PDA
View Full Version : A8 / S8 (D4 Platform) Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. 2013 Audi A8L fuse for radio receiver blew
  2. Cost of Ownership
  3. Airsuspension, Reset all adaption
  4. 17 S8 Plus Battery Replacement Procedure?
  5. Center Console/ Cup Holder Lid
  6. 2013 A8L D4 rear brake pad change
  7. Rear AC Controls
  8. HU: 2016 D4 armrest phone
  9. S8+ Exhaust
  10. A8 D4 2011 intermittent A/C failure
  11. Question on Audi A8! Any advice is helpful
  12. Headlight Assist: Unavailable No Camera View
  13. Need help, 2017 Audi A8 wire broken
  14. 4.0T Waterpump?
  15. Spark Plug Gap W12?
  16. Prevent Dry Start
  17. 2013 A8 hybrid Power steering issue
  18. BG: Ambient lighting coding to make it brighter?
  19. Umbrella holder
  20. A/C Evaporator Drains
  21. 2013 A8L tail lights?
  22. s8 gearbox max torque limit?
  23. Left Headlight Out (Full LED)
  24. CH: Aaudi s8 2021
  25. D4 S8 Rear Deck access. (Rear Seat removal?)
  26. Bought a 2015 S8… and my expectations were blown away
  27. KZ: Anyone using 17" wheels?
  28. Question re Michelin Pilot Sport AS4
  29. 2013 S8 - folding mirror repair help
  30. Thoughts on possible new A 2017
  31. Tail light error on my 2011 A8 D4
  32. Looking to Purchase “high” mileage S8.
  33. 2017 Audi A8L 3.0T (gAs) rotor&pad replacement!Help!
  34. 4.0T Engine making strange ticking/knocking sound
  35. Looking for a great highway + mobile office
  36. 2011 A8 start engine stop engine button
  37. 2013 A8L lane departure control module
  38. Newly-acquired 2013 A8 L 4.0T
  39. Sport differential problem
  40. Ac fan problem
  41. Motor Mount Buzz Test vs. Sensor Coding
  42. S8 starter dead?
  43. Broken seat adjustment button
  44. Looking for subwoofer box
  45. Which is more reliable between the Audi A8L 3.0T and the 201 Audi A8L 4.0T?
  46. No gears working and multiple faults displayed
  47. 2012 A8 4.2L - New OEM software flash boosted HP
  48. My 3 NHSTA Recalls
  49. A8 4.2 tdi Aircon issue ​​​​​​​
  50. MMI screen
  51. Who has the highest mileage S8 D4?
  52. RO: Need help with high beam assist please..
  53. What about the rear axle control arms?
  54. A8 2011 D4 V8 TDI COLD START
  55. Air suspension issue
  56. Noise from the right side while in 1st gear no gas aplied.
  57. RS5 flat Steering wheel swap
  58. 4.0 engine sharing but no problem with Porsche?
