- Questions about new (to me) 2016 CPO A6
- APR Stage I on 3.0 - Initial Impressions
- Just bought CPO 2016 2 days ago and MIL already on?
- Dynamic turn signals
- tire recommendation
- Metal ticking noise from the drivers' door while driving
- 2016 A6 Warranty checklist?
- 2018 A6 FWD vs. AWD
- Something fishy going on at Naples dealership.
- Just did APR Stage 2 to my C7 A6 3.0 - very impressed
- Cylinder head temperature sensor replacement
- 3.0T noise under hard accel. - any thoughts?
- OBD Eleven - opinions
- Folding Mirrors
- TDI recall for SCR catalyst
- Door sills Lit for S Line?
- VAG scan: Cylinder misfire - spark plug and coils
- 25% Discounts! - Revo by Alcon 355 and 380mm Big Brake Packages...
- Apple CarPlay retrofit for C7 A6 (pre facelift) - any recommendations?
- Buying a 2014 A6 3.0 TDI post-fix. Change my mind
- MMI Media won't initialize
- Any one know what these codes are? and how to fix?
- Wheel bearing out of warranty
- Best battery/Jump starts
- 2019 A6 Review
- Pulley Puller Questions
- Mod suggestions? New owner here
- Xpel v Premium Shield
- Projection Lights Reverse Orientation
- Minimum Brake Pad and Rotor Thickness - 2016 2.0t Quattro
- Audi A6 S line
- Change Voice on Nav
- SC pulley removal tool
- DIY or bring it in?
- TDI diesel post fix experiences
- 2012 TCU update - dealer says its customer pay
- Are all front seat options in the A6 this bad?
- Stone Chip Paint Bubble
- Audi Service - Issues, Advice needed
- HID to LED headlight swap???
- Test Drove 2018 A6
- 4677 - Powertrain Data Bus Fualt Code
- 3.0 TFSI making squeaks
- A6 C7 4G Glow Light
- 2019 A6
- Enable mmi hard disk storage
- A/C turns on when I hit Recirculate - normal ?
- Walk all over me, please
- Narrow Driver's seat
- New 2016 A6 TDI
- Audi A6 2006 TCM UNLOCKING
- Audi A6 2006
- If I pull the battery negative wire, will things get messed up?
- Audi A6 -- Auto headlight function
- Replacing pedals with metal finish version
- TDI emissions warranty question
- Door Trim
- Buggy Long-Term Memory - MPG calculation
- Oil?
- Stop Nav from asking about Google connection
- Radio volume goes up & down by itself
- Just got my A6!! What do I mod first
- Will an A7 20" wheel fit on my 2013 A6?
- 2012 A6 mobile data question
- MP3 restart position ....
- Moving Over to A5 B9 SB Thanks All.
- Seat Size differences between standard and comfort seats in A6
- Android auto on a 2012 A6?
- MMI is Dead. Help me resurrect it?
- Sound system upgrade options?
- MMI and Audi Connect
- About to change battery on 2011 A6
- TDI update then NOX sensor throws a code
- Fuel filter on 3.0T
- Memory setting
- Two (2) windshield sensors?
- ABS sensor triage
- TMC Missing
- MMI Updates and warranty
- Audi A6 C7 errors post crash B1015 B1013 B1014 B1006 B1007 Resistance Too High B13BC
- Coolant Pump Recall
- C7 A6 APR stage 1 first run
- Error message trying to set up Homelink with garage door opener
- Audi A6 2018 camera
- D4 A8 steering wheel swap
- Do all 2017 & 2018 C7 A6/S6 come with Apple CarPlay?
- 2013 A6 Prestige - any must do mods?
- 2011 Audi A5 Coupe
- 2018 A6 P+ First Impressions
- 2015 sq5 voice navigation system not working
- 2014 LED Matrix Headlights
- Audi Connect SIM Change
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- ROW turn signals
- Why wont my battery take a charge? While there are lights lit on my insterment pannel
- Shifting issue post TDI fix
- Engineering Menu Access
- Chrome Trim Question
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- Door Trim applique removal
- DIY Window Tints
- Headlights with engine off while in auto
- not A6 related....but want to share with my fellow C7 owners here
- 2012 -2015 A6 3.0T 75K Service Items - Help?
- Head up Display retrofit
- Rear shelf
- Pricing for ABS speed sensor?
- Need Rear Brake Sensor? I give up searching.
- 2014 Audi S7 using too much oil?
- Audi a6 speaker update
- Please help!
- Replica B&O tweeters
- nav maps
- Bose radio base thumpy, XM OK
- 2016 2.0 A6 Quattro driving experience
- Importing A6 to Europe
- 2004 A6 Quattro 3.2
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- Premium audio systems
- How to turn off A6 aircon Auto function
- Audi A-6 2012
- It's A Safe Car
- 2019 Audi A6 US trims and pricing
- New 2016 A6 TDI - should I buy?
- Blown B&O sub on 2012 A6....repair or replace?
- AC evaporator core cleaning
- Help with Brake/Rotor Replacement
- MMI version
- Missing amp connection?
