PDA
View Full Version : A8 / S8 (D4 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Is something wrong with my Bluetooth?
  2. Removing Listed Bluetooth Devices
  3. Seat Belt Removal
  4. Goodyear Eagle Sport all season tires
  5. Power steering issue 2012 A8
  6. Adaptations for 5f module
  7. Keyless entry inop
  8. Wheel Compatibility on A8
  9. A8 4.0T pre-owned purchase decision
  10. Adding subwoofer to B&O S8/A8
  11. Heavy road noise
  12. One Year Since Purchase
  13. Loyal Audi customer just got F○€ked!!
  14. sensor 1 exhaust temp bank 1 G235.
  15. 2015 A8L on 21" before and after
  16. UK: 2014 A8 4.2TDI: LOCATION OF ADDITIONAL COOLANT PUMP?
  17. Eveyone posts about problems, lets hear some good experiences...
  18. Heated wood steering wheel?
  19. Tire Cleaner / Shiner
  20. Part Number Help
  21. 504 oil yes or no?
  22. ABS module repair service
  23. Lane change assist retrofit started
  24. Universal Trailer Wiring Kit
  25. New to Audi and new to this forum
  26. A misfire and engine hesitation.
  27. Signing off
  28. 21inch wheels correct offset
  29. Retrofitting High Beam Assist on 2015 Audi A8
  30. Audi A8 D4 Warm start Issue (Perhaps faulty fuel pump)
  31. Extended warranty from First Automotive
  32. Throttle Reset
  33. Review after 1st year of ownership (2014 A8L TDI)
  34. Parking aid sensors
  35. 2016- 3.0,shifting questions
  36. Replaced PCV/Oil Separator but sill have oil cap suction
  37. Rear bumper removal
  38. Sport Differential
  39. 2017 D4 and 2006 D3
  40. S4 Avant daydreaming inquiry...
  41. Audi A8 d4 factory rear entertainment retrofit RSE
  42. Lift off whine and CEL
  43. MMI 3G+ Software/Nav Update (Fail?)
  44. 2011 A8L 4.2L Air ride warning
  45. Time to start retrofits. Factor Rear entertainment location?
  46. Q8 Loaner
  47. Newb with dumb question about radio presets
  48. A bizarre issue thread - the fuel level sensor saga
  49. Retrofit RS7 Mufflers
  50. AUDI A8 D4 Temperature DISPLAY CHANGE from celsius to Fahrenheit
  51. key fob
  52. question on s8
  53. s8 d4 2015 engine knock
  54. Clicking noise.
  55. Factory Warranty v Audi Care coverages
  56. Looking to buy a '13 S8 - what to look out for?
  57. NVLD Pressure Switch Warranty Extension
  58. Air suspension fail light ( yellow one)
  59. Warranty and engine tune?
  60. Why isn't Quattro adjustable?
  61. natural gold brown inlay..ash wood
  62. Dipstick length - 3.0 engine
  63. Disable wind deflector in vcds?
  64. New Matrix Headlights / IntelliBeam Are Excellent
  65. Lubricant Odor Lingers 30+ days after 35k Service / Ionizer post
  66. Ioniser ?
  67. OIl Consumption. Should I be concerned?
  68. Cost of 55k Service? Brakes?
  69. Brake pad warning will not go out.
  70. Just purchases 2012 A8 4.2L— MOD questions
  71. 14 S8 4.0tt Turbo Lag
  72. DWS06 Contis or Michelin PS4S
  73. Potential 2013 A8 purchase
  74. 2014 audi a8l 3.0t exhaust
  75. 2014 audi a8l aftermarket advanced key
  76. Back-up Light LED Replacement
  77. PLEASE help , rear sunroofs sunshade stuck
  78. 2011 A8 Clock stoped working .....
