PDA
View Full Version : A6 (C7 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. MPG Increase!!!
  2. 2012 A6 F5 Failure
  3. Strange Noise from under car
  4. Night vision adjustment
  5. Audi lighting
  6. DIY: C7 A6 Front Bumper Removal & StoneCarbon2009 RS6 Style Grille Install (Video)
  7. 2012 firmware update
  8. New, leftover 2018 Audi A6 going for as low as $34,999, about $15K-$18K off MSRP....Y
  9. A6 Tire Blister - Do I need 4 ?
  10. Is it tough on the transmission shifting into sport mode?
  11. Side mirrors dimming - turn off?
  12. GPS Week Rollover April 6, 2019
  13. Break Pad Placement With Shim
  14. Steering fault and some other problems...
  15. I got the car!! Now what?
  16. Thoughts on buying a sub 80k mile 12 prestige a6?
  17. Control unit not responding, ODBeleven
  18. Do I need a new battery?
  19. Hard Brake Pedal in the Morning
  20. S-Tronic oil leak at the back
  21. TDI WENT INTO LIMP MODE
  22. rear seat pass through
  23. Noise from front of car...
  24. Another Transmission Problem - Codes P0930 & P1890
  25. Tires for a car ?
  26. 2016 Audi TDI
  27. Air con and thermo fans not working
  28. part numbers.
  29. Rebooting the car
  30. 2014 tdi
  31. What oil off the shelf?
  32. New or Used 2018 Audi A6
  33. 2012 A6 PP 3.0T SC 98k miles
  34. SD SLOT 1 unreadable
  35. Ambient light - color profile
  36. Iphone XS Max issues with Bluetooth
  37. My Steering Wheel sounds like a whining Dog
  38. Parking heater
  39. Diff/2013 A6 Door lock touch sensor problem
  40. Side mirror question
  41. Can you diagnose the thermostat failure with VAGCOM?
  42. 2010 a6
  43. Driver side noise - knock/grind
  44. 2006 Audi a6 3.2 quattro - Gen2 MMI
  45. Door handle sensor problem
  46. Stock exhaust diameter for a stock A6 2.0t C7
  47. I think I’ve finally found “The One”
  48. EVAP Leak - P0456
  49. Text Messages on MMI not working with iPhone X
  50. Will an Audi S6 or A6 s-line Diffuser fit on an A6 Prestige model
  51. Warming car up in middle of work day
  52. Video on MMI
  53. Foot off gas at 20 mph or so - car lurches - sometimes
  54. Audi A6 Premium Deal
  55. A6 2013 hood open indicator
  56. 2.0 A6 - What's the most common application of this motor?
  57. '14 TDI Serpentine Belt Replacement - is there a DYI?
  58. Audi & VW Service in Montgomery, AL
  59. Anniversary pics
  60. varta or exide? what's you choice of AGM battery?
  61. Does VAGCOM void warranty?
  62. Need help with the kick-down adaptations problem
  63. 2012 A6 3.0- Tail Light blinking pattern
  64. Jack Pad Recommendations
  65. 2015 vs. 2016 A6 Prestige
  66. First Oil Change @ 5k or 10k?
  67. Considering 2012 A6 3.0T - Please advise!
  68. Wheel/Tire sizes?
  69. 2018 Sport suspension new tire choice
  70. "Brake" Light Came On Around Right Turn ??
  71. Audi A6 to RS6 converti kit - info and support please!!
  72. 2018 2.0 FSI/ZF 8 HP Questions
  73. New '18 A6 vibrating and rattling?
  74. 2018 A6 Audi Connect PIN
  75. 2012 A6 - Steering Wheel Creaking - Slip Ring Issue [Video Attached]
  76. What would you consider high mileage/ extended warranties
  77. Oil Change Question
  78. Moving to C8 Forum
  79. A6 @ 140 mph on German Autobahn
  80. 2012 Audi a6 in 2019??
