- Long-distance car purchase?
- FI: A6 2.0 tfsi (c6/c7) 2wd purchace
- New ECS Audi C7 A6/A7 3.0T X-Pipe!
- HELP! P2753 issue
- Enabling AUX in Audi MMI RMC
- Water Pump Leak
- Audi multimedia problems
- Throttle body alignment - 2013 A6 3.0
- Need help Parking Aid code B107C14 parking speaker
- UK: Hi guys new to site and hoping for help
- 2017 A6 2.0T Exhaust
- AdBlue
- Manufacturer specific code/ Fan not working
- Weird TPI glitch
- small oil leak
- 2017 A6 2.0T stage 1 ECU tune
- Exhaust set up NO RASP No loss in performance
- Repetitive thermostat housing coolant leak A6 C7 1.8 TFSI
- Help removing gas door from housing
- Headlight, Night Vision assist
- LC: Inquiers about Audi A6 2016 35 TFSI
- MPG DROP- 2014 TDI- POST Diesel Fix
- Rear armrest not coming down
- About to buy a 2015 A6 30.T Quattro Prestige
- audio options
- APR stage 2 dual pulley
- GH: Advice on buying 2012 Audi A6 2.8 fsi?
- Fuel cap question... etc
- Wider tires for the A6?
- MMI Display No Longer Works
- My battery won't die - any warning signs?
- Audi A6 35 tfsi Navi and Camera
- Rattling noise
- Front suspension lower rear control arm
- Help: Dashboard says Transmission in "E"
- 2013 a6 2.0 c7 thermostat?
- replacing front pads, any tips or tricks?
- HVAC PROBLEM
- Missing Piece Help!!!
- Mib 2 replacement?
- A6 C7 2013 thermostat issue ?
- Audi UTR installation manual
- UK: Front Wing (Fender) replacement?
- A6 facelift tailights info?
- Westfalia towbar?
- Can I subsitute Rear bumper Cover: 4G5807067GRU for 4G5807067AGRU
- Anyone have experience contacting Audi of America regarding service?
- Weird Rubbing Noise
- AMI to usb-c cable better than bluetooth for audio?
- 2012 Audi A6 PRESTIGE Auction Buy
- Help Please - MAP Sensor
- NT680 Pro works on Audi?
- Help installing Drive and Crank Pulleys $$ (Long Island NY) Audi A6
- UK: Emission standards on the 2.0l TDI Ultra?
- A6 C7 2012 exterior door handle light No Working
- 2016 A6 C7 grill swap question
- A6 rear deck question
- Airbag wiring issue
- Audi Connect on 2012 A6
- Help identify the front bumper cover part number
- Volume button/wheel issue
- Can one-touch auto window roll-down be disabled?
- 2017 A6 (Post Facelift) LED Headlamp Wiring Diagram/Map?
- BG: full?
- 034 motorsports drivetrain mount inserts
- Spark Plug recommendations
- Suspension noise
- Audi A6 2015 - THEFT PREVENTION
- QA: Audi A6C7 2014 issues
- C7 Service Manual?
- Passenger door not locking and folding mirror tempremental
- 2012 A6 3.0T Q not cold starting
- Fuse blowing
- Successfull RMC to MIB2 upgrade on C7 2012 with strange sound/audio issues
- 20x9.5j wheel query
- Activate my SIM?
- Sheared off my mirror, where can I buy one?
- looking at a (rebuilt salvaged ) a6. plz help
- Devastated about damage
- Allstate Extended Wrap Warranty?
- Reliability mods?
- Audi A6 Quattro
- IE: Ambient lighting install Circuit cut out
- 2013 A6 CVT: lost a/c, horn, power steering + more
- OEM Parts
- Reconditioned Mechatronic Source
- Suspension Upgrades
- Need a little help please - plastic cowl cover.
- RS6 exhaust on A6 2.0tdi 190ps
- A6 3.0T RaceChip results
- HATE the lug nut plastic covers
- Is it still possible to download manuals from ERwin
- inclinometer for A6 MMI menu
- Interior LED light kit?
- Joined to ask a question about buying an A6 and a trans swap
- Adaptive light defective
- Upper control arm
- 2013 C7 2.0T...Tire recommendation?
- suggestions?
- Pro tip: No induction chemical cleaning like Seafoam, CRC etc.
- P2753 error code -- help solve
- UK: 2015 Audi a6 avant 2.0L manual
- Chain tensioner rattle - dealer can't replicate
- CD help !
- 2013 A6 3.0 APR crankshaft Pulley belt.
- A6 problem
- UK: A6 c7 2015 major faults
- New To Audi - A6 2017 Quattro
- All Weather Light Replacement
- Vin decode
- 2018 2.0 TDI Software Update
- 5F Module Coding! 2016 Audi A6 Quattro
- Donate to Discount so you can Quarantine in Your Garage...
- Paint Code?
- Help
- Phone USB port- Why is it here?
- New tires?
- 2.0 or 3.0 TDI, and what 3.0 TDI?
- *Intermittent* stuck rear brake caliper?
