- UK: My car will not turn over unless it’s jump started.. and I have a new battery
- A6 C7 platform side assist fault
- Spark Plug Recommendations
- Great mpg
- WEIRD SOUND WHEN TURNING
- Motor mount nightmare
- 2012 A6 prestige misfiring on the drivers side
- Battery date help
- DIY 2.0L (easier than 3.0L) motor mount replacement, A6 C7
- 2017 A6 C7 3.0 mirrors won't fold in automatically
- Scary rattle noise
- Audi drive select modes
- 2018 A6 2.0 valve cover gasket
- Does this look like a leaking, cracked motor mount?
- Green menu a6 c7 adaptive air suspension
- SI: Quality of materials?
- Dashboard and MMI dead 2013 A6
- 2016 audi a6 C 7.5 3.0t quattro abs, tpms, parking, and headlight range control light
- Audi a6 '12 3.0 p0416
- 3G Shutdown...what will I loose?
- Sound system upgrade
- AU: Oil on spark plugs?
- rain sensor wiper
- Oil in one cylinder
- Audi A6 C7 2012 ACC camera problem
- Audi a6 2.0T or 3.0 supercharged?
- Rear light issue + few others
- Audi Connect/T-Mobile 3G Sunset Update
- TDI Settlement Update - Check Your Mail
- DE: oil and water temperature display in HUD?
- ACC and Audi braking guard: not available
- Diagnosing bad PCV valve, how much suction should there at the oil cap?
- P1893 - Signal Line For Gear Display On Selector Lever
- Adaptive Cruise Control not working in cold weather
- Dash cams
- Selling Advice?
- Bypassing the Engine Oil Cooler on an Audi A6 / C7 (2014)
- Weird rattle at low speed
- Coilovers without lowering?
- WPT tuning for the gen 3
- 2013 A6 Rear End Clunking
- turn signal wire
- Ticking sound?????
- Help with some aftermarket mods
- Audi a6 engine mount
- 2014 A6 Rear Climate Controls--mostly dead
- Prices?
- A6 won't start. Will OBDEleven find codes if not?
- UK: Looking for Help as a Noob Who is Looking to Buy a car
- A6 C7 ACC, lane assist and aux. heater problem
- Parcel Shelf Not Working?
- Audi replaced Water Pump, now says its a Head Gasket
- Mmi system upgrade
- Looking for dipstick!
- Backup Cameria
- Intermittent rear indicators
- 3.0TDI hissing under acceleration
- DE: Audi A6 allroad 3.0 tfsi 310 hp C7 4G - wheel fitting
- Need to get by disk and pad change. can anyone give me some input?
- Rotor Size?
- Massive Oil Leak
- Led Headlight r
- Stiff Suspension on stock C7? Looking for stock OEM replacement perhaps?
- Audi a6 navigation update
- Removing RMC Head Unit
- A6 Thermostat Replacement
- Dashboard light up like a Christmas tree after start
- navigation update
- Keyless Entry
- navigation system
- Car wont start and batter voltage at 10v
- A6 Allroad-Europe- Springs? Want to lift my C7 A6 sedan. Will that work?
- Maintenance Due
- 2015 A6 3.0T - MMI Not Displaying Text Message Option
- A6 2014 Navigation not installed?
- MMI Replacement and Trunk Latch Replacement
- Headlight
- 2015 A6 CarPlay/Backup Camera- Recommendation & Question
- How do I remove the DPF?
- Clutch Pedal Switch for Engine Start (F194) Fault
- AU: 3.0T fouling spark plug
- 2012 A6 shifter issues
- 2012 A6 disconnected hose?
- A6 2.0T Slow acceleration
- No heat or air coming out front center and rear vents
- S4 B8 Muffler on 14 A6 3.0 C7?
- Ignition switch relay stopped working
- SA: Audi A6 Overheat and Max Eng 950 RPM!
- c7.5 CarPlay update question
- 2017 Fuel Door Actuator Part
- A6 c7 no sound from the speakers
- A6 Allroad C7 Panoramic Sunroof Issue(s)
- A6 3T Stage 1 tune future reliability
- 2018 audi a6 2.0l exhaust
- Oil Filler cap leaking oil-possible
- Kind of regular clunking noise around 80km/h
- 2016 c7.5 A6 water leak
- Trouble Code P253900
- 2014 A6 - Steering Warning Light
- Headlight problem
- 2013 Audi A6 3.0T Rear Heated Seats Problem
- How do I remove the rear seat?
- Bluetooth looses connection
- Squeaking sound when stopped
- Disable AFS adaptive headlights on C7?
- Coolant Temperature Issue
- Quiet tapping/popping noise coming from front suspension or engine bay
- Front parking sensors stopped working all the sudden
- 21583- Loss of crankshaft synchronization
- A6 C7 2.0 TDI CNHA: High consumption on IDLE and bad smell
- Speed Limit display: outside operational area
- rattling/clicking noise when braking
- Screen/Radio shutting off and turning on
- Technical qs.... right side loom from A pillar
- DIY Engine Mount Job
- 360 video cameras inop .
- Hard blow from the exhaust (like a fan)
- Replace tensioner when doing alternator belt?
- Prelude to Transmission Issues
- FI: Installing a fixed battery charger (DEFA Multicharger)
- Glossy or matte roof racks
- Join us on telegram chat for c7/7.5 platform
- 2013 Audi A6 3.0TFSICoolant System: Fault Turn Off Engine"
- Protective Flaps/shields for Steering Rack tunnel
- 2016 s6 remote start
- MMI firmware upgrade?
