PDA
View Full Version : Audi allroad
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161
  1. can you disable the automatic door re-lock with vcds?
  2. How often is too often?
  3. Just coincidence or somehow related
  4. Cruise Control Module on my 05?
  5. front plate mounting on 04 allroad with filler plate. fix it ticket last weekend an
  6. 2001 AR radiator replacement
  7. PICS- Custom defrost vent pod installed along with Podi Stepper gauge.
  8. Audi A6 allroad full size spare tyre?
  9. allroad control arm kit question...
  10. Air Suspension Leaks / troubleshooting
  11. Confounding Misfires
  12. Problem with Front Driveshaft Removal
  13. 2001 Suspension and Warning Light Problems
  14. Transmission trouble. I help needed.
  15. 2013 Audi Allroad pics from the Chicago Auto Show
  16. VAG-COM Questions
  17. 2001 Audi Allroad Repair Manual
  18. jack mode??
  19. 2001 Allroad AM not working
  20. 2012 Avant vs. 2013 Allroad
  21. Digital Audio Input
  22. Correct Arnott/Mercedes pump b4 purchase?
  23. 034 SAI delete block-off plates???
  24. 2012 A4 Allroad Test Drive! 1st impressions
  25. I lost all my gears in snow..
  26. Fuel Pump
  27. allroad 4.2 gas mileage and tire wear
  28. Allroad Test Drive in Park City UT- Is this car an A4 or A6 platform?
  29. Headlight (or headlight cover) options...
  30. 2012 A4 allroad 2.0tdi s-tronic
  31. After-run coolant pump...does it do anything???
  32. OEM Parts
  33. :: ECS Tuning :: 2.7T Gasket Kits!!
  34. The Most Memorable Mile Contest
  35. Manual tranny fluid info
  36. Anyone know anything about rebuilding an allroad suspension compressor?
  37. The I Walked Away From that AR thread
  38. ECS Brake Upgrade HELP!
  39. airbag computer module replacement
  40. After market Head lights
  41. What oil to use?
  42. Ever witness the sound of a cv boot tearing to pieces?
  43. IHAVE ALOT MORE ALLROD MOVIES
  44. Trucks And Transport Museum + MY MY AUDI ALLROAD & MERCEDES-BENZ SPRINTER
  45. Need new OEM shocks. Anybody with left overs?
  46. Air suspension distrubution block code...
  47. Inspecting used AR: Can air leaks be detected?
  48. The ups and downs of allroad ownership
  49. a6 wipers
  50. Back Hatch Panel
  51. Another "I'm Buying an AR" thread
  52. Viscous Fan Removal
  53. Classifieds Question?
  54. Show us your dogs
  55. Very unstable in snow
  56. Orange Suspension Light on Button
  57. Ebay downpipes 2.7T
  58. Slippin' and a-slidin', winter tire pressure?
  59. Looking at buying a allroad for the wife and I
  60. Temperature Sender question ...Again
  61. VAG COM in Seattle area??
  62. what tires and size are you using?
  63. servotronic delete
  64. 2001 Allroad 2.7T
  65. Allroad sitting asymmetrically. Lower on one side, but stable height. ??
  66. What keeps air springs seated on Arnott Bilsteins?
  67. Thule Rack
  68. getting heat, what,why. or why not.
  69. "Chipping", gas mileage, and reliability
  70. Noob here
  71. Door not shutting
  72. Allroad Injectors
  73. allroad pulled out of U.S
  74. Starting in -27C
  75. Allroad tune up
  76. Xenon range EURO manual adjustment level retrofit DIY (C5 A6/allroad)
  77. Semi-new here
  78. Allroad parts for sale
  79. 2003 Allroad 2.7t, NO HEAT!!!
  80. keyless push button start
  81. WTB - new-ish turbos???
  82. Cracked tranny bracket/mount?
  83. 2.7t overheating and lack of power
  84. Vote for my car so i can win a contest!
  85. plastic engine covers--what is the point?
  86. Finally! The new 2013 Allroad is coming to the US of A
  87. Gen I or Gen II replacement springs
  88. Can third row seat be added to 2005?
  89. APR ECU upgrade
  90. Left front Suspention POPPED while driving.
  91. Seats from S4
  92. auto start
  93. Need help to pick best independent shop in Seattle
  94. Key remote range
  95. Buying an 02 Allroad
  96. info please
  97. TIP: How to replace the ECT - Engine Coolant Temperator sensor
  98. Rear Wiper Size?
  99. New AR
  100. 402 - when to measure height?
  101. 2008 allroad purchase question - newb
  102. Euro Tow ball Mod Question
  103. Just installed Mercedes Suspension Pump....
  104. Quick question about the antenna
  105. parts source
  106. MFSW Retrofit
  107. Turbo operation
  108. Bad day at the smog test...
  109. Who can recommend a cheap+good indie for heater core change?
  110. Probable 2.7t Allroad project purchase
  111. Front reading lights problem
  112. WTB: TCM for a 4.2L Allroad
  113. Auto folding the outside mirrors.
  114. new Arnott losing air
  115. HAPPY NEW YEAR
  116. 2003 audi allroad miles per gallon issue
  117. 2003 MT purchase
  118. Speaker issue
  119. Dumb question
  120. Cleaning a black car
  121. Programming Homelink feature?
  122. Simply needing a little wheel fitment help.
  123. coast go coast trip
  124. 2001 Allroad Part Out
  125. air compressor fix/relocation
  126. Anyone know where I can get this piece?
  127. Allroad Advice
  128. Monumental Break Squeal
  129. New allroad owner needs 75k service in Colorado
  130. Realistically how much can I sell the allroad for?
  131. :: ECS Tuning :: Up To 25% Off ECS Wheel Spacers!!!
