- 2014 versus 16 wheels- 19 inch- Wheel Weight?
- A6 C7 Exhaust Recommendations
- Error during Clutch valve calibration 0B5
- Mechatronic won't come out, connector housing is stuck
- Sat Nav Issue
- RO: Basic Settings (VCDS) S-Tronic 0CK DL382 ???
- S-Tronic 0CK DL382 problems
- Replacing Front Upper Control Arms W/Out Removing Strut
- Looking to put RS6 back exhaust onto my 3.0 TDI
- PL: Decoding passanger occupancy sensor?
- Custom gear shift knob for my Audi A6 C7
- A6 C7 3.0 Supercharged supercharger difference
- Replacing 18" with 20" wheels....what can I expect?
- Audi A6 c7.5 Speedo.. Climate Controls & Steering Wheel Buttons DEAD!!
- EE: Audi a6 3.0 180kw
- A/C still doesn't work after replacing pressure sensor (G395)
- Post Diesel Fix 2016 versus 2014? Any difference in smoothness? Might go fr. 14 to 16
- Radiator Fans pulsing on and off and not keeping cool
- Stolen battery and cut wires. A6 premium Quattro 2.0T 2015
- Who puts 3 kids in the back seat of their C7?
- Front Suspension Rattle / Clunk - Brake Pads!
- Exhaust on A6
- A Warning to Golfers
- 2013 A6 Door Handle Sensor
- RO: A6 C7 3.0 diesel 272HP shaking at startup - need help
- New to Audi, help with purchase
- UK: A6 3.0TDI C7
- Rear View Mirror A6 Quattro 2013
- Front coil springs
- 2018 A6 3.0T Sport - Rotor Replacement Question
- Back in the A6 family - 2017 A6 3.0T
- 2017 A6 MMI Mib2? Updating maps?
- A little assistance please. (cooling issue)
- DK: multiple errors?
- AU: Anyone else had an electrical fire?
- 2017 A6, Extended Warranty Question
- Seating position
- Calculated Range in Miles based on Tank Level
- Space Saver Spare Tire Replacement
- UK: C7 Auto box issues
- Audi A6 TDI versus BMW 540D?
- Parking Aid Sensor
- Oil consumption on 3.0T?
- Drivers Side Motor Mount DIY
- A/C codes, can someone look and help?
- Audi A6 low speed grinding noise (front left wheel, no brakes applied)
- Battery replacement and code change
- Replacing battery and code change
- Oil Cooler Bolt Part Number.
- Features not working
- C7 inner tail light assy disassemble
- Electrical component not turning off
- Make lighter sockets work with igition off?
- 3G Sunset
- Noise when car starts for a second after oil change. HELP
- A6 Coolant Issues
- Spark Plugs
- A6 2017 Front Camera
- 2015 A6 3.0T Engine/Maintenance concerns?
- Engine EPC light
- SI: Audi A6 2017 wider wheels?
- Pet peeves on the C7.5
- CY: Nothing written on mmi display?
- Latest MMI?
- Does A6 C7 Avant tail lights fit sedan A6 C7?
- Finding a trunk spoiler
- Water Buildup in Drivers Side Footwell - front and back
- Adaptive Air Suspension Retrofit
- Tuning, Maintenance, Longevity & Reliability
- Audi TSB for False Coolant Pump Malfunction P1B1C00
- 1995 A6 2.0 SE All Four Windows Stopped Working
- Audi a6 c7 3.0 TDI 7g s tronic problems
- Andover, MA Cars Coffee Tomorrow
- Dashboard lights
- Voltage in back seat 12v outlets
- 2016 A6 C7 2.0 TDI 190 S-Tronic: P 2002 Help Needed
- Audi 3.0 TDI Quattro
- A6 maintenance and longevity?
- Squeaky shifter (manual) juddery 1st gear on pull away
- 2 inch trailer hitch receiver options
- Car doesn't know it's in Park
- HEADLIGHT SWITCH ELECTRICAL DIAGRAM COLOR CODE?
- Egr delete with only tune?
- Blow off, Diverter or Wastegate???
- You are a very unique group of Audi drivers
- Left mirror indicator barely/not working
- 2011 and engine swap
- Feeling uneasy about cost of repairs, should i fight or pay?
- Back to Audi but New to Leasing
- Two phones: First - Android Auto for maps and Spotify, SoBluetooth for calls
- Intercooler upgrade with dual pulleys and ecu tune?
- A6 TDI TPMS SENSOR
- Help with troubleshooting
- SE: So many trouble codes! Help!!
- Facelift models
- Need help identifying a sound
- Need Advice - Engine Required Additional Oil
- Tire recommendation?
- Fuse boxes
- Longevity of OE Battery?
- C7.5 2.0T Structure-borne Sound retrofit
- Rear Window Roller Blind Retrofit
- Is a 2018MY A6 in the US the C7?
- 2.0T Tiptronic shifts slow unless in Manual
- Performance Brakes for A6 ???
- Audi A6 c7 blank flip screen not working
- Headers on 3.0T
- Oil Change Schedule?
- TDI high mileage car?
- air suspension grayed out raise or lower function
- UK: Transmission circuit failure
- Coolant system Fault message
- 125,000 miles and going strong
- Alternator not charging A6 C7
- VW remote start retrofit
- Reading errors
- Direct speaker replacement for non bose
- Engine hesitation at around 1500 rpm
- Repair Shop/Mechanic in Bay Area Recommendation
- Audi A6 C7 2017 JackSet
- Audi A6 rear diffuser
- g37 throttle vs A6 3.0 throttle
- Audi A6 c7 lowering springs
- Say hello to the A6 e-tron Concept
- C7 Allroad does not raise suspension in allroad mode.
