- 2 different crankcase vent valve(pcv) but the same exact part ?
- C7.5 Audi A6 Steering rack coding
- Need help figuring out codes!!
- Deformed Upper Dash Aluminum Trim
- Audi A6 C7 unlock steering wheel without starting an engine
- For Audi MMI 2G A4 A5 A6 A7 A8 Q5 Q7 2005-2010
- Audi Bose Woofer Audio Upgrade
- Transmission Fluid Plug O-Ring
- Whoever designed the upper radiator hose for the A6 C7
- The 2015 A6 Quattro Premium Plus 2.0T project Wiring help needed
- Aftermarket speaker install 2016 A6 Premium Plus
- Replacement Bose Mid Range Sub
- Made an a/c diagnosis video
- 2nd Valve for Transmission Fluid Cooler failure
- Alarm chirp really low
- Motor mounts??
- Finding the PR Codes for my A6 (2015)
- 3.0t water pump diaphragm leak
- 2016 A6 3.0T Water on passenger floormat
- 2102 A6 Parking sensor issue
- Problems with Audi A6 C7
- Audi 3.0 tfsi rattle startup
- Air suspension: System fault
- Missing Screw? 2014 Audi A6 2.0T
- 2013 Audi A6 Quattro 3.0T Prestige
- A6 Allroad 2014 level 1 air suspension won’t activate
- 7-speed dual clutch gearbox 0B5 Automatic Transmission (seeking advice)
- 2014 Audi A6 ultra 2.0tdi EGR delete
- Anyone used aftermarket engine splash guards (skid plates)?
- Any experience with cheap catalysts?
- MMI upgrade help needed
- Center Differential Fluid Replacement - Audi A6 C7 (ZF 8HP55A)
- Audi A6 3.0 2013(7gear)
- Looking for help with a stripped ball joint bolt thread
- 2015 A6 C7 Replaced Sirius module not working
- Buying a 2014 A6 in 2025
- Front Control Arms and Bushings Replacement Costs
- 2013 A6: Self Inflicted Damage - how badly did I screw up - Advice?
- BCM replacement
- Interchange diffuser/tips/exhaust A6 C7 from C7.5
- Phone no longer connects
- LT: A6 C7 Headlights?
- Lower Timing Cover replacement
- I need help B107A14 (PDC dead)
- DIY Tip: C7 Starter position for transmission install
- Audi a6 2017 front camera
- Swapped engines 3.0 quattro and wont start
- Low fuel pressure in the fuel rail t
- Relay location
- Diagnosing an Oil Leak on my Audi A6 C7 2.8 FSI (2012) – Seeking Opinions and Solutio
- Audi rattle on startup
- 2012 A6 prem + - heater core / heat
- Vibration creeping in reverse. DMF??
- UK: Slight judder / vibration from engine bay when reversing
- 2014 A6 C7 no sound on radio
- Audi a6 allroad suspension problem,
- Kitt
- Parkingsensor change
- Audi A6 hybrid 2013, Issue DTC DTC P0A9400 , P0AB900 , P0A8F00.
- C7 A6 Rear View Mirror 810 857 511 - Taken Apart
- Suspension part name help
- RS6 issues...
- Stuck Open Injector Potential Damage
- Gearbox multitronic Audi A6 2014 problem
- A6 door handle: Can't find this pesky screw
- 2016 A6 Premium Plus with no keys
- MAF Location on A6 C7.5 2.0T
- Where do I find my options sticker
- Startup Issues
- TDI vs 3.0T
- Misfires only bank 1
- 2014 Audi A6 (C7) Adaptive Headlight Fault and No High Beams
- Oil pressure sensor switch
- Water problem
- 2013 S6 Air Suspension Sag
- ‘14 2.0T - Crank but no start after rebuild
- 2011 3.0 engine-gas, Q7, burnt valves
- How to Sell My Car?
- Auxiliary or Secondary coolant pump for EGR V400
- Can anyone guess what happened here?
