- Exhaust Cutouts - Comprehensive Review & Sound Comparison (D4 S8)
- APR Stage 1 issue?
- OEM 20 vs Vossen 21 vs 22, opinion pls?
- Bridgestone Turanza QuietTrack tire question
- Totaled 2017 A8l 4.0T
- Reset Active Head Restraints?
- Sold 2013 Audi S8 - Bought Tesla Model 3 Stealth Performance
- BG: A8 4.0TFSI gearbox change issues... HELP HELP
- Dash noise
- Any way to get traffic to display on Nav without Sirius?
- S8 D4 front left parking sensor open or short to ground
- Error code p0491
- Glow plugs on a 2014 A8 TDI
- Air Vent Switch Not working
- Audi S8 MY2013 Air suspension maintenance/change
- Suspension rattle cause and fix?
- Engine ticking, causes and fix?
- Just purchased a8. What problems do I need to know/inspect??
- HELP :) Driver Air Suspension - Replacement Hose
- Wheel bolt corrosion
- OBD11 helped me quickly track down air suspension problem - need help
- Is it too cold for the A8 ? (2011 A8L)
- 2014 A8 TDI problems?
- Another tire question
- Part number for A8 3.0T dipstick?
- Oil level sensor fault - Max oil level
- Potential Volatge issue
- SafeLite Glass
- Warranty
- Washer fluid warning
- AUDI A8 SOFT CLOSE CAR DOORS
- Autonomous driving 2016 Audi A8
- Audi A8 D4 Bose Subwoofer Repair/Replacement
- Much quieter after new front brakes.....
- Air suspension sensor fault
- Steering heavy or light?
- Carmax 2013? What do you think?
- Oil Strainer Relocation and PCV Valve Job
- Problem with coolant fan nr 2
- Audi A8 D4 hanging headliner
- Pre/Post Facelift Question. Specifically hood
- Rear LED light repair
- Spacers for 20" wheel?
- Parking aid intermittent......
- New 2017 Audi A8 4.0 Owner
- '11 A8L Air Suspension Calibration?
- What does Audi have against USB ports?
- 2012 A8 - Repair List-- This seem normal / expected?
- New owner intro
- Can't release emergency brake after rear pad change
- Hello 2012 Adui A8L 4.2L V8
- Active Head Restraint Fault Msg
- Caliper Replacement
- BMW (mini) Countryman All4 Test Drive vs A8, or anything else that makes sense
- MMI/Navigation Update?
- PCV repair
- Streaming Video on MMI
- Another tire thread
- Battery died, issues after charging
- Wiper Arm Puller Kit - HELP!!
- Veritas Protection
- 2004 A8 Honeycomb mesh grill
- 4.2l FSI V8 A8L exhaust modifications/ other modifications
- Wheel/tire size?
- MMI screen is black help
- Ebay tunes for 4.0T?
- 2015 A8L Audi Pure Care, confusion, mmi covered?
- 2013 A8L on Junkyard Empire
- A8 Automatic Door Lock When Away?
- W12 vs 4.0t
- Navigation Update, Sim Card
- need help replacing xenon head light.
- 2012 4.2 Engine / Ticking Noise
- Trustworthy Indy In DC Metro Area for A8?
- Audi's Dash Camera (UTR) Experience?
- Odd vibrations with the sports diff on and high speed.
- 2015 Audi A8L D4 Rear Cupholder removal/replacement
- Tire Time Again
- Which wiper blades fit?
- Audi A8 D4 Front Suspension rubbing control arms
- New S8
- A8 3.0 aftermarket exhaust setups.
- 2013 A8L 3.0T Exhaust Vibration Question
- Need help with part numbers for under body sound insulation.
- Air Condition Adjustment in MMI?
- P0018 / check engine light
- Switched powered fuse on front cabin.
- QuickJack for Home Garage
- getAudiparts.com | Genuine Audi Universal Traffic Recorder!!
- Full leather package worth it? S8
- TRIANGLE TH201 SPORTEX Tires
- Proclip phone mount highly recommended
- 2015 Audi A8 3.0 35k service
- How to swich off passenger airbag
- S8 4.0 V8 Misfire
- Waterleak
- Speaker Replacement? 13 A8L
- Button combination for rear seat engineering (red) screen?
- A8L D4 (2011) Front Suspension Very High After Collision
- Mighty Nokian Hakkapolitta R3 Tackle First Snowfall
- Change xenon head light
- Vibration issue
- 3.0L V6 Coolant Routing Diagram.
- ODBEleven Early LKA and HUD Elements
- Quiet Chirp, beep noise. Not mechanical.
- New to the Audi world
- Hello All, I'm Proud to re-introduce myself to AW
- APR Stage 1 2014 A8L 4.0
- Introduction
- Help with removal of air conditioning module
- D4 pre and post facelift
- Lane assist/ Active lane assist activation
- Black vs. Silver (buttons)
- 2017 A8L 4.0 bulletin for vibration due to exhaust system:
- What's next? D5 or something else?
- help me install cete active suspension control on s8
- Are D4's noticeably more reliable than D3's and should I go TDI this time?
- Headlight part number
- Audi A8 2017 Alignment.
- Brake pad change help/question
- Transmission Malfunction: You can continue driving.
- OBD II showes 00137 Code
- My A8L vs new M3
- Driving position, squashed Rooflines - Removed my sun visor
- Rear Sunshade Problem (Not the sunroof)
- D4 dipstick issue
- Traffic Sign Recognition for US model?