  59. Leveling Control Module No Coding
  60. Parking neutral swich p0850
  61. W12 6.3L CEJA Head Oil Restriction Inserts
  62. 2015 S8 - Red Audi Exclusive/B&O/Full Leather/Driver Assist/Cold Weather
  63. 2012 S8 automatic seat adjustments on long trips
  64. Announcing the 2013-2017 A8 OIL SCREEN RECALL!!!!
  65. Oxygen Sensor part number confusion!
  66. Audi Production in Germany
  67. A8 reliability
  68. Very odd suspension issue
  69. Importing Music
  70. About strut top mounting?
  71. Lost the 2015 A8L on Sunday
  72. Ceramic rotor lifespan?
  73. NEUE Tires! 265/40/21 on Stock 21x9 rims
  74. What you make of this?
  75. Audi extended TDI warranty
  76. 3.0 TDI Dieselgate
  77. Audi A8 2015 Mysterious Purplish Leak?
  78. 1/008 W12 freshly listed
  79. Abt spoiler for A8
  80. Camshaft position sensor error code
  81. Dreaded yellow suspension fault light
  82. 100k preventative maintenance
  83. How, exactly, does our suspension vent?
  84. KZ: How can i remove this seal?
  85. So where does this wire go..?
  86. Regular maintenance (not done in a service)
  87. KZ: re-calibrate air suspension with bleed all airs from strut
  88. Which is faster: stock S8 plus vs S8 650hp stage 1 MTM
  89. Really neat 4-seater A8 on BaT
  90. 2011 Audi a8 4.2 coolant leak in rear part
  91. A8 Control arm bushing beed VCDS calibration?
  92. Windshield Camera Adaptive Cruise Control Replacement
  93. dj315?
