View Full Version : Audi allroad
- :: ECS Tuning :: NEW!! Billet Aluminum Oil Filter Housing Cap - Audi 4.2L (non -FSI)
- Ingolstadt: The Home of Audi
- RS6 Wheels
- Speakers popping, water found in trunk
- Red Stuff Brake pads
- Decided to put together another shirt for us allroaders....
- air bags
- Heavy wheels
- Having oil sludge problems...
- :: ECS Tuning :: Color Key Fob Covers - Back In Stock!!
- A couple of questions please!
- 2004 Allroad 4.2L Engine Air Filter
- 15% off for the next 48 hours at DetailersDomain.com
- Most weirdest coolant leak?
- Front Suspension Bottomed Out. HELP!
- European front plate
- Help Reprogramming Allroad Alarm/Door Lock with Ross Tech
- Final test on wiring for my custom multifunction 3-spoke TIP steering wheel a success
- How to identify the source of a suspension air leak?
- Crank, No Start... HELP
- Transmission stuffed?
- Fog Light Replacements - Best Choices
- Unsure of an Allroad. Help!
- Bought a cheap broken allroad.
- AUDI 2000 A6 2.5 CRUISE CONTROL LOCATION
- Frt Left CV boot shred in 35K - just a cheap boot?
- :: ECS Tuning :: Alzor 18" Style 601 Wheel Sets - Classic Split 7-Spoke!!
- Need Replacement Shocks for '02 allroad
- Can I stop my Allroad from going up and down?
- OEM Wheels
- Allroad 3.0 TFSI lpg conversion
- Did anyone here buy this?
- 2001 Allroad 6 spd manual - rear right CV Axle drive shaft
- Good night and good luck
- Oil: SN API rating is better than SJ ?
- :: ECS Tuning :: Remote Transmitter Buttons - .99 Cents!
- 2003 Allroad Heater Core Replacement
- CD problem.
- Instrument LCD
- Replacing Controls Arms - What Else? & allroad specific issues
- allroad reliability mods
- Engine Cover Q
- New Allroad Owner - 2005
- VagCom suspension code advice needed
- ESC when accelerating?
- APR Allroad Low Boost Request
- Starter motor help need ASAP
- New Allroad owner with a few questions?
- Did a little front grill mod. Wanted to share....
- 2003 Allroad Manual Shifter Options
- Odd electrical issue
- Problem with A6 Allroad
- Timing Belt off the mark
- 2.7 thermostat orientation
- Tire Valve for 04-05 18" Wheel
- @#$%^&* wiring connector
- 2003 Audi Allroad 2.7 Coolant leak (expansion bootle?)
- Water coming in cabin air filter after car wash
- Save BIG on Sonax Full Effect Wheel Cleaner DetailersDomain.com
- Camshaft Incorrect Correlation
- 2004 Alloy Wheel Weight
- New version of my rear Allroad sport badge
- Spongy brakes after rotor and pad change
- Intermittent Oil Leak?
- Dome light blinking, why?
- Arnott coil over conversion suspension
- need help esp abs level fault!!!
- Experience with Strutmaster coil conversion
- Size of star socket for 2.7 crank bolt
- 2005 allroad 2.7 AM / pick her up tomorrow
- Brake shudder under load
- Oh no!!!! Dendist drill:(
- Shift Lock Override for 2002 Allroad
- Jack points
- Octane booster. How much do I need?
- CNC Cut Mesh Grill Project Finished! Pics inside...
- Oxygen sensors Allroad
- Old Article about quattro system
- 2.7T - cylinder head rebuild - engine out?
- Oil Leak
- Worn climate control and other "soft touch" buttons.
- DMF (Dual Mass Flywheel) Question
- Aux. Fan issues. Specs...
- A6 owner considering stepping up to an Allroad 4.2
- An Arnott air spring leaking!
- Labor Day 2013 Special at DetailersDomain.com
- 2004 A4 Allroad Wagon help!
- '03 Allroad Suspension
- All Road Turbo Going out
- Just bought - need help/clarification
- '02 Allroad electrical issue--hazard lights etc
- 2001 Audi Allroad - Strange Sound While Driving
- HELP PLEASE!!
- A little DIY shift knob repair. A possible solution for those broken tabs....
- Electric steering column repair. Possible or not ?
- cv boot instaler ???
- Allroad 4.2l Not Changing Gears
- Wheel Rubbing
- Whoops rear suspension alignment problem after replacing airbag
- Auxiliary coolant pump relocation.
- VAGMOD
- New member 05 allroad
- torque converter
- allroad 2.7t overheating ....FRUSTRATED !!!
- Tire pressure control monitor
- "Audi World" A4 Allroad Bagged on Vossen VVS-CV3s
- TCM (transmission control module) Software Updated
- Allroad Vs BMW 328d X-Drive Sport Wagon
- Transmission Woes - My turn
- Save 20% off damaged Sonax 5 Liter Full Effect Wheel Cleaner! Limited Qty
- removing luggage compartment panels
- Arnott kit up for grabs...
- Storing my allroad
- WHEEL QUESTION
- Both right side speakers dead
- $1666 +$700 labor quoted for ...
- Allroad - TDI intercooler fit?
- quick easy question
- Oem trailer hitch
- Need HELP >> cont. main company.
