- TGK endlinks and swaybars terrible crunching and popping
- Strange sound only in cold starts
- HVAC coding
- 19" wheeels with +38 offset on a 2014L??
- Frigobar A8 D4
- 2016 Front End
- Suspension parts
- Power Steering Stiffness
- Hood Latch Issues
- Suspension problem.
- Trunk closing intermittently 2015 A8
- oily fluid leak, not motor oil
- A8L Roof Drip Rail Moulding Coming Loose…
- A8 D4 front air strut replacement
- Audi won’t start and rad fan on
- Upcoming Service Vision/Plans
- Hot V
- Tip for possibly resolving D4 Audi A8 ACC and Audi Braking Guard Unavailable Error
- 2012 A8L radio stopped working, fuse? MOST?
- TPMS readings
- Help identify where the hiss is coming from (video)
- The S3G "Unicorn" — My blind-buy A8L 4.2 TDI in Bentley Midnight Amber
- Black roof
- HVAC/Coolant Pump Failure
- Wireless CarPlay & Android Auto Upgrade for Audi A8 – Keep Your Factory MMI System
- What is this called and can I get a replacement?
- Is my car selling driving data to Audi?
- Steering assist U140A 00 error
- Changes to the Rear Level Sensor
- Had some cranking issues Friday night
- 4.0T Turbo Flutter Under Load After Inlet Upgrade
- Velvet Beige interior comes with “brown” leather accents instead of black?
- Help Needed – Removing Cooling Fan on 2011 Audi A8
- UK: How long can we keep going?
- Weird random things happening with driver's window and sunroofs
- Fuel pressure
- How to lock interior mirror in place?
- Moving to Q8 e-tron is
- Forward/back track steering wheel buttons
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- Alcantara and B&O retrofit is progressing...
- BG: Long coding for 55 Chanel?
- Gearbox problem ⁉️
- Vacuum Extraction A8 Base--
- Water Pump hose and coolant replacement
- Opinion wanted - Keep A7 (C7.5) or get an S8 (D4)
- Where is Electric Parking Brake Control Module in an Audi A8 D4?
- Please please help suspension issue
- Control module losing coding?
- Where is the Heater Control Valve located
- Would a widebody D4 S8 look any good?
- Psrk Brake
- Air Suspension Fault Codes
- Moving on from the D4
- Wheel size and offset?
- Looking for books for 2016 S8
- AUDI A8 won't start
- Upgrade Your Audi A8 with Carputech Android 14 Infotainment System!
- Annual Service Cost
- 4.0T Questions
- 20" OEM wheels for snow tires
- Brake job question
- D4 Driver's multicontour seat adjustments not working
- 7,500 mi oil change with 15,000 mi filter change - 504 and Mahle
- 2012 Audi A8L 4.2 lost power while driving, went into neutral now won’t start.
- Hit a deer rebuilding front end of my S8 and replacing turbos some Qa?
- Audi A8L D4 Navigation
- Turbo Oil Strainer Replacement: What Else Should I Do While in the Valley?
- Engine Oil Analyses
- Bad Coolant Switching Valve?
- Help with saving car after flood
- Better air flow
- Mr12volt D4 install
- Oem wheel spacers
- CYLINDER 8 MISFIRE
- C10311 air suspension
- Brake caliper bracket screw
- A8 4.0T Exhaust Pressure Control Valve fault
- D4 A8 judder under braking
- Air Intake Sensor/relay
- D4 A8 B&O Advanced (1,400W) vs D5 A8 B&O Standard (700W)?
- Found a 2013 A8L W12 with only 12k miles
- 2014 Audi A8 3.0 gas strange noise
- d4 s8 random part identification ???
- BLACK FRIDAY SALE ON NOW - STOCK-UP AND SAVE!
- DS1 + bTres combos, save huge
- Brake pad fault
- Analog TV tuner
- Bose Issues
- 2011 a8 MAF location
- Pinnatec Auto Lowering module
- Discussion: Wireless CarPlay & Android Auto for Audi A8 (2009-2018)
- Coast to Coast to Coast
- Difference in boot space between fixed and electric rear seats in D4 SWB?
- Keyless antennas location
- Jhm Rs7 turbos
- Drive train noise
- Front comfort seats lumbar support adjustment seems weak
- S8: P2098 & 2272 - HPFP or O2 Sensor?
- Face Lift for A8L Quattro
- DROOPING EXHAUST PIPE
- Meyle HD Control Arms
- A8 Pre Sense not available
- Replacement Key fob/programming options?
- 2013 Audi S8 (40k km) - Strange idle behavior and whining noise during city driving
- ACC / U111300
- Leaking air strut/spring
- Swirl flaps
- Front grill repair
- Rear A/C vent orientation piece lost
- Engine failure
- First things to-do on my D4
- 2013 Audi A8
- Discussion: CarpuTech 12.3-inch Android 13 Upgrade for Audi A8/S8 D3/D4 (2002–2018)
- My introduction to the D4
- Engine mounts 4.2
- Help with wheels 22/9 and 22/10.5
- A8L D4 2016 Passenger seat memory seat, seat heating, cooling and movements of the ci
- How can I get 5 digits for VIM?
- Air suspension
- PaulW 3.0T Refresh
- PCV valve Diagnosis
- Diff/Gear Oil Change
- D4 part out on FB marketplace
- DRL no longer automatic when FSM are on after dealership visit:
- Engine Trouble Code While Away from Home
- D4 to another D4. Crazy Thought?
