PDA
View Full Version : A8 / S8 (D4 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Engine hiccup while cruising steady state
  2. Cost to Replace Battery in 2017 A8 4.0T (36K miles)
  3. '15 A8 3.0 to '15 S8?
  4. 2017 S8 purchase 40,000 miles
  5. Electrical gone crazy
  6. C103B13 fault code (solenoid for level control system-open circuit)
  7. Fault Code U111300 & U112300. Suspension, ESP, Error
  8. Minnesota TDI
  9. Passenger side oil lines
  10. Audi s8 2013 starts then immediately stops
  11. Solar Roof Panel popping out of sealing frame
  12. Air intake housing question
  13. Component protection
  14. 2013 A8L 4.0T help choosing a tune
  15. Options for roof bars
  16. 2011 A8L D4 Post Squirrel
  17. Back up camera problem
  18. 2018 S8 Plus Owners here ?
  19. 4.0T: 14'a8l oil streaming out back of engine under firewall??
  20. calling 6.3 W12 owners...
  21. JQ Werks paddle shifters
  22. Parking aid sensor replacement in front grill
  23. DIY TCM tuning - ZF 8HP
  24. Internet upgrade.
  25. Cold air intake
  26. Canbus data for project
  27. Wire Clip for MMI
  28. Has any non S8 owners upgraded their front brakes to SQ5?
  29. CL: 📌 Title:** Best Speaker Replacement for Audi A8 with Bose System
  30. CL: 🔥 Best Wireless Apple CarPlay Module for Audi A8 MMI 3G+ · Low Latency & Siri
  31. AEB Settlement?
  32. Exhaust Options?
  33. 8169 - Terminal 30 U140A 00 [040] - Open Circuit
  34. İnability to go straight on the road
  35. steering wheel vibration
  36. Gas Mileage with COD on vs. Off?
  37. Suspension knocking noise
  38. Smallest wheel with Carbon Ceramic Brakes
  39. A8L 4.0 TFSI transfer case oil
  40. Windscreen washer
  41. MMI keeps restarting
  42. transmission filter replace - imperative??
  43. Has Night Vision ever been retro-fitted to a D4 ?
  44. Nice D4 W12 w/22K Miles on BaT
  45. want a good laugh ??
  46. any recommended Fuel Pump Brands
  47. TDI vs 3.0T
  48. Rough idle when cold
  49. A8 No crank problem
  50. Night Vision failure - B2000 F2
  51. D4 front brakes question.
  52. Confused after changing ride height sensor
  53. New owner/member intro
  54. For those who have done motor mounts previously
  55. BH: Weird noise
  56. know of an Audi indie shop in Oceanside, CA ?
  57. Turbo oil line leaking
  58. Rearview mirror cover removal
  59. Help Needed: New Air Struts Installed, 363621 Valve For Damping Adjustment Code
  60. Thermostat Issue any experience?
  61. Roof Bars LWB?
  62. PCV Audi S8
  63. EPC Light and Parasitic Battery Drain
  64. 2016 A8 4.0T Heater Core Leak?
  65. Flying to check out my tentative first Audi! 2013 S8 loaded
  66. Google Fi data only sim in 2015 A8L TDI
  67. S8 D4 - Low level coolant
  68. weird air suspension issue - front right deflates
  69. Which dye can u use with audi g12evo coolant?
  70. Aftermarket grill options
  71. HPFP High Pressure Fitting
  72. this came on ACC and Audi braking guard on my 2015 A8L 4T
  73. Lube Leak
  74. Problem With PCV
  75. Vehicle Data Sticker
  76. Stumped After Disc and Pad replacement
  77. Driver side Low beam headlight does not working
  78. D4 Air ride struts/compressor replacement
  79. Road Force Balancing
  80. Shared Transfer Case/Differential Fluid change?
  81. Door lighting
  82. fitcamx dashcam
  83. Something Burning
  84. Rear window control conundrum. 2016 A8 L
  85. D4 S8 4.0T vs D4 A8 4.0T
  86. BTRES Power Cable Help
  87. 20212 D4 A8L SUSPENSION ISSUES...
