View Full Version : Audi allroad
- 2002 allroad high pressure power steering line removal
- A Case For The Open Source Approach
- Anyone have instructions to reset the ride height?
- my Allroad is sputtering/hesitating up hills.
- Anyone replace the oil seal on the 2.7 sump turbo line in situ?
- Transfer case ATF leak
- Dome Light Gremlins
- Will These Wheels Fit?
- Engine Shut down on test drive after axle install
- Vibration under acceleration...bucking bronco!
- Allroad 4.2 Oil Leak
- Audi allroad 402 mod, what do I need?
- New to this site! need advice
- Will different wheels sizes damage me Allroad?
- 2005 All Road 4.2V8 73k miles.
- RNS-E MK II (193) with Audi AMI
- Inscription position / trunk
- noisy cooling fan, failure probability??
- Roof racks, wind noise, and sunroofs
- Just got a scan tool... EGT DTC
- Commuted just fine. Parked it in the garage and it started pissing coolant.
- 2003 Audi Allroad Control arms
- EGR SAI AGT delete
- Decent Head Unit for 2003 with bose?
- Car Shuts Off about an Hour into the Drive, then is fine
- 2004 Allroad - roughness when driving
- P0741, Torque Converter fails to lock
- Cam belt kits - favorite or preferred?
- Buying An allroad 2010 A4 3L TDI
- Help please-A slightly different Allroad Suspension problem
- Low voltage on start up
- LOW RANGE on my dashboard.
- Please someone with bently manual, what is the torque for 10m triple square bolts???
- Calling all 6MT owners
- new allroad owner
- 2002 audi a4 3.0 02 sensor wire connector wire order
- Allroad water pump failed at 144k miles
- 2.5TDi prestige
- Skid Plate
- 4z7 959 655 c is there a replacement module that can be used?
- Help: Jerky Transmission after TCM FLOOD. 05 AR
- allroad HP-2 sticking caliper
- Turn signal wiring diagram
- 2001 AR Airbag fault code: 65535
- Car won't recognize it's in park....Only starts in neutral.
- Torque converter not releasing?
- going back to adjustable ride shocks worth it?
- This should anger you; it did me.
- Airbag suspension rebuild and fix
- Allroad fuel level sensors 2.5Tdi
- 2005 audi allroad quattro 2.7t wont start after timing belt change
- Could extreme cold drop front suspension?
- Tiptronic transmission "slipping" when cold, Audi Allroad 2003
- OEM brake caliper upgrade
- Need Help: 2005 Shift Lock Solenoid
- Removal of rocker sills (under doors)
- Cold Start Issue - FLOODED? NO SPARK?
- self levelling suspension
- 2.7T burning oil bad, pressurized crankcase
- Need Advice: Purchased '04 Allroad 2.7 auto
- 01 AR Transmission Issue?
- All weather Mats
- New Battery Not Fitting?
- Can a bad coil pack melt the connector 2003 2.7T allroad
- Dash display, gear display
- B5 S4 Cluster in C5 Allroad - Couple of Issues, Anyone seen these?
- Poor windsheild wiper design and performance
- New video about the 01E Manual Transmission
- Roaring SAI and chipping the car
- clutch ignition switch location for 04 allroad 6MT?
- Nothing was stirring, not even a mouse
- What's the best way to replace the IAT (G42) on a 2.7t
- Underfloor ECU Layout
- What the deuce is this warning light
- Menu Control pin out
- FrankenAllRoad Build
- Problems with my tranny...
- The list goes on
- P0302 misfire code that won't go away
- Installing "New" compressor; some stuff didn't come with it
- Need help with releasing fuel pressre from fuel rail
- Studdering... sometimes, problems with Torque Converter, fuel, plugs?
- Smelling gas inside car....
- allroad leaky sun roof -- urgent or annoyance?
- Get Ready Folks - this might come as a shock
- Haunted allroad compressor pitch changes with headlight state
- Audi all-road 2.7 2002 Air Suspension Wiring Diagram
- Coolant Flush
- Interior LED Problem
- Watch out for rodents!
- Height Switches
- Picking up an allroad this week
- New Roof Spoiler
- Compressor cycling a lot while driving
- Woot! Got my (new to me) 2003 AR
- 2003 Audi Allroad Lost Key
- Vss/g22 sensor location
- 2016 Allroad crossbar Rack Options
- Hazard Switch; Headlights issue
- New AR owner- temp stuck in 1st gear?
- what sensor is this? got destroyed during a fan explosio
- spare tire wheels for general use
- Another 'suspension wont raise' question
- Allroad problems
- All road air suspension issues
- Pulling back stalk for Front Washer activates rear wiper
- AR rear gas shock replacement and options? (keeping air suspension)
- Default Any idea how to remove headlight switch knob from the switch assembly?
- Recycled hitch
- Cyl 1 open circuit
- WTB 6 speed manual Allroad
- Replacing starter on '04 allroad 4.2 V8. Where to begin?
- TCU Harness Routing
- all wheel drive ruining tires?
- Rough Idle Until Warm: VAG scan Attached
- Allroad 6 Speed Manual Clunk After Shifting
- Audi allroad ground-level suspension drive
- Boost Leak
- Exhaust Issue? Car sounds like garbage truck
- Bypass Secondary Air Injector?