- Getting P20600 and P20700 DTCs after changing the oil and the air filter
- Dealer Prices: Not so bad.
- A few important torque specs urgently needed
- Control Arm Carnage! info needed -- Front Upper Control Arms and Sway Bar Links
- No response from Intake Manifold Runner Control (IMRC) using OBD11?
- Audi a8 d4 misfire
- What’s my car worth?
- I did a thing!
- myAudi app and Sent Destinations question?
- W12 lurching on acceleration - solved??
- Anybody have a rattle on start up 4.0T?
- Good to be back
- Big repair quote incoming!!!
- Removing instrument cluster
- Deleting directories from previous iPhones?
- Brake bleeding procedure
- Wheel Bearing Woes
- EGR Cooler on my 2014 Audi A8L TDI 3.0 V6
- Motivated to Sell - 2014 S8
- 2013 audi s8 with brake light on (VCDS code inside)
- 2015 S8 - 57,000 miles - Engine/Motor Mounts?
- Swap A8 for A6 e-tron?
- MMI dead after trying to install carplay box
- Dash brake light question
- Zimmerman or Genuine
- 100k S8 Service
- Film coming off underside of gear shift
- S8 upgrade?
- CAT Cancellation 3.0 TFSI
- A8 D4 – Adaptive Light & Camera Assist Errors (Module 4H4 907 357 A)
- Ac drains
- Audi S8 no AC after car wash!
- Tailpipe repair in LA area?
- Help identify this sensor or part number
- Do you have bent wheels?
- Backup camera/Parking
- HELP with side skirts for 2011 Audi A8L
- Any parts list for this passenger side center armrest lever?
- Some AI fun with the W12
- High Pressure Fuel Pump Leak Fix
- 🔥 THENAVMAN MMI MAPS GPS SOFTWARE Update 3G / 3G+ 🔥
- 2017 S8 Upper Dash Panel Leather is peeling. How to remove panel?
- ABS REPLACMENT
- Turbo failure
- 2015 A8 Gear Selector Error - A Sticky Situation - Transmission Malfunction
- Rear sun shade
- Key fob is not locking the doors
- All of the lights - no Kanye
- Quattro shudder ?
- New to me 2016 S8 Base
- APR Ultralink: At Home Flash Tuning is Now Here! (4.0T EA824)
- Help with figuring out a communication error between modules
- Hood release
- Electric Power Steering Rack Failure - C10AE Motor open circuit
- Leak somewhere
- blue ray
- 🛠️ 2010 Audi A8 D4 4.2 V8 FSI – Oil Leak from Transmission Area (Pics Attached)
- VCDS Scan Results - ACC and Braking Guard Unavailable
- Jackal Motorsports Tune
- Failure on engine readiness, no faults? Worried or no?
- Audi s8 vs a8 wheels question
- Shelf Speakers Not Working - Bang and Olufsen
- Front Tow Hook Cover Removal
- Mechanic in the Northern VA / Southern MD
- Basket case W12 warning
- Adaptive Cruise Camera on Back Order
- 2017 Audi S8 Plus: Rear climate control issue
- engine rattle solution! but need help
- MMI control knob
- Dash Cam for a 2012 A8L
- Fuel door emergency cable release location. 2015 S8
- 2013 s8 with ds1 tune, CAT sensor pass issue
- 2014 s8 help
- W12 - stupid expensive price mark ups. need help
- Performance Mods
- Intake manifold removal
- Rear main seal leak d4 3.0tdi
- How critical is tyre wear on the same axle?
- Audi S8 headlight adjustment
- TDI DPF removal help
- Messed up the whole car with ChatGPT and OBD11.. HELP!
- thoughts on coolant leak location from pic?
- Transmission Drain Plug and Fill Plug Torque
- Steering Rack Question
- Start Stop Question
- 2014 A8L TDI for sale
- 2014 A8 L threw lots of codes overnight- any hope left?
- Switch tire size? 265-40-r20 A8 Base
- Ambient air sensor location
- W12 oil separator hoses help
- Code C104807, Level Sensor Error
- DVD Launch while moving
- I have a problem with slight engine knock.
- Engine mounts
- 2015 S8 startup and idle problem
- S8 plus : Time to change the spark plugs ?
- Steering Defective
- Front camera wiring harness
- Audi A8 4.0 TFSI
- Unidentified Sound
- Winter Wheel/Tire Setup
- MMI & CD CARD Connection problem
- Android Auto module options
- Trickle Charger S8
- WOT car is skipping/jerky
- How do I solve this problem?
- Which module controls overhead console ?
- New with 2015 S8 and couple questions
- Keyless System Malfunction?
- Lemforder Control Arms
- Any idea what is this humming sound ?
- TGK sway bar upgrade
- B10D407 - Right rear upper body vent motor mechanical malfunction
- RO: I need some advice
- 2016 S8 (non plus) first real service bill
- 2015 A8L 4.0: remote start activation
- ACC, Lane Assist and Braking Guard Issues
- Implausible ride height... and ACC etc
- I need troubleshooting help 2012 A8L W12 FSI
- Air ride issue - urgent help, need to sell the car
- 2015 A8l 4.0T: Radiator stays cold - overheating after engine wash
- Misfires, misfires and misfires
