PDA
View Full Version : A6 (C7 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. Interior rear window condensaion
  2. Phantom of the Turn Signal!
  3. fuel/trim/o2 sensor issues - rough idle, choking, hesitations - safe to drive?
  4. LED Headlight Replacement Questions
  5. OEM HUD Retrofit?
  6. A6 C7 3.0TDI S-TRONIC Oil smell when stuck in traffic
  7. Consuming oil?
  8. 2012 A6 C7 3.0T No start, intermittent start. Need help
  9. Climate control in very cold weather 2017 a6 2.0
  10. New winter wheels / tires. Milanni Clutch and Pirelli Sottozero 3
  11. RSNAV fundraiser for c7/c7.5 10.25 MMI Upgrade
  12. Question about upgrade 2013 A6 headlights to 2019 A6
  13. New to Audi Connect
  14. AWE's Annual Holiday Special Pricing Event Starts Now.
  15. Rear shocks for the A6
  16. Good or bad idea?
  17. Warranty about to expire. Dealer checkup?
  18. 2016 a6 c7 front bumper removal
  19. GB: A6 servicing costs?
  20. Consistently slow crank that always starts
  21. Alignment - ACC question
  22. Audi A6 C7 3.0T trans noise
  23. Replacing Bushing only vs Replacing control arms
  24. Loud Engine Noise While Accelerating
  25. Changing from OEM Tires
  26. Received 'water pump settlement' letter...
  27. IQ: jumpy climbing hill
  28. UK: Looking to purchase a Audi A6
  29. Traffic Info appears without Audi Connect
  30. Supercharger Pulley removal tool rental/borrow Utah
  31. Main water pump failure 2.0L 2012-2014 class action settlement, extended warranty
  32. A6 TDI versus Q5 TDI? Debating a change
  33. Climate control question
  34. Groaning noise from trans?
  35. LED Headlight Adjustment
  36. A6 Allroad 2014 gear shift will not go into park or reverse.
  37. Noise "rattling" in the right zone of the engine
  38. Telephone is not installed
  39. 2012 Audi A6 C7 Window Chrome Delete
  40. getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
  41. 2012 a6?
  42. Vibration at 65mph
  43. J104 Module (ABS) ground point
  44. Restore Long Term Memory
  45. Rearview mirror instructions
  46. Sync Option for Climate Control?
  47. Maintenance ; Booklet 411??
  48. Alloy wheel paint code/colour ?
  49. External DAC from my iphone to car
  50. How enable original air suspension VCDS
  51. 2016 Audi A6 Reliability?
  52. something new
  53. MMI is not at all working,not resting no sound no Bluetooth no steering audio control
  54. 2016 c7 flat bottom steering wheel airbag
  55. 2016 a6 flat bottom steering wheel airbag
  56. SE: Temp gauge not at a steady 90 degree like other cars please help
  57. DE: Suggestions for Brakes - Avant 2.0TDI S-Line (190 HP)
  58. How do you manually check the oil pressure?
  59. Where is the Cooling Fan Controller Module?
  60. AWE BLACK FRIDAY 2019 STARTS NOW.
  61. Considering '14 3.0 45k to replace totalled '18 2.0
  62. Insurance Buyback
  63. 2013 C6, no washer in cold weather
  64. Cannot view Map/Street in Instrument Cluster
  65. Need help understanding a fault code
  66. Deer Incident in my A6 Today
  67. 2016 A6 display issues
  68. Pistons and Rings
  69. Leaking rear-view mirror A6 C7 2018 model year
  70. Lane/Sign Assiat enable without 8E unit?
  71. High milage service requirments.
  72. Side assist necessities and folding mirrors.
  73. Need help with some issues with my car
  74. New Member, 1st time Audi Owner
  75. VAGCOM Help
  76. Recommended Tire Pressure?
  77. Life out of warranty. What is it like?
  78. pre purchase assistance.
