View Full Version : Audi allroad
- allroad turbos
- TCM Failure & Replaced - Fuel Vapor Leak Solved
- Where are the plugs in the allroad located ?
- (HELP) Wheel shake issues ( HELP)
- New TC and my 1-2 shift is too firm. Common?
- Coolant leak when cold - thermostat housing?
- Radio antenna unit - replacement cost?
- EGT Short to Ground and Cold Start Issue. Need a little advice
- Bose question...
- Is the lift gate supposed to pop up on its own?
- Two set of Tires in Three Years (15k)
- Guidence for Buying my allroad??
- CEL HELP?!?!?!?
- Driver Window Stuck pls help
- iPod/iPhone solutions for the Allroad & Brakes question
- Misfiring Help.
- Undercarriage covers
- Allroad Service Light Reset - 2005 Model Year
- paging 02NoRoad, spacer question?
- 02' Olympic Edition Alroad For Sale
- disabling door open chime
- wheel spacers on stock wheels
- Test Drive - 04-6spd has slight vibration/grinding sound
- My new to me 05 AR
- Purchasing Allroad - Level 4 light color amber
- Siren Noise (Yes Another Thread) Read On. Please
- arnott research
- O2 wire diagram???
- Looking for car fax
- Intake Manifold Spacer Vast 10mm Phenolic
- Hit and Miss
- Thinking about polishing your headlights?
- Interesting PS leak
- Symphony II w/Bose Upgrade
- brake recommendations
- New pics since I updated the look
- Just fried my concert head unit
- two questions
- tire choice
- Another Tire Thread
- why is my AR value so low?
- CV Boot Tear: How to tell if it can be re-booted or should be replaced
- suspension upper mount
- Air Suspension leak driver side (any tricks to repair)
- Started building the mount for my adjustable RS9000 shocks. I also just
- Custom Mounting System For Thule Peloton on OEM Crossbars
- What the... headliner stains?!...
- Anyone know how to tell if a 2003 AR has updated TC?
- Lug Question
- 0-60 chip question
- ABS "¡" suspension malfunction light on at 90mph
- 1000 miles with the Arnott fronts...
- Brake upgrade recommendations?
- oil pressure light problem ???
- plasti-dipped grille--with pics
- An idea(blackout hood)
- Warning Light Trifecta
- Boost loss...
- Source for Air Suspension Valve Module?
- Tinting advice?
- Bowling Ball loose under drivers seat??
- 05 4.2 allroad bumper cover paint color
- 2005 Allroad Sound Systems
- Royal Oak, MI indy repair?
- Arnott Discount Code?
- Anyone using 245-40-19? only .114% difference...
- New Allroad Owner ; TBB, Cracked Fan Replacement, & a Mouse Nest under the Intake
- Pics of my Cupra lip installed on my Allroad
- Voltage Regulator, or Alternator?
- Front Air Bags and CPO
- should I sell my 01 AR? not sure what it's worth...
- Official allroad Photo Thread
- audi roof rack vs Thule/ Yakima etc, mix and match?
- Buying Allroad
- Boost leak or bad n75?
- Arnott air springs & Bilstein shocks installed
- Interior 'trim'-type problems: ashtray & small door pocket won't stay closed, etc
- AR 4.2L. To buy or not to buy...
- How to you remove liftgate interior panel?
- Allroad Lugs
- Paint Scratches - repaired
- Couple of questions from a new AR owner
- Kayak/allroad
- steering groan
- air suspension valve block problems
- Allroad class II trailer hitch
- Tip shifts delayed from 1st to 2nd today about 6 times, lots of rolling stops....
- High pitch whine on cold starts
- A/C fan quit working
- Radio Volume Problem
- Mods for Off Roading?
- financing/stealership question, help!
- Back-up Sensor
- Chips
- 4.2 AR in Canada, when was the last year sold ...
- RS4 Celebration 18"ers for cheap
- 2001 rear hatch sunscreen assembly
- New engine in my AR?!
- Service for Audi in San Diego
- Lookig to buy an allroad.....
- reputable extended warranty that covers things like cv-boots, cam adj leaks??
- Oh no. Reverse is slipping. Considering 6MT swap. Looking for opinions...
- Warranty Questions
- What is everyone's favorite way to connect their iPhone/iPod to their AR?
- Lost OEM Roff Rack Keys...
- Timing belt or chain in 2004 4.2?
- faulty suspention
- Antenna under rear view mirror??
- Replacing brakes...
- What year AR to buy?!?! Help decode packages
- Is this cracked wheel worth anything to anyone?
- Please help with Key programming
- Bumper inserts paint question.
- My rear hatch is squeaking!
- Which to buy: 2005 with 93k or 2003 with 46k?
- Cleaning running board trim on 03 AR
- Hard days work...pics...
- Am I crazy?
- Suspension fault
- Repairs are done, than you Tyrol--- full repair parts list--
- please help with warranty
- lower control arm ball joint integrity... anyone ever break one?
- Stuck in Bootloader constant loop
- arnott shox, replace air springs too? 50k miles...
