- S8 starter dead?
- Broken seat adjustment button
- Looking for subwoofer box
- Which is more reliable between the Audi A8L 3.0T and the 201 Audi A8L 4.0T?
- No gears working and multiple faults displayed
- 2012 A8 4.2L - New OEM software flash boosted HP
- My 3 NHSTA Recalls
- A8 4.2 tdi Aircon issue
- MMI screen
- Who has the highest mileage S8 D4?
- RO: Need help with high beam assist please..
- What about the rear axle control arms?
- A8 2011 D4 V8 TDI COLD START
- Air suspension issue
- Noise from the right side while in 1st gear no gas aplied.
- RS5 flat Steering wheel swap
- 4.0 engine sharing but no problem with Porsche?
- Leveling Control Module No Coding
- Parking neutral swich p0850
- W12 6.3L CEJA Head Oil Restriction Inserts
- 2015 S8 - Red Audi Exclusive/B&O/Full Leather/Driver Assist/Cold Weather
- 2012 S8 automatic seat adjustments on long trips
- Announcing the 2013-2017 A8 OIL SCREEN RECALL!!!!
- Oxygen Sensor part number confusion!
- Audi Production in Germany
- A8 reliability
- Very odd suspension issue
- Importing Music
- About strut top mounting?
- Lost the 2015 A8L on Sunday
- Ceramic rotor lifespan?
- NEUE Tires! 265/40/21 on Stock 21x9 rims
- What you make of this?
- Audi extended TDI warranty
- 3.0 TDI Dieselgate
- Audi A8 2015 Mysterious Purplish Leak?
- 1/008 W12 freshly listed
- Abt spoiler for A8
- Camshaft position sensor error code
- Dreaded yellow suspension fault light
- 100k preventative maintenance
- How, exactly, does our suspension vent?
- KZ: How can i remove this seal?
- So where does this wire go..?
- Regular maintenance (not done in a service)
- KZ: re-calibrate air suspension with bleed all airs from strut
- Which is faster: stock S8 plus vs S8 650hp stage 1 MTM
- Really neat 4-seater A8 on BaT
- 2011 Audi a8 4.2 coolant leak in rear part
- A8 Control arm bushing beed VCDS calibration?
- Windshield Camera Adaptive Cruise Control Replacement
- dj315?
- Audi A8 Taillights EU coding
- Audi MMi mechanism problem
- MD: blowing right side window
- UK: Brake pad warning light coming on
- Retrofitting facelift mass damped suspension forks?
- Shut Off Ride Height Warning D4 A8L
- SA: Camera issue
- Upgrading the older lights with LEDs
- Loose rear sunroof shade
- No heat in S mode?
- UK: BlackVue Front & Rear Camera (with rear blind)
- 2015 S8 Muffler Delete
- 2017 RS7 Muffler Question
- Knock knock.....
- Car lost all power this morning
- 2015 A8L 4.0T Odd failure and odd diagnosis
- Valve Cover gasket? Piston?
- Help identifying leak?
- Anyone have instructions for changing spark plugs for the 4.2?
- Air Suspension error code query
- MD: What you buy from Aliexpress?
- Offroad + Efficiency + Race in Menu
- My Stage 3
- Active sound exhaust in my A8
- I love this car so much!!
- strange noises felt in the gas pedal
- 2015 D4 air suspension solenoid location
- Need help
- Auto Park / Android Auto
- New addition to the family
- Brake Pad Replacement for Audi CCB
- 2013-2017 4.0 T Turbo Oil Screen Recall Thread
- New control arms and ball joints, check!
- AT: Buying an Audi A8 D4 facelift diesel
- Initial Rough Shift When Cold
- Tennessee Potholes
- SA: Level Height Control
- Headlight diagram
- Front end clunk, cant figure it out.
- No Heat
- Texas A8/S8 Owners - Twisted Sisters Drive This Saturday
- New safety recall oil screen
- S8 with B&O Sub install
- APR Stage 2 with Stock Turbos?
- Just took delivery, am I getting into a money pit?
- Wheel Setup?
- 21" Rs6 Style Wheels on my 2017 A8L 4.0
- Lowering 2014 S8
- Which D4 to choose...
- O Wise Forum Members... Guide me to the Sacred A8
- Audi exclusive
- Pinnicals newest 48MM turobs!
- Looking at a used S8
- Removing upper dash trim?
- Error Code help!!!! I have a bunch 2016 Audi A8L
- Audi A8 D4 4.2 TDI 2011 MODEL HEADLIGHT
- Easy to clean wheels?
- Recommended diagnostics tools for D4
- A8L D4 4.0T Sport, How to install twin Airbox?
- S8 stock ride height?
- SA: Car Juddering - Urgent opinions?
- The one mod I have been itching for! BTRes
- Where is the headlight washer pump location?
- Spring cleaning
- Turn signal clicking sound intermittent
- Favorite S8 vanity plates?
- Suspension makes a CHIRP sound
- No warning chime when blinker left on?
- S8 (2017) Crank case vacuum
- Battery change
- Air Suspension very stiff (no error codes)
- Inspection Due reset
- Anyone used Cquence brand 380mm rotors? Seems like a realy good price
- GENDER Reveal - Newest Legacy/Acquisition
- Get Hard - No Really!