  79. Fuel Rail/System Pressure Error
  80. Looking at an 2016 A6 with high mileage
  81. What coolant do I need?
  82. P0420 error code fixes please?
  83. Need an exhaust
  84. MMI Language modification with update
  85. 3,0tdi stalls when accelerating
  86. Towing capacity and where to find a hitch
  87. Yooooooooo!!! newcomer here!!!
  88. Coolant Issue Please Help!!!!
  89. 2014 A6 noisy A/C
  90. Exhaust smoke
  91. Both headlights cracked
  92. 2014 audi A6 TDI code P226D
  93. 2016 A6 TDI - Climate control knobs and buttons
  94. Rear main seal
  95. C7 removing a transmission from a locked engine
  96. Coolant Water Pump replacement, DIY 2.0L TFSI
  97. Cant figure out this noise Help pls
  98. Coolant leak developed same day after run coolant pump recall was performed
  99. window tinting in SW Florida
  100. Audi Vw Standard 502 00
  101. Headlight Chip Protection
  102. O2 spacer
  103. No ACC and No PreSense Alert Message
  104. [Help] Buzzing sound when idle and A/C on?
  105. Moving on, folks!
  106. 2018 2.0 A6 - Help me get to 200k! vs. a Passat TDI trade
  107. N80 Purge Valve location
  108. Car Vibrates and Rattle
  109. New guy asking about tdi issue
  110. Audi A6 C7 weird engine ticking noise
  111. A6 + stage 1 CEL problem for months on end.
  112. Rear window keeps going up, then down
  113. Audi A6 C7.5 passangers airbag retrofit help
  114. Remote start
  115. Spark Plugs?
  116. Back in the Forums
  117. 2012 A6 2.8 FSI quattro S-Tronic gearbox malfunction (P0179E00)
  118. Transmission Fluid Alternatives?
  119. Blowing warm / hot air
  120. School me please
  121. Question about trim piece
  122. 2014 A6 - "Left Reverse Light" replacement
  123. help with part and a few questions
  124. Oil Pan Torque Spec/Sequence A6 3.0 TDI ?
  125. Transmission Flush/change 65k?
  126. Hello, New guy here.
  127. Used A6 3.0T delivery checkup advice
  128. 2016 Audi A6 2.0T idle issues
  129. O2 Sensor Problem??
  130. aircon problem
  131. Newbie to Audi and to VCDS needs some help understanding the faults
  132. 5W-30 or 5W-40
  133. where is the Siruis module located in a.....
  134. Mmi update help
  135. Engine Noise
  136. 2016 A6 2.0T spark plug replacement
  137. 2012 A6 RMC navi need
  138. What did you do to your A6 today?.
  139. A6 3.0 tdi quattro 2015-16 commons problems?
  140. Oil Pressure Switch?
  141. Headlight electrical issue. Fuse in J519 module keeps blowing
  142. LED Headlights - Upgrade Fogs Possible?
  143. Which AMI cable for 2015 facelift A6 C7 Avant for an iPod classic
  144. Electric pump for oil change advise
  145. Rear bearing noise 2013 A6 (c7) 3.0 quattro prestige
  146. 3.2L Cam Follower Is Bad
  147. Didn't Start Car For 8 Months And HAd To Replace Battery
  148. Audi A6 rear shock
  149. steering column height adjustment loss
  150. A6 c7 comfort control module
  151. Dynamic/sequential turn signal
  152. S-line avant roof spoiler on standard trunk (hatch)
  153. ACC and Audi Braking Guard fix with switch bypass
  154. Issue with ambient lighting on c7.5
  155. 2017 A6 US to EURO Taillights.. Only coding? (Both facelift)
  156. Stabilization Program: Fault!
  157. Need Data Plan for My Audi App?
  158. Fog Light Upgrade to White/Yellow - Need O.P.
  159. 2014 2.0T Random Warning Messages
  160. Audi A6 C7 FL Traffic Sign Recognition retrofit guide
  161. should I buy 4 cylnder or 6 cynder gasoline engine ?