  79. No Badge 2014 A8?
  80. Auto start/stop
  81. Advice/Thermostat for cylinder head problem
  82. Possible New Owner...Help with Decision
  83. seat comfort - vertical piping on back
  84. Pristine 2017 Black A8L CPO $50k 12k Miles
  85. FL area: Pre Purchase Inspection Recomendation?
  86. Service Intervals A8 Hybrid
  87. Would you buy a "lemon" car that was bought back by Audi?
  88. S8 vs S8+: Different turbos?
  89. Ross Tech VCDS question
  90. Check engine light on
  91. Bought ‘16 D4 yesterday (3.0)
  92. Changing start stop button?
  93. Personalized Plates: What Do You Have?
  94. Audi A8L 4.0 2015 Reverse while driving
  95. O2 Sensor Help
  96. New Summer Tires for my 2013 S8
  97. New Owner Questions
  98. For the 4.0T people, why kind of fuel economy are you getting?
  99. disabling traction control...
  100. So I did a thing...
  101. Is my speaker blown?
  102. 2012 A8L Rear End Damage -- Body Shop Recommendations
  103. Bluetooth connection and message notifications
  104. Differential & Transmission Fluid Change
  105. Isofix question
  106. Warm start fails | 2012 A8 (D4 Platform) | ECT?
  107. Rear seat footrest
  108. Faulty trunk switch? 2015 A8L
  109. Redline and warm up time
  110. DRL Only in Auto Mode (OBDEleven) help
  111. Audi extended warranty?
  112. 2014 A8L 4.0 Oil Filter?
  113. Burning/electrical smell
  114. Vag Com only way to activate VIM ?
  115. Recirculation button keeps last setting (ObdEleven)
  116. Dog Car Seat Cover
  117. Ever seen a Red S8?
  118. Engine cooling fan runs high
  119. 2017 has CarPlay in MMI yet?
  120. Static clicking sound randomly inside
  121. MMI to lightning quesrions
  122. 2015 S8 Stage 2 Exhaust Note
  123. Wheel Fitment check
  124. Headrest Adjustment
  125. 2013 A8L 4.0t Top Headlight Bracket broken
  126. iPhone Cable
  127. Clean/Maintain OCD and Me ... and You?
  128. Wheel and tire size calculation and fender gap
  129. Should I buy a warranty?
  130. Warranty Expiration Checklist
  131. Migrating from the D3 Boards
  132. Audi app a bit crap?
  133. exhaust flap issues
  134. 35k Service on 4.0T Cost $0 under CPO
  135. 2010 A8 D4 MMI update
  136. S8 vs d5 A8 ride comparisons
  137. 2016 S8+ Brake Squeak
  138. Starting to look at D4’s - pano roof reliability?
  139. Audi A8L RSE - Rear maps not updating! HELP!
  140. interested ion a s8 what do i need to know
  141. Audi Recalls Nearly 75,000 Vehicles Due to Fire Risk
  142. Audi A8 2011 Suspension fault
  143. Trunk opens but doesn't lift up
  144. Buying a 2015 A8
  145. Outside air coming in from the windscreen area
  146. 2016 vs 2015 S8
  147. New 2015 Audi S8 owner question about AMI/MMI
  148. Drive select - individual settings
  149. Racechip for 2016 A8 4.0T:
  150. New Safety Recall notice - Fuel Pressure Damper
  151. Did Audi dealership ever lie to you?
  152. VCDS VIM programming help
  153. Car disabled this morning
  154. Interior cleaning
  155. External Video and iPhone mirroring
  156. 2014 headlight swap
  157. A8 NWB 3.0T
  158. To buy or not to buy
  159. Anyone here has the Blackvue DR900S installed?
  160. FNG with a P0133 Code
  161. Security access code 31347 doesn't work
  162. 2011 Audi A8 quattro d4
  163. S8 exhaust tip dimensions?
  164. Beater and the Beast
  165. Help replacing audi battery using Obdeleven Pro
  166. Newbe
  167. I need a favor from you guys!!!
  168. A8 D4 22" Wheels 285/30 or 265/30
  169. New Product - S8 D4 Programmable CETE Exhaust Valve Controller...
  170. Ceramic Brakes
  171. Multi V-belt, change intervals?
  172. A8 vs Genesis G90
  173. Help Identifying Noise from Engine
  174. 2015 3.0 Certification Question
  175. 2013 Audi s8 lowering procedure?