  88. A8 OEM Parts
  89. Warranty Question Regarding O2 Sensors
  90. Optima Battery
  91. Headlight condensation
  92. Higher Milage - Fix stuff or sell it?
  93. W12 Engine Misfires
  94. SparK Plug Recommendations please
  95. 18 inch wheels on my W12?
  96. SEAT POSITION SENSOR
  97. Found ECU Loosely covered with plastic
  98. Michelin Pilot AS 4
  99. Car Radio Android13 For Audi A8 2011-2017 Auto with flip out/in functionality
  100. A8 3.0 flex fuel?
  101. EPC Light and VCDS 18604 Oil Pressure Switch 3
  102. LED Headlight Fan
  103. 360° camera
  104. Air suspension issue. Please help
  105. GE: MOTUL to LIQUI MOLY
  106. Error Code P0671 - Glow Plug 1
  107. Wiper stalk replacement instructions
  108. S8 Plus D4 Ceramic Brakes Conversion To Steel
  109. Timing Belt change
  110. Flashing Glow plug question?
  111. Rear Massage Seat Function
  112. REAR SEAT ENTERTAINMENT NO POWER - audi s8 d4
  113. Audi A8 2015 MMI,Radio&Sound modules No Communication
  114. Downsized Winter Wheels and Tires!
  115. D4 or D5 S8?
  116. S8 Lower Control arm bolt bit?
  117. Steering wheel weight vcds adjustment
  118. 4.0T oil leak from front passenger side of engine
  119. Which is Circuit B Maff Sensor
  120. UK: Great Engine Overhaul
  121. Lost or misplaced S8 key - Replacement
  122. Rear sunroof shade problem
  123. Looking to purchase A8
  124. Fuel related issues
  125. A8 D4 Suspension Problem
  126. 2015 Audi A8L P0343 Bad Cam Shaft Sensor
  127. Spark plug replacement
  128. Bose no sound
  129. Audi A8 D4 Active Sound
  130. Which wheel is this?
  131. Coolant Leak on 2017 Audi A8L 4.0T
  132. alarm siren location
  133. VW 511 oil for 4.0T?
  134. Fitting 2016 S8 bumper to my 2016 sport executive
  135. ACC and Audi Brake Guard Unavailable after washing car – with easy fix
  136. Confort keys (keyless go) not working properly
  137. Front suspension woes
  138. High oil consumption 3.0tfsi
  139. New Exhaust Option?
  140. 2012 A8L 4.2 transmission?
  141. Top Hose that connects to Coolant pipe Union
  142. 360 camera guidelines disappeard
  143. Next move after D4?
  144. 2013 Audi A8 - will not start intermittently
  145. 2016 A8 no AC
  146. Aftermarket AV upgrade- which option?
  147. A8 open circuit
  148. D4 vs D5 4.0T fuel economy?
  149. More Codes. Sorry.
  150. On to new adventures! Selling the collection off
  151. 2014 s8 Dash Button and console lights not working
  152. Sports diff fault
  153. Oil change prices in your area, Oct 2024
  154. Long Time Lurker, New Owner
  155. Black edition window trim
  156. Sad, but time to say goodbye for now
  157. Brake light on after pads change
  158. Audi A8 D4 pre-facelift 4.2tdi starting problem when warm/driven
  159. Underboost error
  160. UK: Adaptive Cruise Control retrofit help please 🙏
  161. Mystery Engine Part - O2 Sensor Replacement
  162. Transfer Case Oil
  163. 4.0TT Knock/Tick
  164. Motor Mount Code Question
  165. W12 Owner’s Club Meetup
  166. POE and PAG
  167. Lexani Tires - The start of a stupid journey, with a stupid beginning
  168. 4.2 FSI Intake Flap & Air Injection Flow
  169. 75k Major Service... 4.0
  170. A8 D4 oil in ignition module and spark plug area
  171. 2015 Audi A8L 3.0 Front Suspension Refresh (rattles and squeaks)
