- 2014 - A6 - Premium Plus - Upper Timing Cover
- 120mm BMW wheels on Audi?
- Oil leak after water pump replacement
- Electrical problem?
- Media USB problem
- AdBlue/DEF in A6 C7
- Indicators not working
- C7 Audi A6 3.0T Project: ECSTuning Bumper Spoiler & Grille Accents i
- C7 a6 screen not working
- ACC will not work over 30mph
- 2012 A6 prestigue - rear CV Shafts
- 2012 A6 prestigue - rear cv shafts
- parking sensor help
- Audi A6 C7 4G - sq5 engine swap
- Tuning for my 2017 A6 2.0T Quattro?
- Audi a6 c7 ambient lights
- Audi a6 c7 matrix light help
- Mmi firmware and maps uptade
- New Audi owner
- Audi A6 C7 - knock/clunk noise
- NZ: Gearbox Malfunction error P187B 00
- A6 power steering rack
- S Line Versus Sport? Is S line lower or stiffer?
- Class Action Lawsuit against Audi 2.0t TFSI Engine
- New Parking Sensor Issue?
- 2016 Audi A6/A7 3.0 TFSI Path to Oil Separator
- New Audi Owner
- Diagnosing failed supercharged clutch help? P25E9
- 2015 3.0 TFSI rough idle
- AU: Service Interval 2012 A6
- Where do you buy your brakes/pads?
- ACC and road sign recognition conflict
- VIN Holder Part Number?
- MMI connection issue - Please help
- LED headlight wiring diagram
- What's wrong with my A6?
- Firmware Version not showing
- C7 A6 Stolen w/ No Key Fobs
- 2014 pre facelift RMC screen is driving me crazy!
- UK: A6 Avant 3.0 BiTDi.
- Audi leaking coolant and oil
- 2016 a6 tdi prestige s line
- Engine Overheating Warning
- 2016 a6 tdi prestige s line: min wheel diameter?
- 2021 A6 55TFSI
- I need to be able to control MMI programmatically. For example to send button command
- Front Bushing Audi A6 C7
- chip tuning?
- Radio add on mirror phone to unit
- A6 c7 3.0t crank sensor
- 2016 Audi A6 3.0T intake codes
- CH: What are these wheels called?
- ACC camera basic settings
- Where is AMI interface Port?
- Water on the carpet
- 2015 A6 BiTDi dash buttons dont illuminate
- RS6 2015+ rear diffusor to BiTDI s-line bumper
- Headlight Interior Switch
- Decided to sell my 2016 A6.
- HR: TPMS/ESC/EPB/AIR SUSPENSION LIGHTS
- IE: Thoughts on oil sump plug
- Stiff Suspension after encountering a rear light error
- PowerStop Brakes
- CarPlay retrofit options; anyone got any experience with these 5 options?
- Engine Swap Audi A6?
- Auto Dimming not working
- What is this wire for? Rear windscreen
- New ACC camera new problem, ACC and Audi Braking Guard unavailable
- IE: A6 avant rear ARB options
- Fuel sender unit?
- How to remove passenger/driver side footwell trims to pull the carpet?
- 2016 - 2018 Audi 3.0 TFSI Supercharged Oil Separator Replacement
- ACC and Audi braking guard: Unavailable
- S-Tronic problem. Gearbox overheating
- 2015 A6 2.0 TDI Avant Manual 6 speed - judder
- C7 Auto folding mirrors
- 2012 c7 oxygen sensor replacement help
- 2013 audi a6 3.0T Exhaust
- Sport mode automatically engages 2017 A6 2.0T Quattro
- IE: Audi A6 C7 Auto
- Cluster / HeadUp Display Speed limit
- Overheating, low colant level
- A/C blowing hot air
- Tires for year-round summer (So-Cal)
- TDI Fans – I got $76,098.73 for my 2015 A6 TDI with 146,179 miles
- 64 reg audi a6 2.0tdi 190bhp
- Mapping 4-zone A/C
- 2013 A6 C7 carbon clean?
- oil filter housing/while I'm there
- Lower the tachometer! can someone help me? Thank you! A6 c7 2017 s tronic quattro
- Headliner sagging
- 2013 audi a6 3.0T P0235
- Audi a6 3.0T 2013
- SK: Harsh downshift from 2-1, occasional 3-2 (OB5/DL501, S-tronic)
- ACC camera? Breaking guard unavailable
- Electronic Brake Malfunction
- Sunroof won't catch on track
- Auto Start Stop Scenario: Feature or Malfunction?
- 2000 audi a6 cannot get radio out or find code please help
- VagCom Work - Marietta,Dallas, Roswell, GA Area
- Bluetooth Module Location
- Message Greyed-out on MMI
- Small vibration in steering wheel
- Audio streaming 2012-2014 Ac7 A6
- UK: No A/C?
- 3.0t Supercharger removal— lower coolant in reservoir?
- DE: Help me chose
- LY: Gearbox overheating please adapt driving style
- Retrofit from Audi Sound System to Bose
- Parking system
- Where is the Airbag Modul ? C7 2014
- Ambient lighting
- Build quality
- 2012 A6 3.0T Prem+ exhaust?
- 20" stagger Quattro help. Wider up front?
- RS6 Grill installed
- ACC unavailable fault
- IE: 2016 Audi A6 S line 2.0 diesel
- 2016 A6 P0456
- Choosing a Replacement Battery (non-dealer)
- Audi A6 C7 MMI not responsive, stuck in initializing only
- Increasing Heather Steering Wheel Temp with OBDEleven
- 2014 A6 AC blows hot
- New Project Car Reveal + Upcoming TT vs G35 Race
- Changed spark plugs in Audi A6 2.0 2016 now car misfires when I accelerate
- Car dies after driving for a bit
- UK: Transmission Mount Insert
- UK: Glow Plug Circuit High Issue - Help!