- Telephone not installed - RMC_EU_P12321
- C7.5 MMI version
- 2012 A6 3.0T - upper timing chain replace
- Multi failure
- C7.5 JP MMI CarPlay/AA activation
- Front camera not working - what does that affect
- Audi A6 C7 2012 freezing cabin
- Android Touch Screen For AUDI A6 C7 2012-2018 | Apple Carplay & Android Auto
- 2014 Audi A6 3.0T help removing A-Pillar cover sunroof leak Please Help
- Anyone know what is going on? 2014 A6 3.0t
- A6 C7 - Right Xenon Light do nit adjust it self??
- Help, I think that I am having oil leak into my coolant
- Menu grayed out on MMI
- Audi A6 C7 ambient light Ali Express
- A6 C7 Potential ECU failure?
- A6 C7 ACC & start-stop function fault
- about rmc mmi
- 2017 A6 3.0T Audio Skipping Issue (Android Auto and Bluetooth)
- NL: Is the Webasto key considered a "registered vehicle key"?
- A6 C7 Navigation maps update (help needed)
- Loose ball joint nut after installation
- code p0606 with check engine light and epc light.
- 2014 premium plus imei
- Aftermarket rim with wheel spacers
- 2011 Audi A6 C7 - paddle shifters retrofit
- For Audi A6 A6L RS6 S6 2012-2018 12.3inch Touch Screen with Carplay Android Auto
- Mechatronic Unit / Gearbox Coding
- Need Advice on P0299, P0100, P0102 Error Codes, and ESC/TPMS Lights
- 3.0T -> 3.2T Build
- NO: DAB installation rear side window
- Judder on uphill Audi CVT
- Fuel system doesnt stay primed
- Ac wiring
- Clunk while shifting down, help!
- Filter Change CVT Audi A6 2013
- Coolant Loss - Unexplained. A6 TDI
- Help with oil leak
- Urgent help please :)
- Can't Find Coolant Leak
- HELP! Rmc not working!
- Audi A6 AllRoad C7 Undertrays left hand side
- Strange noise then shifting UP 3.0 BiTDI 2012
- 2.0 TFSI (252 hp) problems.. please help!
- Audi A6 EA837 Engine rebuild
- Michelin or Pirelli?
- APR Stage 1 and Timing Chain
- Ratching/scraping noise in front of my A6 2013 2.0 TDi
- No boost after half throttle
- What’s the best spark plug for a 2015 3.0T motor?
- Strange “problem” with the transmission box
- Interlock Ingnition Device
- New AdBlue Pump 4G0131969J is a Walbro Universal? Need Advice
- 2.0t mods
- Coolant hose coupler parts search 3.0 TFSI
- Should I stage 1?
- Diesel Efficiency
- chip tuning
- Audi a6 c7 boot wiring loom part
- Halogen headlight issues.
- MMI update failure
- Cold - Hot air blowing - 0560 Supply Voltage Terminal 30 for Coolant Pump B11D5
- Judder/shaking up hill from full stop
- Need some help.
- Best wet traction tires for my A6?
- Charging system floating
- Retrofitting LED Interior Dome Lighting
- DE: No brake lights n' no start
- A6 Quattro Mystery Hole
- Audi a6 c7 not starting
- 2012 Audi A6 3.0 P1701 & P1570 Codes
- Vibration when moderate to heavy braking/ speeds over 85mph
- ACC & Brake Guard Unavailable Due to Other Module
- UK: Yellow engine warning
- Help with grey instrument DIS screen
- Ignition coil codes bank 2
- UK: A6 2.0TDI (2015) - Starting Issue
- please advise on retrofit oem LED tail lights on audi a6 c7 2011 to oem 2015
- obd2 to reset service interval
- 3.0tfsi fuel pump relay
- Brake Pads! Warning & BRAKE light on
- C7 A6 NON-SLINE CARBON FRONT LIP?
