Install Alexa Auto
- Need help with brake issue
- 4.2 Engine Owners: What's your spec?
- Lifetime Transmission fluid change?
- D4 Auction on Cars & Bids
- UK: Buying S8 Plus D4 2016 - is 72k miles a problem ?
- Disk Rotor and Pad Replace Video
- Looking for a D4 grill, tow hook & headlight washer cover
- anybody got a sneak preview of 2022 A8 ordering guide?
- Best Shop to upgrade turbos and tuning?
- Intake cover heat foam needed
- New D4
- 14 A8 4.0 overfilled oil please help
- Price of performances is going UP.
- So that's why the car was a little laggy.....
- PL: [D4 13 4.0TFSI] Speed limit?
- Wireless CarPlay, Wireless Android Auto Interface for Audi cars with 3G/3G+/MIB MMI /
- Upgraded Throttle body install on A8L 4.0T
- A/C compressor Not starting up..Please Help!!
- Serpentine Belt Noise
- Secondary air pump failing?
- No new perpetual Pro licences for OBDeleven after 2021-06-15
- 21"x9" Audi Sport 5 Arm-Rotor Wheels, weight?
- Fully loaded 2014 A8 W12 6.3 five-seater
- Air filter change and Squeakins
- A8L Quattro repair question
- Anyone running 265/40/21? Will they fit? Feedback?
- A8L Quattro repair questions
- Highest speed you have pushed your D4?
- Opinions on electric cars and future of flagships?
- A8 service/gearbox northwest
- The End Of My D4 Era
- Passenger footwell flap motor (The DIY)
- DK: 3.0 TDI vs 4.2 TDI Transmission?
- Michelin 275/35ZR21 XL PILOT SPORT ALL SEASON 4
- A8 L exhaust video
- Looking at buying an A8 D4
- Facelifting tail lights
- Any Experience with this Bizarre A/C Behavior??
- [Canada] Looking at getting a 2015-2016 Audi S8. Worth it? So many questions!
- speaker and window issue
- CDRA: Two random holes in Block
- Default vehicle settings
- Key Copy Options?
- TD1 Workaround
- Former D3 owner contemplating D4 S8
- Blown front air strut/Service Air Suspension. Able to DIY?
- 2013 Audi A8L MMI Failure (Glitch)
- High frequency vibration while driving, through seats and steering.
- Car upgrade??
- DEALER Service Reports
- Getting to the J852 Lane departure camera
- Annoying rattles
- Total Loss???
- Recommendation for front brake pads
- ZF8 tune with HPtuner on a8 ?
- Coat Hanger?
- Ashy Tray? For real?
- Weird Knock sound from rear wheel
- 1/4 time after APR Stage1
- iPhone 12 Pro / iOS 14.5.1 AMI disconnects
- Boston Meet Up
- D4 versus D5?
- B&O Rear center subwoofer rattle fixed easy
- Raising frames per second in MMI navigation
- Emergency brake malfunction
- Braking guard function question
- Google Earth overlay
- DIY: Access for installing downpipes or reaching rear coolant bleeder valve
- anyone familiar with the massage system design ?
- Audi A8 MMI Navigation Plus - Bluetooth Problem
- Suspension Stiff Problem 2011 A8/D4
- What Caliper color should I use on a Black Car?
- 2017 s8 Rotor questions
- Black optic front grille mod
- Audi quote me $2000 for replacing sticky buttons
- Solved - Battery / Terminal 30 / ECM - PCM lost communications
- New battery but do these numbers look right?
- Not many D4 drivers like this one...
- Start-Stop effects
- Door lock actuator (sensitivity adjustment?)
- Front Brake Rotors and Pads replacement?
- Will APR Tune Completely Void OEM Warranty?
- A8 D4/4H Boot side trim removal with side pocket cargo net
- "BRAKE" Warning signal
- Lil Sierra Mountain Road Trip in the A8, MPG Results!
- Brake rotors for 2015 S8
- Windshield Protector
- 2012 A8L - shaking between 36-46 mph
- Bump stops on 2017 s8plus? - Cete installed
- Front Lower Control Arm
- P209800 - Post Catalyst Fuel Trim System Bank 2 - Too Lean
- Latest Revision Part Number - RH 4.0 Engine Mount
- Front Spoiler, side skirts,
- New Wheel possible?
- New Brake Pad Procedure
- Looking to purchase S8 , p2096 code and seems slower than should b
- Sirius XM Options - Limited?
- Brake Bleeding Sequence
- 2015 Audi A8 4.0 help
- T-Mobile- no longer working ?
- MM1 Update Question, If you would please
- P0481 & P0693 Coolant Fan 2 Faults. Help!
- Michelin 275/40/ZR20 Tire pressure?
- CarPlay Wakaa Carlinkit RSNav which is better?
- Lowering my A8L with VCDS, yet another post.
- Typical VW MPG Optimism?
- Magna Tuning body kit. Anyone use them before?
- Terminal 30 Open Circuit faults - U140A00
- Adaptive light malfunction -- all fix now
- Multimedia 5F - HDD failing? SSD upgrade?
- Brake Shims
- Help Sourcing Speedline 2702 21'' wheel
- Zimmermann Rotors vs OEM
- Keyfob resync procedure anyone?
- Heated wing mirror failed?
- A8 interior lights
- Resonator Question with Magnaflow Mufflers
- VCDS Motor Mount Deactivation?
