View Full Version : Audi allroad
- UA: 2004 allroad c5 4.2 question
- '05 allroad:'15 Golf R:'21 A4 or A6 allroad?
- 2013 allroad tool and wheel chock stock location
- i had 1st service done and few days later i find my ac not blowing cold air
- Cargo cover
- 2014 Audi Allroad premium plus
- 2024 Allroad Smartphone Interface
- Suger Defender | Blood Balance
- 01 Allroad tip trans slipping in both 1st and 2nd
- Valve cover gasket help
- 2005 Allroad purchasing a 2002 Allroad parts car
- Audi A4 Allroad B9 Facelift Exhaust
- Used Allroad has "Full paint body finish"
- 2011 allroad no drive
- Anyone recognize this logo on a 2005 C5 Allroad?
- Central Locking Problem A6 Allroad
- Just an Idea
- A4 allroad juddering when standing still
- location of cooling fan relays on RHD models?
- AU: Swapping 2.7t front calipers for 4.2 VCDS requirment
- Considering a 110 000km A4 All Road
- Intermittent rear door courtesy lights
- Tire Size Question
- Hood/bonnet latch wiring
- Regular cruise control
- Hood/bonnet latch
- Allroad level sensor delete/removal?
- Winter wheel setup
- Please Educate me on the Allroad & Avant.
- Arnott rear bag install, can’t lock to shock absorber
- 2001 Audi allroad radio not working no fuse will stay in the correct spot
- 2023 A4 Allroad fuel link leak
- 2003 2.7T manual trans parts car… OR salvaging advice
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- Arnott Gen 2 airstruts at NAPA
- Ticking Noise Under Acceleration, CV joints?
- 04 allroad can't log into self leveling controller
- NOT the torque converter, right?!
- 2004 Allroad Start Up Problem?
- Show Us Your Winter Wheel/Tire set up
- need to find a replacement engine with warranty!
- My Allroad is getting closer!!!!
- Hard-to-locate coolant leak 3.0 TDI
- A6 C6 Allroad Battery 2008 drain
- 2015 Allroad Engine Rebuild
- Water in vehicle
- 2004 2.7T VCDS 08 HVAC login code?
- Engine overheats, no solution, advised to replace
- Steering wheel swap
- 2.7T misfire?
- 05 4.2 for sale for parts or repair
- Whacko ECM in 2005 C5 Allroad 4.2l
- UK: Audi A6 quattro music question
- C5 temporary spare replacement
- 2005 Drivers Airbag
- Self Leveling / ESP / ABS lights on at once - how to troubleshoot?
- 2017 Allroad US Under hood photo for stickers please?
- Strut top bracket. I need a couple.
- Overheating
- Overheating
- C5 allroad for sale
- UK: Allroad C6 01437 Code | Jacking Mode | Sagging | help ;-)
- Best Air Suspension Conversion for an '05 4.2?
- Need 2 latches for the warning triangle door
- 05 allroad Passenger turbo coolant leak
- 2023 A4 Allroad
- Head gasket
- Rear suspension triggers low when ignition off
- AU: Any advice on high KM Allroad 2.7?
- FI: 03 allroad suspension problems
- Allroad 4.2 codes 18080 and 18047 both together
- Allroad TDI swap, need advice/help
- AC compressor switching on and off every minute
- Brake and Tail Light Indicators Malfunction
- Front bolts on 03 Allroad splash guard/ air intake
- audi a4 b8 allroad diffuser replacement
- 2005 Allroad Brake conversion Question
- UK: 2000 Allroad C5 2.5TDI Auto Gearbox Fault after Service
- 2018 Q3 Cranking Issue
- A8 transmission transplant
- Misfire/stalling issue
- 19x9.5 ET 33
- Mmi repair needed in illinois
- Need photo of Tip magnet
- Blown (not working) 2013. Ideas welcome.
- AE: Audi set my car on fire. Family survived
- Audi set up car on fire. Family survived.
- Please help me to remove a rear mirror bracket
- GR: '01 2.7 tip frustratingly overheating
- Coilover problem
- 3.0tdi swap into C5 allroad possibility
- Backup Camera Module
- Audi allroad 2004 4.2 with Lucas 2 piston front calipers.
- 2015 Allroad Quattro oil sensor/ECV issue
- UK: Audi AllRoad A6 C6 2006 air suspension problem
- RO: Service plan for A4 B8.5?
- straight line in my right rear window a4 allroad
- Hit a curve on icy road
- Audi 2005 Suspension issues
- Allroad 2.7T 2005 - Heater supply pipe replacement
- 2014 all road wheels and tires?
- C5 RS6 exhaust on Allroad 4.2?
- UK: Audi AllRoad 2.0 TDI Not Starting
- UK: Audi A6 v6 all road 2003 electronic malfunction
- Aftermarket headlights/taillights 2001 allroad
- Audi Allroad Blackline Taillight Set, Dynamic Amber Signal
- A4 allroad
- can I downsize wheels on 2022 A6 Allroad?
- Weird things happening..
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 00143 Front Dampening Adjustment Valve
- 2023 Allroad Hitch q
- Adding back-up camera to '05 allroad
- question for camshaft swaps
- 2017 A4 Allroad Audio Issue
- C5 Allroad crank no start 2.7t (?bad ECU)
- 03 Allroad Power steering fluid
- C5 Allroad 2.7T - Slow to Defrost Windows
- Arnott front air spring :(
- Electronic stability control
- 2016 2.0t A4 Allroad Very Bad Gas Mileage
- Air suspension valve block replacement
- egnition
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- Bouncy A4 Allroad
- 2018 Allraod clutch replacement
- Heater Core flush '05 A6 Allroad
- Selling one of my allroad's
- Audi C5 Allroad with Touareg 255/55/r18 wheels?
