View Full Version : Audi allroad
- '01-'05 Allroad Suspension Kit from Suncore (?!), DIY & Opinion
- Need an advice about this warning lamp
- looking 4 parts
- Help please re part number 4Z7927803A
- CZ: 2016 A4 vs 2021 A6 - feedback, issues, help wanted
- Snapped key in ignition
- HELP PLEASE !!!missfire/ running rough/ cutting off after timing kit done
- AR does not "start"
- Help Troubleshooting cam timing code
- A/C not the same temp at each vent
- 04 2.7T TCM question
- Mud Flap hardware source
- getAudiparts.com | Black Friday/Cyber Monday Promo Code: BFCM2020
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- All 4 shocks flat in morning - 2004 Allroad 2.7T
- 2004 Allroad - Bosch 5.0, 5.3 or 5.7 ABS?
- Audi Allroad 2006. Upper Control Arm Snapped in Half?!
- Black Friday Sale Starts Now 10% Discount
- ABS error 0259
- New rearward lower control arm will not fit
- 2004 2.7tt brake pads- what’s your preference?
- Gearbox problem any Audi’s
- Diagnose Smoking Passenger Side Combination Valve
- Coolant Connector Broke during Trans swap
- More Audi Suspension problems *sigh*
- Wheels and snow tires in NorCal
- Faults galore. Some help please
- 02 allroad suspension
- Allroad and A6 hood the same?
- Now power to the radio unit?
- After the flood, one last issue I need help with...
- Audi Allroad 2.7T - down pipes
- Our lovely and faithful 2005 allroad 4.2 will be coming up in an insurance auction...
- 2003 allroad 2.7T fuel issue
- 2004 Allroad 4.2 100K maintenance
- Our beautiful 2005 4.2 was in a minor-seeming accident, insurance calling it totaled
- Audi a6 allroad 2015 triptronic fault 18021
- Bleeding Bosch 5.7 ABS Module - 2005 allroad how to?
- Help in Souix Falls
- Buzzing noise from engine bay, changes with RPM
- Audi a6 allroad c7 Air suspension problem.
- C5 Allroad 2.7 V6 - Fault Codes
- Looking into another allroad?
- Phone history
- 2004 Allroad 2.7. Max fuel level to replace fuel pump
- Repair?
- UK: 2005 allroad, drained battery, now wont start
- 2006 A4 1.8T Cabriolet 75K Maintenance?
- Manual swap questions
- C5 2.7t Control Arm Kit
- 2013 Audi allroad front grills
- 2014 Audi allroad advice
- VAGCOM Instrument Settings - Wiper Fluid Sensor?
- AU: 2008 allroad front engine torque mount?
- Allroad that has sat for 4 years
- coolant temp sensor
- What Version If MMI Do I have?
- coolant leak diagnosis
- 2014 Reverse Bulb Replacement How To?
- 2002 Allroad All New Air Struts, Passenger Rear Lowers
- Audi 2.7T Allroad - Timing & Valve Cover Pandemic
- Maintenance schedule vs Actual car mileage
- Audi Allroad B8.5 Coilovers
- Audi A6 Allroad air suspension help.
- 05 allroad ac issues
- CA: plastic license plate, help me to find?
- Mystery engine harness connector
- coolant drain
- Keep or sell diesel Allroad??
- Heater won't blow hot
- 03 Allroad the millionth air suspension question
- Audi Allroad 2005 Mud flap hardware
- B8.5 Allroad riding on RS5 Wheels with 275/30/20 Tires
- 03 Allroad wheels?
- Engine noise when connecting battery. Battery drain???
- Vagcom Error Codes on 05 Allroad - Suspension
- B8.5 19in wheel sizing?
- Starting/testing engine while car up on jacks?
- Help re-installing the inlet pipe my turbocharger
- Cluster, electrical stall and battery related issues (I believe)
- steering difficult but no dash lights on
- C5 allroad snaps CV axle twice
- 4.2L Allroad Transmission Auto or Manual?
- Another Allroad front end rattle post...Solved!
- SE: Audi allroad 2.0L diesel 2013 automat, strange sound!
- NZ: ENGINE FIRE!!! Allroad C5 2.7t Continued
- GearBox ratio vs Rear Diff ratio A6 4F manual 2010
- Experiment in valve bending
- Protection Plate Under Suspension Air Compressor
- Buzzing sound coming from engine
- Why Does All The Spam Remain For Days?
- Audi allroad 2.5 v6 180hp injector or Something else?
- Whirring noise = new front axle?
- Bouncy Butt
- Ignition switch and Door Locks/Interior Lights
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Audi A6 Allroad 2003
- What hapened to Allroadfaq.com?
- 2005 Allroad hood interchangeable with A6 hood?
- Audi Allroad C6 Air compressor locatrion
- A6 C6 - EGR and Throttle Bodies
- Fender alignment - 2005 allroad 4.2L
- want to buy mu first Allroad
- Best place to list an Allroad for sale?
- UK: A6 allroad headlight issue
- Classic got bamboozled on service at the dealer, but have a question.
- AVOID Dan Fast Muffler in Bellevue WA: warning, they will screw up your car!
- Rear Arnott airspring won’t twist onto oem shock
- Car shaking, stopped, now won’t move, PLEASE HELP!
- PLEASE HELP!!
- 2003 Allroad fuel pump
- Help to lower my C5 allroad (4.2 v8)
- Headliner and Dashboard Fabric ADHESIVE
- Crank but no start
- Water in passenger footwell. 2014 audi a6 allroad
- UK: Water in passenger football. 2014 audi a6 allroad
- 17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
- Part in spare wheel well ID? What part is this?