- Headliner coming off from the rear
- How to fix the front door bose speaker in the bottom
- ACC, Braking Guard, Lane Assist: Unavailable! A6
- Head gasket water leak with only 60000km 2013 have to change Why?
- First post: Is it repairable? If so can I get an estimate please?
- BG: Boost pressure regulation, V6 diesel
- TDI MPG IDEAS? Aftermarket Tunes?
- No start - Starter stuck Fault
- 2017 A6 Oil? leak
- Rodents destroy TDI Adblue hose
- HELP engine start system Fault
- Squeky noise coming from front left side of the car
- 2013 2.0T w/ CVT Misfires and Poor Shifting (VCDS Codes Included)
- Repost in correct forum - Radio region JPN to EUR
- Headlight high beam does not work
- NZ: Fold in mirror does not fold out
- UK: A6 C7 Q 3.0 TDI no ignition
- A6 Avant 2.8fsi C7 - Grumbling sound/vibration
- ACC and Audi braking guard unavailable
- Rear Sway Bar For Sale?
- Need Help Getting Out of Limp Mode
- Bi-xenon Headlamp electrical connector
- Tired of the "delay and surge" from a stop. Any solution?
- Bad oil leak/spraying after an oil change
- OEM Dynamic Rear Turn Signal retrofit
- Help! A6 C7 headlamp Wiring data
- Bluetooth Problem
- RS6 Grill mod for an A6 diesel?
- Problem vcds coding… Im idiot… please help…
- Help! Extremely unusual P2181/P1889/P2099
- TR: Audi A6 2.0 TFSI Quatto Vibration Problem in D or R
- wheel/brake noise
- Audi A6 2.0T 2014 Timing Chain Query
- Locating a stolen vehicle?
- Nox Sensor and Quattro module
- Anyone running a radar?
- IE: Audi A6 2014 Quattro 3.0L - Software Updates
- different hp outputs
- Where to tap for aftermarket amplifier power?
- UK: A6 Allroad C7 272 PS TDi Aux Belt pulleys and Tensioner
- UK: steering noise issue 2.0 quattro
- Couple of error codes
- Can't fine the part number
- Stuck disc
- Audi A6 C7 2.0 TDI (140kw /190 ps) Gearbox issues
- 2014 Audi A6 Intermittent Hesitation
- SI: full led?
- keyless entry
- Engine Vibrate at Idle
- UK: Audi A6 2.0D quattro 2017
- DK: 2016 FL RVC retrofit?
- Misfire issue
- Ipod integration?
- 2017 A6 2.0T quattro rough 3 ->2 downshift in Efficiency Mode
- 2013 Audi A6 3.0T No A/C; Code for Humidity Sensor and Coolant Circulation Pump
- Brake Pad Warning Light!
- A6c7 air con issue
- Intake Camshaft
- 2014 A6 2.0 0-60 in 8 seconds?
- UK: Clanking/rattle sound when car is on slow speeds
- BG: C7 320 BiTDI + ZF8 jerky gearbox changes
- c7.5 A6 Turbocharger Speed Sensor Short To GND P2580
- UK: Service intervals
- Audi A6 Quattro 2.0 vibrations on idle and full lock
- Help with A6 C7 Error Code Diagnosis
- new wheels
- UK: All dash warning lights coming on
- Extended Service Contract saves the Day
- Strange noise
- Start-stop time out?
- Coolant Leak/Oil Separator
- Car shakes when standing and accelerating
- MMI firmware
- Parking assist now not working
- Accident Help Requested
- C7.5 Thermostat job regrets
- SI: Service intervals and replacements
- MMI screen in always open
- HU: Audi A6 C7 Side Assist Retrofit
- 2012 Audi A6 3.0 starting problem/Transmission malfunction
- AL: Where is located Headlight washer fuse (C7 Europian version)
- Windshield washer aiming
- SI: Req Dataset 4G8907468 0113
- Swapping Sports Suspension for 'Regular' suspension package
- Mojio 4G Upgrade
- Radio problem
- SI: Air suspension and headlight range control fault
- UK: A6 2013 - electrics going crazy- help please
- Lexxson CarPlay and Android Auto Wired/Wireless for 2012-2016 Via AV Input
- a6 c7 2.0 tdi cnha 2015 - starting problem
- Assistance Please! CEO Came On!
- AUDI S tronics jerks while in P
- 2018 A6 transmission issue. Need advice!
- Battery Life?
- Fog mode is active
- Camshaft sensor calibrate
- Audi side assist System failure and ACC and Audi braking guard unavailable
- Blackout plate behind grille logo?
- Rear view camera VCDS
- UK: Knocking noise from front
- Audi a6 c7 bixenon
- 2014 A6 3.0l PCV valve
- KR: Retrofit Standard seats to Comfort Premium seats (ventilated seats)
- Audi A6 allroad 3.0 tfsi 310 hp C7 4G - custom exhaust
- P179D00 Cooling oil valve Electrical error
- Alternator fault - battery not charging
- 13812 - Exhaust Gas Temperature Sensor 4 Bank 1
- Heating only on one side
- NO: Air suspension fault
- No A/C - G395 or Secondary Coolant Pump
- Radar detector placement
- Rear Main Seal @45k???
- Timing belt chirping sound
- S-Tronic clutch slip?
- SE: Audi A6 2.0 diesel 2016/2017: where can I find a sport exhaust?
- Help with Neutral Idle Control
- Driver Assist Package Lane Departure times out in 10-15 seconds. Changes?
- Just Bought Used A6 / Water Rushing Noise when AC is on?
- New wheels for A6 Allroad
- Is the rear view mirror trim replaceable?
- Does my 2016 A6 use 3G?