- At Startup engine revs / hangs at over 1000 RPMs
- Audi A6 C7 mmi not working
- Got P190F00 code
- 2014 TDI motor mounts needed at low mileage
- Lane Departure Question- Doing odd things
- ABS not functioning
- Cant see map update. 2017 BE
- Starting problems with my Audi A6
- Poor FM DAB Reception...
- APR Tune on High Mileage C7 A6
- What am I missing?
- No dash lights
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Audi A6 2013 Left front whoooooing sound
- IE: Audi A6 C7 S-Tronic 7 Speed 2016
- 2006 audi a6 4.2 timing chain
- Bogging Issue
- Fault code p2022
- Fault code p2022
- electrical issue?
- Diff Fluid Change Interval?
- SOS: 2018 A6 fault code U140A00
- Picked up something "new"
- Cam shaft Sensor Bank 2 & Valve Cover Gasket replace
- Reliable 2012-2014 A6?
- 2014 2.0TDI S-Line Ultra Suspension
- What’s up with this happening so soon
- 2012 A6 (C7) Did Audi dealer really update my satnav? Help!
- A6 c7 2017 wheels
- Brake Replacement Cost?
- No fuel pump sound when driver door is opened
- A6 the cheaper way to a 3.0?
- OBDeleven, VIM MIB not supported
- UK: All dash light on
- A6 C7.5 Exhaust Upgrades?
- engine intermittently won't start or turns off immediately transmission error
- Audi Adaptive Lights
- Oil Vac/Extract Question 3.0
- Another Suspension Thread - ST Coilovers??
- trunk spolier?
- 2019 A6 2.0L Engine Stalling
- Media/Sat "Unavailable" Messages on MMI
- First time posting and problems
- AUDI LED CARBON STEERING WHEEL
- VAGCOM Wrench Reset - Service Due
- Lowering AAS with VCDS.. anyone ever try it?
- Help, Removing center console bezel..
- Head lights automatic levelling error
- 2014 A6 Lane Departure- Too Jerky- Is it adjustable?
- UK: A6 C7 2016 Reverse Camera Retrofit
- Vapor Canister Purge Solenoid
- Vag-com DRL wink disable $50 to do for me- NY, NJ, CT, Long Island
- Ready for TDI Recall
- AUDI A6 SOFT CLOSE CAR DOORS
- 2018 A6 3.0 oil filter gaskets
- Turn on
- DRL's don't shut off when blinker is on..
- AUDI LED STEERING WHEEL
- whistling sound while driving....
- Missing plug rear bumper
- Humming sound while driving
- Flat bottom steering wheel from S3
- UK: Almost bought an A6 but it has issues!
- Sweeping signal lights
- Replacing low beam HID D3S headlight bulb with LED?
- 2016 A6 Premium plus s-line. Fog light?
- Tire recommendations for quiet ride with sport package?
- We Build Faster. Shorter lead times on AWE Exhausts.
- Corroded connector on the gearbox unit S-tronic / 0B5 / DL501
- Start/ Stop error
- Audi A6 2007
- No spare on new A6 Allroad
- Head Light Clear Case Swap
- Gas price on Audi connect
- 2015 A6 Steering Wheel Retrofit
- HP TUNERS TCM TUNE ZF8HP
- Seafoam vs. Supercharger
- Intake compatibility A6/S4
- front license plate delete question
- Need help with a noise on possible purchase
- 2012 A6 Sound Upgrade Advice
- SE: Audi A6 Avant project
- A6 ultra 2018 retrofit options and possibilities
- Buying used A6. Which black is this ?
- 2.0TDI multitronic hill start and roll back
- Anyone know what could be causing this sound?
- Android Auto WiFi
- I want wheel spacers so bad, but........
- Stagger wheels
- Fan Controller Modulre
- Coolant Crossover Pipe
- Warranty Repair Advice
- P0641 what might be wrong
- 2013 Audi A6 3.0 T Engine Light
- Side Mirror turn signal
- 2014 A6 3.0 TDI 94K miles - low coolant?
- About CO²
- C7.5 Audi A6 Air Intake 3.0T?
- Audi A6 not accelerating properly...
- Production Numbers
- DRLs flash with Compustar remote start
- Exhaust Repair
- C7.5 A6 2.0T intake exist?
- A6 reversing camera retrofit
- Open door, engine shut down
- 2014 A6 - underbody trim name and #
- Lost Short Term Memory
- 3.0T intake question Breather filter
- Is there a procedure for transmission adaptation reset
- USB phone mount
- New to forum, looking at buying a 16 a6 tdi prestige
- DPF Light and Removing for stage 2 remap.
- Chipwerke vs racechip?
- Engine start system fault error
- Weird exhaust sound
- Squeaking interior pillar
- importing a car into the USA from Canada process questions
- Buying a 2012 A6 3.0T
- Converting A6 Air Suspension to KW Coils
- Led interior retrofit
- How to get rid of this message?
- Osram Xenarc Night Breaker Laser D3S
- Headlight button is "Alive"
- New to the C7 Forum
- Spark Plugs, platinum, double plat, silver or iridium
- wheels?
- Steering error message
- Avant vs Allroad
- 2016 vs 2017 audio options
- 2012 A6 C7 code for auxiliary water pump V50???
- CORNER LIGHT BULB REPLACEMENT HELP ???