- 2012 Audi A8 Relay for Ride-Height Compressor Mechanical Failure
- Audi A8 2016 Sunglass holder Spring replacement
- Bought a Q5 to get my A8 back!
- Brake Pedal croaks
- MMI/Navigation Aftermarket
- S8 Ceramic brake squeal
- Speaker buzz from front centre dashboard Bose speaker
- Broken LED Headlight Bracket
- CH: Tyre pressure warning Audi S8
- 2014 AUDI A8L TRUNK ISSUES
- Hi! I whant to update my Mmi on my audi a8 d4 facelift made in december 2013.
- DO NOT MISS OUT ON THIS SALE! GET THE GIFT YOU WANT
- Audi S8 Plus Maintenance Supplement
- 2013 Audi A8L 4.0T vibration from 70 mph and up
- front brakes source
- Data blocks VCDS
- TD1 Avoidance -- 2nd ECU
- The crazy extra large wheel size phenomenon
- 2012 Audi A8 - Broken Dipstick Tube Cap
- (wrecked) ...Insert Explitive-Laden Title Here...
- Transmission Service or Not
- Climate control unit removal
- UK: Audi A8 Headlights Bulbs ?
- A8 or S6
- Ex D3 owner looking to get into a D4
- Anyone with a Gen 1 D4 3.0TFSI APR tune
- Newbie Tire Replacement Question
- Share Your DIY Air Strut Replacement Experience
- Audi A8L 2011 Drive Power seat not working
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Preventive PCV and oil screen change?
- Transmission issue
- Oxygen sensor Audi S8
- Engine Dies when Turning and hold steering wheel to maximum left
- S8 vs. flying object on freeway - advice appreciated
- Quality Leather Conditioner/Cleaner
- Any way of just getting the red interior lighting to work without the whilte...?
- Will these wheels fit the s8 with no problem?
- Rear End Shimmy
- Are the brake pads/rotors and installation at the dealership more expensive on a 4.0?
- Trubo speed sensor
- Updated ECU software number for 4.0T?
- Audi A8L vs Mercedes CLS550
- Combine Black Friday and Movember to Save Lives and Some Dough!
- Rear Spoiler
- Ordered New Snow Tires: Nokian Hakkapelitta R3
- A8’s Rear Pads
- HELP: Spilled Hot Cider on Control Buttons
- Engine mount fault code won't go away
- Tire pressure in kPa instead of PSI
- Bearing hub kit
- Audi A8l,2014 3.0 TFSI FULE FILTER REPLACEMENT
- Automatic remote start for Audi A8 yet...?
- Multiple System Failure - 2016 S8
- Going from OEM 20" wheel to 19" OEM wheel...?
- Active head restraint reset?
- Turbo oil screen replacement and pcv valve on 2013 A8l 4.0t with 76k miles
- Vibration at 1200 RPM - 12mos after downpipes!
- Control RES from front seats?
- Leads on a used S8?
- 2014 a8l 3.0 - p0337 crankshaft pos sensor
- What’s the lightest 21” wheel for my s8
- Clunk when I take foot off brake pedal
- Squaking Noise from front end.
- Upgrade to ApplePlay
- Left Audi ownership
- Fuel Filter question
- A8L aggressive engine braking and driveline slop
- Sunshade parts question
- Fuel Line to high pressure pump
- Transmission mount insert
- Charging phone in the S8
- EPC Light - Underboost
- A8l D4/4H front lighter fuse
- 2011-2012 4.2 A8 issues? Any catastrophic failures
- Front Brake pads and rotors DIY
- 2012 JUST HIT 200K...
- Cold Air Intake Options? (Please Read)
- Fluid Leak at Axle Bolt. Diagnosis?
- Oil change 3.0T Oil filter warning
- Carbon ceramic brake noises
- Small bed spring squeak sound from dash
- TDI phase 2 recall complete - new vcds fault
- Anyone audition/test drive a Jaguar XJ before deciding on their A8...?
- UpgradeMyAudi.net Apple Car Play module $700 + install
- VCDS Non-standard Tire/Wheel Size
- "Remote Start" Audi A8 L 4.0T
- Dropped Audio
- fuse location for interior lights power door and roof
- MMI Upgrade to k_0942
- Anyone else using HP Tuners to tune the TCU
- VCDS for MAC
- Where to put in GDI cleaner
- SQ5 winter tires fit A8 d4 ?
- 2012 A8L High Pressure Pump Replacement
- A good way to avoid blowing the turbos in A8 4.0
- rear parking buzzer location
- Boosting Advice?
- Next Inspection message
- Pretty sunset
- 2011 A8L suspension issue
- Water on the floorboard
- Aftermarket Rotors?
- National Breast Cancer Awareness - Donate, Save Lives and more...
- Doors locking when washing
- Carplay Wireless? - Weekend Project
- S8+ Dynamic Package questions
- Real world numbers: Stock vs Stage 1 times for A8l 4.0t
- Tv tuner, firestick, PS4
- Green Screen For 2011 A8
- Carplay
- Rotor stuck on wheel hub assembly.
- A8L 4.0 Alignment Cost :eek:
- A8 D4 4H0 907 637
- Christmas in October (2013 A8L 4.0T)
- Vaca Pics - 1350 miles in 6 days
- Full Headlights Seem Always On - D4 A8
- Vibration is back - after downpipes
- Just Bought a 2011 Audi A8
- A8 Diesel - Steering Wheel twitch when shutting off engine !?!?!
- Rear Camera Will Not Automatically Come ON
- Help: Vibration at low speed - Audi says it is the flex pipe
- Seat and wheel heat