- Audi a6 c7 2013 front crash sensor
- Any news on 3.0tdi settlement in Canada
- BMW_535I Owner Switching To Audi/ A6 Buying Advice
- Engine sound
- Navigation System
- Tire road hazard warranty
- Dropped lightbulb in trunk latch
- buying a vehicle out of state
- Audi A6 c7 starting issue
- P179D - Electrical Malfunction
- Are Audi's worth the xtra cost?
- getAudiparts.com | Give a little TLC: Genuine Audi Car Care Products!!!
- Transmission Errors After Oil Change
- Can you change suspension for a softer ride
- NEQ Club Cruise...or Scenic Drive...or Mountain Carving. Two for2018!
- Idle
- N187 code
- Accessory mode
- Long crank before starting
- Cracked Trunk Light Housing
- Best Wishes and Farewell
- Converted Lexus owner looking for advice
- Shifting Issues 3.0t
- Rear brake pad sensor replacement only ?
- ChangesTo OBD Interface On 2018 A6
- First time A6 buyer seeking advice
- Location of steering Electro hydraulic pump on Audi A6 C7 engine UK.
- 2016 A6 - MMI and Phone software versions
- Recaro Seat Bracket for A6 C7
- Suggestions on buying A6
- Wheel Bearing
- Google Earth & GPS
- Gearbox malfunction + many warning lights
- transmission type
- Knocking front suspension
- 2011 A6 Rims and Tires
- No power at fuse (fuel pump relay) only when I crank
- ** PLEASE HELP ** SIM Card will not read in my 2012 A6
- A6 Avant 2011 3.0 V6 TDI Sat Nav issues
- Saying goodbye to my '14 A6 TDI and hello to...
- Downpipe ?
- Best MMI Charge Cable for iphone 7
- Audi c7 2013 tdi se body kit options
- what is the name of this particular trim?
- UK: Audi A6 with no USB port?
- comfort module
- Fuel Mileage
- TDI recall updat impresssions
- 2005 audi a6 low pressure windshild washer
- C7 Wipers always in ready position
- vibration audi a6 2016, 3.0
- With the launch of C8 in Geneva, here comes the other NEW Audi model!
- Is it time to set up a C8 forum?
- Memory setting not changing passenger mirror?
- 2014 TDI QUATTRO - TRAILER WIRING
- Daytime running lights while backing in reverse. Nice little dance!
- AUDI Q3 2.0TDI SLINE 2013 FWD
- Replaced interior dome/map lights with LEDs. Weird flickering when push them on
- Audi q3 navigation not available!
- 2015 Audi A6 3.0t Sirius Traffic not comparable?
- 2012 - 2104 A6 major issues and model differences
- HID headlight upgrade
- Does Sport Pkg come with different seats?
- iPod Touch artwork
- Subwoofer Implementation Time
- Headlight Switch button function
- CPO Warranty and whats after ?
- 2012 A6 - Screen Mirroring (Android)
- battery charge
- Steering making noise after hitting curb
- How much cabin noise do your tires produce??
- Winning at Pothole Navigation
- 3D Logo Projector caused air bag light to come on
- Firing Order vs Cylinder Arrangement
- Audi A6 C7, advice on 5mm wheel spacers and longer bolts
- Rear Window Exploding
- A6 Maintenance schedule
- Presenting the new S-FLO Carbon Intake for the C7 A6/A7 3.0T.
- SD card unreadable.
- 2010 A6 - Bluetooth Connectivity
- How reliable are the '12-'13 A6?
- No Fuel To Engine.
- 2019 C8 Audi A6 (unconfirmed) leaked images
- Car died. No start, nothing
- Nasty groaning noise when applying brakes and sometimes turning
- Play radio / iphone in accy w/o headlights on?
- New Member
- MMI Connect APP remote accrss 2018 A6?
- C7 A6 S-Line rear valence and AWE exhaust
- New Member
- 1,500 miles after the TDI fix and...
- 2013 A6 Passenger Seat Won’t Rotate Up
- Remote Start Help with RF Loop/Ignition Bypass
- back camera
- Jolt out of first gear
- Touch up paint
- NEW! ECS Billet Paddle Shifter Extension for the C7 A6
- Replacing brake pads and rotors question
- 1100 to replace thermostat on 2013 A6 3.0T
- TPMS Malfunction, No Parking Brake sign, and Check Engine Light
- First time Audi buyer. Thoughts on this A6 price
- Something to check or just overly sensitive?
- Engine compartment noise after shut off
- 2016 A6 2.0T Quattro Rear Brake Pads
- Love my new A6 !!!
- MMI updates
- Bluetooth connection issues (iphone)
- Steering Shaft Boot Noise
- Extended Warranty ?
- Coincidence or by design?
- 2016 Audi A6 Video Playback Question
- Media
- Thumping from front end, steerwheel creak
- Passenger airbag
- A6 2018 progressive 340hp
- 2012 A6 Wiring Diagram
- Problems with back lights/boot
- 2015 A6 delete all Navigation Directory addresses
- Wind Noise
