View Full Version : Audi allroad
- Allroad ABS issues--ECBM or Controller?
- 04 allroad starting problem
- Fault code help - Level and Suspension
- See my ad for tires FS in classifieds.
- After Run pump relocation kit; Apikol or EuropaParts?
- Heater core flush results
- if you could get 40mpg + on 87 and pull near 400hp.,
- nefmoto 91 oct file
- Brake package.
- Looking for a rear cago retractable cover
- Allroad with aftermarket wheels
- effects of too much oil?
- OEM parts
- Coolant change WTF??? Lower hose "clamp"?
- brake pads (collier) worn out on the left wheel but not on the right wheel.
- new HP oem style air bags coming out soon,
- 402 mod sucks, i did this instead, recode
- 2005 Allroad
- Front Wiper Blade Replacement
- Arnott Strut/Coil Spring Conversion
- Going for Arnotts
- How To Stop Full On Blowers When Starting
- Shifting a 6-sp MT
- Suspension down
- Bridgestone RE960AS vs. ContiExtreme DWS vs Yokahama
- Power Steering
- Wipers Stuck In Service Position
- Wanted to share : allroad long and short sleeve shirts available.....
- Suspension Control Module
- Oil Level Sensor Defective Warning Light
- how to fix poor heat, heater core
- Push bar???
- Part Identification (P0941)
- 2002 ALLROAD
- Leaking Headlamp Washer
- Allroad Dashboard ticking / Clicking
- Wipers problem - steelership at fault I think
- Heater issues, are there certain diagnostics that ONLY a dealer can do?
- Visit to Dealer shop
- Air leak after installing new Arnott's
- Heater system airflow vanes/flaps...
- More skidplate!
- Height adjust. Fails in cold weather
- take a minute thrirty to visit You Tube "Audi goes up"
- First snow fall today, safe to say the AR is ready
- Our Annual SEMA Special at Detailer's Domain
- Running light 'short'
- Winter features
- 2001 allroad HEAVY raw gas smell qith defrost on
- 2013 A4 Allroad - Tasty!
- First frosty morning, REALLY pissed...
- allroad OEM 18" rims wanted
- New blower motor
- Early vs, Later Allroads
- Front license plate euro frame
- How do you reset door open light on dash?
- Warranty options?
- CEL for an Evap Leak
- Performance catalytic converters? And ODB11 reader
- Car alarm randomly going off
- Wiper going slow, stopping - dying?
- wiper blades - source
- Stranded by massive coolant leak - 2.7T allroad
- Silly Question - how do you turn on the fog lights with only the parking lights?
- Possible to alter speed controlled lowering?
- New Guy from the Showme state.
- Brake Pad light causing Check Engine light?
- Height warning light.
- TCM wiring harnass trouble!
- Part number for Bosch 02 sensors (precat)
- Deal of the day Save 70% off Uber All Purpose Towels at Detailer's Domain
- Need Help =(
- leather on steering wheel?
- Traded my 98 V70R for an 2001 allroad this weekend!
- 03 Allroad Remove or Disable Air Suspension?
- Knock from front, driver's side suspension
- Trailer Wiring and Suspension Question
- Im thinking about buying an Allroad
- Brake pedal making a clicking noise
- 3 leaks: Floor, Seat Belt retractor & Exhaust.....
- windshield washer
- Anyone konw how Arnott give assurance for peoples in other countries?
- REISU MOTORSPORTS HOUSTON
- Oil burning smell
- Wheels: suggested retailers, manufacturers, and use of wheel spacers
- Cam locking tool question
- Busted Speaker
- Exhaust smoke / stupid question of the week
- Broken allroad Suspension Air Compressor Wanted
- Buying advice
- Cup holders
- "New" 04 4.2 allroad - now thinking about selling
- No buttons on my steering wheel?
- Differnt height on all 4 wheels.
- Selling My allroad.
- Rear Sunshade
- WHICH SUSPENSION ?
- Bad tires for AR, suggestions for replacements?
- Time for 75K service: other upgrades to consider?
- HELP ASAP! Air suspension "adapatation not learned"
- WeatherTech DigitalFit Floor Liners?
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- Looking for a Level Sensor Replacement DIY Write-up...
- mechanic recommendations - Fairfield County, CT
- Japanese allroad forum
- New Allroad Owner :)
- Audi Allroad 2.7T quattro lack of power
- 2.5TDI V6 2004 Allroad gearbox/differential problems
- Anyone thinking of a Magnaflow kit for their allroad....
- Susention leak.
- Allroad Rear Differential Output Seal Clearance Issue
- Anyone runs or heard of staggered tires on AR?
- Replacing front Air Spring
- 2002 Allroad Bose Subs
- Hi This is Jacob147258..
- Bought my first Allroad
- Radio Problem
- Aluminum bottom door trim
- cam seals w/o ruining valves
- Gettin' Ready to Pull the Engine/Trans...