  81. New Key
  82. Home Link/Garage Door Opener
  83. Questions from a newb
  84. Front Bumper differences pre-2016 face lift?
  85. Wheel and Tire question
  86. gear not engaging; 2012 A6 3.0T tiptronic
  87. MMI Black Screen - code 02259
  88. Rotor and Pad Recommendations in Canada..
  89. Mystery driver info display
  90. 2014 a6 rear bumper removal
  91. 2014 A6 rear end clunk
  92. Replacing broken grille with RS6 quattro grille, has anyone done this?
  93. Feasible to swap in OEM sport suspension?
  94. TCU factory reset cost at dealer
  95. Looking at Purchasing 2015/16 A6
  96. Trade-in PODS recall for a newer Audi
  97. Spark Plug Replacement
  98. Audi Dealership Loaner Cars
  99. MMI Passenger seat adjustments
  100. Problem with Advanced key?!
  101. engine light code p2026
  102. Very strange sound in my 2014 A6 - ideas?
  103. Awful creaking sound!
  104. New TDI on the way!
  105. Time chain replacement
  106. Lane assist malfunction
  107. A Cold, Snowy Drive
  108. Is oil consumption normal?
  109. who makes the OEM Wiper Blades? Bosch or Valeo
  110. Comparison 2014 A6 to 2018 CT6
  111. 2014 A6 Service Light
  112. My 2013 A6 3.0T Engine Has broken down. Please advise
  113. Rétroviseur Chauffant coté chauffeur
  114. A6C7 2015 CVT 2.0 FWD
  115. Roof bars and roof box
  116. Are LED headlights covered by Audi(Fidelity) extended warranty?
  117. Interior Console Gear Shift Panel Cover for A6 2012
  118. Anybody have a good use for the useless sunglasses holder?
  119. AWE Annual Holiday Special Pricing Event
  120. Retrofit tow bar Audi A6 2012
  121. YouTube Video of Valet taking my car on a Joyride
  122. Headlight Symbol
  123. Audi A6 Options & Rarity 2014-2016 Exclusive Line?
  124. Cold air intake
  125. New A6 owner here, looking for recommendations for making the car sound better.
  126. For those that have installed an aftermarket intake...
  127. mmi
  128. Anticipating purchase of 2018 A6 3.0
  129. 2018 A6 HID Bulb Help
  130. Ignition switch
  131. Considering 2017 A6 - Competition Package
  132. Cold air intake options
  133. Looking for an independent Audi mechanic in Burlington county, NJ
  134. Buring Oil
  135. Cold air intake?
  136. Good Bye - Had FUN!
  137. Akebono pads not covering entire rotor surface
  138. PODS recall parts must be in!
  139. Turbo flutter at 3k RPMs
  140. Some MP3's in MMI showing black screen like video
  141. INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
  142. winter tires or all season ?
  143. Heating problem
  144. Dipstick part number
  145. Anyone running an aftermarket downpipe w/stock exhaust?
  146. Do I have the right oil filter for 2016 3.0?
  147. CVT Geabox problem?
  148. Muffler options
  149. Headlight washer
  150. Help Me! Ambient light and brighness: Adjust?
  151. Auto Stop/Start stopped working
  152. Shopping for a new TDI for my buyback Passat / Audi Mechanic Recommendations - SATX
  153. Fan 1 Control Circuit
  154. Choppy (cupping) tires? Suspension + alignment are good.
  155. Lots of new B7 A6's released for sale
  156. 2013 A6 2.0 quattro with 98k?