- Sold my A8. Now what??
- SQ5 21" Wheel question on 17 A8
- Malone Stage 1 Tune
- Replacing coolant regulator (Union) 4.2 L
- Sunroof/Sunshade re-calibrate
- EPC dash light at the track!!! 2017 A8 4.0
- Battery reset
- UK: 22"
- Lane Assist Camera stolen, repair guy asks for windshield replacement
- Wakaa installed, MMI screen not working
- VCDS CAN Gateway - No Response
- Vredestein Tires
- Code P2755, anyone had this problem and what was the solution?
- 2016 A8 4.0l ECP & CEL light
- Outer Tail Lamp Assembly Replacement, ULO brand?
- P050A00 - Cold Start Idle Air Control System Performance
- Heated Rear View Mirror failure and DTC ...
- 4.0 turbo Audi warranty extension announced
- New, 2016 A8L 4.0t owner, couple questions for you all
- Air Suspension is to low - error message?
- D4 wiper blades
- Front Suspension Work
- Retrofitting with Full Led headlights Audi A8 D4. Help
- RSE/full leather bits for sale
- engine addititves? - 4.0T
- Extended Can-Bus and Rearview Mirror with HBA
- New real carbon fiber spoiler arrived!
- 2014 A8 License Plate Bulbs
- ZA: Audi A8 Transmission problem
- Front end overhaul 2014 S8
- Factory pathway of the power cable to the electric steering rack?
- Revisiting my front suspension
- Stealth light bar installation...
- UK: High Revs in High gears at slow speeds for first few mins driving
- KZ: Engine not warming up
- Quick and easy USB port solution
- New owner with pics and questions
- Oil level sensor; pre-emptive replacement?
- 4.2 Preventative Maintenance: Coolant leaks
- 2012 A8 Drive Select "thump/clunk"
- Sport Differential fluid confusion
- A8L Trunk Motor does not work
- Rear view image looks wonky
- 2016 A8L 3.0T tuning options?
- Steering defec
- Engine Oil Cooler Removal
- 2010 Audi A8 4,2 fsi quattro fan control.
- SA: Car Hiccups
- Tuned stage 1 A8 4.0 vs stock S8
- Let the spending begin!
- Extended Warranty
- Leaking roof
- Acc/brake guard warning
- 2011 A8 SUNROOF
- MMI Black Screen
- Recognize these wheels?
- 2005 Audi A8 Weird Noised
- Weird Noises when car is turned off
- Really need help ( Mecanic erase all adaptations to suspension module
- UK: Location of ACC unit Audi A8L 64 plate
- Front suspension sag with cold weather
- Help with VCDS error code 677386 / C1046
- B&O sub replacement, ANC disable?
- VCDS calibrating air suspension problem
- Turbo Boost Sensor? P154F00 on OBD11
- A8/S8 4.0TFSI Suction oil cap, PCV replaced.
- Accidentally cleared OBD codes for MIL light
- Name that fluid!!
- O2 sensors, fuel trim faults-LEAKING OIL NOW!
- Aftermarket Wheel Issue?
- Will SQ5 21 inch wheels fit my 2014 S8?
- Disable Stop/Start function
- 2012 A8 D4 4.2 FSI Gearbox problem
- UK: Replacing TPMS Sensors?
- 2016 A8L relay heating issue
- Ignition Coil - Far From Hom!
- UK: 2009 Audi A8 2015 rear window defroster not working
- CD changer stuck in a loop
- Remote Start Install
- RO: Water sloshing, and no heat on very low temperatures - might these be related?
- Hood / Bonnet Difficulty Latching
- Audi A8 D4 L Base Oil Leak front right of engine
- Turbo inlet oil?
- SA: Engine issue? Opinion
- Should I be concerned (34: Level Control)?
- Winding noise during REVERSE D4
- D4 Outer Tail lamp LED
- S8 Plus Model Years
- Coolant leak, 4.0T
- ACC not available VCDS log help pls
- New to me S8 Plus
- anyone try vredestein hypertracs?
- S8+ changing direction while braking
- 4G on A8s?
- Sunroof just stopped working..
- 2015 A8 intakes
- Privacy glass
- Audi s8 d4 blow off valve
- A8 panoramic sunroof - shade cables?
- PPI inspection?
- SA: Weird ticking noise while de acceleration
- Help! Rotational 'howling' noise that goes away when braking
- Audi 1995 ABZ D2 A8 Sold need info on new purchhase
- 2105 Audi A8 TDI Firmware
- Does Occupancy Sensor module need calibrated?
- UK: Audi A8 Cameras SE Eexecutive
- Three beeps from the back of the car after shutdown
- 2016 A8L 4.0 T rear seats heating option
- Buying a Q??
- Hood gas struts?
- Oil pan removal
- Any OS 13 issues?
- SA: Gearbox opinion!
- 3rd Party Warranty Expiration
- 2015 Map Update / Cellular 3G
- Airbag light ??? Bright !
- Fan noise after start
- 2014 S8 Stereo Upgrade
- Key Fob two way communication
- D4 - has anyone reinstalled side skirts??
