PDA
View Full Version : A8 / S8 (D4 Platform) Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. My car randomly goes into limp mode...ESP, Hill Start, Air Susp and Tire pres lights
  2. Car was lowered. is this going to be a problem?
  3. Transmission fluid replacement
  4. D4 S8 Drive Select Question
  5. Will this S5 wheel fit on 2011 Audi A8?
  6. Thinking of coming to the D4 Dark Side
  7. 2014 A8 4.0t misfire/ hard start
  8. S8 2015, Cutting Out After Restarting Loads Of Codes
  9. Proper leather care for our aging cars
  10. Remove pin type clips
  11. EPC light on, car acting strange.
  12. 2017 S8 Plus surprised me with every warning light possible
  13. 2106 S8 Brake Pad warning won’t clear plus 2x cooling fan 2 warnings
  14. Received Audi AEB Settlement claim form today...
  15. 2013 S8 60k multiple misfires cylinders 1-4...I'm lost
  16. Royal Choice - King Charles Picks Audi A8L
  17. 21x 10.5 offset 22
  18. audi a8 d4
  19. Tire fitment?
  20. Keyfob issue as well as air suspension - Urgent
  21. Parking sensors in front bumper help
  22. Had alignment but still pulls right, shop says tires to blame
  23. Where to plug a DahCam wiring harness into?
  24. 2015 Audi S8 D4 - Accumulator/System Pressures?
  25. Advice Needed: wrong rear differential fluid added (SAE 75W-85 GL5)
  26. 4.0T coolant pump 2 location?
  27. Reconnect battery and horn stuck on
  28. Where to begin…. ACC and Lane Change
  29. Crankcase breather valve 2015 3.0L
  30. Sunroof / Moonroof Stuck Open
  31. Seat issue
  32. Where can I download Audi's digital map of Europe
  33. Activating Battery Meter
  34. DS1 tuning maybe useful..
  35. help with engine mounts + parts advice
  36. Oil cooler advice
  37. S8 OEM Wheel load rating
  38. D4 2014 a8L air spring/line fault after pothole hit
  39. Odometer
  40. How long to keep 2015 A8 4.0
  41. Exhaust Actuators
  42. Help with purchase advice of 4.2 vs 4.0 v8
  43. MMI software updates
  44. 2015 S8 new owner!