- Piggie Pipes on allroad 6 speed MT
- Totally new and very strange problem!
- Interesting problem with Keys and Alarm with my Allroad
- midwest mechanic referral
- Torn throttle body boot....yet again...one year later!
- Allroad 6 spd tranny swap S4 or A6
- air con condensate drain location?
- Radio upgrade
- Air Compressor rubs on Sway Bar
- Drivers headlamp issues
- 05 4.2 Allroad Jump Timing
- Allroad 2002 tip on the track?
- Suspension troubleshooting and diagnostic
- Fastest 1/4 mile Allroad
- Suspension Control Level Surpassed
- 03 AR suspension won't stay in L4
- Brake pads and rotor recommnedations
- error code ps2098
- Wifi/Bluetooth OBDII dongle
- Front Suspension Noise
- Coolant blow out and possible other work
- Allroad Issues
- Oxygen Sensors
- Audi A6 Quattro 3.0 TDI 2006 starting problem
- Sooooo my new allroad doesn't want to start reliably. Help?
- Factory settings on suspension Level Control
- was Nav Plus RNS-E offered in US Allroad?
- Test driving a 2004 allroad
- Allroad A6 rear Air Spring-how do you undo top nut?
- Evolution Imports "Thor" Skid Plate for Allroad
- need new trunk door lower chrome trim piece
- clutch / transmission problems - ticking
- 2002 2.7 stutter, O2 codes
- charging system
- AIR BAGS
- apr chip for 04 allroad
- Weekend trekking
- 04 allroad automatic
- Power Steering System Blow Out
- Wanted: How-To, Window Troubleshooting
- Window regulator
- Suspension failure
- Power Steering Rack Failure
- Oil temperature
- Good Audi repair shop in CT?
- Fuse layout
- Help with codes
- 2013 RNSE DVD
- Help, Audi God, Gurs be mereceful.
- Rear Hatch
- Oil filter housing plug broken
- Cooling Fan constantly running
- Steering Rack Replacement
- Cargo cover stopped springing back
- Steering fluids burst out
- first audi purchase-tips??
- Coolant Leak after oil leak fixed
- rear seat removal
- Wheels and Hitch
- How to Bypass Suspension Compressor??
- Tips/tricks for removing broken screws..
- :: ECS Tuning :: Stage 4 Front Big Brake Kits!!
- Another Coolant Leak *2001 Allroad***
- 2002 Allroad TCM PART number-"F"
- Oil on coil #3
- Anyone know G290 temp sensor resistance?
- Misfire cyl 1, not coilpack or ICM?
- '03 AR cruise control
- '03 AR front vibration
- leaving the airbags, on to coils.
- Remote failure and airbag alert post flooding
- Engine banging
- Serpentine belt keeps coming off
- Father's Day Special @ DetailersDomain.com
- FS: C5 fog light Lamin-x film
- Rear transmission output seal
- EGT replacement fun
- Knocking front left corner after Bilstein/Arnott install
- Custom Puddle Lights
- Allroad bearing housing/knuckle
- Arnott Coil Conversion Check Engine Light Emissions Warning
- Car lowers when parked in driveway
- Access to CAN bus?
- Simple Question: What is this part?
- Losing Coolant & Fast HELP
- 2003 Audi Allroad Wheel Center Cap Needed!!
- Allroad Alarm Keep Going Off
- Is there SEAT CD in VAS5054A Spanish V19 Version?
- allroad Repair Shop Reco's in NYC Area?
- 2013 Allroad Whistle at speeds above 70
- 2001 AR - random alarm issue
- P0041 error code
- Blauparts experience.... left with no choice but to share...
- Front door window controler
- Center joint on the Main driveshaft
- How long have you driven with 17125 tc vag code?
- What lights do you see when your 2.7t starts?
- Stuck in neutral
- Blinking Brake Light with other dash lights on.
- Random Misfires all of a sudden
- Trailer wiring/connector
- Audio Upgrades
- 05 allroad 4.2 115k for sale
- Damn .. Allroad $4,600 off MSRP for Memorial Day
- Timing belt replaced.
- Feeler: Decided to let my DP's go...
- gear box problem
- Memorial Day Special at Detailer's Domain Starts Now - Stock up!
- Why choose a 2013 Allroad over a Q5 ?
- 2002 AR 6 spd - drive noise under hard accel
- Vag com tool
- Drawing 330 mA - where to start?
- :: ECS Tuning :: RockyMounts Bike Racks For Your Audi!!
- Coil-Overs, Alignment Issue?
- 2002 allroad euro plate tub
- For Anyone Who Saw the New Star Trek Movie
- When to replace shock absorbers?
- Lifting Pads for Allroad
- Upper control arm choices
- O2 sensor bank 1 and exhaust temp sensor location ?
- Bought an Audi AllRoad 2 days ago! lots of problems! HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 04 Allroad 4.2L - MFSW Retrofit and Stereo Upgrade Question
- Question for 4.2L Allroad owners
- Newb 90% sure on a 2004 Allroad
- Suspension - Right Rear air spring
- Dice IPOD connector on my 2001 Allroad
- Paint codes
- Coolant leak
- Allroad Electronic Stability Light Flashing
- 4.2 Warning