- NEED HELP FIGUIRING OUT WHAT THIS PART IS ON MY AUDI ALLROAD 2001 2.7
- Fuse 27 heated steering wheel/rear wiper data
- 03 allroad suspension advise
- '01 Bose system
- 2004 allroad 2.7t wheel spacers/bolts
- P0741 02 Allroad ... what to do
- 6MT Aftermarket Shifter Knobs :: Show Yours
- Black Friday/ Cyber Monday deals from Car Parts Discount
- :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
- 04 ar 2.7 blowing fuse 5
- Inner CV joint issue
- Drivers side turbo oil leak?
- Ultimate Performance Wheels UP620 on 2015 allroad
- 2015 Allroad Towing
- allroad advice
- New member, new (to me) ar
- Nav won't turn off
- Door Alarm Lights Always On?
- ABS, ESP and Jack Mode lights on...
- 600hp Fully Built Stage 3+ Allroad
- RPM's dropping and car almost stalls
- Converting Symphony II to Bose
- Rear wiper remains always on intermittent setting
- Stereo Code
- Upgrade from Symphony II to Newer RNS-E Mark 2
- Rear drops evenly when in Jack Mode
- Thinking of picking up a 2004 2.7 Allroad
- Advice on buying an Allroad
- Bleeding air from new steering rack?
- NSR Door
- New Allroad. Noob Questions
- Putting a 2001 allroad into storage
- Sudden dead battery
- Air suspension compressor 40a 32v fuse (orange)
- Advise on Shocks for Allroad
- 2003 Allroad - Screen is all black!
- Special promotion for Audi World Forum members
- Seconary air pump
- Water in Electrics
- allroad down on the back overnight
- VCDS First Time - Self-Diagnosis (Pretty clean!!! but...)
- Forum group buy with Car Parts Discount
- Another one with air suspension problems
- What is this diverter valve?
- ABS, ESP and Ride Level Lights on after repair.
- Water pump and gasket
- C5 AR 2.7T Transmission Options
- fog light relay Audi alllroad 2001 2.5tdi
- Rear Side Airbag igniter N201 and N202
- The Replacement
- GPS base connections
- Found an 04 Allroad with 71K - suspension issue
- Audi A6 - gear stuck on park when the ignition is on or car is on
- Audi A6 Allroads not starting, cranking but not firing
- AllRoad not starting
- Anyone know where the door contact switch wires terminate? Won't go into sleep mode.
- Airbag failure (suspension)
- Advice to potential all road buyers
- Grill filler plate - Newbie
- New Car, Air Suspension issues
- Taz audi allroad 2.5 tdi auto
- Wondering if anyone has gotten this ebay exhaust or what they think about it?
- Air suspension work while engine is switched off?
- Allroad aux pump relocation
- 02 AR suspension help request
- Allroad "double spoke" wheels/vibration
- Error code P0610
- mAllsbrook
- No first gear!? Anyone with the same problem? Newbie
- VW /Audi - cheating ?
- valve N75
- Air suspension on 2001 vs 2005 models
- Rear Cargo Cover Repair?
- New to the club
- Help set me straight; Cam plugs, tensioners, etc..
- STFA and found nothing: Exhaust Rumble and CEL
- So the Torque Converter is toast.. what else is wrong?
- Would ya again?
- 2002 leaking coolant
- "Login lost due to dropped session" constantly
- Help I'm Trapped And Can't Get Out
- Beware Cheap Car Hoists
- Looking to buy a crankshaft position.sensor for a.:2001
- 2002 OVERHEATING
- Cam tensioner help/advice
- Engine light P1453
- 2004 Allroad
- What are the odds of a Chinese cam tensioner bad out of the box?
- 2002 audi allroad 2.7 quatro passenger seat will not move forward or back
- 2005 AR DVD navigation?
- allroad 2002 wheels
- 4Z7 907 553 G Interchangeability
- 2.7t no pull?
- Limp Mode 2.7 Tip
- Transmiision from an A4
- 2004 ar 6spd- Slightpower surge after shift
- Alpaca Allroad. What color wheels?
- Allroad Center Cap
- turboback exhaust?
- allroad splash guard recommendation?
- Audi meetup ny/nj !
- :: ECS Tuning :: C5 allroad 2.7T ECS Assembled Ignition Service
- :: GruvenParts.com - Sale - SPC 81350 Adjustable Front Control Arms for Allroad !
- Auf Wiedersehen! I've sold my allroad.
- Allroad rim fitment question
- Blow off valve?
- Rims for 04 Allroad?
- Question about air
- New Compressor Rebuild Kit for Audi Allroad
- Air leak/ what part is this?
- Allroad Pre-purchase inspection
- Special promotion for Audiworld members
- Simple question - air ride
- What Would You Do??? Please Leave A Reply
- Noise from engine when car is OFF
- Electrical Gremlins
- Smoke after VCG Job
- A6 C5 Allroad rubbing/knocking
- At wits end over Allroad starting problem.
- been offered new rims/tyres
- VAGCOM Help in KC?
- Help! 2001 Allroad Ignition problem
- UNDER THE PASSENGER SEAT
- Water temperature issues
- Front end shake, looking for input
- Arnott Gen II rears with OE Shocks
- Help - Connection from transmission
- Best 1/8" Audio Jack solution for Audio Playback?
- Replacing the front AC fan - field repair