- 2013 A6 3.0. Winter wheels
- 2016 2.0T wastegate calibration IS20 turbo
- help - caliper bracket clearance issue
- What do H7 bulbs on HID headlights do?
- 2015 A6 2.0T - metal in coolant
- 2016 A6 2.0T - corrugated hose on turbo inlet
- Engine Replacement for CGWB
- Adjust headlight height?
- Steering wheel weight vcds adjustment
- How to update MMI RMC
- Humming sound when driving
- Last resort before going to the dealer: driver side headlight out.
- Corrosion on door denied by Audi
- AUDI A6 C7 MMI iPhone connection
- 2016 A6 2.0T - DIY to replace turbo
- 2013 Prestige Headlights
- Enable/activate lane assist and VIM
- Tunes!!!!
- 2012 3.0T - Timing Chain Replacement +
- Key fob doesnt connect to the remote start after alternator replacment
- AL: Audi A6 2.0 C7 4G diesel 2014
- Brake pads - vcds
- 3.0t Direct engine swap plug and play
- Audi a6 c7 3.0Bitdi 230kw
- Seat Stuck All The Way Back; Won't Move / Manual Adusjment?
- Looking for a rear diffuser
- Engine Air Filter Cover Part Number?
- Radio not working when my iPhone is connected to car via Bluetooth on a phone call
- Engine & Cabin Air Filters ?
- A6 C7 gearbox failure
- Rattling noise when accelerating
- UK: Help, hoping this is the correct place to post as new here
- Parallel Park Assist Retrofit - Cost Sharing of PDC Hole Punch Anyone?
- UK: Help
- Used 2013 A6 2.0t premium plus
- Radiator cleaning
- C104311 - Level Control
- A/C Error codes
- Purple royal opinion.
- Car randomly shuts down while driving
- Car has trouble starting in morning.
- Timing chain cover
- UK: Washer Tank Leak
- Left Front Center Parking Aid Sensor Error
- Transmission Malfunction
- Wheel center bore?
- Indicator intermittent fault
- 2016 A6 3.0t Superco
- Good quality windshield.
- A6 C7 Dash Vibration
- Exhaust
- UK: Coolant leak - new to me 2012 A6 3.0 BiTDI
- Audi A6 C7 Stiff suspension issue.
- Audi UK - chance of A6 recall?
- Buying oil dipstick for 2012 Audi A6 Quattro 3.0t Premium Plus
- Does anyone know how to code adaptive xenon headlights?
- Audi vaccum leak smoke test
- UK: 2015 Audi a6 ultra?
- New to me 2013 A6
- Replace water pump & thermostat before failure
- MMI Hard Drive Failed, Drive not recoverable
- Wiper Stalk Replacement Options
- 2013 a6 power steering, tmps fault and stabilization fault
- UK: Corrosion boils on my car!!
- 2013 Audi A6 power steering, tmps fault and stabilization fault
- Car shakes/misfires + EPC light at high RPMs
- Loud rattling noise after PCV and oil cooler change
- Low compression and misfire
- Does anybody know what this is for?
- Rear Caliper Replacement Bolts?
- 2017 A6 Electronic Steering Rack replacement
- Fan won’t turn off - P2181 error code
- Pulling Engine - Stuck on steering shaft
- change wheels help
- 2013 3.0t Audi A6 Squeak
- Apple CarPlay accuracy issues
- Audi A6 c7 3.0 tdi Engine noise
- Are any aftermarket brand window regulators OK?
- Car feels twitchy. Wheel alignment specs?
- C7.5 A6 2.0 Exhaust??
- Anyone interested in a frameless mirror?
- Audi A6 C7 Cooling Fans Stay On when Car off
- MMI Run Around
- Audi a6 c7 3.0tfsi(2014) Problems with the Steering Rack
- Second AC Compressor siezed up
- Rear / reverse camera retrofit
- Problem with keeping AMI/AUX input active when playing audio stream.
- Engine / Transmission Under-tray Bolt Thread
- Is this my Flywheel?