- When replacing the TCM, does the manufacture code...
- Traffic Jam Assist in my new Allroad A6?
- 2002 all road 2.7t
- 17" Wheels on a 2013 Allroad
- B8 Allroad Front Plate Fillers
- 2013 allroad - taller tires?
- UK: 2014 C7 ALLROAD
- A good way to clean the diesel "nozzles".
- How to know if the TC and valve body are the problem with my transmission?
- Allroad B8 bumper coversion?
- 2001 2.7 Quattro front air bags will not Lift... Help
- C5 Allroad 6-speed swap!
- Offroad wheels and tires for allroad?
- Driveshaft/Prop Shaft Seal
- 4B0971073M need harness info
- TPSM sensor
- SE: Turbo failure A4 2.0 tdi 190
- Audi allroad 3.0 2008
- 4.2 Allroad Valve Cover Gaskets
- 04 allroad air suspension problems
- Gearbox
- AU: 2007 audi a6 c6 allroad diesel air suspension relay
- Allroad 2004 Right rear door
- Allroad A6 X Reg (year of manufacture 2000)
- Cooling system/AC malfunction
- Rear shock absorber mount
- 2003 allroad 2.7t timing belt/transmission
- Trailer hitch for 2022 A6 AR?
- Rear park lights won't turn off
- Valet Key/ Emergency Start Case
- 2003 Allroad Suspension control switch not lighting up and staying active
- New alignment readings
- Cylinder Misfire! (5)
- disabling traffic sign recognition
- 02 6 speed no shift question
- Trying to install aftermarket head unit into a non-bose Allroad 2003
- Coolant flange for 2004 audi allroad 4.2
- PT: Pneumatic suspension
- Trani Rebuild Kits
- Need help with wheel fitment! Stock 2018 A4 Allroad Prestige
- Towing Capacity Audi A6 All Road 2022?
- '01 Allroad CAN bus/K-line/OBD issues
- Coolant hoses for 2.7t V6
- 2002Audi All road Quattro Serpentine Tensioner Pully
- ECU Recoding - Incorrect coding for coil swapped allroad
- Misfire Cylinder 4
- 05 Audi allroad 2.7t tiptronic to 02X swap
- Headlight compatibility
- Windshield scratched, what should I do next?
- 2004 2.7t
- 2005 Bumper question
- '01 Allroad project
- 2013 allroad needs new engine
- Transmission issue with A6
- Where can I get valvoline coupons?
- Audi A6 allroad 3.0 tfsi 310 hp C7 4G - custom exhaust
- Woot! Got my (new to me) 2003 AR
- 2004 2.7t heater box multiple temperatures
- 2004 4.2 All-Road Radiator Hoses??
- C5 ar rear mudflaps anyone?
- Do you have broken cargo cover end caps?
- Heated steering wheel not working
- Air suspension to coil conversion
- AR c5 2.7t vibrate after changed timing belt
- 04 Allroad auto trans
- Watch out for rodents!
- Timing belt slipped, damaged valves, etc
- 2015 all road struts
- Mechanical noise?
- 03 Allroad 6 speed swap issues
- Bypass Secondary Air Injector?
- It helps boost the working of the ECS and CNS
- Rear air suspension going down, no error codes
- DK: Rusty doors Allroad C6 2007
- 02 C5 Allroad 2.7 ABS NO COMMUNICATION
- 2005 Allroad Suspension issue (of course)
- 2022 Allroad - is Bang & Olufsen worth it
- 2005 Audi Allroad C5, Fuel Door Actuator
- 01V CODE EYK Refurbished, Need some insight
- Air suspension work while engine is switched off?
- '04 allroad 2.7T auto transmission issue
- Transmissioin fluid additive ZF5HP19?
- 2006 Audi Allroad - battery issue?
- Is it rear differential noise?
- Glovebox question + Advice
- Replacement front control arms.
- 2016 Allroad \side view mirror issue
- 2003 Allroad - ABS code - can't recode
- BE: 2004 Quattro AC Issues
- Catching up (maintainence question)
- Multiple Broken Clutch Fan Blades
- Navigation and Media won't initiialize
- Electrical failure
- Just ordered a 2022 Allroad
- Do I need to reprogram to install a TCM
- 2005 AllRoad Electrical issues
- 2018 allroad, remove rear sunshade bar
- BE: Low oil pressure light on my '04 4.2?
- rear seat cup holder
- AU: 2009 A6 Allroad - suspension drop hard left or right turn
- ABS Coding
- 02 2.7t epc light on no start
- C7 allroad parkingsensor
- 2014 Audi Allroad
- 2003 allroad windshield cowling
- heat not working and losing coolant
- Gateway Control Module failure - 2019 Allroad
- 02 all road headlight light
- Allroad 3.0 Tdi Cranks but wont start !!
- Question about selling 2003 Allroad
- Inflation Relief - Black Friday thru the end of November Sale...
- Cold Weather Starting on a 2016 Audi e-tron
- Repair savaged RNS-D loom, or rip out entirely?
- Suspension conversion remorse - advice needed
- Dashboard/mmi changes when towing
- B8.5 Center Diff Fluid Alternatives
- 2010 3.0TFSi A6 Allroad. alternator no signal Fault code
- How much would it cost to fix this?
- the green light /button for air suspension audi a6 2003 allroad does not respond
- Air pump suspension does not respond - Audi a6 Quattro 2003 - all road 2.7t, petrol