  45. A8 Rear Right Air Suspension Leak Issue. I'm close to burning the car
  46. SK: problem with vented seats
  47. LED Reverse Light Upgrade
  48. LED Glovebox and Trunk Upgrade Writeup
  49. An assortment of issues
  50. 2016 A8L Starting Issues…
  51. 13 A8 4.0T: Need help locating oil leak
  52. Ughhh. Sport diff error and now adaptive cruise and lane assist error
  53. 2013 A8 75K Miles Running Hot
  54. Urgent Help with 2 Codes - Oil Pressure Valve
  55. NVLD Switch
  56. Possible to use 4G LTE/5G modem for MMI?
  57. 2015 8L complete bumper cover
  58. Screaming Audi A8/2015/D4
  59. 2024 A8 Tire Sizes ... Large Sidewalls
  60. D4 Remote Start
  61. HUD cutout looking funny or normal?
  62. Codes After Tune
  63. REALLY want an A8, but...
  64. Exclusive paint
  65. 2016 S8 Plus 21" x 10.5" Offset Fitment
  66. NL: Detailed and new wheels coming up!!! 22s PICS
  67. MMI screen won’t come up
  68. RSNAV - no longer available for Audi S8 D4
  69. Coolant leak Job
  70. TDI permanent Swirl flap arm replacement fix
  71. Strange smell from Air vents.
  72. Rear Wheel Bearing
  73. 2013 S8 displays sports differential malfunction light
  74. Apple CarPlay install
  75. UA: Tyres Audi a8l 2015?
  76. D4 A8L ride and steering gone firm
  77. Just bought a D4 A8 - need help with codes
  78. Level control
  79. ACC Brake Guard unavailable
  80. SA: TR%
  81. Turbo oil screen recall
  82. 2013 S8 vs 2016 S8 Plus - ACC and others
  83. Seat belts
  84. Front passenger carpet
  85. Steering defective do not drive Vehicle
  86. s8 2013 gear problem need help
  87. P0491 & P0492 - 2015 A8L 4.0T
  88. Audi A8 2012 not displaying radio information on dash
  89. Looking to Buy 2015 A8L with 168k miles
  90. Bass speaker replacement
  91. S8 Rollover
  92. Bought 2016 S8 Plus
  93. 2012 FSI Oxygen Sensor VCDS Code Diag
  94. Airbag Light on codes included, No Solution!
  95. a couple questions
  96. NL: I never complained about my car but...
  97. Minor question about front bumper trim below grille
  98. A8 is gone. Lots of things for Sale
  99. 2014 A8L TDI 3.0 - NEED HELP --
  100. Audi A8 LWB 3.0 TDI technical spec help
  101. Front Parking sensor not engaging
  102. 2016 A8 4.0T 118K Codes P0172 and P0175 HIGH PRESSURE FUEL PUMP FAILURE
  103. Transmission coolant valve error - which one is it?
  104. MK: 4.2 tdi I Can't find solution for CHECK ENGINE
  105. S8 carbon fiber dash/door trim question
  106. UK: D4 3.0tdi 2011 Heater matrix Hot/Cold + Coolant loss in expansion tank issue
  107. Poll: TFSI Valve Carbon Fouling / Buildup / Cleaning Issues
  108. Buying a 2013 Audi S8
  109. Help for 2011 a8L upgrades
  110. 2017 S8+ or 2020 S8
  111. W12 Auxiliary Parking Heater Writeup
  112. Oil and pressure diff sensor help
  113. Exhaust Flaps not working
  114. Level Control Fault Code
  115. Crank, No Start
  116. 2015 A8 D4: motor mounts replaced and FlexRay broke
  117. 2015 S8 sport differential replacement and fill questions
  118. Audi A8 coolant temperature not going up
  119. Performance Malfunction in Cooling System - Check Engine light
  120. share your clever Audi a8 modifications
  121. Activation FOB key when engine running
  122. 2012 Audi A8 4.2L D4 Oil Pan Bolts Diagonal Sequence Diagram
  123. Random Misfire, Again...
  124. 2015 A8 L key fob not recongnized after battery replacement...help!
  125. Engine Block Heater Options
  126. Fuel Gauge Malfunction Fix
  127. Audi D4 4H W12 S8 OE Stock Front Brake Rotors (non-CCB)
  128. 20” wheels on S8+ will they fit?
  129. Brake fluid change guys
  130. Question about Audi Side Assist
  131. ACC / Side Assist Unavailable.
  132. D4 A8 S8 Practical tips for oxygen sensor O2 issues & replacement
  133. Power Steering Module undiscoverable???
  134. 4.0 TFSI catalytic converters fail?