- JE: Weird Service Interval Issue
- Rear washer switch pumps both front and rear 04 C5 Allroad 4.2
- Loud Grind/Rattle when decelerating
- FS: Audi C5 allroad third row seat
- '04 allroad 2.7T rear suspension too firm
- 02 allroad windshield wiper problem
- Audi Allroad Fresh Headliner
- SUSPENSION COLLAPSED
- michal
- Rear washer route through allroad? - possible leak
- Cars a mess
- Audi Allroad 2001 defect backlight
- Parting out
- 2004 Audi allroad no start
- Glovebox question + Advice
- 2005 All Road new to me!
- 402 mod help in SF Bay Area
- 2013 allroad brake and rotor replacement
- 2001 Allroad Rescue/Recovery
- 2005 Allroad needs O2 sensor
- New Member, some questions
- Stubborn instrument cluster
- HELP! Where can I find these plugs?
- 2002 Audi Allroad
- Audis4parts A6 coil suspension swap
- A6 C5 Air Suspension Repair: Tyre Slime / Chinese Air Spring
- Rear Suspension Issues.
- Fault code 01772 and 01400. Air suspension problems
- 2004 Allroad - how long will she run?
- Allroad stopped.
- Windshield scratched, what should I do next?
- S7 Suspension rear drop (no code)
- Allroad losing air in front not back
- 05 Allroad - Transmission input shaft seal
- A6 Allroad Front Suspension
- 2003 Audi Allroad No start...
- 2004 audi a4 breaks locking up after master cylinder replacement
- Looking to buy a 2003 with suspension issues - some questions
- strange sound/beep and cracking sound when parked/locked
- 2005 Allroad gear selector display
- Want to swap the Radio for one compatible to apple car play
- Alternator - do not charge before reaching 2000 rpm
- Help: (new) battery (also) discharging on my 04 2.7
- 2004 Allroad 2.7t - Noob needs ECU advise/help
- ENGINE FIRE!!! Allroad C5 2.7t
- Dealer is asking $500 to repair my new A6, saying the issue is caused by rodent
- 2001 Allroad Grille problems
- Arnott Rear Allroad Regular Air Shock or GenII?
- Key fob programming using the emergency key?
- How to make clock numbers in MMI
- AKE / BAU Diesel knock / misfire / fault codes
- b pillar switches
- winter tyres
- Register of Encumbered Vehicles check worth the money?
- Allroad air valve activation
- 04 Air suspension question
- 2003 audi allroad
- Stock Boost on 2.7TT allroad
- Secondary air injection pump
- Cargo mat/liner recommendation for a4 allroad 2019
- buyers guide
- help with Allroad front axle?
- Hiccups and cuts under acceleration
- Air suspension to coil conversion
- Copper tube that runs from Caliper to Master Cylinder
- New to the Forums 2015 Allroad
- Audi allroad coolant pump failure
- Heated steering wheel not working
- Engine assemnly
- Blacked out Allroad in VA
- 2004 audi all road buying tips?
- NZ: 2008 Audi Allroad Quattro 3.0 TDI - Should I buy?
- 2013 Allroad CV Axle Repair
- 01435 - Brake Pressure Sensor 1 (G201): can this lessen brake force?
- Mystery cable attached to bonnet release 2005 BAU AR
- 2003 Allroad ESP module
- Trunk latch interchangability?
- Rear air suspension going down, no error codes
- Is she totaled or will they try to repair her ???
- Valve Gasket Consensus?
- Brake/ESP/suspension light brake warning
- New allroad owner
- Audi A3 2008 Concert Radio. Issues with buttons
- 2013 Allroad Pemium Plus. What to watch out for.
- Preimum gas recommended/ Do I need Premimum?
- Oil in spark plugs...
- Here's my deal
- Could it be related? 3 questions, 2001 Allroad
- Lug Nut/Bolt Size on 2018 Allroad?
- 2002 allroad pass door won't open
- A6 Allroad C5, 2005 2.5 TDI auto: whistle / whine at approx 60 - 90 mph
- July incentives
- RESOLVED - Water in Passenger Side (front and rear) after rain
- 2003 Allroad windows no going up. plz help!
- 2003 Allroad Transmission issues. sluggish and slipping reverse
- I'm back
- Camp allroad Tahoe bound!
- Automatic transmision stucked in Parking
- Level sensor
- Help! Should I Buy?
- Installed new turbos now car runs rough
- Ac help
- 2005 allroad 2.7T - cranks, does not start
- VAGCOM can't communicate with suspension control module
- 2011 AUDI A4 Q Avant (47-Sound System -- Status: Malfunction 0010)
- 2013 allroad front bumper swap
- 2003 Quattro 2.7, air suspension has no power, and front is on the ground
- 2001 Allroad... may buy, what issues? Help! Help!
- 2005 Audi allroad running lean/horrible gas mileage
- air ride snafu
- EGTs and Tranny Temp Sens
- Recent purchase,so far very happy
- 6 spped swap
- Diagnostic codes.
- Loose wire in fuse box
- Dashboard/mmi changes when towing
- 05 Audi allroad 2.7L BIG BOLT ID
- Allroad air supension flashing yellow light
- Reverse rake
- 2004 Allroad 2.7T skips when up to temp, Engine light now on
- C7 allroad parkingsensor
- towing with an '04 allroad?
- Introduction and Inquiry (2001 2.7t)
- 2003 Allroad - Transmission leaking at passenger output shaft.
- 2013 Audi A4 Manual Boost Gauge Installation
- 2005 allroad
- HELP! B5s4 needs new head gasket/cylinder head?
- New dyno run - 2002 Allroad manual
- Towing troubles
- Problem with mounting rear Top Strut Mounting
- Air con pressure switch - where is it ?