  94. Audi A8 Taillights EU coding
  95. Audi MMi mechanism problem
  96. MD: blowing right side window
  97. UK: Brake pad warning light coming on
  98. Retrofitting facelift mass damped suspension forks?
  99. Shut Off Ride Height Warning D4 A8L
  100. SA: Camera issue
  101. Upgrading the older lights with LEDs
  102. Loose rear sunroof shade
  103. No heat in S mode?
  104. UK: BlackVue Front & Rear Camera (with rear blind)
  105. 2015 S8 Muffler Delete
  106. 2017 RS7 Muffler Question
  107. Knock knock.....
  108. Car lost all power this morning
  109. 2015 A8L 4.0T Odd failure and odd diagnosis
  110. Valve Cover gasket? Piston?
  111. Help identifying leak?
  112. Anyone have instructions for changing spark plugs for the 4.2?
  113. Air Suspension error code query
  114. Help identifying leak
  115. MD: What you buy from Aliexpress?
  116. Offroad + Efficiency + Race in Menu
  117. My Stage 3
  118. Active sound exhaust in my A8
  119. I love this car so much!!
  120. strange noises felt in the gas pedal
  121. 2015 D4 air suspension solenoid location
  122. Need help
  123. Auto Park / Android Auto
  124. New addition to the family
  125. Brake Pad Replacement for Audi CCB
  126. 2013-2017 4.0 T Turbo Oil Screen Recall Thread
  127. New control arms and ball joints, check!
  128. AT: Buying an Audi A8 D4 facelift diesel
  129. Initial Rough Shift When Cold
  130. Tennessee Potholes
  131. SA: Level Height Control
  132. Headlight diagram
  133. Front end clunk, cant figure it out.
  134. No Heat
  135. Texas A8/S8 Owners - Twisted Sisters Drive This Saturday
  136. New safety recall oil screen
  137. S8 with B&O Sub install
  138. APR Stage 2 with Stock Turbos?
  139. Just took delivery, am I getting into a money pit?
  140. Wheel Setup?
  141. 21" Rs6 Style Wheels on my 2017 A8L 4.0
  142. Lowering 2014 S8
  143. Which D4 to choose...
  144. O Wise Forum Members... Guide me to the Sacred A8
  145. Audi exclusive
  146. Pinnicals newest 48MM turobs!
  147. Looking at a used S8
  148. Removing upper dash trim?
  149. Error Code help!!!! I have a bunch 2016 Audi A8L
  150. Audi A8 D4 4.2 TDI 2011 MODEL HEADLIGHT
  151. Easy to clean wheels?
  152. Recommended diagnostics tools for D4
  153. A8L D4 4.0T Sport, How to install twin Airbox?
  154. S8 stock ride height?
  155. SA: Car Juddering - Urgent opinions?
  156. The one mod I have been itching for! BTRes
  157. Where is the headlight washer pump location?
  158. Spring cleaning
  159. Turn signal clicking sound intermittent
  160. Favorite S8 vanity plates?
  161. Suspension makes a CHIRP sound
  162. No warning chime when blinker left on?
  163. S8 (2017) Crank case vacuum
  164. Battery change
  165. Air Suspension very stiff (no error codes)
  166. Inspection Due reset
  167. Anyone used Cquence brand 380mm rotors? Seems like a realy good price
  168. GENDER Reveal - Newest Legacy/Acquisition
  169. Get Hard - No Really!
  170. Sold my A8. Now what??
  171. SQ5 21" Wheel question on 17 A8
  172. Malone Stage 1 Tune
  173. Replacing coolant regulator (Union) 4.2 L
  174. Sunroof/Sunshade re-calibrate
  175. EPC dash light at the track!!! 2017 A8 4.0
  176. Battery reset
  177. UK: 22"
  178. Lane Assist Camera stolen, repair guy asks for windshield replacement
  179. Wakaa installed, MMI screen not working
  180. VCDS CAN Gateway - No Response
  181. Vredestein Tires
  182. Code P2755, anyone had this problem and what was the solution?
  183. 2016 A8 4.0l ECP & CEL light
  184. Outer Tail Lamp Assembly Replacement, ULO brand?
  185. P050A00 - Cold Start Idle Air Control System Performance
  186. Heated Rear View Mirror failure and DTC ...
  187. 4.0 turbo Audi warranty extension announced
  188. New, 2016 A8L 4.0t owner, couple questions for you all
  189. Air Suspension is to low - error message?
  190. D4 wiper blades
  191. Front Suspension Work
  192. Retrofitting with Full Led headlights Audi A8 D4. Help
  193. RSE/full leather bits for sale
  194. engine addititves? - 4.0T
  195. Extended Can-Bus and Rearview Mirror with HBA
  196. New real carbon fiber spoiler arrived!
  197. 2014 A8 License Plate Bulbs
  198. ZA: Audi A8 Transmission problem
  199. Front end overhaul 2014 S8
  200. Factory pathway of the power cable to the electric steering rack?
  201. Revisiting my front suspension
  202. Stealth light bar installation...
  203. UK: High Revs in High gears at slow speeds for first few mins driving
  204. KZ: Engine not warming up
  205. Quick and easy USB port solution
  206. New owner with pics and questions
  207. Oil level sensor; pre-emptive replacement?
  208. 4.2 Preventative Maintenance: Coolant leaks
  209. 2012 A8 Drive Select "thump/clunk"
  210. Sport Differential fluid confusion
  211. A8L Trunk Motor does not work
  212. Rear view image looks wonky
  213. 2016 A8L 3.0T tuning options?
  214. Steering defec
  215. Engine Oil Cooler Removal
  216. 2010 Audi A8 4,2 fsi quattro fan control.
  217. SA: Car Hiccups
  218. Tuned stage 1 A8 4.0 vs stock S8
  219. Let the spending begin!
  220. Extended Warranty
  221. Leaking roof
  222. Acc/brake guard warning
  223. 2011 A8 SUNROOF
  224. MMI Black Screen
  225. Recognize these wheels?
  226. 2005 Audi A8 Weird Noised
  227. Weird Noises when car is turned off
  228. Really need help ( Mecanic erase all adaptations to suspension module
  229. Really need help ( Mecanic erase all adaptations to suspension module
  230. UK: Location of ACC unit Audi A8L 64 plate
  231. Front suspension sag with cold weather
  232. Help with VCDS error code 677386 / C1046
  233. B&O sub replacement, ANC disable?
  234. VCDS calibrating air suspension problem
  235. Turbo Boost Sensor? P154F00 on OBD11
  236. A8/S8 4.0TFSI Suction oil cap, PCV replaced.
  237. Accidentally cleared OBD codes for MIL light
  238. Name that fluid!!
  239. O2 sensors, fuel trim faults-LEAKING OIL NOW!
  240. Aftermarket Wheel Issue?
  241. Will SQ5 21 inch wheels fit my 2014 S8?
  242. Disable Stop/Start function
  243. 2012 A8 D4 4.2 FSI Gearbox problem
  244. UK: Replacing TPMS Sensors?
  245. 2016 A8L relay heating issue
  246. Ignition Coil - Far From Hom!
  247. UK: 2009 Audi A8 2015 rear window defroster not working
  248. CD changer stuck in a loop
  249. Remote Start Install
  250. RO: Water sloshing, and no heat on very low temperatures - might these be related?