- 3.0 TFSI CGXB vs CTUA Engine compatibility?
- ACC Not available Help
- AT:MMI Emergency Flash Utility
- EGR cooler replaced - coolant leaking and problems (A6 C7 2.0 TDI 190 hp)
- Problem a6 RMC
- A6 C7 pre-face lift to facelift
- 2014 Audi A6 C7 cluster stopped working?
- IE: Help… 2017 Audi A6 …
- 14 A6 TDI to a 16 TDI feels much stiffer? Any changes in spring ratios with 16?
- ES: FALLO GPS 0 SATELITES A VECES
- C6 or C7?
- Retrofit Apple CarPlay
- Main beam HELP!!!!
- LED light upgrade
- HVAC fresh air/recirculation air flap motor adaptation
- A6 2016 Electronics Keep cutting off mid-trip
- Mapping/GPS dropping favorite/home settings
- Strange Battery/Alternator Issues Only When Below 30 Degrees
- Sunroof rubbing noise
- UK: Dipstick?
- Total confusion regarding fuel gauge sensor error and diesel refill
- Rear Passenger Seat Belt Buckle Rattle
- DE: A6 C7 2.0 tdi 190 hp, check engine light on
- Gauge Cluster lights
- Rotor Recommendations?
- audi a6 3.0t maybe leaking oil out of Exhaust
- what is this?
- A6 4G2 2.8 V6 204 BHP Clutch friction plates replacement
- Fuel fill-up keeps clicking off
- TCU for C7 A6 8-speed Tiptronic?
- Extended Warranty Question
- Is this diesel sound OK?
- Transmission Jerking
- 275/35/20 Tires Fit the A6?
- Rear Rotors Warped
- IE: Please Help A6
- A6 C7 Rear View Mirror Question
- Cup Holders (frivolous)
- 2012 A6 issues - P0691 MMI display..need advice
- C7 with APR Stage 1 and going to the dealership
- Crazy Question: Can an A6 be lifted slightly for better ground clearance?
- Key fob not working
- Installed my Thule Rack
- Need help fixing my sliding ashtray compartment lid
- Cold Air Intake for 3.0
- New to Me A6 3.0!!
- Engine Making a Ticking Noise: 3.0T
- Need Car Cover recommendations
- Central locking problem
- P0018 Code
- Engine Temp Climbing Toward Redline - Maybe thermostat?
- Hello everybody! motor mounts on A6 with 36k miles!?
- My New (to me) A6 Competition
- UK: Map Updates Edinburgh
- A6 C7 2.0t Timing chain or belt
- IE: Ad Blue Fault Alarm and Engine Check Light
- 2013 A6 C7 Allroad — CV Joint Replacement
- UK: 2016 A6 avant - fuse mistake
- UK: Engine tapping noise, diesel
- Right Adaptive Headlight/Main Beam Headlight Error
- All lights on the dash are coming up every morning
- Terrible recent Audi decisions (killing the supercharged v6 & releasing quattro ultra
- Trying To Soften & Raise a Sport Suspension With Tire Change
- Remote Key Not Working
- humming noise seemingly from rear, only heard while inside car
- Coolant Leak in footwell
- NO: Occasionally Distorted R Front speaker sound (a6-c7, non-BOSE)
- front brake chatter
- My Audi Mobile Access Problem
- MMI screen stuck
- UK: Updating MHi2 firmware
- almost bought a A6 2016 2.0, but
- IE: Sat Nav Audi A6
- UK: A6 engine seized(?)
- Audi A6 2015 MMI problem
- Audi A6 C7 arm rest cover replacement
- A6 C7 weird behavior
- 2018 A6 Quattro Sport Engine Air Filter
- A6 3.0 acceleration whine
- How to disable the auto up-down of the rear window shade?
- SI: Car does not start - signal problem?
- Heater Exchanger Options
- Thermostat / Crossover Pipe leak
- UK: Please help! P00af00, diesel
- S4 vs A6 vs S6
- Wheel hub threads damaged?
- Whine from Auto Gearbox
- Car does not start sometimes
- Battery died and key not turning
- Motor Mounts replacement A6 2012 3.0T
- Audu a6 c7 rear camera glitch
- Pine cone Stash In Engine Bay 2017 A6 3.0
- Leak from underside
- Replace Steering Wheel Logo
- Dashboard Air Vent
- AL: Is this exhaust noise normal when accelerating ( A6 C7 2.8 FSI )
- Parking sensors stopped working because of old battery?
- Dash and screen upgrades
- Clutch and flywheel replace
- BOSE 14 Speakers - where are they?
- Parking Brake Malfunction after rear pads replacement?
- Passenger Turn signal + brake light not working
- Potential new purchase
- Audi A6- Adblue cap stuck
- Glove Box Removal?
- Audi A6 C7 2.0 TDI Stronic knocking noise
- Headlight dead driver side
- Belt squeaking?
- Coolant pump B circuit open 261A00 confirmed A6 2014
- Runner flap stuck closed
- RMC -> MIB2 Climatronic panel & Turbo/supercharger
- Low Power on 3.0tfsi 2012
- Spare part code for lashing strap in the trunk?
- IE vs ECS Intake Help
- 2018 3.0T Tune?
- Need help ASAP??
- Max engine speed 4000 RPM
- MAP Sensor
- Body Shop recommendation Denver
- Trying to understand dynamic/comfort.
- A6 3.0 Intake Options?
- Steering wheel replace
- Break pad warning broken