  157. Oil Extractor
  158. 2.0t runs rough after 1min when cold
  159. mmi software update to have apple CarPlay
  160. Unknown bulb in bi-xenon headlight housing? HELP! HELP!!
  161. Europrice.us Black Friday Deals are almost here...
  162. 3.0 carbon cleaning before/after
  163. A6 2.0 with APR Stage 2 vs A6 3.0
  164. Climate control
  165. A6 jacking point - pinch weld damaged
  166. Park assist retrofit?
  167. Rear brake question
  168. Wheels too far from strut?
  169. Brake Sensor for EBC pads?
  170. Myaudi & MMI Connect Apps - ODB2 Connector
  171. Rotor Size is driving me crazy
  172. MMI Version for refreshed C7 (2016-2018
  173. OEM Pirelli P Zero Mileage Disappointment
  174. Help! EPC Light and Engine Light came on.
  175. Rear armrest cup holders
  176. MMI Oil level monitor after Service
  177. A6 MMI Version
  178. First Audi
  179. how to convert ANS files?
  180. Oil Change DIY discrepancy
  181. Water Pump Relaced at 12k
  182. Headlight range control module (J431)
  183. key fob
  184. do C7 A6 cars have the 'after run' heater feature
  185. steering rack
  186. P200600, P200700, P001600, P034100 what to do?
  187. Q about key-less open problem
  188. Gear Oil
  189. Staggered 20 inch tires on 2012 A6 will they fit
  190. Just purchased 14’ Audi A6 2.0. Few questions
  191. ENGINE ECU update
  192. A6 C7 3.0 TDI - Power Steering Problem after driving in floods
  193. Does the MMI screen in the 2018 A6 retract while driving?
  194. Buying a used A6
  195. 20" 5-arm Titanium Rotor Wheels Center Hub Part Number
  196. beam me up?
  197. Custom foglight setups on those without factory foglights
  198. Fog Lights on may LED's go out with higher speed? Snow driving with LED package?
  199. Extended Warranty
  200. No drivers door open visiual warning?
  201. Cabin Filter
  202. key not recognized
  203. i have 2011 q5 base
  204. Heater not as warm on one side
  205. A/C compressor clutch - always engaged
  206. Audi A6 C7 lowering with spring plates/spacers
  207. exhaust rattle noise Audi allroad 2015
  208. 12 A6 C7 Prestige key fob not recognized
  209. Winter Tires
  210. Rattling sound at idle allroad 2015 320hk
  211. Fuel cap/tether replacement
  212. Retrofit C7.5 rear bumper on C7
  213. Tail Light Assembly
  214. Rattle from passenger seat area
  215. Radio Presets Remapped When in Reverse
  216. 2015 Audi A6 - No Text Messaging Feature
  217. left turn signal/brake light /rear light warning
  218. Brake Guard Unavailable / Adaptive Cruise Control stopped working
  219. Can I tap into existing USB?
  220. Composite coiul springs
  221. 2011 Problem with rear lamps (USA->EU)
  222. Xpel saves the paint, for the second time
  223. Fuel leak after 20AR Fuel Line Leak Recall
  224. Audi A6 3.0T coilover help!
  225. High idle revs
  226. Part #s needed to add heated/paddles sport wheel to car with 4 spoke non-heated?
  227. Destroyed my passenger mirror - thoughts?
  228. Bought it
  229. Chirp when locking/unlocking
  230. Audi Q7 transmission coller valve.
  231. Power Seat programming
  232. Audi A6 2012 Supercharged Oil Consumption
  233. oil dip stick
  234. Faulty chain tensioner?
  235. Air Bag Recall
  236. Child Proof Catch Fault
  237. A6 C7, MIB II Main unit audio issue , noise, no sound to rear right speaker
  238. A6 (C7) Key Fob unrecognized
  239. Common things to look for when purchasing used A6 TDI
  240. Oil Dipstick for 2018 A6 2.0
  241. Coding for drivers door control module
  242. A6
  243. I FEEL ALL ROAD LEGAL NOW - TDI FIX
  244. Guys, AC stopped working abruptly on my A6 3.0
  245. Any Ideas on how to get car audio to output to external speakers or device.
  246. Hydrosilex -- my review, what's yours?
  247. Buying a car (2013 A6) with accident history
  248. My leather seat bottom is ruined
  249. UK: mpg for A6 Avant
  250. Replacing spark plugs in A6 3.0 - recommendation needed