- Fault code: Position Sensor in Left Center Vent
- 2013 Audi A8 Twin Turbo 4.0t
- Help please : Battery / smoke / fire?
- New S8 Owner Today, Many years in waiting
- Custom Ambient Lighting?
- Adaptive Cruise and side assist 2012 A8
- Thread: Tune & Lowering $$$ Nashville TN
- Bosch Quietcast Pads and Rotors
- Multimedia 5F - 16347 fault
- 2016 A8L V8 4.0L moves...But will she LAUNCH?
- Audi A8 4.2 FSI acceleration rattle
- Throttle / Transmission jerking - Checking reset via ODBEleven
- 2018 3.0T A8l Tuning? APR Ultracharger/pulleys
- 2002 S8 Windshield
- VCDS
- Humidity sensor location
- Auto Start/Stop Loud Clunk - 2017
- Which HVAC Coolant Circulation Pump?
- CPO vs Extended Warranty
- A8 2012 v8 4.2 check engine light
- Interior trim color?
- Cera Tec, Who Uses It? Why?
- 2013 W12
- Android Auto on MMI
- Low S8 Plus Coolant Warning / Coolant Leak Somewhere Help!
- NO: Why did Audi change brake rotors from floating to ventliated in 2015?
- Cabin Heat Question
- Turbo failure TSB (revision 9 released Oct. 30,2020)
- "Do not exceed 4000rpm" message popped up
- Oil Screen thread #23423 - Where to have done and price?
- trailer hitch class 3?
- 2004 Audi A8 Seat covers??????
- KE: 2011 Audi A8L 3.0 TFSI Quattro V6 A/C not blowing cold
- Eliminate oil screen totally?!
- Second key
- Websites for Custom Parts?
- Headliner - Swap or Dye?
- notice coolant getting low
- 1/4 mile track is open, can I pick your brains 2017 A8 4.0?
- Wipers not working
- 2013 A8 with EPC warning light and multiple DTC's
- 4.2L fuel consumption?
- Thigh support seat extension adjustment?
- Just picked up my CPO 2-17 A8L 4.0TT Sport
- Oil screen service confusion/mileage/year
- Opinion Snap-on Trim Covers
- Extended warranty or just buy new turbos?
- Use this Website to Get a Copy of Your Window Sticker
- Audi A8 2012 3.0 TDI L Rear Seat Apple Carplay
- Rear / 360 Camera Problems and Fix Audi D4 A8 S8
- Looking to purchase a 2015 S8 D4 - What should I look out for?
- Escort Redline 360C
- CETE install question Post facelift D4S8
- S8 2017 air suspension too stiff when braking
- Just bought my 2015 A8 4.0 (story)
- "Coolant Low" PLUS No Hot Air In Cabin. What could it be?
- A8 Leathers
- A8 vs A8L ride difference?
- Engine choices?
- 2011 A8 - heater blower replacement
- Any interest in full leather RSE massage front seats?
- Brake Fluid Flush?
- D3 to D4?
- A8 D4: B&O vs Bose
- Audi A8 2011 right side window defrost motor issue
- Major 4.0 Engine Issue
- Help with OEM 21 inch wheel.
- Top Gear UK Season 4 Ep 4
- Savannah Beige Metallic, is it just me?
- 2017 A8 4.0T With Magnaflow Dual Exit Mufflers Question
- What the heck is this noise?!
- 4x 265 40 20 DUNLOP SP WINTER SPORT 3D AO 104V WINTER SET USED AUDI A8 S8 UK
- D4 A8 commemorative book
- 2016-2018 S8 APR Stage I Tune
- No Owners Manual
- S8 4.0T water pump cost
- New Toy 2015 S8
- Anyone with 19" wheels - ever try 245/50/19?
- What the hell is this sound!?
- cold air intake?
- Air Suspension Compressor Fuse/Relay
- Snowflake Indicator On Cluster - What does it control
- Would you rather...
- 12v outlet - stay hot for trickle charger?
- Going from 20's to 19's. Will these fit? Yes I've searched. Still dumb though. :(
- Need info on this part. 2011 A8L
- Service History Sanity Check
- 2012 A8L VCDS 150016 fault Help
- Auto Did Fault 150016 invalid data record
- Grooves in brake rotors and low speed squeal
- 2016 S8 Plus - Turbo gone
- My 2008 Audi S8 Strange noise
- VCDS help for a rookie.
- Warranty needed on a high quality, low mile D4?
- S8+ D4 trunk spoiler part number?
- Audi A8L 4.0 Turbo Muffler Delete
- Accuracy of OBD 11 Pro
- Received a free part today
- Maybe a 3K vibration poll?
- Fender badge
- Not enough data error message
- Engine hesitation when turning
- New buyer A8L 4.0T 2017
- A8 Horch
- 2013 a8 front air ride suspension won’t go down
- Differential module position
- Air suspension fault light A8L 2011
- 2011 - 2012 Buying advice?
- Horn going off
- Instructions/Help needed to replace rear passenger sunshade - 2015 A8L
- Latest MMI Firmware and Navigation Maps?
- Do i go for it ? 2016 4.0
- 14 days or 5000 miles to service?
- New S8 Owner - Vehicle quirks
- Finally back from body shop
- New S8+ Owner
- Audi a8 d4 no lights inside and outside then lock / unlock car
- Crazy for getting another?
- 4.2 Engine Review
- O2 sensor on ‘17 S8 plus
- Clean valve and fuel injector
- Can I make the screen on demand only?