  135. Insane Turbo Discount
  136. D4 6.3L W12 Oil Change DIY Writeup
  137. Audi a8 door backlighting
  138. Car not starting (Intermittent)
  139. Turn off active noise cancelation in VCDS 2015 A8L?
  140. Integrated vcds
  141. Replacement of Fuel Injectors 4.0 T
  142. Passenger side headlight washer accessible from top?
  143. Virtual gauges - MMi
  144. 2013 S8 Key Fob programming
  145. Door Trim Exterior
  146. A8 2011 4.2 - P0456 - evaporative emission (evap) system - very small leak detected
  147. Coolant leak 4.0t
  148. Christmas Holiday Sale
  149. Suspension strange noise
  150. Adios.....but keeping it in the Family
  151. Indictors as parking lights
  152. A8 3.0TFSI Shudder Sound ????
  153. driver massage wont start
  154. 034Motorsport Street Density Motor Mounts
  155. Bad Sport Diff Temp and Pressure sensor how to change 2011 audi a8l
  156. Coolant Type 2012 W12
  157. ACC camera EOL
  158. Gearbox oil change questions?
  159. BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
  160. EGR/2015 a8 3.0
  161. BLACK FRIDAY SALE,, SuperSprint Italy
  162. on board camera security code
  163. Ride comfort with Winter/Snow tires
  164. Ventilated seats
  165. Parking Camera
  166. S8 body kit on A8 D4 2012
  167. Which oil for 4.2 v8 petrol engine?
  168. Mechanic says NO to aftermarket wheels
  169. Cam Adjuster valve gasket
  170. Suspension D4
  171. Sunroof headliner
  172. Picking up my D4 S8 Monday - help with winter wheels/tires?
  173. New to me S8 plus, couple random questions
  174. Steering Issue
  175. 2017-2018 S8 Brilliant Black
  176. 3.0TFSI Long Crank Time
  177. 2015 A8L massaging seats
  178. Dynamic pitch angle offset
  179. Which tune would you go with?
  180. Replaced front end air suspension. Now it says “Air Suspension System Fault”
  181. Rear seat and air bags question
  182. Dynamic steering full lock left & right unequal?
  183. Audi TDI Production Numbers
  184. 3 Year Itch?
  185. VCDS connection issues
  186. Bang & Olufsen Dash speaker rattle
  187. Made a NY/LA trip
  188. A8L on a 2.3 mile roadcourse!!
  189. Edit I meant
  190. 1999 Audi A7 V8 quattro?
  191. Traffic Sign Recognition
  192. Would rather have D4 W12 or D4 S8/S8+??
  193. W12 with Active Warranty Spotted on Craigslist!
  194. Might be time to sell the Audi...
  195. Strange squeal from V8 4.0T
  196. USA: 2014 3.0 TDI dpf delete questions
  197. Window switches disabled while in reverse
  198. It just needs gas, right?
  199. Best way to sell my dad’s 2015 Audi A8 diesel?
  200. Seat position sensor open circuit to b+
  201. Where do I find TPI 2034239...?
  202. A8L buying advice/help
  203. UK: Mr hael?
  204. DIY: Gas cap strap repair
  205. Known issues thread for 2015-2018 A8...?
  206. Any "mods" to make the rear tail light section look more like the 2019+...?
  207. Buy older S8 or newer A8
  208. UK: Diesel Oil change?
  209. Before buying your A8 - did you look at the Jaguar XJ...?
  210. Are these wheels Audi OEM?
  211. FOB alternatives (Flipper Zero)
  212. 2011 A8L 4.2L CDRA voltage question
  213. Cardon shaft removal help please.
  214. Need some help with suspension issue 🤷‍♂️
  215. Time for New Tires Again
  216. Losing oil
  217. My 2017 S8 Plus with a few OEM Updates
  218. plastic pieces
  219. Audi A8L Passenger Side Oxygen Sensor Replacement
  220. Crankshaft Audi A8
  221. D4 Owners Who Previously Owned D3's - What do you like / dislike about your D4?
  222. SE: Adjust timing with engine still in?
  223. Floor Jack suggestions?
  224. No power to air compressor
  225. PDR Question
  226. Who runs sportscatted downpipes???
  227. Timing chain issue or?
  228. Body Roll
  229. Triangular screen in the center of the dashboard
  230. UK: Diesel Misfire cylinder 5?
  231. Rear License Plate Upgrade OEM+ / Also a Sad Tale
  232. NAUDITDI from NY
  233. The End Game Subwoofer - Simple Add On
  234. S8 drag racing YouTube video
  235. Transmission Adaption Procedure
  236. A8 D4 Facelift - Radio Tuner Control Box Location?
  237. Anyone running the Intergraded Engineering 4.0T fuel plungers??
  238. New 22s fitted and dropped with links
  239. Fixed the sunglass holder, now the sunshade is broken
  240. Extended Warranty,: Endurance, Fidelity, Zurich...
  241. Tightening caliper bolts
  242. anyone run these 21" stock wheels??
  243. Bad News / Good News
  244. Audio intermittently cutting out
  245. Stalls after starting
  246. Front S8 Badge Question
  247. A (Hopefully) Definitive Thread on D4 Brakes - CCB vs. Standard Materials
  248. Possibly Buying S8+
  249. Hose part number
  250. Good mechanic in Vancouver, Canada area