  132. 2Bennett Clutch Reviews?
  133. Suspension Compressor Question
  134. Arnott Inc Discount Code good thru 1-31-12
  135. improving sound quality in RNS-E? low bass...
  136. :: ECS Tuning :: Winter is here!!
  137. PLEASE HELP!
  138. what is this switch (below instrument cluster on the right)?
  139. driver side door
  140. :: ECS Tuning :: C5 Avant/Allroad Roof Rack Base Bars!!
  141. snow tires
  142. 2003 Audi Allroad worn out buttons
  143. Allroad front control arm kit
  144. :: ECS Tuning :: Save 10% On FK Automotive Products!!
  145. noob question re: air suspension auto-leveling
  146. Converted cluster to metric, weird characters show
  147. Need some Cam Plug Help
  148. 2.8 Swap?
  149. Transmission in the 4.2L Allroad
  150. CV Axle Replacements
  151. a diatribe on plastic
  152. Mercedes air pump 164320050428?
  153. Airbags - change spring rate
  154. Allroad suspension - Arnott bags, Bilstein shocks
  155. Suspension when below 0C/32F
  156. Manual gear box
  157. Gear changing on cold engine
  158. Head light adjustment
  159. Need brakes OEM or Aftermarket
  160. :: ECS Tuning :: Rear Aero Wiper Conversion!!!
  161. :: ECS Tuning :: Save 10% On EBC Brake Components
  162. Brake Shriek
  163. :: ECS Tuning :: APR Holiday Sale Through 1/2/12!!!
  164. Torque converter clutch. AR 4.2L
  165. Grinding noise on start. AR 4.2L
  166. Just bought 2004!
  167. Is leaving car in L3 OK?
  168. Heated Steering Wheel is HOT!
  169. Advice on fixing/selling 02 allroad 6 speed manual
  170. Looking for a "low" mileage allroad 4.2
  171. CONFIRMED: 2012 Audi A4 Allroad Quattro Arriving in July
  172. Not MacGyver!
  173. Allroad front bumper
  174. Last Minute Holiday Promotion - 15% off - Flat Shipping - $20 gift code on next order
  175. Allroad leans to the right
  176. How to diagnose Compressor problem?
  177. Nokian, the Swedish winter tire experts have a new all season tire "eNTYRE".
  178. Clink ! clink!
  179. 2001 Allroad Twin Spoke Rims Removal
  180. 2001 Allroad Twin Spoke Rims Removal
  181. Alarm beep adaptation
  182. Help, Need Advice form "All"road Experts
  183. Largest battery that fits?
  184. Xenon upgrade for allroad 2.7t (2k4)
  185. Replacing an armrest cover...
  186. :: ECS Tuning :: ON SALE - Bentley Manuals!!
  187. speed signal input
  188. Heater issue, once bitten, twice shy...
  189. Driving on Lift Mode
  190. DISABLING AIR SUSPENSION
  191. Center LCD Instrument Problem
  192. horrible vibration
  193. BUY 2 GET 2 FREE UBER Microfiber Towels - Start now ends 12/8/11
  194. Where is this plume of smoke coming from?
  195. Front door latch issue
  196. Audi A6/S6/RS6 Avant black headliner
  197. Brake Light
  198. how to lock in 4th level 60mph +
  199. Will 235/55/17 tires fit
  200. Air Suspension Diagnosis Help Needed
  201. About to order parts for timing belt and valve cover gaskets
  202. sunroof
  203. air suspension POS
  204. No heat #2, can't you manually switch on aux pump?
  205. end all fixes uofrade suspension.
  206. Guess the Cost (new shop test)
  207. FS 2004 allroad 4.2 V8 76k miles
  208. Iphone 4s
  209. Weird whining noise when I start my car.
  210. does anybody still have the old vcds 10
  211. Prospective buyer
  212. 2001 Allroad Rim/Tire Question
  213. poly any bushing
  214. New wheels
  215. Headlight adjustment error on display related to ride height?
  216. rear subwoofer
  217. What tyres next?
  218. new standard.vcds obd2 style dyno
  219. Amber 'height warning' light comes on.
  220. LOST POWER TO DRIVE WHEELS WHILE PARKING!
  221. Not so good cup holders
  222. Air suspension compressor... failed?
  223. cv axle went after beating the shot.....117vt
  224. Lots of things fixed today on the allroad
  225. :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
  226. 6 spd shifting problem
  227. FS: AWE Drivetrain Stabilizer + allroad adaptors
  228. Rear Cargo light won't come on when hatch is opened
  229. Do i need any clamps for PCV replacement?
  230. Black Friday Special at Detailer's Domain
  231. Front to rear drive shaft bolts
  232. Battery draw = large draw
  233. Need help finding source of oil leak - Allroad
  234. Dice Silverline DUO + G2 cradle?
  235. After-Run Coolant Pump Circuitry System
  236. Question on drivetrain vibration I am feeling
  237. 2002 6spd on CL on LI NY
  238. Why buy an allroad ?
  239. Air suspension - height log
  240. airbag light
  241. ALLROAD IS FLEX MUTI FUEL
  242. MPH versus RPM's
  243. RPM's and MPH?
  244. ABS, ESP, AND SUSPENTION LIGHT ON!!!
  245. how to flash your ecu with vcds
  246. Outside air temp display
  247. 16985 ECU Memory Checksum Error
  248. Liquid inside rear view mirror - Double images - Need more info
  249. Allroad hood.
  250. Cam plug