  176. LED REVERSE BULBS
  177. 2015 Audi A8 4.0T new to forum and new turbos
  178. UK: Servotronic reset on 2012 3.0 tdi rhd?
  179. 2012 Audi A8 Steering Problem
  180. Help: 13 A8L jerking when auto start
  181. Brake rotor sizes
  182. VAGCOM in Toronto - Canada Area.
  183. snow tire size for D4 on 18" wheel
  184. VAGCOM in Albany area?
  185. Battery replacement coding in vcds
  186. Spark Plug life
  187. Approaching 75K Service
  188. Winter Warrior Rivals Arctic Snow Cat / Fog Lights Question
  189. 2015 A8 Vibration at 3K RPM
  190. Audi S8 2016 Brake Thickness
  191. 2013 A8L 4.0t
  192. Weird sound from front right wheel assembly
  193. A8L 4.0 won't lower from raised ride height
  194. windshield washer fluid, so annoying to fill up
  195. Front Tires Wearing Out Quickly (2017 A8L 4.0T)
  196. Sway bar end link options
  197. Very confused about APR upgrades to my 3.0TFSI
  198. Reset Gearbox Change Ups
  199. Snow in wheelwell removal tool
  200. What is this under the driver dash board?
  201. A8 front rotors 356mm v 380mm
  202. Winter driving program fault
  203. Anyone selling s8 plus?
  204. 2015 model versus pre-2015
  205. Fuel Rail Recall for 3.0 TFSI
  206. First post...hope im not breaking any rules.
  207. 2015 A8 TDI, to CPO or not to CPO
  208. Strange Spring / Creaking Sound from Center Console
  209. Engine cover ?
  210. 4.0TT Turbo Failure Thread - S6 S7 RS7 A8 S8
  211. *EXTENDED* Intro Price - LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE/FLASH
  212. Just found a coolant leak. Need help finding part number!!!
  213. Update mmi?
  214. No Heat
  215. Cold start issue
  216. Keyless question
  217. 2012 A8L coolant leak, is this the recall?
  218. Anyone interested in a wheel trade?
  219. Warranty on Rear seat center console
  220. Tire Size Change
  221. 4.0t Double Oil Amount!!
  222. 13 S8 changes to exterior
  223. 2015 Audi A8 3.0 TDI Tuner/Programmer suggestions
  224. 2012 A8 timing chain tensioners???
  225. Anyone have an issue with the rear roof shade not closing?
  226. Is vcds required when replacing a 2015 audi battery?
  227. Gone but not forgotten :(
  228. 2013 AUDI S8 AIR SUSPENSION PROBLEM ???
  229. Engine RPM Clatter
  230. Coolant leak fix?
  231. Audi A8L D4 3.0t Vibration
  232. Satellite stuck linking
  233. Need part# for Post Catalytic Bank 1 Oxygen Sensor
  234. Buyer Advice 2012/2013 A8 (4.2 v. 3.0SC)
  235. Interior Lighting Color Profiles
  236. Light malfunction
  237. Underinflated tire pressure
  238. Widest tire on 2016 S8
  239. Upper Control Arm Bushings - Where to buy?
  240. Front Grille License Plate Mount for 2018 S8?
  241. APR Stage 1 Today
  242. BackUp Camera
  243. Simple mods on my 2014 A8L
  244. Service due light reset
  245. Turbochargers for 4.0 CEUA
  246. Oil change due - question
  247. Brake Issues 2017 A8
  248. Possible New Purchase, 2012 A8L Yes/no
  249. RHD D4 on Copart
  250. 4.0 Nearing 35k Service. What did you pay for yours?