  162. TDI Post-fix MY 2016 vs Older MYs
  163. MMI Control Knob not working
  164. Misfires on 2014 A6 3.0T
  165. A little different Oil consumption thread
  166. GB: A6 Avant Clutch judder
  167. need advice about MMI knob that cant select option
  168. Audi Group Marietta/Roswell Area?
  169. 2012 A6 3.0T quattro
  170. Caliper covers for 2016 TDI A6 Prestige (Ibis White)
  171. Fuel gauge reads zero
  172. Oil leak
  173. MMI Software Security Update + What Else?
  174. VAG-Com vs OBDeleven (alternative)
  175. A6 C7 long crank no start
  176. 2013 A6 Autoshow Purchase
  177. 17 inch winter tire size 2016 A6 3.0t
  178. Brake Sensor / Air Bag Light,
  179. How to avoid blind spots
  180. High pressure fuel pump and fuel line
  181. Rear bumper tow hook hole cover?
  182. Automatic parking sensors activation
  183. Can I upgrade my 2G MMI unit to a 4G LTE one?
  184. Rear Console Sockets
  185. How to neutralize Auto door locks
  186. Steering gets tight after 30 mins of driving...
  187. Brake Pad Sensor
  188. How to determine wheel size options
  189. SK: Can low battery level cause all error messages?
  190. C7.5 - MMI starts bootup/initialize when unlocking car
  191. 2016 A6 C7 Rear Seatbelts and Airbag Module
  192. ACC and Audi Braking Guard: Unavailable
  193. I’m loving it!
  194. CPO 2016 audi a6 3.0t
  195. A couple of dew questions
  196. Fuel flap sticking/binding
  197. How much should I sell it for?
  198. Car won't start steering column ISSUES
  199. Inside Air Temperature - 2017 A6
  200. 3.0T rear main seal
  201. Rocker panel tear. How to fix?
  202. 2012 A6, Is this the rear main seal leaking? Advice Appreciated
  203. Help-A6 C7 Removed Dash Under Steering - What is this Hella Resistor?
  204. Powder coat my oem wheels?
  205. Audi A6 2015 TDI transmission issue
  206. Do German people wear sunglasses?
  207. Brake Replacement Question
  208. Stage 2 tune 2013 A6 3.0t
  209. A6 3.0t Seat Ventilation
  210. DPF and Sensor issue
  211. Gas pedal
  212. Is Audi Automotive Paint Always Bad?
  213. 2012 A6 Rear HVAC Body Vent Not Working
  214. Coolant leak - TDI emission warranty
  215. Help: Audi exhaust rattle
  216. put mobil 1 5W-30 in A6 - now what?
  217. A6 AC knob stuck on cold
  218. Purpose of camera on windscreen
  219. trunk open half.
  220. Bluetooth randomly disconnecting
  221. Audi a6 2013 rear screen has these socket
  222. trunk does not open completely in audi a6 2019
  223. 2013 audi a6 airbag module location help needed
  224. Rear License Plate Screws
  225. Service Action 91U7 Infotainment Systems Software Security Patch
  226. New TDI Emissions Action 23Z8
  227. 2014 2.0 L Quattro Coolant flush questions
  228. [Pics] Coolant leak from auxiliary water/coolant pump, passenger side bottom.
  229. Audi issues service action to update infotainment software
  230. Battery replacement
  231. AUDI A6 C7.5 35TDI Lower plate
  232. Bi-Xenon lights turn off a min after switched on
  233. Purchase advice: '17 A6 Comp.
  234. Knock at startup
  235. Scratches in rear bumper
  236. Brake Light & Pad Message Still On After Changing Pads...Need Help
  237. New wheels and tires for 2016 A6 TDI Prestige in Minnesota ?
  238. Mirror Casting (using Chromecast) via AMI on Audi A6 (C7)
  239. TDI Road Trip(s)
  240. TDI Stumbles/hesitates thumps at speed
  241. 2016 A6 P+ 3.0T S - New Owner
  242. Is my HVAC broke? It constantly blows in High
  243. Steering wheel rubbing noise resolved?
  244. drilled rotors vs non drilled
  245. what is this little black knob?
  246. 2016 A6 Quattro 3.0T Prestige System Max Current Draw...
  247. AK-Suspension-Control lowering module for air suspension
  248. Trying to find CAI That Works
  249. 2012 A6 3.0T will not start
  250. DIY WheeL Bearing Question