- A6 and Q7 floor mats - are they the same?
- Has anyone used Camber Bolts to adjust camber on an Audi A6 C7?
- US Looking for input RE: Dealer Warranty for pre owned 2016 A6 2.0T
- Diameter of anti roll sway bar 4G0411309E?
- Rear wheel bearing and hub
- Used A6 maintenance tips....
- Rough Idle just went over 100K is it motor mounts?
- 2013 Audi S6 Has been Down Since October 2020 Please Help
- How difficult is it to install a cold air intake into a C7 3.0T?
- Heater problems
- Vibration when braking but not brakes
- Repairs and Preventative Maintenance North of 70,000 Miles
- is it possible to switch off auto mirror fold ?
- Transmission Trouble
- MMI cable for old iPod 3rd Gen Firewire
- Sell Your Gas Powered Audi Now
- C7 avant air compressor and relay
- 2017 Audi Connect features questions and issues
- Headlight Washer Cover
- AC Behavior
- diagnosing error code on 2014 A6 im looking to purchase
- Key fobs resync after car battery failure
- Any reason to upgrade from 14 A6 TDI to a 2016? Features?
- A6 2.0 TFSI DOHC LOUDER?
- Black gloss rear Badge
- Tire size for 9.5J 19" alloys
- MMI reboots constantly
- Replace driver window switch bezel trim
- NO: Auto function LED Matrix wont work
- Practicality of buying high mileage (140k) 2012 A6 w/the 3.0T?
- A6 (C7) Airbag Fault
- No fuel pump prime when opening door
- Fault
- what is this ?
- Back up camera
- ESC/ABS - TPMS - Parking Brake lights together
- Lower control arm recommendation.
- Camshaft
- on-board computer (fuel consumption) Retrofit
- D5s bulb 25w vs. 35w?
- Air Suspension fault on allroad 2016
- C7 19inch wheels black, photo request!
- PCV Replacement?
- ★ Car starting with fan blowing!
- Video in motion facelift (2018) with VCDS?
- HELP!!! HELP!! Poured Head Gasket Sealer in engine oil
- Water ingress through front interior light unit.
- 2014 A6 Sport Package- Is this lowered?
- Strange smell after gearbox repair
- Knocking like sound on front left&right wheels
- AU12 rims on a 2013 3.0T Prestige?
- Audi A6 3.0T Is the Best Sedan Money Can Buy
- UK: SE Pre facelift Halogen to Pre facelift LED rear lights
- Headlight replacement question
- Spark plugs?
- Some idiot ruined my nice clean 2016 A6 this weekend
- Independent shop for transmission work - CT/Westchester recommendation
- Hate the ride of my 2016 A6 TDI Prestige S line
- MMI Problems
- a6 c7 bose problem
- Adblue heater fault- P20B9
- HIGH BEAM & CORNERING LIGHTS NOT WORKING ON 2012 A6 AUDI PRESTIGE
- 2.0T to 4.2 conversion
- What underbody panel is this
- No connection to OBD2 port
- Multiple Warning Lights
- 3.0T "popping" noise front end
- UK: Audi A6 Saloon 1.8 TFSI SE Executive S Tronic no USB and CarPlay is not working
- Right Dipped Headlight Bulb Replacement
- 2013 audi a6 3.0t broken wire from connector ..name of connector
- Parking brake fault
- UK: Inspection reset?
- UK: 2016 se model wood inlays
- AE:A6 2016 2.0T 252PS Air intake?
- NO: Can anyone tell me what this is?
- Best Carplay retrofit option for 2013 A6 C7 MMI 3 G+
- Coolant leak after 2500RPM
- VIN decode; C6 or C7? Looking at 2011 A6 4.2 Prestige for sale
- VCDS Cable
- Steering wheel
- Noticeable steering wheel and gas pedal shudder
- Suggestions for more power??
- APR Throttle Body
- 2012 A6 Carista app error code 00784
- Answers for steering wheel swap?
- ECU Tuning, Superchargers, Turbos.
- Caliper Cleaning - Suggestions?
- Audi A6 C7 fault problem P01BC... pressure oil high and acceleration itself
- Water in rear footwell 2012 A6 3.0 TFSI
- 2012 Audi A6 3.0t bad starter
- Audi A6 3.0T Breather issue - help!
- Help with road noise
- Brake Pads?
- 3.0Tfsi. Timing Chain / Tensioner failure
- 2012 Audi A6 3.0t
- Looking for correct bushing for suspension arms.
- 2016 a6 TDI refill adblue?
- Evap system
- A6 3T Burns 1 Qt every 2 tanks. 2 Questions....
- Vibrations of the engine at low RPM
- Pre-sense rear problem
- 2014 Facelift Xenon installation
- Brake pad wear indicator
- checking the phase of the timing chain via VCDS
- 2017 A6 60K Maintenance Cost?
- A6 3.0 tdi stalls and no error code is present
- Water around the headlight assembly
- Audi A6 2013 2.0 won’t start
- Audi A6 judder, fault code P033F00, 2018 diesel
- 3-Spoke Steering wheel
- 2016 S6 to replace my 2012 A6 3T - what to expect?
- Fuel Sensor Issue on C7
- Used A6 Buying Advice (100K, Grandma Owned)
- Headlight range control module location
- What's my car worth?
- Whistle Above 50mph
- Problem Phone And Media are not showing on dashboard screen
- NL: Car is not starting, engine light is blinking
- Coilovers and Audi Drive Select System - Will there be any Issues???
- Oil cannister gasket failure
- Power Steering Fluid?
- Updating boring seat stitch
- cost of oil change in Canada?