- Heater Core Replacement
- 2004 Audi Allroad Trans Code FXL
- Vibration Under Load
- Transmission fluid change
- bent rim sagga, 3 oem wheels for sale.
- wheel fitment issue
- Finding small air leak in AR suspension
- Is the steering rack pinion tension adjustable?
- This Newbie Needs Help
- engine mount blunders
- Y connector problems-anti freeze
- Is it an Audi or and air plane?
- Tools needed to read faults on my allroad
- HELP - engine won't start
- How to get the "Manual Mode" in level control?
- Warning lights -sometimes
- Audi allroad Generation-II failure
- P1453
- Anyone running w/o the underbelly panels?
- Reliability Mods: What To Do
- TCM compatibility question
- Air suspension self-study
- FREE leather shift boots and more for Your Audi!
- allroad
- Air suspension valve block
- Driver's mirror gremlin
- P0491 & P0492 AFTER running for 10 minutes
- where is the switch that turns the lights on in the trunk hatch
- Arnott coil spring kit v. gen II air springs
- Audi o,e. part numbers
- FS: Allroad Winter Wheels With Tires
- Darin Intake mode - K&N cone
- noter Suspension problem thread
- car height is wayyyyy off
- Dog owners - Questions about using a dog guard or not.
- frankenturbo info??
- Running hot
- 2001 Allroad Air suspension question
- 402 mod - level - errors
- ABS issues after Hurricane
- Air suspension valve block air lines color chart
- Anyone have a TCU for an allroad with steering wheel tip controls for sale?
- Arm for stock hitch
- Urgent help needed near Indianapolis.
- Rust
- Remove passenger side valve cover 2.7T
- center support bearing on propshaft
- ordering stuff for transmission
- What size wheels do you want....
- looking for a manual allroad
- Auto transmission slipping in 1st gear...
- 04 Allroad ABS question
- Unitronic group buy
- Would someone with a 6mt help me out? I would like to know the following: How many
- lifetime transmission fluid ?
- Fuel door
- Suspension: Level Control Module
- Upper rubber shock mount installation help
- front passenger tire question
- what audi is this?
- White smoke from wheel well?
- Turbo help
- 2bennett Coilovers Any Good
- Strange squeal after shifting into reverse
- Wheel/Tire Help. Thanks!
- Just did Exhaust and Tail lights...
- Air suspension airline replacement
- Ipod adapter
- Drip Drip Drip ... Drip
- swimming pool on pass side front and back !
- 2006 Allroad A6 Navigation System
- A4 Allroad
- tip recode 0032
- Who's allroad is this?
- 402 mod - height measurements ground/fender - stock, lowered
- Roof-mounted bike rack
- AUDI FAULT CODE P0741 17125 100% FIX.TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO
- more supportive seats in a c5 allroad
- Off topic but....
- How to Win Hearts, A Race, and Respect
- Air Suspension - up, down, front, rear
- $1000.00 do I really need new DVs?
- 50+ mpg challenge and a desighn for poontoons and wings.
- i finally happy with the dam thing for know.
- Allroad 2.5TDI V6 whining noise when slowing from speed
- 2004 A6 allroad 2.5 V6 TDI
- Checking Oil
- Clicking Noise Under Braking
- Removing and fitting seats.
- Electrical Problem - Shift lock inop, climate control dead, oil light flashing
- Part number for rear parking sensor?
- Why does my steering go off-center at different levels?
- tcu for 2003 allroad 2. tip
- Offset Difference between Winter and Summer Wheels
- Need Help FIxing WIndow...
- allroad wheel choices - opinions welcomed
- 2001 allroad 6-speed 47K miles w/warranty for sale!
- swaped n75 from tt to allroad....>
- For Sale: BRAND NEW oem Floor mats (carpet)
- For Sale: Allroad OEM trailer hitch tounge and harness
- APR allroad chip
- Driver's door doesn't close smoothly, looks like it has lowered a bit. Any thoughts
- front air suspension
- oil pres.?
- Headlight bulb replacement
- Spare Tire for 01 Allroad
- Disabling TPMS
- VW/Audi ETKA
- Dimmable +12V
- Random (Multiple) Misfire & Valve Covers
- A/C only blows cold on one side
- Show Pride In Your Ride and WIN $100 !!!
- Before you overhaul, or replace your trans/TC read this
- what is the psi for the 2.7t for a chipped ecu?
- 2001 Audi S4 for $6995 with 141k miles on it... Worth it?
- load reduction relay 370
- AUDI VERMONT get to gether.RALLY:)
- ISO: Rear 4-Ring Badge
- Allroad tranmission "core" and rear Diff
- Waterfest 17 Special at Detailer's Domain - 20% off!
- Allroad vs. A3 ???
- Wastegate Control Lines
- Shock replacement
- electric small drive with generator
- Odd cruise control jerk?
- so, building a super allroad
- Need new key. Alternative to dealer?
- 17" Split spoke rim and mounted tire FS in CT
- Replace mirror switch
- Fuel guage indication