- Bilstein Shocks/Air Springs from Arnott Ind.
- I need a set of F&R AR shocks - junk, trashed, blown etc.
- Need Help Finding yrk2.7t.....
- Random misfire diagnosis.
- Height Sensor Wiring (and hello!)
- Side Mirror Part Comparison
- My auto door locks have a mind of their own
- Clutch input circuit manfuntion P0704
- Sirius
- any trick to clutch bleeding? that valve is a huge pain to access
- How to remove the bottom cushion of rear seat?
- XM radio recommendations needed
- Finally selling the allroad
- HELP!! have no reverse
- Leaks and control arms oh my...
- Allroad steering wheel
- Thinking of getting an allroady, but need to know one big thing
- will A6 lower control arms fit the allroad? they look identical
- Brake warning light, is it front or rear?
- newbe here
- Steering contols gone bad?
- Any one running 225/60/17 tires?
- New Brakes
- Projector light size
- Steering? Rumbling sound when turning under acceleration
- Leaking something??? hrmm
- Goood source for control arms? ?
- Potential causes of abnormal body roll/movement?
- Roof Rack Question
- quick question for BOSAL hitch owners or knowledgable hitch types
- Anyone have tip valve body problems for '03?
- 2002 Allroad 2.5 diesel tiptronic - UK
- Need detailing info for black allroad.
- :: ECS Tuning :: New Website Now LIVE !!!
- help spark plugs.
- where to buiy (online?) replacement tire valve stems
- Help with service histore
- My 03 tip is shifting a second or two late ...................
- Coilpack failure?
- Auto Dim rear view mirror is only half working??...
- Front suspension sinks at night
- A.W.E. releases Gen2 downpipes with massive price drop!
- weird noise when going over bumps, suspension???
- Clutch Pulsates
- Anyone with pics of a "Curt/Uhaul" trailer hitch installed?
- sorry.... another hitch thread, with rant
- help a fellow allroader out
- Sunroof shade has detached itself.
- Spacers on twin-spokes causing bad vibration
- Old to New Airbags
- TPMS how does it work?
- How bad have I screwed up.`
- AIR SUSPENSION BAG LEAK URGENCY
- ARNOTT question
- 3 sides sagging overnight..........
- allroad Air Suspension Pump , Fuse or Relay or??
- CID repair
- touch up paint for interior trim?
- NOOB Q re: fitment, offset, spacers?
- Removing a steering rack on 01 Allroad
- '04 allroad Central Locking Issue
- trailer wiring harness
- Reason to own an allroad
- recommendation for getting Timing belt changed
- Diverter valve hose replacement/upgrade...
- Tire/ESP Problems - please help
- Tire recommendations
- Turn Signal Indicators - I can't turn left
- please help
- Whistling upon start up? Ideas?
- 6sp transmission mounts...
- Anyone use H&R sway bars on their ar?
- Northeast ALLROAD owners........
- My input shaft to the rear diff is leaking...
- can't reset SRI via trip odo + ign on
- Added Stratmosphere Hyperboost Diverters and...
- Signs of a bad motor ( snub) mount???
- Is it possible to edit a post?
- cargo cover problem
- Where to buy nuts and bolts?
- park assist not working
- Clay Bar
- RNS-E adapter
- Is replacing the radiator fan a DIY?
- bad pixels in between speedo and tach.. best fix?
- AC not working - low side pressure
- '02 2.7T throwing P0300 again
- Rare Red AR/6 Speed on ebay
- Signal/Wiper Stalk Failure(s)?
- tractor for sale
- creaky steering especially slow right turns....
- HELP...
- Anyone else have an H2O leak?
- Those in PA/NJ/NY/DE/MD...
- Paging Autosolution - YGM
- Extended warranty issue... NEVERMIND
- nor-cal allroaders - anyone interested in meeting for dinner and or a beer tomorrow?
- Rant!!!
- Picked up an 05 allroad for the wife this weekend
- Auto leveling with engine off
- need help
- One of the benefits of living in SC... attending the BMW Performance Driving School.
- new front pads and rotors put on this weekend, super noisey
- What are the options of a turbo leaking oil?
- just bought the wife an Allroad 2.7T, now for the quest for parts and questions
- Free cargo floor cover, S. FLA
- 2001 Allroad headlights
- What RPM is normal for crusing @ 80 mph?
- Part Numbers for buttons knobs and center cap
- MSD Ignitions
- Maintenance costs per year?
- Need suspension height sensor - anyone have one laying around?
- This month is Christmas for me so to speak...
- allroad in Italy ....
- ar repair work for next week...
- Chicagoland allroaders...
- Warranty
- Like Rosanne Rosanna Danna...
- Allroad Grill?
- Follow up: Tips on reconnecting battery. 5 concerns...
- Headlight bulbs...
- rear trans output shaft seal leaking transfluid or gear oil? Indy and dealer tell...
- Moving to New Mexico
- Independent Audi Repair Shops
- Need help: Tip on reconnecting the battery?
- something is wrong.. 6:30am