  172. A8 D4 Air ride suspention issue!
  173. I have a 2020 audi a8l sunroof
  174. D4 vs D3...questions for those who have had both...
  175. Polyurethane bushings
  176. New brake pads and old rotors?
  177. Engine Air Filters
  178. Audi Mechanic near Linden NJ?
  179. Brake warning light
  180. Help with VCDS scan - Both banks rich and CEL
  181. Audio upgrade paths
  182. AU: ODIS?
  183. Searching for the previous owner of this 15’ A8
  184. Need a solution
  185. Camera Calibration specs for 2011 A8 4.2L
  186. KZ: Combustion misfire, ignition coil order
  187. PaulW's Project TDI
  188. UK: Audi A8L 4.2L diesel Quattro 2017 D4
  189. Tow eye cover
  190. HUD delamination fix
  191. Audi S8/A8 D4 key fob - not working intermittently.
  192. Power Steering stiff
  193. Squeak in front suspension
  194. Floating disc creaks
  195. S8 D4 Brake Pad Warning Light
  196. Alignment
  197. MMI 3GP - possible to downgrade?
  198. Yes, you CAN tow with your A8!
  199. Stage 3 S8 goodies incoming
  200. Check Engine Light Reappearance
  201. High Pressure Fuel Pump or Other Cause of Hard Start?
  202. Burkeomatic's A8L Build Thread
  203. Detachable tow hook fitting
  204. Anyone know the part number for the seal of air box
  205. Steering column lock faulty after replacing with new
  206. Removing entire positive cable from Battery to Engine bay?
  207. 16 A8 4.0 Excessive Oil Consumption / Faulty PCV
  208. Question about plastic intake tube
  209. 2015 A8 3.0 TDI. 43k KM - good deal or avoid?
  210. 4H1819403E9B9 Cowl Cover
  211. Intake Manifold Flap Codes
  212. Moteur A8 4.0 TDI de 2003
  213. How to remove center console side panels
  214. 2015 A8L front disc brake pads...what size?
  215. Tire Consumption
  216. Keyless entry - Key not recognizing - Help from everyone
  217. Loud whistle still occurs after replacing PCV 2 times.
  218. Front seat ventilation
  219. Key intermittent issue recognizing
  220. 2013 Audi A8 - disable auto stop/start
  221. Upgrade Maps & MMI
  222. Side Assist Fault
  223. What is this?
  224. Do I want to tacke this A8L restoration?
  225. 2014-2015 Audi A8L Singapore Import
  226. A8L Staggered Low ET 21" Help and Suggestions please!
  227. 2013 A8L W12 - thermostat replacement, whole housing required?
  228. Replace windshield camera
  229. HR: Audi a8 4.2 TDI 2010y problem whit chanel 01 and 11
  230. MAP SENSOR LOCATION
  231. Has anyone played around with the tire size like this before?
  232. Carplay for Audi A8 plug and Play!
  233. AC Question
  234. Audi a8 4.2L starter replacement
  235. S8 D4 high engine oil temperature
  236. ACC - is it really 2.5 MPH increments?
  237. OEM extended shift paddle question
  238. D4, A8/S8 seat backs with table top
  239. 4.2 FSI Oil Filter issue
  240. 2013 Audi s8 start then stops.
  241. Air Suspension Fault in Audi A8L 2015 V6 50TFSI
  242. Timing chain wear on 4.2FSI
  243. $270 software update?
  244. Stage 4 2017 A8L
  245. Road noise
  246. Which A8 to avoid?
  247. UK: Stone chip protection stickers?
  248. Changing the gear selector?
  249. 2016 S8...new owner with silly question
  250. 2013 A8L 4.0 Power Steering Pump Replacement
